REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | LICELL_A_CONN_BATTERY_IC_5.35MM | HU2032-LF | CONN_BATTERY |
CR1 | DIODE_SCHTKY_SOD-123_IC_1.35MM_ | MBR0540T1G | SOD-123 |
CR2 | DIODE_SCHTKY_SOD-123_IC_1.35MM_ | MBR0540T1G | SOD-123 |
CR3 | DIODE_SCHTKY_SOD-123_IC_1.35MM_ | MBR0540T1G | SOD-123 |
CR4 | DIODE_SCHTKY_SOD-123_IC_1.35MM_ | MBR0540T1G | SOD-123 |
D1 | DIODE_SOD123_A_IC_1.35MM_480-78 | CMHD3595 | SOD123_A |
D2 | DIODE_SOD123_A_IC_1.35MM_480-78 | CMHD3595 | SOD123_A |
D3 | LED_0603LED_IC_0.65MM_370-75905 | RED LED | 0603LED |
D4 | LED_LED_0603_IC_0.8MM_370-75078 | BLUE | LED_0603 |
D5 | LED_0603LED_IC_0.65MM_370-75905 | RED LED | 0603LED |
D31 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D32 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D33 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
D34 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | DO_VMN2 |
DS1 | KCDC02123RY_20P_LED20_1P44_14X1 | KCDC02-123-RY | LED20_1P44_14X10 |
DS2 | KCDC02123RY_20P_LED20_1P44_14X1 | KCDC02-123-RY | LED20_1P44_14X10 |
F1 | INDUCTOR_FERRITE_IND_0805_DISCR | 1000@100MHZ | IND_0805 |
F2 | INDUCTOR_FERRITE_IND_0805_DISCR | 1000@100MHZ | IND_0805 |
F3 | INDUCTOR_FERRITE_IND_0805_DISCR | 1000@100MHZ | IND_0805 |
F4 | IND_IND_0603_DISCRETE_1MM_180-7 | 60 OHM 100MHZ | IND_0603 |
F5 | IND_IND_0603_DISCRETE_1MM_180-7 | 60 OHM 100MHZ | IND_0603 |
F6 | INDUCTOR_FERRITE_IND_0805_DISCR | 1000@100MHZ | IND_0805 |
F7 | FUSE_RESETTABLE_FUSE_SMD050_IC_ | 1A | FUSE_SMD050 |
F8 | IND_IND_0603_DISCRETE_1MM_180-7 | 60 OHM 100MHZ | IND_0603 |
F9 | INDUCTOR_FERRITE_IND_0805_DISCR | 1000@100MHZ | IND_0805 |
FL4 | EMIFILTER_NFM55P_CC2220_NFM55P_ | NFM55PC155F1H4B | CC2220_NFM55P |
J1 | MICRO_USB_CONN_9PIN_CON9_MICROA | USB AB 5 | CON9_MICROAB_USB_SHELL_TH |
J2 | 0821-1X1T-43-F_CON20_RJ45_USBA_ | USB_TYPE_A + RJ45-12 | CON20_RJ45_USBA |
J3 | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | CON19_SDCARD_28X16_SM |
J4 | SIG_TIE_100X200_SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
J5 | DUAL_DB9M_RA_DUALDB-9M_RA_31.98 | 1734279-3 | DUALDB-9M_RA |
J6 | CONN_SOCKET_20X2_CONN2X20_20X7M | CONN MICRO EDGE 2x20 | CONN2X20_20X7MM_PCI_EXT |
J7 | CONN_SOCKET_20X2_CONN2X20_20X7M | CONN MICRO EDGE 2x20 | CONN2X20_20X7MM_PCI_EXT |
J8 | CONN_SOCKET_20X2_CONN2X20_20X7M | CONN MICRO EDGE 2x20 | CONN2X20_20X7MM_PCI_EXT |
J9 | CONN_SOCKET_20X2_CONN2X20_20X7M | CONN MICRO EDGE 2x20 | CONN2X20_20X7MM_PCI_EXT |
J10 | CONN_SOCKET_20X2_CONN2X20_20X7M | CONN MICRO EDGE 2x20 | CONN2X20_20X7MM_PCI_EXT |
J11 | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | HDR103_STAG_SM |
J12 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J13 | CON_SATA_PLUG7_CON_7_SATA_V_SM_ | Vertical SATA | CON_7_SATA_V_SM |
J14 | CON_SATA_PLUG7_CON_7_SATA_V_SM_ | Vertical SATA | CON_7_SATA_V_SM |
J15 | SIG_TIE_100X200_SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
J16 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J17 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | HDR103 |
J18 | SIG_TIE_100X200_SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
J19 | CONN_COAX_1P_F_CONN_SMB_IO_7.95 | CON_1_SMB | CONN_SMB |
J26 | W3GD-164AN63B52UW_CON_PCIE164_1 | W3GD-164AN63B52UW | CON_PCIE164_1_SM |
J27 | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | HDR103_STAG_SM |
J28 | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | HDR103_STAG_SM |
J29 | CONN_2X35_CON2X35_SKT_0P8_SM_5. | CONN SKT 70 | CON2X35_SKT_0P8_SM |
J30 | SKT_DIMM_240P_SKT_DDR3DIMM_240_ | 78156-0001 | SKT_DDR3DIMM_240_1MM_SMT |
J31 | SKT_DIMM_240P_SKT_DDR3DIMM_240_ | 78156-0001 | SKT_DDR3DIMM_240_1MM_SMT |
J32 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J33 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J34 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J35 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR 1X2 TH | HDR102 |
J36 | QTH-030-02-L-D-A_CON_60_QTH_0P5 | QTH-030-01-L-D-A-K-TR | CON_60_QTH_0P5_SM |
J37 | SIG_TIE_100X200_SIG_TIE_100X200 | PLANE SHORT TIE | SIG_TIE_100X200 |
J38 | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | HDR103_STAG_SM |
J39 | HTST-108-01-L-DV_HDR208_HTST_SM | HTST-108-01-L-DV | HDR208_HTST_SM |
J40 | CONN_HDR_25X2_CON_FTR-125-01-S- | HDR_2X25 | CON_FTR-125-01-S-D |
J41 | ATX_12V_PWR_CONN_CONN_ATX12V_2X | CON_2X2 | CONN_ATX12V_2X2 |
J42 | CONN_HDR_3X1_HDR103_STAG_SM_IO_ | HDR 1X3 | HDR103_STAG_SM |
J43 | CONN_PWR_12X2_CON_ATXPWR_2X12_A | CON_2X12_PWR | CON_ATXPWR_2X12_A |
J44 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR 1X2 TH | HDR102 |
J45 | CONN_HDR_2X1_HDR102_STAG_SM_9.6 | HDR_1X2 | HDR102_STAG_SM |
J46 | HDR_1X3_HDR1X3_TH_IO_12.04MM_21 | HDR 1X3 | HDR1X3_TH |
J47 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR 1X2 TH | HDR102 |
J48 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR 1X2 TH | HDR102 |
J49 | CONN_HDR_2X1_HDR102_8.71MM_210 | HDR 1X2 TH | HDR102 |
J50 | HTST-105-01-S-DV_HDR205_HTST_SM | HDR_2X5 | HDR205_HTST_SM |
J51 | CONN_COAX_1P_F_CON_SMA_IO_9.652 | CON 1 SMA | CON_SMA |
J52 | CONN_COAX_1P_F_CON_SMA_IO_9.652 | CON 1 SMA | CON_SMA |
JP1 | CONN_HDR_1X1_HDR101_IO_8.585MM | HDR 1X1 | HDR101 |
L1 | IND_IND_0603_DISCRETE_1MM_180_1 | 60 OHM 100MHZ | IND_0603 |
L2 | DLW43_CHOKE_0805_DISCRETE_1MM_1 | 90OHM | CHOKE_0805 |
L3 | IND_BLA31A_IND_BLA31_1.0MM_180- | 220 OHM@100MHZ | IND_BLA31 |
L4 | IND_BLA31A_IND_BLA31_1.0MM_180- | 220 OHM@100MHZ | IND_BLA31 |
L5 | INDUCTOR_IND_IHLP-5050_DISCRETE | 0.47UH | IND_IHLP-5050 |
L6 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L7 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L8 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L9 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L10 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L11 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L12 | COIL_IND_IHLP-5050_DISCRETE_6.5 | 0.33uH | IND_IHLP-5050 |
L13 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
L14 | COIL_IND_IHLP-5050_DISCRETE_6.5 | 0.33uH | IND_IHLP-5050 |
L15 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
L16 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
L17 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
L18 | BEAD_FERRITE_IND_0603_DISCRETE_ | 120OHM | IND_0603 |
L19 | BEAD_FERRITE_IND_0603_DISCRETE_ | 120OHM | IND_0603 |
L20 | INDUCTOR_IND_IHLP_DISCRETE_3MM | 2.2UH | IND_IHLP |
L21 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
L22 | IND_IND_0603_DISCRETE_1MM_180_1 | 60 OHM 100MHZ | IND_0603 |
L23 | COIL_IND_IHLP-5050_DISCRETE_6.5 | 0.33uH | IND_IHLP-5050 |
L24 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L25 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 75 OHM | IND_0603 |
L26 | DLW43_CHOKE_0805_DISCRETE_1MM_1 | 90OHM | CHOKE_0805 |
L32 | IND_IND_0603_DISCRETE_1MM_180_1 | 60 OHM 100MHZ | IND_0603 |
L33 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
MP5 | TPS_RECT_TESTPOINT_079_051MIL_2 | HK-3-G-T-SO5 | TESTPOINT_079_051MIL |
P1 | RJ45_MAG_LED_CON_RJ45_MAG_LED_G | RJ45-12 | CON_RJ45_MAG_LED_GETH |
Q1 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | SOT23 |
Q2 | MOSFET_N_8P_TDSON8_1P27_6X5MM_1 | BSC080N03MSG | TDSON8_1P27_6X5MM |
Q3 | MOSFET_N_8P_TDSON8_1P27_6X5MM_2 | BSC016N03MSG | TDSON8_1P27_6X5MM |
Q4 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q5 | MOSFET_N_8P_TDSON8_1P27_6X5MM_1 | BSC080N03MSG | TDSON8_1P27_6X5MM |
Q6 | MOSFET_N_8P_TDSON8_1P27_6X5MM_I | BSC020N03MSG | TDSON8_1P27_6X5MM |
Q7 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q8 | MOSFET_N_8P_TDSON8_1P27_6X5MM_1 | BSC080N03MSG | TDSON8_1P27_6X5MM |
Q9 | MOSFET_N_8P_TDSON8_1P27_6X5MM_I | BSC020N03MSG | TDSON8_1P27_6X5MM |
Q10 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q11 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q12 | MOSFET_N_8P_TDSON8_1P27_6X5MM_I | BSC020N03MSG | TDSON8_1P27_6X5MM |
Q13 | MOSFET_N_8P_TDSON8_1P27_6X5MM_1 | BSC080N03MSG | TDSON8_1P27_6X5MM |
Q14 | IRF6718L2TR_IRF6718_IC_0.756MM_ | IRF6718L2TRPbF | IRF6718 |
Q15 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q16 | IRF6718L2TR_IRF6718_IC_0.756MM_ | IRF6718L2TRPbF | IRF6718 |
Q17 | IRF6718L2TR_IRF6718_IC_0.756MM_ | IRF6718L2TRPbF | IRF6718 |
Q18 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | SOT23 |
Q20 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | SOT23 |
Q21 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | SOT23 |
Q22 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | SOT23 |
Q23 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | SOT23 |
R1-191 | RES_CASE4527_12X7_DISCRETE_470- | 140 | CASE4527_12X7 |
R2-191 | RES_CASE4527_12X7_DISCRETE_470- | 140 | CASE4527_12X7 |
SW10 | SW_DIP_8_SW_DIP16_8POS_SM_2.36M | SW DIP-8 | SW_DIP16_8POS_SM |
SW11 | SW_TACT-SPST-2_SM_6_22X6_38_SW_ | DTSMW-69R-V-T/R | 6_22X6_38_SW |
SW12 | SW_TACT-SPST-2_SM_6_22X6_38_SW_ | DTSMW-69R-V-T/R | 6_22X6_38_SW |
SW13 | SW_TACT-SPST-2_SM_6_22X6_38_SW_ | DTSMW-69R-V-T/R | 6_22X6_38_SW |
U1 | VBUS054B_LLP75_6A_IC_0.85MM_312 | VBUS054B-HS3-GS08 | LLP75_6A |
U2 | LT1764AEQ_DD-PAK5_IC_4.572MM_3 | LT1764AEQ-2.5 | DD-PAK5 |
U3 | ZL2006_QFN36_0P5_6X6_IC_1MM_315 | ZL6100 | QFN36_0P5_6X6 |
U4 | SN74CB3Q3253DGVR_TVSOP16_IC_1.2 | SN74CB3Q3253 | TVSOP16 |
U5 | 2076_2_8P_SOP8-1_IC_1.73MM_312- | MIC2076-1YM | SOP8-1 |
U6 | ADG804_MSOP10_60X12_IC_1.10MM_3 | ADG804YRM | MSOP10_60X12 |
U7 | IDTQS3VH257_16P_TSSOP16_IC_1.2M | IDTQS3VH257PA | TSSOP16 |
U8 | HIN211_0_SSOP-28_IC_2MM_312-758 | ADM561JRSZ | SSOP-28 |
U9 | TPS73701_SOT223-6_IC_1.8MM_312- | TPS73701 | SOT223-6 |
U10 | ZL2006_QFN36_0P5_6X6_IC_1MM_315 | ZL6100 | QFN36_0P5_6X6 |
U11 | MAX931_SO_SO8_IC_1.75MM_312-301 | MAX931CSA+ | SO8 |
U12 | 128MB_FLASH_S25FL129P_8P_WSON_8 | S25FL129P0XNFI001 | WSON_8 |
U13 | ADG804_MSOP10_60X12_IC_1.10MM_3 | ADG804YRM | MSOP10_60X12 |
U14 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U15 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U16 | ZL2006_QFN36_0P5_6X6_IC_1MM_315 | ZL6100 | QFN36_0P5_6X6 |
U17 | MAX3394E_TDFN_9P_TDFN_8_0P65_3X | MAX3394E | TDFN_8_0P65_3X3 |
U18 | MIC47100YMME_MSOP8_0P65_3P1X3P1 | MIC47100YMME | MSOP8_0P65_3P1X3P1 |
U19 | FDC6330_SSOT_6P_SSOT6_1P7X3_IC_ | FDC6330L | SSOT6_1P7X3 |
U20 | TPS74701_SON_11P_QFN_10_0P5_3X3 | TPS74701 | QFN_10_0P5_3X3 |
U21 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U22 | TPS74801_QFN20_THIN_IC_1MM_315 | TPS74801 | QFN20_THIN |
U23 | FDC6330_SSOT_6P_SSOT6_1P7X3_IC_ | FDC6330L | SSOT6_1P7X3 |
U24 | TPS51200_QFN_10_0P5_3X3_IC_1.0 | TPS51200 | QFN_10_0P5_3X3 |
U25 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U26 | P3041_P5020_C_1550371_R1_P3041_ | P3041_P5020 | C_1550371_R1 |
U27 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U28 | PI2PCIE2214ZHE_TQFN42_TAB_IC_0. | PI2PCIE2214ZHE | TQFN42_TAB |
U29 | TPS72518_DDPAK5_1P7_10P6_IC_4.8 | 1.8V/1.0A | DDPAK5_1P7_10P6 |
U30 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U31 | 85104AGI_TSSOP20_IC_1.2MM_312-7 | 85104AGI | TSSOP20 |
U32 | ICS843N3960_TSSOP_20P_TSSOP20_0 | 843N3960AGILF | TSSOP20_0P65_4P5X6P6 |
U33 | ICS843N3960_TSSOP_20P_TSSOP20_0 | 843N3960AGILF | TSSOP20_0P65_4P5X6P6 |
U34 | ICS85108AGILF_TSSOP24_0P65_7P9X | ICS85108AGILF | TSSOP24_0P65_7P9X4P5 |
U35 | PI2PCIE2422_TQFN_42P_TQFN42_TAB | PI2PCIE2422ZHE | TQFN42_TAB |
U36 | 85104AGI_TSSOP20_IC_1.2MM_312-7 | 85104AGI | TSSOP20 |
U37 | ICS843N3960_TSSOP_20P_TSSOP20_0 | 843N3960AGILF | TSSOP20_0P65_4P5X6P6 |
U38 | 8535_01_TSSOP_20P_TSSOP20_IC_1. | ICS8535AG-01 | TSSOP20 |
U39 | TPS54310_HTSSOP20_IC_1.2MM_312- | TPS54310 | HTSSOP20 |
U40 | 1G125_SC-70_IC_1.1MM_312-75240_ | SN74LVC1G125DCKR | SC-70 |
U41 | AT24C64AN_SO_8_IC_1.75MM_334-76 | AT24C64C | SO_8 |
U42 | 32373_LFBGA96_0-8MM_5-6X13-6MM_ | 74ALVTH32373ZKER | LFBGA96_0-8MM_5-6X13-6MM |
U43 | TPS72515_DDPAK5_DD-PAK5_420X625 | TPS72515KTTR | DD-PAK5_420X625 |
U44 | TPS72501_A_DD-PAK5_420X625_IC_5 | TPS72501KTTTG3 | DD-PAK5_420X625 |
U45 | 74-244_20P_TSSOP20_IC_1.1MM_312 | 74LVT244APW | TSSOP20 |
U46 | SN74LVC1G07_SC-70_IC_1.1MM_312- | SN74LVC1G07DCKR | SC-70 |
U47 | 100201_SO_10_SC70-5_IC_1.1MM_31 | SN74CBTLV1G125DCKR | SC70-5 |
U48 | SN74LVC1G07_SC-70_IC_1.1MM_312- | SN74LVC1G07DCKR | SC-70 |
U49 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | MSOP_10_0P5_3X3 |
U50 | DS3232S_SO20W_IC_2.67MM_315-767 | DS3232 | SO20W |
U51 | MPC94551EF_SO8_IC_1.75MM_312-75 | MPC94551 | SO8 |
U52 | 980020-48-P2_TSOP48_SKT_CUST_5. | 980020-48-P2 | TSOP48_SKT_CUST |
U53 | IDTQS3VH257_16P_TSSOP16_IC_1.2M | IDTQS3VH257PA | TSSOP16 |
U54 | MAX931_SO_SO8_IC_1.75MM_312-301 | MAX931CSA+ | SO8 |
U55 | 74LV08_SSOP14_IC_2MM_312-79550_ | 74LV08 | SSOP14 |
U56 | IDTQS3VH257_16P_TSSOP16_IC_1.2M | IDTQS3VH257PA | TSSOP16 |
U57 | MAX931_SO_SO8_IC_1.75MM_312-301 | MAX931CSA+ | SO8 |
U58 | 74LV08_SSOP14_IC_2MM_312-79550_ | 74LV08 | SSOP14 |
U59 | MAX16999_UMAX_8P_UMAX8_TAB_IC_1 | MAX16999AUA10+ | UMAX8_TAB |
U60 | S-TSO-SM-056-C1_TSOP56_SK_5.33M | SKT TSOP 56 SMT | TSOP56_SK |
U61 | S-TSO-SM-056-C1_TSOP56_SK_5.33M | SKT TSOP 56 SMT | TSOP56_SK |
U62 | ZL2006_QFN36_0P5_6X6_IC_1MM_315 | ZL6100 | QFN36_0P5_6X6 |
U63 | MAX16006_TG+_QFN24_4X4MM_IC_0.8 | MAX16006ATG+ | QFN24_4X4MM |
U64 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | AT24C02B-TH-B | TSSOP8 |
U65 | AT24C64AN_SO_8_IC_1.75MM_334-76 | AT24C64C | SO_8 |
U66 | ADG804_MSOP10_60X12_IC_1.10MM_3 | ADG804YRM | MSOP10_60X12 |
U67 | VBUS054B_LLP75_6A_IC_0.85MM_312 | VBUS054B-HS3-GS08 | LLP75_6A |
U68 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U69 | SN74CB3Q3253DGVR_TVSOP16_IC_1.2 | SN74CB3Q3253 | TVSOP16 |
U70 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U71 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U72 | 100201_SO-1_SOT-553-5P_IC_0.6MM | NL17SZ126XV5T2G | SOT-553-5P |
U73 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U74 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U75 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U76 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U77 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U78 | LCDA15C-8_TBT_SO16_IC_1.75MM_31 | LCDA15C-8.TBT | SO16 |
U79 | 74LCX138_SO16_IC_1.753MM_312-7 | 74LCX138MX | SO16 |
U80 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | MSOP_10_0P5_3X3 |
U81 | 25AA1024T_SOIJ_8P_SOIJ_1P27_5X5 | 25AA1024T-I/SM | SOIJ_1P27_5X5 |
U82 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U83 | SN74CB3Q3253DGVR_TVSOP16_IC_1.2 | SN74CB3Q3253 | TVSOP16 |
U84 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U85 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U86 | VSC8244_PBGA260_19X19MM_0P16_2M | VSC8244XHG | PBGA260_19X19MM_0P16 |
U87 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U88 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U89 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | MSOP_10_0P5_3X3 |
U90 | ICS8304_SO8_1P27_4X5_IC_1.75MM_ | ICS8304AMLF | SO8_1P27_4X5 |
U91 | NC7SB3157_6P_SC70-6_1.1MM_312-3 | NC7SB3157 | SC70-6 |
U92 | ICS307M-02_SO16_IC_1.75MM_312-7 | ics307m-02 | SO16 |
U93 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | MSOP_10_0P5_3X3 |
U94 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U95 | MAX3394E_TDFN_9P_TDFN_8_0P65_3X | MAX3394E | TDFN_8_0P65_3X3 |
U96 | MAX3394E_TDFN_9P_TDFN_8_0P65_3X | MAX3394E | TDFN_8_0P65_3X3 |
U97 | MAX3394E_TDFN_9P_TDFN_8_0P65_3X | MAX3394E | TDFN_8_0P65_3X3 |
U98 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U99 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U100 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U101 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U102 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U103 | FDC6330_SSOT_6P_SSOT6_1P7X3_IC_ | FDC6330L | SSOT6_1P7X3 |
U104 | PI2PCIE_28TQFN_TQFN28_0P5_3P6X5 | PI2PCIE2212ZHE | TQFN28_0P5_3P6X5P6 |
U105 | PI2PCIE2214ZHE_TQFN42_TAB_IC_0. | PI2PCIE2214ZHE | TQFN42_TAB |
U106 | NOR_2IN_SOT-23-5_IC_1.45MM_312- | SN74LVC1G02DBVR | SOT-23-5 |
U107 | SN74LVC1G07_SC-70_IC_1.1MM_312- | SN74LVC1G07DCKR | SC-70 |
U108 | ADT7461_MSO8_IC_1.1MM_315-75543 | ADT7461 | MSO8 |
U109 | 74_16245A_TSSOP48_IC_1.2MM_312- | 74LCX16245 | TSSOP48 |
U110 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U111 | ATMEL_SERIAL_EEPROM_64K-1_TSSOP | AT24C02B-TH-B | TSSOP8 |
U112 | ICS83021AMILF_SOIC8_IC_1.75MM_ | ICS83021AMILF | SOIC8 |
U113 | 74_16245A_TSSOP48_IC_1.2MM_312- | 74LCX16245 | TSSOP48 |
U114 | 74-244_20P_TSSOP20_IC_1.1MM_312 | 74LVT244APW | TSSOP20 |
U115 | A3P1000-FGG484_BGA_484_1MM_23X2 | A3P1000-FGG484 | BGA_484_1MM_23X23_A |
U116 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U117 | MAX4906ELB_0_DFN_10_0P4_2X2_IC_ | MAX4906FELB+ | DFN_10_0P4_2X2 |
U118 | SN74LVC_SOT-23-5_IC_1.45MM_312- | SN74LVC1G86 | SOT-23-5 |
U119 | SN74LVC_SOT-23-5_IC_1.45MM_312- | SN74LVC1G86 | SOT-23-5 |
U120 | SN74LVC_SOT-23-5_IC_1.45MM_312- | SN74LVC1G86 | SOT-23-5 |
U121 | SMS3_3_SOT23-6_IC_1.45MM_312-76 | SMS3.3TCT | SOT23-6 |
U122 | NLU2GU04_ULLGA6_1P45X1_0P5MM_IC | NLU2GU04 | ULLGA6_1P45X1_0P5MM |
U123 | NL27WZ32_US8_IC_0.9MM_312-79554 | NL27WZ32 | US8 |
U124 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U125 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U126 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U127 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U128 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
U129 | NL27WZ32_US8_IC_0.9MM_312-79554 | NL27WZ32 | US8 |
U130 | NLU2GU04_ULLGA6_1P45X1_0P5MM_IC | NLU2GU04 | ULLGA6_1P45X1_0P5MM |
U131 | MAX4599EXT_SC70-6_IC_1.1MM_315- | MAX4599 | SC70-6 |
X1 | SG8002_XTLOSC4_5X7_5_IC_1.8MM_2 | 33.333M | XTLOSC4_5X7_5 |
X2 | CLKOSC_4PIN_OSC4_7P5X5MM_IC_1.4 | 25MHZ | OSC4_7P5X5MM |
Y1 | OSC3_7X5MM_IC_1.8MM_230-76774_2 | 24.000MHz | 7X5MM |
Y2 | SIT9002_OSC6_5P1X7P1_SM_IC_1.0M | SiT9002 | OSC6_5P1X7P1_SM |
Y3 | CLKOSC_4PIN_OSC4_7P5X5MM_IC_1.4 | 25MHZ | OSC4_7P5X5MM |
Y4 | OSC3_OSC4-86X79-EH26_IC_1.8MM_2 | 125MHZ | OSC4-86X79-EH26 |
