4层703PIN
Name | PCB Decal | PART DESC | +5V | TESTPOINT | Red Testpoint | +7V | TESTPOINT | RedTestpoint | +12V | TESTPOINT | RedTestpoint | +12V_FMC | LED-0603 | LEDALINGAP GRN WHT DIFF 0603 SMD | -2P5V | TESTPOINT | RedTestpoint | 1PT8V | TESTPOINT | RedTestpoint | 2_048V | TESTPOINT | RedTestpoint | 4PT096V_REF | TESTPOINT | RedTestpoint | 5V_REF | TESTPOINT | RedTestpoint | AMP_PWR+ | TESTPOINT | RedTestpoint | AMP_PWR- | TESTPOINT | RedTestpoint | C1 | C0805 | CAPACITOR,0805, 10UF, 16V | C2 | C0603 | MLCC,0603, X7R, 50V, 100NF | C3 | C0603 | MLCC,0603, X7R, 50V, 100NF | C4 | C0805 | CAPACITOR,0805, 10UF, 16V | C5 | C0603 | MLCC,0603, X7R, 50V, 100NF | C6 | C0603 | MLCC,0603, X7R, 50V, 100NF | C7 | C0603 | MLCC,0603, X7R, 50V, 100NF | C8 | C0805 | CAPACITOR,0805, 10UF, 16V | C9 | C0603 | MLCC,0603, X7R, 50V, 100NF | C10 | C0603 | MLCC,0603, X7R, 50V, 100NF | C11 | C0805 | CAPACITOR,0805, 10UF, 16V | C12 | C0603 | MLCC,0603, X7R, 50V, 100NF | C14 | C0603 | CAPACITORCERAMIC, 1UF, 10V, X7R, 0603 | C15 | C0603 | MLCC,0603, X7R, 50V, 100NF | C16 | C0805 | CAPACITOR,0805, 10UF, 16V | C17 | C0603 | MLCC,0603, X7R, 50V, 100NF | C18 | C0805 | CAPACITOR,0805, 10UF, 16V | C19 | C0805 | CAPACITOR,0805, 10UF, 16V | C20 | C0603 | MLCC,0603, X7R, 50V, 100NF | C21 | C0805 | CAPACITORCERAMIC, 2.2UF, 16V, X7R, 0805 | C22 | C0805 | SMDCapacitor | C23 | C0805 | CAPACITORCERAMIC, 2.2UF, 16V, X7R, 0805 | C24 | C0805 | SMDCapacitor | C25 | C0603 | SMDCapacitor | C26 | C0805 | SMDCapacitor | C27 | C0603 | MLCC,0603, X7R, 50V, 100NF | C28 | C0402 | CAPCER 0.1UF 16V 10% X7R 0402 | C29 | C0805 | CAPACITOR,0805, 10UF, 16V | C30 | C0603 | CAPACITORCERAMIC, 1UF, 10V, X7R, 0603 | C31 | C0402 | SMDCapacitor | C34 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C35 | C0603 | MLCC,0603, X7R, 50V, 100NF | C36 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C37 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C38 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C40 | C0603 | MLCC,0603, X7R, 50V, 100NF | C41 | 508 | CAPACITOR,0508, 100NF, 25V, X7R | C42 | C0805 | CAPACITOR,0805, 10UF, 16V | C43 | C0603 | MLCC,0603, X7R, 50V, 100NF | C44 | C0805 | CAPACITOR,0805, 10UF, 16V | C45 | 508 | CAPACITOR,0508, 100NF, 25V, X7R | C46 | C0603 | MLCC,0603, X7R, 50V, 100NF | C47 | C0603 | SMDCapacitor | C48 | C0603 | MLCC,0603, NP0, 50V, 56PF | C49 | C0603 | MLCC,0603, NP0, 50V, 56PF | C50 | C0603 | SMDCapacitor | C51 | C0603 | SMDCapacitor | C52 | C0603 | MLCC,0603, X7R, 50V, 100NF | C53 | C0603 | SMDCapacitor | C54 | C0603 | MLCC,0603, X7R, 50V, 100NF | C55 | C0603 | SMDCapacitor | C56 | C0603 | MLCC,0603, X7R, 50V, 100NF | C57 | C0603 | MLCC,0603, X7R, 50V, 100NF | C58 | C0603 | MLCC,0603, X7R, 50V, 100NF | C59 | C0603 | MLCC,0603, X7R, 50V, 100NF | C60 | C0805 | CAPACITOR,0805, 10UF, 16V | C61 | C0603 | MLCC,0603, X7R, 50V, 100NF | C62 | C0805 | CAPACITOR,0805, 10UF, 16V | C63 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C64 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C66 | C0805 | CAPACITOR,0805, 100NF, 50V, X7R | C69 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C70 | C0805 | CAPACITORCERAMIC, 4.7UF, 16V, X7R, 0805 | C71 | 1206 | CAPACITORCERAMIC, 10UF, 16V, X7R, 1206 | C76 | C0603 | CAPACITOR,0603, 100PF, 50V | C77 | C0603 | CAPACITOR,0603, 100PF, 50V | C186 | C0402 | SMDCapacitor | D3 | PWRDI-323 | DIODESCHOTTKY 30V 1A PWRDI-323 | GND2 | TESTPOINT | RedTestpoint | GND3 | TESTPOINT | RedTestpoint | J1 | SMA_90DEG | CONNSOCKET SMA R/A DIE CAST PCB | J2 | SMA_90DEG | CONNSOCKET SMA R/A DIE CAST PCB | J3 | CON\POWER3 | 3Pin Terminal Block (5mm Pitch) | J4 | SMA_CARD_EDGE_RF | CONNJACK END LAUNCH PC GOLD SMA | J5 | SMA_CARD_EDGE_RF | CONNJACK END LAUNCH PC GOLD SMA | J6 | n/a | n/a | J7 | ASP-134604-01 | 160Pin 10mm Male VITA 57 Conn | JP1 | LINK0301 | 3Pad Solder Link | JP2 | LINK0301 | 3Pad Solder Link | JP3 | LINK0301 | 3Pad Solder Link | JP4 | LINK0301 | 3Pad Solder Link | JP5 | LINK0301 | 3Pad Solder Link | JP7 | LINK0301 | 3Pad Solder Link | JP8 | LINK0301 | 3Pad Solder Link | JP9 | LINK0301 | 3Pad Solder Link | L2 | IND-LPS3015 | Primarypower inductor, 3 mm × 3 mm ×1.5 mm | LK2 | SIP-2P | 2Pin (0.1" Pitch) Header & Shorting Shunt | LK3 | SIP-2P | 2Pin (0.1" Pitch) Header & Shorting Shunt | LK4 | JUMPER_2 | 4Pin (2x2) 0.1" Header & Shorting Block | LK5 | JUMPER_2 | 4Pin (2x2) 0.1" Header & Shorting Block | LK6 | 3PIN-SOLDERBRIDGE | 2Way solder Bridge | LK7 | 3PIN-SOLDERBRIDGE | 2Way solder Bridge | R1 | R0402 | RESISTOR,0402 100R,0.0625W,1% | R2 | R0402 | RESISTOR,0402 100R,0.0625W,1% | R4 | R0603 | SMDResistor | R6 | R0603 | RESISTOR,0603 16K9 | R7 | R0805 | RESISTOR,0805 0R0,0.1W | R9 | R0603 | SMDResistor | R10 | R0603 | SMDResistor | R11 | R0603 | RESISTOR,0603 35K7 | R12 | R0603 | RESISTOR,0805 0R0,0.1W | R14 | R0805 | RESISTOR,0805 0R0,0.1W | R15 | R0603 | SMDResistor | R16 | R0805 | RESISTOR,0805 0R0,0.1W | R17 | R0805 | RESISTOR,0805 0R0,0.1W | R18 | R0805 | RESISTOR,57K6, 0805 0.1% 25PPM 0.1W | R19 | R0805 | RESISTOR,0805, 12K1 1%, 0.125W | R20 | R0603 | SMDResistor | R21 | R0603 | SMDResistor | R22 | R0805 | RESISTOR,0805 0R0,0.1W | R23 | R0603 | SMDResistor | R24 | R0603 | RESISTOR,0805 0R0,0.1W | R25 | R0603 | SMDCapacitor | R26 | R0603 | SMDResistor | R27 | R0603 | SMDResistor | R28 | R0603 | SMDResistor | R29 | R0603 | SMDResistor | R30 | R0603 | SMDResistor | R31 | R0402 | RESISTOR,0R, 62.5MW, 1% | R32 | R0402 | RESISTOR,0R, 62.5MW, 1% | R33 | R0402 | RESISTOR,0R, 62.5MW, 1% | R34 | R0402 | RESISTOR,0R, 62.5MW, 1% | R35 | R0603 | SMDResistor | R36 | R0805 | RESISTOR,SURGE, 0805, 1%, 1M | R37 | R0603 | RESISTOR,0603 1K,0.063,1% | R38 | R0603 | SMDResistor | R39 | R0805 | RESISTOR,0805 0R0,0.1W | R40 | R0603 | SMDResistor | R41 | R0603 | RESISTOR,0603 1K,0.063,1% | R42 | R0603 | RESISTOR,499R, 0603, 0.1%, 0.1W | R43 | R0603 | RESISTOR,499R, 0603, 0.1%, 0.1W | R44 | R0603 | RESISTOR,499R, 0603, 0.1%, 0.1W | R45 | R0805 | RESISTOR,0805 0R0,0.1W | R48 | R0603 | SMDResistor | R49 | R0603 | RESISTOR,499R, 0603, 0.1%, 0.1W | R50 | R0603 | SMDResistor | R51 | R0603 | SMDResistor | R52 | R0805 | RESISTOR,0805 33R | R53 | R0805 | RESISTOR,0805 33R | R54 | R0603 | SMDResistor | R55 | R0603 | SMDResistor | R56 | R0603 | SMDResistor | R57 | R0603 | RESISTOR,0603, 820R, 0.1%, 0.1W | R58 | R0603 | RESISTOR,0603, 820R, 0.1%, 0.1W | R59 | R0603 | SMDResistor | R60 | R0603 | SMDResistor | R62 | R0805 | RESISTOR,0805 100K,0.1W,1% | R63 | R0805 | RESISTOR,0805 0R0,0.1W | R64 | R0603 | RESISTOR,0603 10K,0.063W,1% | R101 | 603 | RES560 OHM 1/4W 5% 0603 SMD | REF | TESTPOINT | RedTestpoint | U1 | LFCSP-32 | 18-Bit,5 MSPS PulSAR® DifferentialADC | U2 | TSOT-6 | Step-DownRegulator | U3 | LFCSP-8-2MM | AdjustableLDO Regulator | U4 | SO8NB | Op-Amp | U5 | SO8NB | VoltageReference | U7 | SO8NB | ICEEPROM 2KBIT 400KHZ 8-SOIC | U8 | SO8NB | VoltageReference | U9 | DQFN-16 | ICTRANSLATOR DUAL 4BIT 16-DQFN | U10 | LFCSP-8-5 | LinearRegulator ADJ, 20V, 300mA, Ultralow Noise, CMOS | U11 | SO8NB | Op-Amp | U12 | LFCSP-8-2MM | AdjustableLDO Regulator | U13 | SO8NB | VoltageReference | U14 | LFCSP-16-3MM | DifferentialADC Driver | U15 | SO8NB_EP | LowNoise, High Speed Amplifier for 16-Bit Systems | U16 | SO8NB_EP | LowNoise, High Speed Amplifier for 16-Bit Systems | U17 | SOT23-5 | SingleINV | U18 | LFCSP-8-5 | LinearRegulator ADJ, 20V, 300mA, Ultralow Noise, CMOS | VADJ | TESTPOINT | RedTestpoint | VCM | TESTPOINT | RedTestpoint | VCM_EXTERNAL | TESTPOINT | RedTestpoint | VCM_OUT | TESTPOINT | RedTestpoint | VIO_1PT8V | TESTPOINT | RedTestpoint |
