TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
Name | PCB Decal | Value | Part Type | ANT1 | ANT-3PA | | ANT-3P | CN1 | CN13A | | 11 | CON1 | 12P-1.0AAA | | 12PSMT | CON2 | 12P-1.0BA | | 12PSMT | CON3 | CON_24P_0.5MM_B | CON26-2 | CON26-2 | CON511 | FCC24-H | | FCC30P-H | D1 | DIO/DO-214AC | 1N4001 | DIO | D2 | DIOSMDA | IN4148 | 1N5817 | D3 | DIOSMDA | IN4148 | 1N5817 | D4 | DIOSMDA | 1N4148 | 1N5817 | D5 | DIOSMDA | IN4148 | 1N5817 | D6 | DIOSMDA | IN4148 | 1N5817 | D7 | DIO/DO-214AC | 1N4001 | DIO | D8 | D1206 | IN4148 | D | D9 | D4MM | 1N5404 | IN4004 | D10 | D1206 | IN4148 | D | D11 | DIOSMDA | 1N4148 | 1N5817 | D15 | DIOSMDA | 1N4148 | 1N5817 | D26 | DIO/DO-214AC | 1N4001 | DIO | D27 | DIO/DO-214AC | IN5822 | DIO | D501 | DIOSMDA | IN4148 | 1N5817 | D502 | DIOSMDA | IN4148 | 1N5817 | D603 | SCHOTTKY.DN | IN5822 | S.DIODE | EC11 | CAPE12.5X21-A | 2200u/20V | CAP_E12.5X21_A_3300UF_16V | ESD | D_ESD5 | NC | D | H | O | | O | IC1 | QN8035 | QN8035 | TUNER | IC5 | SI4730 | SI4702/30/31/NC | SI4730/31 | J1 | CON18P-3AAAAA | | CON18P-3 | J2 | SOCKET12/5569A | 12PIN socket | SOCKET-12P(PVM430S35) | J3 | CON-3PIN-2.54 | | CON-3P-25 | L1 | 603 | FB | INDUCTOR | L2 | L-0603 | FB310 | IND | L3 | L10A | 3.3UH | INDU/CHOKE | L4 | L0805 | FB | IND | L5 | L0805 | 10UH | IND | L7 | L-0603 | 1UH | IND | L11 | L0805 | 10UH | IND | L12 | CHOCK-H | | CHOCK-H | L15 | L0805 | FB | IND | L16 | L-0603 | FB | IND | L18 | L6MM_8 | 100UH3A | L8MM | L21 | L-0805 | FB | IND | Q1 | SOT23 | NC | 9014C | Q2 | SOT23 | S8050 | 9014C | Q3 | SOT23 | NC\2N3904S | 9014C | Q4 | SOT23 | NC | 9014C | Q5 | SOT23 | 2N3904S | 9014C | Q6 | SOT23 | 9015 | 9015C | Q7 | SOT23 | 9014 | 9014C | Q8 | SOT23 | S8050 | 9014C | Q9 | SOT-23 | AM3407 | MOS | Q10 | SOT-89 | 2SB1132 | PNP/BCE | Q11 | SOT-89 | 2SB1132 | PNP/BCE | Q12 | SOT23 | NC\2N3904S | 9014C | Q13 | SOT23 | 2N3904S | 9014C | Q401 | SOT23 | 2N3904S | 9014C | Q501 | SOT23 | 2N3904S | 9014C | Q503 | SOT23 | 2N3904S | 9014C | Q508 | SOT23 | S8550 | 9015C | Q509 | SOT23 | 2N3904S | 9014C | Q612 | SOT23 | 9014 | 9014C | RCA2 | AV6-8.4 | | RCA-6AV | S1 | SW-RST | RES1 | SW4P | SD1 | SDCARD_HMF | SD | CN15SD | TUNE | SI4702 | | SI4702 | TX | O | TX | O | U1 | SOP-32 | YX803 | PT2312 | U2 | TO-252-5P | AP1507-ADJ/NC | AP1507 | U3 | TL431 | TL431 | TL431 | U4 | DIP8-SOP | BA4558 | KIA4558 | U5 | TSOP-28M | TDA7313 | 7313 | U6 | AMS1117 | AMS1117-3V3 | AMS1117 | U7 | AMS1117 | AMS1117-1V8 | AMS1117 | U8 | IC8 | SPIFLASF25T80 | SPI25T80 | U10 | DIP28\SSOPH1 | AM5888S | AM5888 | U11 | SOP8 | 24C02 | 24C02 | U12 | FLEXIWATT25 | TDA7384A | TDA7384A | U13 | TO-252(DPAK) | 78M05 | 7805 | U15 | TO-252(DPAK) | 78M09 | 7805 | U501 | SPHE8104LW-128P | SPHE8202T-128 | SPCA760-128_2A | U507 | TSOP54-2 | ELIEMT M12L64164A-5T/SDRAM 16Mx4 | 4MX16 | V | O | | O | V1 | PADS-4 | VIA/NC | PADS-4MM | V2 | PADS-4 | VIA/NC | PADS-4MM | V3 | PADS-4 | VIA/NC | PADS-4MM | V4 | PADS-4AAA | VIA/NC | PADS-4MM | V5 | PADS-4AAA | VIA/NC | PADS-4MM | X1 | X'TAL | 17.2800MHz | CRYSTAL | XT | XTALK3 | 27.00MHZ | X | XT1 | XTAL3AA | 32.768KHz | XTDIP | XT5 | XTAL3AA | NC | XTDIP | ZD1 | ZD/LL-34 | 6V8 | DIODE/ZENER-5.1V | ZD603 | ZD/LL-34 | 3.9V | DIODE/ZENER-5.1V |
