重要提示:PCB作品文件展下载说明
Item | Qty | Reference | Part | Package | 1 | 1 | CA21 | 1pF,50V, NPO | 0402 | 2 | 1 | CA23 | 2.7pF,50V, NPO | 0402 | 3 | 13 | C17,C26,C35,C45,CA77,
CA81,C133,C144,C151,C154,
C156,L29,L30 | 10pF,50V, NPO | 0402 | 4 | 4 | CON1,CON2,CON5,CON6 | Miniaturecoaxial Connector for Mini PCI, GND pad*2 | UFLR-MINIPCI | 5 | 7 | C6,C9,C34,C52,C54,C129,
C136 | 100pF,50V, NPO | 0402 | 6 | 18 | C8,C11,C15,C31,C51,C53,
C57,C58,C135,C137,C139,
C141,C143,C150,C155,C158,
C162,C167 | 1uF,6.3V, X5R, T=0.5mm | 0402 | 7 | 4 | C12,C14,C28,C30 | 22pF, 50V, NPO | 0402 | 8 | 5 | C16,C32,C145,C87,C337 | 10uF,6.3V,X5R,T=0.8mm | 0603 | 9 | 4 | C18,C27,C36,C46 | 1.2pF,50V, NPO | 0402 | 10 | 4 | C19,C21,C37,C40 | 0.6pF,16V, high frequency | 0402 | 11 | 4 | C23,C25,C43,C44 | 1.8pF,50V, NPO | 0402 | 12 | 2 | C24,C42 | 9pF,50V, NPO | 0402 | 13 | 5 | C33,C160,C166,C56,C89 | 2.2uF,6.3V, X5R, T=0.8mm | 0603 | 14 | 6 | C47,C48,C49,C50,C128,C827 | 2.2uF,6.3V, X5R | 0402 | 15 | 40 | C55,C59,C82,C84,C85,C94,
C96,C97,C130,C148,C152,
C157,C159,C161,C168,C169,
C170,C171,C172
C72,C100,C101,C164,C165,
C243,C244,C246,C247,C252,
C291,C294,C298,C299,C333,
C609,C825,C826,
C2453,C5232,C5233, | 0.1uF,10V, X5R | 0402 | | 2 | C5238,C2452 | 0.1uF, 25V, Y5V | 0402 | 16 | 1 | C60 | 1.5nF,50V, X7R | 0402 | 17 | 3 | C65,C66,C67 | 4.7pF,50V, NPO | 0402 | 18 | 8 | C71,C74,C75
RC1,C79,C91,C95,C132 | 4.7uF,6.3V, X5R, T=0.8mm | 0603 | 19 | 5 | C73,C290,C5236,C2450,C2451 | 10uF,16V,X5R, T=1.25mm | 0805 | 20 | 1 | C76 | 1nF,2000V, X7R | 1206 | 21 | 2 | C78,C88 | 1uF,6.3V, X5R, T=0.8mm | 0603 | 22 | 2 | C80,C81 | 1pF,50V, NPO | 0402 | 23 | 1 | C90 | 4.7uF,6.3V,X5R, T=1.25mm | 0805 | 24 | 2 | C92,C93 | 15pF,50V, NPO | 0402 | 25 | 2 | C114,C118 | 1nF,50V, NPO | 0402 | 26 | 3 | C131,C2454,C5237 | 12pF,50V, NPO | 0402 | 27 | 1 | C153 | 4.7nF,50V, X7R | 0402 | 28 | 2 | C262,C293 | EC,470uF, 16V, φ*H=8*11.5mm, LF | CAP315
(CAP-1108-DIP) | 29 | 1 | C335 | 0.1uF,16V, X7R, T=0.8mm | 0603 | 30 | 4 | C2455,C2456,C5234,C5235 | 22uF,6.3V, X5R, T=1.25mm | 0805 | 31 | 9 | D9,D10,D12,D13,D14,D15,
D16,D17,D18 | LED,Yellow-Green | 0603 | 32 | 1 | J1 | PinHeader, 4x1, pitch=2.54mm, straight,L=11mm, LF | P4x1-2.54mm | 33 | 1 | J2 | Connector,USB Type A, Recept, RA, white, w/backshell | USB-A-RECEPT | 34 | 1 | J10 | DC Jack,D=2.0mm, H=10.7, LF | DIP | 35 | 5 | LA11,L1,L11,L14,L20 | 2.7nH | 0402 | 36 | 4 | L2,L3,L12,L13 | 10nH | 0402 | 37 | 4 | L6,L10,L15,L19 | 1nH | 0402 | 38 | 2 | L7,L16 | 1.2nH | 0402 | 39 | 2 | L8,L17 | 2nH | 0402 | 40 | 2 | L24,32 | Powerinductor, 2.2uH, Idc=2A, 2.5*2.0*1.2mm, shield, LF | L/2.5*2.0 | 41 | 1 | L31 | BEAD,47-ohm@100MHZ, 0.3A, Rdc=0.35-ohm | 0402 | 42 | 3 | L44,L2513,R98 | 0ohm, 1/8W, 1.5A, LF | 0805 | 43 | 2 | L2450,L2512 | 2.2uH-GNR5040P-2R2N | L/IND/SMD/LVS5045 | 44 | 16 | RA1,RA2,RA3,R10,R11,R212,
R213R34,R35,R99,R103,R104,
R108,R187,R2935,R2 | 0ohm, 1/16W, 1A, LF | 0402 | 45 | 1 | R6 | 0ohm, 1/10W, 1A, LF | 0603 | 46 | 11 | R15,R16,R17,R73,R83,R88,
R89,R90,R91,R95,R96 | 4.7K-ohm,LF | 0402 | 47 | 1 | R18 | 1K-ohm,LF | 0402 | 48 | 2 | R33,R105 | 5.1K-ohm,LF | 0402 | 49 | 2 | R36,R37 | 51-ohm,LF | 0402 | 50 | 1 | R38 | 1M-ohm | 1206 | 51 | 1 | R61 | 24.3K-ohm,LF | 0402 | 52 | 2 | SR2,R74 | 10K-ohm,LF | 0402 | 53 | 2 | R77,R78 | 1K-ohm,LF | 0402 | 54 | 1 | R100 | 20-ohm,LF | 0402 | 55 | 15 | R134,R135,R136,R137,R138,
R139,R140,R141,R142,R143,
R144,R145,R146,R147,R148 | 75-ohm,LF | 0402 | 56 | 1 | R156 | 20K-ohm,LF | 0402 | 57 | 2 | R158,SR1 | 22-ohm,LF | 0402 | 58 | 10 | R177,R178,R180,R184,R188,
R189,R190,R191,R192,R193 | 330-ohm,LF | 0402 | 59 | 2 | R2450,R2932 | 100K-ohm,LF | 0402 | 60 | 1 | R2451 | 110K_1% | R0402 | 61 | 1 | R2452 | 15K_1% | R0402 | 62 | 1 | R2933 | 115K/1% | R0402 | 63 | 1 | R2934 | 24.9K-ohm,LF | 0402 | 64 | 1 | S1 | Switch,Push, H=9.6mm, 7.5mm*25mm, RA | SW-DIP-25*7.5 | 65 | 1 | S3 | Switch,Tact, H=5.85mm, RA | DIP-4P-RA | 66 | 1 | U1 | MT7628DAN | MT7628AN/DRQFN156/SMD/P0.5/12X12 | 67 | 1 | U4 | SPI,Serial Flash, 64Mbit,2.7-3.6V, 100MHz | SOP-8-200mil | 68 | 1 | U7 | MT7612E | MT7662/WSQFN76/SMD/P0.4/9X9/S | 69 | 1 | U8 | XTAL,40MHz, CL=11.5pF, 7ppm, LF, 高溫規格/85度,Fundamental | XTAL-SMD/3.2X2.5 | 70 | 2 | U11,U13 | LANXMER, 10/100M, 1:1, 2*port for EMI | DIP-20PIN-2510 | 71 | 1 | U12 | RJ-45,4Port, black,no Shield, Stamped pin 3u"Gold plating | RJ45-4P-NO-SH | 72 | 1 | U14 | LANXMER, 10/100M, 1:1, 1*port for EMI | DIP-16PIN-2010 | 73 | 1 | U15 | RJ-45,1Port, black, no Shield, Stamped pin 3u"Gold plating | RJ45A-NO-SH | 74 | 1 | U2450 | RT6224DHGJ6F,TSOT23-6 | SOT23-6 | 75 | 1 | U2607 | RT6224DHGJ6F,TSOT23-6 | SOT23-6 |
重要提示:PCB作品文件展下载说明
