查看: 1838|回复: 1
[Allegro16.6以下] TWR-K60F120M Kinetis K60 120 MHz塔式系统模块 8-1245
发表于 2018-11-29 22:34:47 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
19 TWR-K60F120M Kinetis K60 120 MHz塔式系统模块.rar (12.54 MB, 下载次数: 4)
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883 ICBT1
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC1
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC2
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC3
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC5
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC6
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF DISCRETEC7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC10
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC11
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC13
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC14
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC15
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC18
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC19
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UF10%DISCRETEC20
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC22
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC23
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC26
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PF DISCRETEC28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC29
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC30
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC31
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC33
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC34
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC35
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC36
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC37
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC38
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC39
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC40
CC0402_25CAP_NP_CC0402_25_DISCRETE_.55MM27PF DISCRETEC41
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC42
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.94M1000pF DISCRETEC43
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC44
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC45
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uF ICC46
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC47
CC0402_25CAP_NP_CC0402_25_DISCRETE_.55MM27PF DISCRETEC48
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UF DISCRETEC49
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC50
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC51
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC82
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC86
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC87
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UF DISCRETEC88
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIR ICD1
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGE ICD2
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOW ICD3
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRN ICD4
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRN ICD5
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54C ICD6
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_OR + ELECTRODE ICD7
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_YEL + ELECTRODE ICD8
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54C ICD9
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3L ICD10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_GRN + ELECTRODE ICD11
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED2_ELECTRODE ICD12
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ1
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ2
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10 IOJ3
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ4
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10 IOJ5
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ6
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ7
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ8
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ9
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ10
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19P IOJ11
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ12
CON5_USB_MINI_A_SMTUSB_MINI_B_SKT_CON5_USB_MINI_A_CONN USB MINI-B 1x5 IOJ13
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3 IOJ14
CON_SDCARD_8F_SM_RACONN_MICRO_SD_CARD_REVERSED_CONConn MicroSD IOJ15
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ16
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ18
HDR102CONN_HDR_2X1_HDR102_IO_8.71MM_HDR 1X2 TH IOJ19
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ21
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ22
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ23
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3 IOJ24
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL1
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL2
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM DISCRETEL3
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL4
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHM DISCRETEL5
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL6
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL7
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZ ICL8
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPD ICQ1
SOT23NPN_SOT23_IC_1.12MM_480-75173_MMBT3904LT1G ICQ2
SOT416TRAN_NPN_RES_SOT416_IC_0.95MM_4PDTC115T ICQ3
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER1
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER2
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER3
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER5
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER6
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER7
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER8
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER9
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER10
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER11
RC0603_OVRES_RC0603_OV_DISCRETE_470-753833 DISCRETER12
RC0402_25RES_RC0402_25_470-80310_10K10k ICR13
RC0402_25RES_RC0402_25_470-80310_10K10k ICR14
RC0402_25RES_RC0402_25_DISCRETE_470-7646330 DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0K DISCRETER17
RC0402_25RES_RC0402_25_DISCRETE_470-3078270 DISCRETER18
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER19
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER20
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER21
RC0603_OVRES_RC0603_OV_DISCRETE_470-753833 DISCRETER22
RC0603_OVRES_RC0603_OV_DISCRETE_470-753833 DISCRETER23
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER24
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER25
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER26
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER27
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER28
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER29
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER30
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER31
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER32
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER33
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER34
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER35
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER36
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER37
RC0402_25RES_RC0402_25_DISCRETE_470-30841.3K DISCRETER38
RC0402_25RES_RC0402_25_DISCRETE_470-30841.3K DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99K DISCRETER40
RC0603_OVRES_RC0603_OV_DISCRETE_470-753833 DISCRETER41
RC0603_OVRES_RC0603_OV_DISCRETE_470-753833 DISCRETER42
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER43
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER45
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER46
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER47
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER48
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER49
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER50
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER51
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015K DISCRETER52
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER53
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER54
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70K DISCRETER55
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER56
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER58
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER59
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER60
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER61
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER62
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER63
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER64
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER65
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER66
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER67
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER68
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER69
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER70
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER71
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER72
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER73
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER74
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER75
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER76
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0K DISCRETER77
RC0402_25RES_RC0402_25_DISCRETE_470-312810M DISCRETER78
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER79
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER80
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER81
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER82
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2K DISCRETER83
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER84
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER85
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER86
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER87
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER88
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER89
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER90
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER91
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER92
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER93
RC0402_25RES_RC0402_25_DISCRETE_470-307268 DISCRETER94
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER95
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER96
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER97
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER98
RC0603_OVRES_RC0603_OV_DISCRETE_470-80210 DISCRETER99
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER100
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER101
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER102
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER103
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER104
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER105
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER106
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER107
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER118
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER122
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER123
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER124
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER125
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER126
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER128
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K5%DISCRETER130
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400 DISCRETER132
RC0402_25RES_RC0402_25_DISCRETE_470-312810M DISCRETER133
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER138
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440 DISCRETER139
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110K DISCRETER313
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW1
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW2
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switch ICSW3
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP2
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP3
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP4
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP5
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP6
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP7
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP8
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP9
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP10
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP12
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP13
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP14
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACK ICTP15
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP16
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACK ICTP17
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP18
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP19
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040 ICTP21
LQFP144_0P5_20X20MMK60_LQ_LQFP_144P_LQFP144_0P5_20PK60FN1M0VLQ12 ICU1
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YM ICU2
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WS ICU3
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4 ICU4
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451Q ICU5
SOIC1474-125_14P_SOIC14_IC_1.75MM_31274HCT125 ICU6
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503B ICU7
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60MMC9S08JM60CLD ICU8
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125 ICU9
TSOP48_18P5X12P4MT29F2G16AADWP_TSOP48_18P5X12P4MT29F2G16ABAEAWP:E ICU14
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZ ICY1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHz ICY2
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHz ICY3
XTAL4_3P3X2P6_SM_FLCRYSTAL_JXS63_XTAL4_3P3X2P6_SM_12MHZ ICY5
重要提示:PCB作品文件展下载说明
发表于 2022-4-20 18:26:45 | 显示全部楼层
