查看: 11398|回复: 88
[Allegro16.6以下] 军用24口三层网络交换机BCM56024+BCM5248UA2KQMG+BCM5482SA2KFB PCB和
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2019-9-21 13:51:59 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    CE15CAP_CC0805_10UF10uFCC0805
    D1DIO-LED-QUAD-VERT_1_D0603_GRNGRND0603
    D2DIO-LED-QUAD-VERT_1_D0603_GRNGRND0603
    D3DIO-LED-QUAD-VERT_1_D0603_GRNGRND0603
    D4DIODE TVSBI-DIR_1_SMA_S3K 3AS3K 3A VRF1.2VSMA
    D7DIO-LED-QUAD-VERT_1_D0603_GRNGRND0603
    D8DIO-LED-QUAD-VERT_1_D0603_GRNGRND0603
    D9DIODE TVSBI-DIR_1_SMA_S3K 3AS3K 3A VRF1.2VSMA
    D10DIODE TVSBI-DIR_SMB_D_SMAZ5.6_SMAZ5.6_DNISMB_D
    D3440CPQ045/TO_2_SOT23-123_BAT54ABAT54ASOT23-123
    DP1DIODEZENER_2_SMA_SK24SK24SMA
    FB1FB_LC0603_600600LC0603
    FB2FB_LC0603_600600LC0603
    FB3FB_LC0603_600600LC0603
    FB4FB_LC0603_600600LC0603
    J1HDR2X7R-J_HDR2X7VR_S-M-.100-2X7S-M-.100-2X7HDR2X7VR
    J14JL9A-29ZJBS_JL9A-29ZJBS_JL9A-29JL9A-29ZJBSJL9A-29ZJBS
    J15JL9A-29ZJBS_JL9A-29ZJBS_JL9A-29JL9A-29ZJBSJL9A-29ZJBS
    J16JL9A-29ZJBS_JL9A-29ZJBS_JL9A-29JL9A-29ZJBSJL9A-29ZJBS
    J17JL9A-29ZJBS_0_JL9A-17ZJBS_JL9A-JL9A-17ZJBSJL9A-17ZJBS
    J18CON3_HDR254F-1X3X850_CON3CON3HDR254F-1X3X850
    J19CON3_CON20VP3R96-3TM_CON3CON3CON20VP3R96-3TM
    J20CON4_0_CON20VP2R54-4TM_CON4_0CON4_0CON20VP2R54-4TM
    J21CON4_1_CON20VP2R54-8TM_CON8CON8CON20VP2R54-8TM
    L1FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L2FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L3FB_SMD1210_0_LC1206_DISCRETE__1BLM21PG600SN1xLC1206
    L4FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L5FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L6FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L7FB_SMD1210_0_LC1206_DISCRETE_BLBLM21PG600SN1LC1206
    L8FB_SMD1210_0_LC1206_DISCRETE__1BLM21PG600SN1xLC1206
    L9FB_SMD1210_0_LC1206_DISCRETE__1BLM21PG600SN1xLC1206
    L10FB_SMD1210_0_LC1206_DISCRETE__1BLM21PG600SN1xLC1206
    L11FB_SMD1210_0_LC0603_DISCRETE_BLBLM21PG600SN1LC0603
    L12INDUCTOR_LC1206_150MA150mALC1206
    L13INDUCTOR_LC1206_150MA150mALC1206
    L14INDUCTOR_LC1206_150MA150mALC1206
    L15INDUCTOR_LC1206_150MA150mALC1206
    L16INDUCTOR_LC1206_150MA150mALC1206
    L17INDUCTOR_LC1206_150MA150mALC1206
    L22FB_SMD1210_LC0603_DISCRETE_BLM2BLM21PG600SN1xLC0603
    L23FB_SMD1210_LC0603_DISCRETE_BLM2BLM21PG600SN1xLC0603
    L24FB_SMD1210_LC0603_DISCRETE_BLM2BLM21PG600SN1xLC0603
    L25INDUCTOR_1_L-2P-12X11_7H6_2UH,72uH,7mOHM7A_CDH105R-2R2L-2P-12X11_7H6
    L26INDUCTOR_1_L-2P-12X11_7H6_2UH,72uH,7mOHM7A_CDH105R-2R2L-2P-12X11_7H6
    L27INDUCTOR_1_L-2P-12X11_7H6_2UH,72uH,7mOHM7A_CDH105R-2R2L-2P-12X11_7H6
    L28INDUCTOR_1_L-S12X12H8_2UH,7MOHM2uH,7mOHM7A_CDH105R-2R2L-S12X12H8
    L29INDUCTOR_0_L_2P_3_5X6_BEAD_DNIBEAD_DNIL_2P_3_5X6
    L31INDUCTOR_0_L_2P_3_5X6_BEAD_DNIBEAD_DNIL_2P_3_5X6
    L32INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L33INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L34INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L35INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L36INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L37INDUCTOR_LC1206_150MA_DNI150mA_DNILC1206
    L39FB_SMD1210_LC0603_DISCRETE_BLM2BLM21PG600SN1xLC0603
    L40FB_SMD1210_LC0603_DISCRETE_BLM2BLM21PG600SN1xLC0603
    MH1MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    MH2MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    MH3MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    MH4MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    MH5MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    MH6MH-8VIA_1_MT8-4-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-4-6_5MM
    RN6RESISTORPACK_0_RPACK8P4R_2222RPACK8P4R
    SW1RA-PUSH-BUTTON_SW_TACT_A_SD-SH-SD-SH-7562-9.5-BSW_TACT_A
    SW2SW-SPST-12-34_0_SW_2P_3_75X6MM_PB-SPST-MOMSW_2P_3_75X6MM
    T1H1343_0_XFMR_SO24_30FB-22NL30FB-22NLXFMR_SO24
    T2H1343_0_XFMR_SO24_30FB-22NL30FB-22NLXFMR_SO24
    T3HK027_8_TR_SOP40_H1164H1164TR_SOP40
    T4HK027_2_TR_SOP40_H1164H1164TR_SOP40
    T5HK027_7_TR_SOP40_H1164H1164TR_SOP40
    T6HK027_7_TR_SOP40_H1164H1164TR_SOP40
    T7HK027_7_TR_SOP40_H1164H1164TR_SOP40
    T8HK027_7_TR_SOP40_H1164H1164TR_SOP40
    U1BCM56024_BGA896_30X30_(S1+S2+S3BCM5602BGA896_30X30
    U2S29GL256N_0_TSOP56_S29GL256N11TS29GL256N11TFR20TSOP56
    U3MT46V128M8TG_0_TSOP66_MT46V128MMT46V128M8TG-6TTSOP66
    U4MT46V128M8TG_0_TSOP66_MT46V128MMT46V128M8TG-6TTSOP66
    U5ICS553M_0_SO8_LP2996MXLP2996MXSO8
    U6BCM5248U_1_QFP14X20_128_BCM5248BCM5248UA2KQMGQFP14X20_128
    U7BCM5248U_1_QFP14X20_128_BCM5248BCM5248UA2KQMGQFP14X20_128
    U8BCM5248U_1_QFP14X20_128_BCM5248BCM5248UA2KQMGQFP14X20_128
    U9BCM5482SKPB_0_BGA121-1MM_BCM548BCM5482SA2KFB BGABGA121-1MM
    U10MAX3232_0_TSSOP16-0R65-4R40_MAXMAX3232TSSOP16-0R65-4R40
    U11BUF-OCT-244_2_SSOP20-208_74LCX274LCX244FWSSOP20-208
    U12MAX6711_2_SOT23-5_EM6325CYSP5B-EM6325CYSP5B-2.9+SOT23-5
    U13BUF-OCT-244_1_SSOP20-208_74LCX274LCX244FWSSOP20-208
    U14ICS553M_1_SO8_ICS553M_1ICS553M_1SO8
    U15ICS553M_1_SO8_ICS553M_1ICS553M_1SO8
    U16ICS553M_1_SO8_ICS553M_1ICS553M_1SO8
    U17AP1510_1_WDFN_RT8015ART8015AWDFN
    U18AP1510_1_WDFN_RT8015ART8015AWDFN
    U19AP1510_1_WDFN_RT8015ART8015AWDFN
    U20AP1510_1_WDFN_RT8015ART8015AWDFN
    U21MAX6711_2_SOT23-5_EM6325CYSP5B-EM6325CYSP5B-2.9+SOT23-5
    U22SN74LV123APW_TSSOP16-170_SN74LVSN74LV123APWTSSOP16-170
    Y1XTAL_3_XTAL_49US_25MHZ25MHzXTAL_49US
    Y2MF-T3392-125MHZ_OSC_5X7_IO_S161S1613EP-125.0000OSC_5X7
    Y3OSC_SMD_SG636PCE_OSC_5X7_IO_S18S1803B-25.0000OSC_5X7
    Y4OSC_SMD_SG636PCE_SY-AGX-7050_IOSiT8103AC-82-25E-25.000625SY-AGX-7050
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2019-9-21 13:55:25 | 显示全部楼层
    PCB 原理图,GERBER, 生产工艺一起打包。 资料仅限技术参考学习交流,禁止转载分享到网络上。
    5RMB 。不需要的看看就好。   军用产品。
    BCM56024_24_SCH_PCB.7z (4.03 MB, 下载次数: 66)
    24口交换机程序和烧写说明_bom.7z (9.92 MB, 下载次数: 55)
    不断学习才能进步
    社区居民忠实会员最爱沙发终身成就奖优秀斑竹奖
    发表于 2019-9-21 13:59:17 | 显示全部楼层
    不断学习才能不断进步
    5 天前
  • 签到天数: 103 天
    发表于 2019-9-21 14:30:40 | 显示全部楼层
    感谢老吴分享,正好需要
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-9-21 16:34:58 | 显示全部楼层
    谢谢分享24口三层网络交换机BCM56024+BCM5248UA2KQMG+BCM5482SA2KFB PCB和原理图程序
    昨天 16:13
  • 签到天数: 186 天
    终身成就奖社区居民忠实会员
    发表于 2019-9-21 18:19:53 | 显示全部楼层
    发表于 2019-9-21 19:51:42 | 显示全部楼层
    发表于 2019-9-21 20:38:16 | 显示全部楼层
    发表于 2019-9-21 21:43:16 | 显示全部楼层
    发表于 2019-9-21 22:16:49 | 显示全部楼层
