Name | Part Type | PCB Decal | Value | D1 | 1/4M11Z10_0_2 | D0805_A2 | BZT52C5V1S | FB1 | FB | L0402 | FB | J1 | CON20_1 | STAMP_HOLE_1D27_19P | CON19 | J2 | CON30_1 | STAMP_HOLE_1D27_28P | CON28 | J3 | CON20_1 | STAMP_HOLE_1D27_19P | CON19 | J4 | CON30_1 | STAMP_HOLE_1D27_28P | CON28 | L1 | INDUCTOR | L2016 | 2.2uH | L2 | INDUCTOR | L2016 | 2.2uH | L3 | INDUCTOR | L2016 | 2.2uH | L4 | INDUCTOR/SM | L0402 | 1.8nH | L5 | INDUCTOR | L2016 | 2.2uH | Q1 | MOSFET_N_GDS_0 | SOT_723 | WNM3013-3/TR | U2 | X1000_BGA190_13X13_V1_2.0 | BGA190_0D8 | X1000_BGA190_13X13 | U5 | SST25VF016B_1 | WSON8_1D27 | GD25Q128CS1G | U6 | FAR-F6KA-2G4500-A4VD | F6HF2G441AF46 | B39242B9604P810S01 | U7 | WM-BAN-BM-13_2 | WLBGA63_0D4_XD2 | BCM43438 | U9 | DCDC_RT8096C_0 | DCDC_SOT23-5 | RT8059GJ5 | U10 | LDO_RT9073A | LDO_ZQFN-4L_1X1X0P4 | RT9073A-18GQZ | U11 | DCDC_RT8096C_0 | DCDC_SOT23-5 | RT8059GJ5 | U12 | DCDC_RT8096C_0 | DCDC_SOT23-5 | RT8059GJ5 | U13 | LDO_RT9073A | LDO_ZQFN-4L_1X1X0P4 | RT9073A-25GQZ | Y1 | CRYSTAL_4 | CRY_3_2X2_5 | X3S024000DC1H-X | Y2 | CRYSTAL_0 | CRY_3_2X1_5 | NX3215SA-32.768KHZ-STD-MUA-8 | Y3 | CRYSTAL_4 | CRY_3_2X2_5 | X3S026000B91H-NZ |
底板
Name | Part Type | PCB Decal | Value | D1 | DIODE_PIN_0_2 | D0805 | WSB5503W | ESD30 | 1/4M11Z10_0 | ESD0402_A2 | LXES15AAA1-153 | J1 | CON-I/O_MICROUSB_0 | MICROUSB_DIP | CON-I/O_MICROUSB_5PIN | J2 | CON100_0 | AXK700147G | AXK700147G | J3 | HEADER_22X2_3 | HEADER22X2_2D0 | HEADER 22X2 | J4 | CON-I/O_MICROUSB_0 | MICROUSB_DIP | CON-I/O_MICROUSB_5PIN | J5 | HEADER_22X2_4 | HEADER8X2_2D0 | HEADER8X2 | J6 | MMC-SD_0 | TFCARD | T-FLASH | J7 | CONN_PCB_5_0 | CON5-SMD-1MM | CON5-SMD-1MM | J8 | CONN_PCB_5_0 | CON5-SMD-1MM | CON5-SMD-1MM | J9 | CONN_PCB_5_0 | CON5-SMD-1MM | CON5-SMD-1MM | J10 | CONN_PCB_5_0 | CON5-SMD-1MM | CON5-SMD-1MM | J11 | PIN_0.2_5_2 | SIP_2P | JUMPER | J12 | CON-I/O_MICROUSB_0 | MICROUSB_DIP | CON-I/O_MICROUSB_5PIN | J13 | PIN_0.2_5_2 | SIP_2P | JUMPER | J14 | PIN_0.2_5_2 | SIP_2P | JUMPER | J15 | PHONEJACK_STEREO_SW_0 | AJ5X14_SMD | PHONO-1/8 | J16 | PHONEJACK_STEREO_SW_0 | AJ5X14_SMD | PHONO-1/8 | K1 | CON3_0 | SW_3P_6A | CON3 | L1 | INDUCTOR | L2016 | 2.2uH | M1 | MIC | MIC6M_DIP | MIC | SPK1 | SPK | SIP_2P_2D0 | 8 OHM | SW1 | SW_PUSHBUTTON_1 | SW-5P | PUSHBUTTON | SW2 | SW_PUSHBUTTON_1 | SW-5P | PUSHBUTTON | SW3 | SW_PUSHBUTTON_1 | SW-5P | PUSHBUTTON | SW4 | SW_PUSHBUTTON_1 | SW-5P | PUSHBUTTON | SW5 | SW_PUSHBUTTON_1 | SW-5P | PUSHBUTTON | U1 | SGM4064 | TDFN-2X2-8L | SGM4064YDE8G/TR | U2 | MP62055_1 | SOT23_5 | R5524N002B | U3 | FT232RL | FPC-SSOP28-26-209 | FT232RL | U4 | SGM4917 | SGM4917 | SGM4917B | U5 | KB4898_4 | LM4871 | LM4871NOPB | U6 | DM9161_2 | TQFP48_0D5 | DM9162EP | U7 | RJ45-LED | RJ45_LED_FOX | RJ45_LED | U8 | FC618SM_0 | FC618SM | HST-1027SR | U9 | 24C16_0 | SO8 | 24LC16-S08 | U10 | SGM6014-ADJYTD10G/TR | TDFN_3X3_10L | SGM6014-ADJYTD10G/TR | Y1 | CRYSTAL_4 | CRY_2D0X1D6 | NC(25M_20PPM) |
