TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
wms8160a1_pcb.7z
(633 KB, 下载次数: 8)
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | 3P3VA | SMD_TP_1MM | TestPoint_1mm | SMD_TP_1MM | 3P3VSUS | SMD_TP_1 | PLLTP | SMD_TP_1 | 5V | SMD_TP_1 | PLLTP | SMD_TP_1 | 5VIN | SMD_TP_1 | PLLTP | SMD_TP_1 | B1 | PIN_A-PL | PIN/X | PIN_A-PL | B2 | PIN_A-PL | PIN/X | PIN_A-PL | B3 | PIN_A-PL | PIN/X | PIN_A-PL | B4 | PIN_A-PL | PIN/X | PIN_A-PL | D1 | SOD-106 | RB051L-40 | SOD-106 | D2 | SOD-106 | RB051L-40 | SOD-106 | D3 | SOD-106 | RB051L-40/X | SOD-106 | D4 | SOT23-132 | BAT54S | SOT23-132 | D5 | SOT23-132 | BAT54S | SOT23-132 | D6 | SOD123 | RB161M-20 | SOD123 | D7 | SOD123 | MMSZ5246B-TP | SOD123 | D8 | SOD123 | MMSZ5235B | SOD123 | D9 | SOD123 | RB161M-20 | SOD123 | EN5VIN | SMD_TP_1 | PLLTP | SMD_TP_1 | ENVCC | SMD_TP_1 | PLLTP | SMD_TP_1 | J1 | SMD_PJK107-M-PL | PJK-107 | SMD_PJK107-M-PL | J2 | CON-A2502_PL | CON-A2502 | CON-A2502_PL | J3 | CON-_USB-A-SOCKET_A1D41F | SUA-110E | CON-_USB-A-SOCKET_A1D41F | J4 | CON-_USB-A-SOCKET_A1D41F | SUA-110E | CON-_USB-A-SOCKET_A1D41F | J6 | SMD_RJ45_SMT8P8C_M_PL | SMT8P8C | SMD_RJ45_SMT8P8C_M_PL | J7 | CON-FFC-6210-30 | 6212-30 | CON-FFC-6210-30 | J8 | JACK_PJK-114-M-PL | PJK-114 | JACK_PJK-114-M-PL | J9 | DIP_JACK_PJ-328-M-PL | PJ-328 | DIP_JACK_PJ-328-M-PL | J10 | PAD_1X2_2_2P-PL | 1x2-2.0/X | PAD_1X2_2_2P-PL | J11 | PAD_1X2_2_2P-PL | 1x2-2.0/X | PAD_1X2_2_2P-PL | J12 | HEADER1X4-100 | 2211S-04G/X | HEADER1X4-100 | J13 | CON-85201-2805 | 85201-2805 | CON-85201-2805 | J14 | CONN_1223-06-02-PL | 1223-06-02 | CONN_1223-06-02-PL | J15 | SMD_CONN_52207-0467-PL | 52207-0467 | SMD_CONN_52207-0467-PL | J16 | CON-FFC-6210-30 | 6212-30 | CON-FFC-6210-30 | J17 | SMD_CONN_52207-0467-PL | 52207-0467 | SMD_CONN_52207-0467-PL | J18 | CON-FPC-A951250-1 | 9631S-50Y913 | CON-FPC-A951250-1 | L1 | CHOKE-IHLP-2525CZ-01 | 6.8uH | CHOKE-IHLP-2525CZ-01 | L2 | CHOKE-IHLP-2525CZ-01 | 6.8uH | CHOKE-IHLP-2525CZ-01 | L3 | CHOKE-CDRH3D28-PL | SFE3015-3R3M-R-S-LF | CHOKE-CDRH3D28-PL | L4 | CHOKE-CDRH3D16-4R7Y | STD03015100M | CHOKE-CDRH3D16-4R7Y | L5 | CHOKE-CDRH3D16-4R7Y | STD03015100M | CHOKE-CDRH3D16-4R7Y | LED1 | LED-LT8A23-51-UR96-T5 | LED LAMP RED | LED-LT8A23-51-UR96-T5 | LED2 | LED-LT8A23-51-UR96-T5 | LED LAMP GREEN | LED-LT8A23-51-UR96-T5 | LED3 | LED-LT8A23-51-UR96-T5 | LED LAMP GREEN | LED-LT8A23-51-UR96-T5 | LED4 | LED-LT8A23-51-UR96-T5 | LED LAMP GREEN | LED-LT8A23-51-UR96-T5 | MIC1 | MIC-WM-64PC | O422-40C1-PCD-00-L/X | MIC-WM-64PC | Q1 | SOIC8-50X204 | GS9435 | SOIC8-50X204 | Q2 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q3 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q4 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q5 | SOT23-GDS | GN2305 | SOT23-GDS | Q6 | SOIC8-50X204 | GS4953 | SOIC8-50X204 | Q7 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q8 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q9 | SOT23-GDS | GN2305 | SOT23-GDS | Q10 | SOIC8-50X204 | GS9435 | SOIC8-50X204 | Q11 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q12 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q13 | SOT23-GDS | GN2305 | SOT23-GDS | Q14 | SOT23-GDS | GN2305 | SOT23-GDS | Q15 | SOT23-GDS | SPN7002S23RG | SOT23-GDS | Q16 | SOT23-BCE | MMBT3906 | SOT23-BCE | RN1 | RN-8P4R-31P5X062 | 100 | RN-8P4R-31P5X062 | RN2 | RN-8P4R-31P5X062 | 100 | RN-8P4R-31P5X062 | RN3 | RN-8P4R-31P5X062 | 100 | RN-8P4R-31P5X062 | RN4 | RN-8P4R-31P5X062 | 100 | RN-8P4R-31P5X062 | RSMRST- | SMD_TP_1MM | TestPoint_1mm | SMD_TP_1MM | RV1 | SMD_VR_100K-PL | 10K/X | SMD_VR_100K-PL | SD1 | ZWSDC0506-PL | ZWSDC0506 | ZWSDC0506-PL | SW1 | SMD_TS-A87-PL | KFC-A05-03 | SMD_TS-A87-PL | SW2 | SMD_TS-A87-PL | KFC-A05-03 | SMD_TS-A87-PL | SW3 | SMD_TS-A87-PL | KFC-A05-03 | SMD_TS-A87-PL | SW4 | SMD_TS-A87-PL | KFC-A05-03 | SMD_TS-A87-PL | T1 | H1183 | S16013LF | H1183 | U1 | SMD_WM8650_IOB_120P-PL | WM8650_CoreBoard | SMD_WM8650_IOB_120P-PL | U2 | SC-82 | S-80860CNNB-B9LT2G | SC-82 | U3 | SOT23-5 | S-80829CNMC-B8OT2G/X | SOT23-5 | U4 | SOIC8-50X204 | EUP8207-84ADIR1 | SOIC8-50X204 | U5 | SOT23-132 | AP6209-33GB | SOT23-132 | U6 | SMD_EUP3472ADIR1_SOP8-PL | EUP3472ADIR1 | SMD_EUP3472ADIR1_SOP8-PL | U7 | SMD_RT8008PB_SOT23-5-PL | AAP2408VIR1 | SMD_RT8008PB_SOT23-5-PL | U8 | LQFP48-19P7 | VT6113_LQFP | LQFP48-19P7 | U9 | SOT23-132 | AP1722B-33GC | SOT23-132 | U10 | QFN48-19P7-TH | VT1603A | QFN48-19P7-TH | U11 | SSOP48-25X378 | HT82B40R | SSOP48-25X378 | U12 | SOT23-6 | EUP2584 | SOT23-6 | U13 | SOT23-5 | EUP2571 | SOT23-5 | VBAT | SMD_TP_1 | PLLTP | SMD_TP_1 | VCC33 | SMD_TP_1 | PLLTP | SMD_TP_1 | VIN | SMD_TP_1MM | TestPoint_1mm | SMD_TP_1MM | VPACK+ | SMD_TP_1MM | TestPoint_1mm | SMD_TP_1MM |
