Name | Part Type | PCB Decal | Value | CN1 | CONNECTOR_DB9 | DB9-RA-F | CONNECTOR DB9 | CN2 | RCA_JACK | DCJACK | DC_JACK | CN3 | USB-A-F_0 | USBCON4 | USB-HOST | CN4 | USB_B_0 | USBCON4B | USB_B | D1 | LED_3 | D-0805 | G LED | D2 | LED_3 | D-0805 | G LED | D3 | DIODE_SCHOTTKY | D-S214AC | SS14 | D4 | DIODE_SCHOTTKY | D-S214AC | SS14 | D5 | LED | D-0805 | Y LED | D6 | DIODE_SCHOTTKY | D-S214AC | SS14 | D7 | DIODE_ZENER | D-1206 | 5.1V ZENER | D8 | DIODE_0 | D-214AC | 1N4004 | D9 | LED_3 | D-0805 | G LED | D10 | LED_3 | D-0805 | R LED | D11 | DIODE_SCHOTTKY | D-S214AC | SS14 | J1 | CON8 | SIP8 | CON8 | J2 | CON8 | SIP8 | CON8 | J3 | CON3 | SIP3 | CON3 | J4 | CON8 | SIP8 | CON8 | J5 | CON4_2 | SIP4 | CON4 | J6 | CON6 | SIP6 | CON6 | J7 | CON2AP | SIP2 | CON2AP | J8 | CON3 | SIP3 | CON3 | J9 | CON3 | SIP3 | CON3 | J10 | CON3 | SIP3 | CON3 | J11 | HEADER_16X2 | HEADER16X2 | HEADER 16X2 | J12 | CON3 | SIP3 | CON3 | J13 | HEADER_2 | SIP2 | SIP2 | J14 | CON10_3 | SIP10 | CON10 | J15 | CON3 | SIP3 | CON3 | J16 | CON10_3 | SIP10 | CON10 | J17 | HEADER_20X2_2 | HEADER16X2 | HEADER16X2 90 M | J18 | CON1_2 | SIP1 | CON1 | J19 | PHONEJACK_STEREO_SW | PHONEJACK-S | PHONEJACK STEREO | J20 | BNC | RCA | BNC | J21 | BNC | RCA | BNC | J22 | PHONEJACK_STEREO_SW | PHONEJACK-S | PHONEJACK STEREO | J23 | CON2_2 | SIP2 | CON2 | J24 | CON1_2 | SIP1 | CON1 | J25 | HDMI_0 | CON-HDMI19-0.5 | HDMI_Type_A | J26 | TP_DIP | SIP1 | TP | J27 | CON4 | SIP4 | CON4 | J28 | TP_DIP | SIP1 | TP | J29 | CON4 | SIP4 | CON4 | J30 | CON2AP | SIP2 | CON2AP | J31 | CON1 | SIP1 | CON1 | J32 | CON3_2 | SIP3 | CON3 | J33 | CON2 | SIP2 | CON2 | J34 | HEADER_2 | SIP2 | SIP2 | JM1 | CON1_2 | SIP1 | CON1 | JM2 | CON1_2 | SIP1 | CON1 | JP1 | HEADER_9X2 | HEADER9X2 | HEADER 9X2 | JP2 | JUMPER | SIP2 | JUMPER | JP3 | JUMPER | SIP2 | JUMPER | JP4 | JUMPER | SIP2 | JUMPER | JP5 | HEADER_10X2 | HEADERBG10X2H | HEADERBG10X2H | JP6 | JUMPER | SIP2 | JUMPER | JP7 | HEADER_2X2 | HEADER2X2 | HEADER 2X2 | JP8 | HEADER_2X2 | HEADER2X2 | HEADER 2X2 | JP9 | HEADER_2X2 | HEADER2X2 | HEADER 2X2 | JP10 | HEADER_2X2 | HEADER2X2 | HEADER 2X2 | JP11 | JUMPER | SIP2 | JUMPER | L1 | INDUCTOR_2 | L-0805 | 1.8uH | L2 | INDUCTOR | L-0805 | Bead | L3 | LSMD44_226 | L-170 | 4.7uH | MK1 | MICROPHONE | MICROPHONE | MICROPHONE | Q1 | 2N7008_0 | SOT-23-1 | BSN20 | Q2 | 2N7008_0 | SOT-23-1 | BSN20 | Q3 | PMOS1 | SOT-23-1 | SI2301 | Q4 | PMOS1 | SOT-23-1 | NC/SI2301 | Q5 | 2N3906_1 | SOT-23-1 | 8550 | Q6 | PMOS1 | SOT-23-1 | SI2301 | Q7 | BJT-NPN_0 | SOT-23-1 | NC/8050 | Q8 | PMOS1 | SOT-23-1 | SI2301 | Q9 | BJT-NPN_0 | SOT-23-1 | 8050 | RCH1 | R_13 | R-0603 | 3K | REG1 | LD1117/SOT_0 | SOT-23-3 | RT9179PB | S1 | SW_2P2T | SW-2P2T | SW 2P2T | SD1 | MICROSD_0 | TF-109BC | TF_CAR | SW1 | SW_PUSHBUTTON_0 | SW-TACT | RESETb | SW2 | SW_PUSHBUTTON_0 | SW-TACT | POWER | SW3 | SW_PUSHBUTTON_0 | SW-TACT | POWER | SW11 | SW_PUSH-S | SW-TACT4 | SW PUSH-S | SW12 | SW_DIP-8 | SW-DIP8 | SW DIP-8 | TC1 | CAPACITOR_2 | C-1210+ | 4.7uF | TC2 | CAPACITOR_2 | C-1210+ | 4.7uF | TC3 | C1206_106 | C-1210+ | 4.7uF/6V3 | TC4 | C1206_106 | C-1210+ | 4.7uF/6V3 | TC5 | C1210_476_10V+ | C-1210+ | 47uF/10V | U1 | GPCV1248 | QFP128-0.4 | GPB51PG | U2 | NAND_FLASH_0 | DIP48-TSOP724 | NAND PSU1GA30HT | U3 | GPR25L005B | DIP8-SOP209 | GPR25L321B_NC | U4 | MX25LXX05 | DIP16-SOP300 | GPR25LxxxB | U5 | GPR25L32_0_2 | DIP8-SOP209 | GPR25L321B / 209ml | U6 | SDCON_0 | CARD-SD | SDCON | U7 | TS4890IST_0 | DIP8-SOP150 | GPY0031 | U8 | XC62RP2502_0 | TPD4S010 | EMI4182/TPD4S010 | U9 | XC62RP2502_0 | TPD4S010 | EMI4182/TPD4S010 | U10 | ICL232_0 | DIP16-SOP150 | ICL232 | U11 | APL3202 | SOT-23-3 | APL3202 | U12 | LD1117/SOT_0 | SOT-23-3 | HP5013BM33E | U13 | AT1366B_0 | SOT-26 | AAT1217 | Y1 | CRYSTAL | X'TAL-32768 | 32.768KHz | Y2 | CRYSTAL | X'TAL | 12MHz |
