en.b-l475e-iot01a1_sch.zip
(4.17 MB, 下载次数: 11)
Comment Pattern Quantity Components
0R 0402_RES 6 R2, R6, R12, R13, R42, R43 Resistor
0R 0603_RES 1 R61 Resistor
100K 0402_RES 5 R23, R29, R49, R54, R59 Resistor
100nF 0402_CAP_NPOL 39 C1, C3, C5, C7, C9, C10, C11 Capacitor_not polarized
C12, C13, C17, C19, C20, C22
C23, C25, C26, C28, C29, C31
C32, C33, C34, C36, C42, C43
C44, C45, C47, C48, C54, C55
C57, C60, C61, C62, C63, C65
C73, C74
100pF 0402_CAP_NPOL 1 C67 Capacitor_not polarized
100R 0402_RES 2 R39, R45 Resistor
1050170001 CON_USBMICROB_MOLEX_105017-0001_H2P90 1 CN7 USB-MICRO-B, 1050170001, SMT, MOLEX
10K 0402_RES 7 R14, R15, R16, R31, R48, R51 Resistor
R67
10nF 0402_CAP_NPOL 1 C58 Capacitor_not polarized
10pF 0402_CAP_NPOL 4 C35, C37, C51, C52 Capacitor_not polarized
10uF 0603_CAP_NPOL 8 C16, C38, C39, C40, C41, C46 Capacitor_not polarized
C49, C50
1K 0402_RES 7 R3, R18, R19, R21, R24, R52 Resistor
R56
1K5 0402_RES 1 R50 Resistor
1uF 0402_CAP_NPOL 7 C6, C8, C24, C56, C59, C64 Capacitor_not polarized
C68
2.2uF 0603_CAP_NPOL 3 C27, C75, C76 Capacitor_not polarized
200K 0402_RES 1 R38 Resistor
20K 0402_RES 1 R4 Resistor
22R 0402_RES 4 R32, R33, R34, R35 Resistor
2K2 0402_RES 5 R8, R9, R10, R11, R53 Resistor
2K7 0402_RES 1 R28 Resistor
30K 0402_RES 1 R1 Resistor
330R 0402_RES 5 R20, R25, R44, R47, R55 Resistor
36K 0402_RES 1 R46 Resistor
4.7uF 0603_CAP_NPOL 4 C18, C21, C30, C66 Capacitor_not polarized
475900001 CON_USBMICROAB_MOLEX_47590-0001_H3 1 CN9 USB-MICRO-AB, 47590-0001, SMT, MOLEX
47K 0402_RES 4 R26, R57, R58, R62 Resistor
47pF 0402_CAP_NPOL 2 C53, C71 Capacitor_not polarized
4K7 0402_RES 3 R27, R40, R41 Resistor
5.1pF 0402_CAP_NPOL 2 C14, C15 Capacitor_not polarized
680R 0402_RES 1 R22 Resistor
742792042 0603L 1 L2 Inductor
BAT60JFILM DIO_SOD323 4 D2, D3, D4, D5 BAT60JFILM
BSR14 SOT23-3 2 Q1, Q2 BSR14 NPN switching transistor SOT23 (Marking U8)
BT Module SPBTLE-RF 1 M1 SPBTLE-RF
Close SB 15 SB1, SB2, SB3, SB4, SB5, SB6 Solder Jumper
SB7, SB8, SB10, SB13, SB14
SB15, SB17, SB18, SB21
Comment LOGO_ST_Size3 1 Logo_ST
EMIF02-USB03F2 ESD_FLIP-CHIP-BGA11_1P44X1P94_P050 2 U18, U20 2-line IPAD, EMI filter including ESD protection
FCM1608KF-601T03 0603L 1 L1 Inductor
Header 10X1_Female_SMD F-V50XC-1X10R-LF 1 CN1 Header, 10-Pin, SMD, Single row,female
header 2 pins 2.54mm CON_SAMTEC_TSW-102-07-G-S 1 CN6 Header 2 pins
Header 4 pins CON_SAMTEC_TSW-104-07-G-S 1 CN8 Header, 4-Pin
Header 6X1_Female_SMD F-V50XC-1X06R-LF 1 CN4 Header, 6-Pin, SMD, Single row,female
Header 8X1_Female_SMD F-V50XC-1X08R-LF 2 CN2, CN3 Header, 8-Pin, SMD, Single row,female
HEADER_2X5 Header M 2x5x2.54 TH V 1 JP4
HEADER_2X6_PMOD Header F 2x6x2.54 TH H PMOD 1 CN10 PMOD Connector Warning Specific Pinout
HTS221 HLGA6L-2x2x0.9 1 U6 Humidity + Temp MEMS
ISM43362-M3G-L44 ISM43362-M3G-L44 1 M2 ISM43362-M3G-L44 Wifi Module 802.11 bgn
Jumper_2.54mm CON_SAMTEC_TSW-102-07-G-S 4 JP5, JP6, JP7, JP8 Connector jumper 1 position
LD_BICOLOR_CMS LED_BI-GR_HSMF-A201-A00J1 1 LD6 Bicolor Led
LD1117S33TR REG_SOT223-TAB 1 U14 LOW DROP FIXED AND ADJUSTABLE POSITIVE VOLTAGE REGULATORS (3.3 Volts)
LD1117S50TR REG_SOT223-TAB 1 U13 IC REG LDO 5V 0.8A SOT223
LD3985M33R REG_SOT23-5L 1 U16 Ultra low drop-low noise BiCMOS voltage, regulators low ESR capacitors compatible
LED 0603_LED_Blue 1 LD4 Light-Emitting Diode
LED 0603_LED_GREEN 4 LD1, LD2, LD5, LD9 Light-Emitting Diode
LED 0603_LED_RED 2 LD7, LD8 Light-Emitting Diode
LED 0603_LED_Yellow 1 LD3 Light-Emitting Diode
LIS3MDL VFLGA12-2x2x1 1 U5 IC,Sensor
LPS22HB HLGA10L-2X2X0.76 1 U7 IC,Sensor
LSM6DSL LGA14L-2.5X3X0.86p0.5 1 U3 Accelero + Gyro MEMS (6 Axis)
LT1963EST-3.3 SOT223_SC73 1 U12 LT1963EST-3.3 LDO Low Noise 1.5A fast Transient Response
M24SR64-Y SOP8 1 U8 M24SR64-Y 64K_EEPROM NFC/RFID
MP34DT01-M HCLGA-4LD 3x4x1 2 U2, U10 MEMS audio microphone
MX25R6435F SOP8L 1 U11 MX25R6435F Serial Flash Memory 64M
Not Fitted (0R) 0402_RES 3 R5, R7, R30 Resistor
Not Fitted (10K) 0402_RES 4 R36, R64, R65, R66 Resistor
Not Fitted (8.2pF) 0402_CAP_NPOL 2 C2, C4 Capacitor_not polarized
Not Fitted (NX3225GD-8.00M) CRY_NX3225GD_2P 1 X1 Crystal 8Mhz, 8pF, -+50PPM, SMD
Not Fitted 0402_CAP_NPOL 3 C69, C70, C72 Capacitor_not polarized
NX3215SA-32.768K CRY_NX3215SA_2P 1 X2 Crystal 32.768kHz, 6pF, -+20PPM, R=50K, SMD
NX3225GD-8.00M CRY_NX3225GD_2P 1 X3 Crystal 8Mhz, 8pF, -+50PPM, SMD
Open SB 6 SB9, SB11, SB12, SB16, SB19 Solder Jumper
SB20
PT PTB 6 TP1, TP2, TP3, TP4, TP5, TP6 Point de test
SPSGRF SPSGRF 1 M3 SPSGRF-915or SPSGRF-868
ST890CDR ICC_SO8_5X4_P127 1 U17 1.2 A current limited high-side power switch with thermal shutdown
STM32F103CBT6 ICC_LQFP48_7X7_P050 1 U15 Medium-density performance line ARM-based 32-bit MCU with 128KB Flash
STM32L475VGTx LQFP100 14x14x1.6 1 U1 STM32L475VGTx
STMPS2141STR MOS_SOT23-5L 1 U19 Enhanced single channel power switches
STSAFE-A100 SOP8 1 U9 STSAFE-A100
SW-PUSH-CMS_BLACK SWI_WEALTHMETAL_TD-0341_4P - BACK 1 B1 Push-button SMD
SW-PUSH-CMS_BLUE SWI_WEALTHMETAL_TD-0341_4P - BLUE 1 B2 Push-button SMD
TC2050-IDC-NL CON_TAG-C_TC2050-IDC-NL 1 CN5 Tag_Connector Header, 10-Pin, Dual row No legs
TSV631AILT SOT23-5 1 U21 TSV631AILT Rail-to-rail input/output, 60 礎, 880 kHz, 5 V CMOS operational amplifiers
VL53L0X LGA12-optical 1 U4 Proximity sensor MEMS |
