REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIO-LED-QUAD-VERT_1_D0603_GRN_D | GRN_DNI | D0603 |
D2 | DIO-LED-QUAD-VERT_1_D0603_GRN_D | GRN_DNI | D0603 |
D3 | DIO-LED-QUAD-VERT_1_D0603_GRN_D | GRN_DNI | D0603 |
D7 | DIO-LED-QUAD-VERT_1_D0603_GRN | GRN | D0603 |
D34 | 40CPQ045/TO_2_SOT23-123_BAT54A | BAT54A | SOT23-123 |
D44 | LED_0603_LED0603_G/0603_KNGM060 | G/0603 | LED0603 |
J17 | HEADER_2*22_D2A22N-2X42_MTMM22- | MTMM22-10-S-D-070 | D2A22N-2X42 |
J18 | HEADER_2*20_D2A20N-2X38_TW2003- | TW2003-L-D-250-150 | D2A20N-2X38 |
J20 | HEADER_1*4_1W-D1A4-0637_KL25101 | KL2510180004 | 1W-D1A4-0637 |
J21 | HEADER_2*10_D2A10N-2X18_MTMM10- | MTMM10-10-S-D-070 | D2A10N-2X18 |
J22 | HEADER_1*6_D1A6_HYE-2.54_HYE-2. | HYE-2.54 | D1A6 |
J23 | HEADER_2*4_D2A4N-2X8_MTMM4-10-S | MTMM4-10-S-D-070 | D2A4N-2X8 |
L1 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L2 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L3 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L4 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L5 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L6 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L7 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L8 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L9 | FB_SMD1210_0_LC1206_DISCRETE_BL | BLM21PG600SN1 | LC1206 |
L13 | INDUCTOR_LC1206_150MA | 150mA | LC1206 |
L19 | INDUCTOR_LC1206_150MA | 150mA | LC1206 |
L22 | FB_SMD1210_LC0603_DISCRETE_BLM2 | BLM21PG600SN1x | LC0603 |
L23 | FB_SMD1210_LC0603_DISCRETE_BLM2 | BLM21PG600SN1x | LC0603 |
L27 | L_L-S4_5X4H3_2_3.3UH,2.1A,4.5X4 | 3.3uH,2.1A,4.5x4 | L-S4_5X4H3_2 |
L28 | L_L-S4_5X4H3_2_3.3UH,2.1A,4.5X4 | 3.3uH,2.1A,4.5x4 | L-S4_5X4H3_2 |
L39 | FB_SMD1210_LC0603_DISCRETE_BLM2 | BLM21PG600SN1x | LC0603 |
L40 | FB_SMD1210_LC0603_DISCRETE_BLM2 | BLM21PG600SN1x | LC0603 |
L41 | FB_SMD1210_LC0603_DISCRETE_BLM2 | BLM21PG600SN1x | LC0603 |
MH1 | MH-8VIA_1_MT8-3-6MM_4-40X3/4IN- | 4-40X3/4in-SCREW | MT8-3-6MM |
MH2 | MH-8VIA_1_MT8-3-6MM_4-40X3/4IN- | 4-40X3/4in-SCREW | MT8-3-6MM |
MH3 | MH-8VIA_1_MT8-3-6MM_4-40X3/4IN- | 4-40X3/4in-SCREW | MT8-3-6MM |
MH4 | MH-8VIA_1_MT8-3-6MM_4-40X3/4IN- | 4-40X3/4in-SCREW | MT8-3-6MM |
RN3 | RESISTORPACK_0_RPACK8P4R_22 | 22 | RPACK8P4R |
RN4 | RESISTORPACK_0_RPACK8P4R_22 | 22 | RPACK8P4R |
RN5 | RESISTORPACK_0_RPACK8P4R_22 | 22 | RPACK8P4R |
RN6 | RESISTORPACK_0_RPACK8P4R_22 | 22 | RPACK8P4R |
SW1 | SW-SPST-12-34_0_SW_2P_3_75X6MM_ | PB-SPST-MOM | SW_2P_3_75X6MM |
T3 | HK027_8_TR_SOP40_81FB-22NL | 81FB-22NL | TR_SOP40 |
T4 | HK027_2_TR_SOP40_81FB-22NL | 81FB-22NL | TR_SOP40 |
U1 | BCM56024_BGA896_30X30_(S1+S2+S3 | BCM56024 | BGA896_30X30 |
U2 | S29GL256N_0_TSOP56_S29GL256N11T | S29GL256N11TFR20 | TSOP56 |
U3 | MT46V128M8TG_0_TSOP66_MT46V128M | MT46V128M8TG-6T | TSOP66 |
U4 | MT46V128M8TG_0_TSOP66_MT46V128M | MT46V128M8TG-6T | TSOP66 |
U5 | ICS553M_0_SO8_LP2996MX | LP2996MX | SO8 |
U6 | BCM5248U_1_QFP14X20_128_BCM5248 | BCM5248UA2KQMG | QFP14X20_128 |
U12 | MAX6711_2_SOT23-5_EM6325CYSP5B- | EM6325CYSP5B-2.9+ | SOT23-5 |
U13 | BUF-OCT-244_1_SSOP20-208_74LCX2 | 74LCX244FW | SSOP20-208 |
U14 | ICS553M_0_SO8_ICS553 | ICS553 | SO8 |
U15 | ICS553M_0_SO8_ICS553 | ICS553 | SO8 |
U18 | MP2012_QFN6-3X3MM-TH_MP2012DQ-L | MP2012DQ-LF-Z | QFN6-3X3MM-TH |
U19 | MP2012_QFN6-3X3MM-TH_MP2012DQ-L | MP2012DQ-LF-Z | QFN6-3X3MM-TH |
U21 | MAX6711_2_SOT23-5_EM6325CYSP5B- | EM6325CYSP5B-2.9+ | SOT23-5 |
U22 | SN74LV123APW_TSSOP16-170_SN74LV | SN74LV123APW | TSSOP16-170 |
Y2 | MF-T3392-125MHZ_OSC_5X7_IO_S161 | S1613EP-125.0000 | OSC_5X7 |
Y4 | OSC_SMD_SG636PCE_SY-AGX-7050_IO | SiT8103AC-82-25E-25.000625 | SY-AGX-7050 |
