HX6A28参考设计.rar
HX6A28参考设计.7z
(3.49 MB, 下载次数: 20)
以下内容由管理员 @老吴 整理补充
Name | Part Type | PCB Decal | Value | CN1 | 88T340-19-VS_0 | CON_HDMI\SM\RA | HDMIA-19-02F | CN2 | 88T340-19-VS_0 | CON_HDMI\SM\RA | HDMIA-19-02F | CN5 | HEADER_4 | JST-4-2.0 | JST-4-2.0 | CN6 | HEADER_4 | CON4-P2.54-V | JST-4-2.54 | CN7 | 88T340-19-VS_0 | CON_HDMI\SM\RA | HDMIA | CN8 | HEADER_4 | JST-4-2.0 | JST-4-2.0 | CN10 | HEADER_4 | CON4-P2.54-V | JST-4-2.54 | CN12 | HEADER_2_3 | SW-3-1.7-F-D | SW-3-1.7-F-D | CN13 | PHONEJACK_STEREO_SW_6 | EPJ-035-05-TPI | NC,EPJ-035-05 | CN14 | HEADER_2_3 | SW-3-1.7-F-D | SW-3-1.7-F-D | CN15 | 88L302-13S | EPJ-035-05-TPI | NC,PHONE JACK_ PJ3518 | D1 | ZDC833/SOT | SOT23BEC | BAT54C | D2 | DIODE_DIAC | D0603 | NC,VPORT0603100KV05 | D3 | DIODE_DIAC | D0603 | NC,VPORT0603100KV05 | D4 | ZDC833/SOT | SOT23BEC | BAT54C | D5 | DIODE_DIAC | D0603 | NC,VPORT0603100KV05 | D6 | DIODE_DIAC | D0603 | NC,VPORT0603100KV05 | D10 | B340A | SMA | B340A | D11 | LED_0 | LED-1206 | LED(GREEN) | D12 | LED_0 | LED-1206 | LED(GREEN) | D13 | LED_0 | LED-1206 | LED(GREEN) | D14 | LED_0 | LED-1206 | LED(GREEN) | D15 | LED_0 | LED-1206 | LED(GREEN) | D19 | LED_0 | LED-1206 | LED(GREEN) | D20 | B340A | SMA | B340A | D21 | B340A | SMA | B340A | D22 | LED_0 | LED-1206 | LED(GREEN) | D23 | DIODE_DIAC | D0603 | NU,VPORT0603100KV05 | D24 | DIODE_DIAC | D0603 | NU,VPORT0603100KV05 | DJ1 | PHONEJACK_3 | DC-JACK-3 | DJ-014 | FB23 | B300R2A5 | R0805 | B300R2A5 | FIELD1 | TP_TEST_POINT | TP-1.1D-C | P3V3 | H1 | JGK_0 | M6.5H3.5 | NC, | H2 | JGK_0 | M6.5H3.5 | NC, | H3 | JGK_4 | M6.5H3.5 | NC, | H4 | JGK_0 | M6.5H3.5 | NC, | H5 | PHOTOPAD_0 | SEN-PIN | NC,PHOTOPAD | H6 | PHOTOPAD_0 | SEN-PIN | NC,PHOTOPAD | H7 | PHOTOPAD_0 | SEN-PIN | NC,PHOTOPAD | J1 | HEADER_2 | HEAD-2X1-2.54 | HEADER 2 | J27 | JUMPER | HEAD-2X1-2.0 | NC,1583EN | L1 | INDUCTOR | LC110-50-1.0 | 22uH | L2 | INDUCTOR | LC110-50-1.0 | 22uH | P1 | PIN_HEAD_1 | HEAD-6X2-2.0 | NC,PIN HEADER | P2 | PIN_HEAD_1 | HEAD-6X2-2.0 | NC,PIN HEADER | P3 | PIN_HEAD_1 | HEAD-6X2-2.0 | NC,PIN HEADER | Q2 | 2N7002 | SOT23GSD | 2N7002 | Q3 | NPN_BEC | SOT23BEC | PMBS3904 | Q21 | 2N7002 | SOT23GSD | 2N7002 | Q23 | NPN_BEC | SOT23BEC | PMBS3904 | S1 | SW_TACT-SPST-2/SM | SW-4-6.5-F-D | MCU Reset | S2 | SW_TACT-SPST-2/SM | SW-4-6.5-F-D | MODE_1 | S3 | SW_TACT-SPST-2/SM | SW-4-6.5-F-D | MODE_2 | S4 | SW_TACT-SPST-2/SM | SW-4-6.5-F-D | MODE_2 | SW1 | SW_TACT-SPST-2/SM | SW-4-6.5-F-D | M2 Reset | SW2 | SW_DIP-4/SM | DIP-8 | SW DIP-4 | SW3 | SW_KEY-Y1011_1 | SW-3-90 | SW KEY-Y1011 | TP1 | TP_TEST_POINT | TP-1S-R | TP,TEST POINT | TP2 | TP_TEST_POINT | TP-1S-R | TP,TEST POINT | U1 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U2 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U3 | 56T662-10 | SLP2510P8 | NC RClamp0524P.TCT | U4 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U5 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U6 | 56T662-10 | SLP2510P8 | NC RClamp0524P.TCT | U10 | 56T1133917 | SOP8-P-6.2-1.27 | MX25L4005AM2C-12G | U11 | HX6A28-A_0 | LQFP128-0.4-SKT | HX6A28-A | U13 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U14 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U15 | 56T662-10_2 | SLP2510P8 | NC,RClamp0524P.TCT | U16 | CAT6613 | LQFP100-0.5 | CAT6613 | U17 | 1117-33_TO252_0 | TO252GOI | 1117-33 | U18 | 1117-18_TO252_0 | TO252GOI | 1117-18 | U19 | 51MCU_STK6011_2_PLCC44_0 | PLCC44-SKT-S | W79E632A40PN | U20 | IR_RX | JST-3-2.0 | NC,IR_RX | U22 | AP1530_5 | _SOP-8-7.5-DEP | AP1530 | U23 | AP1530_5 | _SOP-8-7.5-DEP | AP1530 | U24 | 1117-33_TO252_0 | TO252GOI | 1117-33 | U25 | 56G1133906(2) | SOP8-P-6.2-1.27 | NC,M24C02-WDW6P | U26 | AP1530_4 | SOP8-P-6.2-1.27 | NC,CS4334 | U27 | 56G1133906(2) | SOP8-P-6.2-1.27 | NC,M24C02-WDW6P | U28 | 56G1133906(2) | SOP8-P-6.2-1.27 | NC,M24C02-WDW6P | U501_1 | PLCC44_IC_SOCKET | PLCC44-SKT | AMP C_822499_D | X1 | CRYSTAL | HC-49U | 24.576MHz | X2 | 24.576MHZ | HC-49U | 22.118MHz |
