查看: 1954|回复: 7
[IC] DDR2和DDR3硬件和布局设计
发表于 2019-6-24 09:15:41 | 显示全部楼层 |阅读模式
PCB layout DDR2 DDR3
DDR2_DDR3 Low-Cost PCB Design guidelines for aetix-7 spartan-7 FPGAs
DDR2 and DDR3 SDRAM Board Design guidelines,external memory ixterfaces handbook
cadence High-Speed PCB Layout flow
Board Design Layout Guidelines an520
Atmel SMART SAMA5D2 Layout recommendations
AN3940, Hardware and Layout Design guidelines for ddr3 sdram memory interfaces
AN2536 High Speed Layout Design guidelines
AN520 - DDR3 SDRAM Memory interfaces and layout guidelines
AN444 - Dual DIMM DDR2 and ddr3 sdram interfaces design guidelines
Addressing the DDR3 design challenges using cadence
AC453 - Layout Guidelines for rtg4-based board design
Layout Design Considerations for ddr2 sdram memory interfaces an2910
AC453 - Layout Guidelines for RTG4-Based Board Design.pdf
6.49 MB, 下载次数: 7, 下载积分: 金币 -1 枚
Addressing the DDR3 design challenges using Cadence.pdf
1.15 MB, 下载次数: 5, 下载积分: 金币 -1 枚
AN 444 - Dual DIMM DDR2 and DDR3 SDRAM Interface Design Guidelines.pdf
7.46 MB, 下载次数: 2, 下载积分: 金币 -1 枚
AN520 - DDR3 SDRAM Memory Interface Termination and Layout Guidelines.pdf
909 KB, 下载次数: 2, 下载积分: 金币 -1 枚
AN2536 High Speed Layout Design Guidelines.pdf
658 KB, 下载次数: 3, 下载积分: 金币 -1 枚
AN3940, Hardware and Layout Design Considerations for DDR3 SDRAM Memory Interfaces.pdf
535 KB, 下载次数: 0, 下载积分: 金币 -1 枚
Atmel SMART SAMA5D2 Layout Recommendations.pdf
429 KB, 下载次数: 0, 下载积分: 金币 -1 枚
Board Design Layout Guidelines an520.pdf
7.44 MB, 下载次数: 0, 下载积分: 金币 -1 枚
Cadence High-Speed PCB Layout Flow.pdf
812 KB, 下载次数: 0, 下载积分: 金币 -1 枚
DDR2 and DDR3 SDRAM Board Design Guidelines, External Memory Interface Handbook.pdf
2.63 MB, 下载次数: 6, 下载积分: 金币 -1 枚
DDR2_DDR3 Low-Cost PCB Design Guidelines for Artix-7_Spartan-7 FPGAs.pdf
970 KB, 下载次数: 0, 下载积分: 金币 -1 枚
Layout Design Considerations for DDR2 SDRAM Memory Interfaces - AN2910.pdf
606 KB, 下载次数: 0, 下载积分: 金币 -1 枚
    昨天 17:59
  • 签到天数: 17 天
    发表于 2019-6-24 09:41:12 | 显示全部楼层
    发表于 2019-6-24 10:20:48 | 显示全部楼层
  • 签到天数: 16 天
    发表于 2019-6-24 12:10:18 | 显示全部楼层
    发表于 2019-6-24 15:43:31 | 显示全部楼层
     楼主| 发表于 2020-10-2 09:33:28 | 显示全部楼层
    5 小时前
  • 签到天数: 39 天
    终身成就奖社区居民
    发表于 2020-10-11 08:43:52 | 显示全部楼层
    发表于 2020-10-14 10:21:50 | 显示全部楼层
