Name | PCB Decal | Value | Part Type |
ANT0401 | NC-PAD-RFANT-2X3A | | NC-PAD-RFANT-2X3 |
ANT0402 | NC-PAD-RFANT-2X3A | | NC-PAD-RFANT-2X3 |
ANT7201 | NC-PAD-RFANT-2X3A | | NC-PAD-RFANT-2X3 |
ANT7401 | NC-PAD-RFANT-2X3 | | NC-PAD-RFANT-2X3 |
D6601 | DIODE-SCHOTTKY-RB520G-30 | | DIODE-SCHOTTKY-RB520G-30 |
D7201 | SOD-523 | | DIODE-SWITCH-1SS400 |
D7401 | TVS-RSBC6.8CS | | TVS-RSBC6.8CS |
FB3100 | SL0603-S | | BEAD-600-OHM-100MHZ-0603 |
FB3101 | SL0603-S | | BEAD-600-OHM-100MHZ-0603 |
FB3102 | SL0603-S | | BEAD-600-OHM-100MHZ-0603 |
FB6206 | SL0402 | 1000ohm | BEAD-1000-OHM-100MHZ-0402 |
FB6207 | SL0402 | 1000ohm | BEAD-1000-OHM-100MHZ-0402 |
FB6208 | SL0402 | 1000ohm | BEAD-1000-OHM-100MHZ-0402 |
FB6210 | SL0402 | 1000ohm | BEAD-1000-OHM-100MHZ-0402 |
FB7401 | SL0402 | 1000ohm@100MHz | BEAD-1K-OHM-100MHZ-250MA-0402 |
FB7402 | SL0402 | 1000ohm@100MHz | BEAD-1K-OHM-100MHZ-250MA-0402 |
J3100 | AUDIO-SPK-SE36S5308-141T | | AUDIO-SPK-SE36S5308-141T |
J3102 | AUDIO-RECEIVER-MRJ07111-70 | PAD | AUDIO-RECEIVER-MRJ07111-70 |
J4101 | LCM-TFT-TFT1N3479-W-E | | LCM-TFT-TFT1N3479-W-E |
J4102 | LCM-TFT-TFT1P3551-W-E | | LCM-TFT-TFT1P3551-W-E |
J5101 | NC-FPC-Z9368-CAMERA(BACK)-MB-20 | | NC-FPC-Z9368-CAMERA(BACK)-MB-20 |
J6100 | CON-BAT-AC0100-130 | | CON-BAT-AC0100-130 |
J6202 | CON-POWER-9102-00215-04R | | CON-POWER-9102-00215-04R |
J6203 | CON-USB-MICRO-UAF95-05254-1500 | | CON-USB-MICRO-UAF95-05254-1500 |
J6204 | CON-EAR-ARR3.665.316 | | CON-EAR-ARR3.665.316 |
J6301 | NC-FPC-ZY968-KEYBOARD-MB-22 | | NC-FPC-ZY968-KEYBOARD-MB-22 |
J6400 | SOCKET-SIM-CAF99-06200-SF06 | | SOCKET-SIM-CAF99-06200-SF06 |
J6402 | SOCKET-SIM-CAF99-06200-SF06 | | SOCKET-SIM-CAF99-06200-SF06 |
J6404 | SOCKET-SIM-CAF99-06200-SF06 | | SOCKET-SIM-CAF99-06200-SF06 |
J6500 | SOCKET-CARD-TFRHS-00815-TP00 | | SOCKET-CARD-TFRHS-00815-TP00 |
L0400 | SL0402 | 10nH | IND-CER-10NH-0402 |
L0402 | SL0402 | 22nH | IND-CER-22NH-0402 |
L0403 | SL0402 | 22nH | IND-CER-22NH-0402 |
L0405 | SL0402 | 6.2nH | IND-CER-6.2NH-0402 |
L0406 | SL0402 | 6.8nH | IND-CER-6.8NH-0402 |
L0407 | SL0402 | 6.2nH | IND-CER-6.2NH-0402 |
L0417 | SL0402 | 2.4nH | IND-CER-2.4NH-0402 |
L0421 | IND-NF-0402 | NF | IND-NF-0402 |
L0422 | IND-NF-0402 | NF | IND-NF-0402 |
L0423 | IND-NF-0402 | NF | IND-NF-0402 |
L7200 | SL0402 | 6.8nH | IND-CER-6.8NH-0402 |
L7202 | SL0402 | 5.6nH | IND-CER-5.6NH-0402 |
L7401 | SL0402 | 12nH | IND-CER-12NH-0402 |
L7402 | IND-WIRE-SDWL1608CS | 72NH | IND-WIRE-72NH-0603 |
L7403 | IND-WIRE-SDWL1608CS | 150nH | IND-WIRE-150NH-0603 |
L7404 | SL0402 | 9.1nH | IND-CER-9.1NH-0402 |
MIC3101 | MIC-OB-F15LX42-221-C10C33EP | | MIC-OB-F15LX42-221-C10C33EP |
MLV3102 | SMLV0402 | (NF) | MLV-AVLC5S02050 |
MLV3103 | SMLV0402 | (NF) | MLV-AVLC5S02050 |
MOT6601 | NC-MOTOR-Z4TH9B1240233 | | NC-MOTOR-Z4TH9B1240233 |
Q6100 | MICROFET-2X2 | | FET-P_DIODE-FDFMA2P853 |
RN4101 | SR0402X4 | 100 | RES-N-100X4-0402 |
RN4102 | SR0402X4 | 100 | RES-N-100X4-0402 |
RN4103 | SR0402X4 | 100 | RES-N-100X4-0402 |
RN7401 | SR0402X4 | 100 | RES-N-100X4-0402 |
RN7402 | SR0402X4 | 100 | RES-N-100X4-0402 |
TP6219 | NC-TP-JTAG-SC6600L | | NC-TP-JTAG-SC6600L |
TVS0301 | SOD-523 | | TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523 |
TVS6201 | SOD-523 | NF | TVS-ESD5Z7.0T1G |
U0101 | BGA9X9-200 | | ASIC-SC6610-200G |
U0400 | RF-SAW-1.35X1.05 | | RF-SAW-SAFEB1G96FA0F00 |
U0402 | CON-RF-SWITCH-MM8430-2610RA1 | | CON-RF-SWITCH-MM8430-2610RA1 |
U0403 | RF-PA-RF7163 | | RF-PA-RF7163 |
U0404 | RF-TRANSCEIVER-SR528 | | RF-TRANSCEIVER-SR528 |
U0405 | RF-SAW-SAWEN942MCN0F00R14 | | RF-SAW-SAWEN942MCN0F00R14 |
U0410 | RF-SAW-1.35X1.05 | | RF-SAW-SAFEB881MFL0F00 |
U0500 | MEM-NOR-W25Q32DWZPIG | | MEM-NOR-W25Q32DWZPIG |
U3100 | AW8145CSR_TOP_VIEW | | AW8145CSR-TOP |
U7102 | QN8036-16PIN | | QN8035_16P |
U7200 | RF-SAW-BBF-2012-2G4S1-B1 | | RF-SAW-BBF-2012-2G4S1-B1 |
U7201 | BLUETOOTH-ES-BC6888A04-ICXL | | BLUETOOTH-ES-BC6888A04-ICXL |
U7400 | IC_QN8610 | | RF-TV-QN8610-NKNA |
U7402 | SOT23-5 | 2.8V | POWER-LDO-RT9193-28GB |
VR1016 | SOD-523 | NF | TVS-ESD5Z7.0T1G |
X0201 | XTAL-32K-6.9X1.4 | 32.768KHZ | XTAL-CRYSTAL-SSP-T7-FE-12.5PF |
X0400 | CRYSTAL-26M | 26MHz | XTAL-CRYSTAL-SQ3D02600B2IBA |
X7400 | CRYSTAL-26M | 26MHz | XTAL-CRYSTAL-X3S026000B91H-NZ |
