TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
Name | PCB Decal | Part Type | D1 | PD_DIODE-SS34-SS14 | CD_DIODE | D2 | PD_DIODE-SS34-SS14 | CD_DIODE | D3 | PD_DIODE-SS34-SS14 | CD_DIODE | D4 | PD_DIODE-SS34-SS14 | CD_DIODE | D5 | DIODE_0603 | LED | D6 | DIODE_0603 | LED | D7 | DIODE_0603 | LED | D8 | DIODE_0603 | LED | D9 | PD_DIODE-SS34-SS14 | CD_DIODE | D10 | PD_DIODE-SS34-SS14 | CD_DIODE | F1 | PD_FUSE_HOLDERS | FUSE-HOLDER | F2 | FUSE-5MMA | FUSE-CLIP | F3 | FUSE-5MMA | FUSE-CLIP | H1 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | H2 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | H3 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | H4 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | H5 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | H6 | HOLD_3.2_6.0_6.4 | CUSTOM_HOLD | J1 | PD_SIP_2X5 | SIP_2X5 | J24 | 32PF-2X16 | 32P-2X16 | J25 | CE4201RB-2X2 | CW4201-2 | J26 | DIP2.54-4P | 4PIN-2.54MM | J27 | 5PIN_2.0MM | CON-5P | J28 | DIP2.54-4P | 4PIN-2.54MM | J29 | 5PIN_2.0MM | CON-5P | J30 | DIP2.54-4P | 4PIN-2.54MM | J31 | 5PIN_2.0MM | CON-5P | J32 | DIP2.54-4P | 4PIN-2.54MM | J33 | 5PIN_2.0MM | CON-5P | J34 | 2PIN_2.0MM | CON-2P | J35 | 5PIN_2.0MM | CON-5P | J36 | DIP2.54-4P | 4PIN-2.54MM | J37 | 5PIN_2.0MM | CON-5P | J38 | DIP2.54-4P | 4PIN-2.54MM | J39 | 5PIN_2.0MM | CON-5P | J40 | DIP2.54-4P | 4PIN-2.54MM | J41 | 5PIN_2.0MM | CON-5P | J42 | DIP2.54-4P | 4PIN-2.54MM | J43 | 5PIN_2.0MM | CON-5P | J44 | 2PIN_2.0MM | CON-2P | J45 | 5PIN_2.0MM | CON-5P | J46 | 5PIN_2.0MM | 5PIN | J47 | 5PIN_2.0MM | 5PIN | J48 | CON-2P | CON-2P | J49 | PD_SIP_2X5 | SIP_2X5 | J50 | CON-4-1.25 | CON-4P-1.25 | J51 | CON-2P | CON-2P | J52 | 2PIN_2.0MM | CON-2P | L5 | PD_RES_1/4W | INDUCTANCE | LED1 | PD_LED_DUAL | LED_DUAL | LED2 | PD_LED_DUAL | LED_DUAL | Q1 | SOT23M2 | C945 | Q2 | TO-252 | IRG4PC40F | Q14 | SOT23M2 | C945 | Q16 | TO-252 | IRG4PC40F | Q17 | TO-252 | IRG4PC40F | U1 | SO16WB | A3966 | U2 | SO16WB | A3966 | U3 | SO16WB | A3966 | U4 | SO16WB | A3966 | U5 | PD_IC_SO-8 | MIC4427BM | U6 | SO16WB | A3966 | U7 | SO16WB | A3966 | U8 | SO16WB | A3966 | U9 | SO16WB | A3966 | U10 | PD_IC_SO-8 | MIC4427BM | U11 | SOT23-5 | NC7SZ04 | U12 | PD_IC_SOIC_8-LEAD | IC_EPCS4SI8N | U13 | TQFP144 | EP2C8T144 | U14 | PD_IC_SOT-89-5 | PT4115 | U15 | PD_IC_SOT-89-5 | PT4115 | U16 | PD_IC_SOT-89-5 | PT4115 | U17 | PD_IC_SOT-89-5 | PT4115 | U18 | SOT23-5 | NC7SZ04 | U19 | SOT23-5 | NC7SZ04 | U20 | SOT23-5 | NC7SZ04 | U21 | SOT23-5 | NC7SZ04 | U22 | PD_IC_SO-8 | MIC4427BM | U23 | PD_IC_SO-8 | MIC4427BM | U24 | PD_IC_SO-8 | MIC4427BM | U25 | PD_IC_SO-8 | MIC4427BM | U26 | PD_IC_SO-8 | MIC4427BM | U27 | PD_IC_SO-8 | MIC4427BM | U28 | PD_IC_SO-8 | MIC4427BM | U29 | PD_IC_SOIC-14 | 74LVC14 | U30 | PD_IC_SOIC-14 | 74LVC14 | U31 | PD_IC_SOIC-14 | 74LVC14 | U32 | PD_IC_SOIC-14 | 74LVC14 | U33 | PD_IC_SOIC-14 | 74LVC14 | U34 | SOT23-5 | NC7SZ04 | U35 | PD_IC_TO-252 | IC_LM1117 | U36 | PD_IC_TO-252 | IC_LM1117 | U37 | TQFP144 | EP2C8T144 | U38 | PD_IC_SOIC_8-LEAD | IC_EPCS4SI8N | U39 | PD_IC_SO-8 | MIC4427BM | U40 | PD_IC_SO-8 | MIC4427BM | U41 | PD_IC_SO-8 | MIC4427BM | U42 | PD_IC_SO-8 | MIC4427BM | U43 | PD_IC_SOIC-14 | 74LVC14 | X1 | PD_CRYSTAL-50M-32M-4P | CRYSTAL-4P |
