Name | PCB Decal | Value | Part Type | ANT0 | ANT_A | | ANT_A | ANT1 | ANT_A | | ANT_A | D1 | DIO-TO-269AA/MBS | DIO-MB6S | DIO-BRIDGE | D2 | DIO-SOD323 | MMSZ5237BS | ZENR | D3 | DIO-SOD323 | MMSZ5237BS | ZENR | D4 | DIO-SOD523/SC79 | BAS516 | DIODE | D5 | DIO-SOD523/SC79 | BAS516 | DIODE | D6 | DIO-214AC/SMA | SMAJ58A-13-F | DIODE | D7 | BM431 | TLV431 | BM431 | D8 | DIO-MINIMELF/SOD-80 | SBM540 | DIODE | D9 | DIO-MINIMELF/SOD-80 | SMAJ15A-E3/61 | DIODE | D10 | DIO-MINIMELF/SOD-80 | 1N4148W | DIODE | D11 | DIO-MINIMELF/SOD-80 | 1N4148W | DIODE | D13 | DIO-MINIMELF/SOD-80 | 1N4148W | DIODE | D14 | DIO-MINIMELF/SOD-80 | 1N4148W | DIODE | D15 | DIO-214AC/SMA | SK34 | DIODE | D16 | DIO-MINI_MELF_A | SS14 | SS12-E3_61T | D23 | DIO-TO-269AA/MBS | DIO-MB6S | DIO-BRIDGE | D32 | DIO-SOD523/SC79 | BAS516 | DIODE | D33 | DIO-MINIMELF/SOD-80 | 1N4148W | 1N4148W | D37 | DIO-SOD123 | NC | DIODE_SHOTTKY | J1 | HDR-1X4P25 | HDR-1X4P25 | HEADER4.1 | J2 | HDR-1X4P25 | HDR-1X4P25 | HEADER4.1 | J3 | JACK-XA5JB2-88-100111 | XA5JB2-88-100111 | JACK-XA5JB-88-100111 | J4 | JACK-XA5JB2-88-100111 | XA5JB2-88-100111 | JACK-XA5JB-88-100111 | J5 | SPK | PB32CE04H_17XX | MIC-NEW | J6 | CONB | FPC_24PIN_1MM | CONB | J34 | JACK-DC011 | DC_JACK | JACK-DC | JMP2 | JMP-1X2 | SHORT | JUMPER | JMP31 | JMP-1X2 | | JMP-2X1 | JP1 | CON-5P20 | HDR-5P20 | CON-5P20 | K4 | K | TS-A32U50A | TSA32U50A | L1 | SLF6025T-101MR33-PF | 100UH | SLF6025T-101MR33-PF | L2 | R1206 | 10uH | COIL-CHK | L9 | 603 | 3.3UH | L-POWER | L10 | IND-13X9MM5 | TPO3316-330M | INDUCTOR | L11 | IND-1810 | NNLC322522T-4R7K-N | INDUCTOR | LP6 | IND-0805 | BLM18EG471SN1D | INDUCTOR | MIC1 | HDR-1X2P254 | MIC | MIC1.1 | POE1 | POE-MODULE | POE_MODULE | POE_MODULE | Q1 | SOT23-PWR | BC807-25 | BC856AL | Q2 | TR-SOT23 | TR-MMBTA42 | TR-NPN | Q3 | SOT23-PWR | IRLML6401 | IRF9530N/TO_1 | Q4 | SOT23-PWR | BC807-25 | BC856AL | Q6 | 2SB1188-Q | NC | 2SB1188 | Q7 | TR-SOT23 | 2N3904 | NPN-SOT23 | Q8 | TR-SOT23 | 2N3904 | NPN-SOT23 | RN1 | RN_MNRL4 | MNR14E0ABJ750 | RESAR_IS_4/SM | RN2 | RN_MNRL4 | MNR14E0ABJ750 | RESAR_IS_4/SM | RN3 | RN_MNRL4 | MNR14E0ABJ750 | RESAR_IS_4/SM | RN4 | RN_MNRL4 | MNR14E0ABJ750 | RESAR_IS_4/SM | RN5 | RN_MNRL4 | RN0402-330J | RESAR_IS_4/SM | RN6 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN7 | RN_MNRL4 | RN0402-330J | RESAR_IS_4/SM | RN8 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN9 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN10 | RN_MNRL4 | RN0402-330J | RESAR_IS_4/SM | RN11 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN12 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN13 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN14 | RN_MNRL4 | RN0402-330J | RESAR_IS_4/SM | RN17 | R4X0R | RN0402-330J | R4X0R | RN18 | RN_MNRL4 | RN0402-330J | RESAR_IS_4/SM | RN20 | RN_MNRL4 | MNR14E0ABJ000 | RESAR_IS_4/SM | RN21 | RN_MNRL4 | NC | RESAR_IS_4/SM | RN23 | RN_MNRL4 | NC | RESAR_IS_4/SM | T1 | TXMR-15F-10 | TXMR-15F-10 | TXMR-15F-10 | T2 | PA1138NL | TXMR_PA1133NL | PULSE-PA1138NL_3 | U1 | SSOP-16 | LTC4267CGN | IC-LTC4267CGN | U2 | PS2911-1 | PS2911 | PS2911-1 | U3 | SOIC20 | SN74HC377DWR | 74HC377-SO_2 | U4 | SOIC20 | SN74HC377DWR | 74HC377-SO_2 | U5 | SC14452-PCB | SC14452 | SC14452_3DM | U6 | SOIC-8 | NCP3063DR2G | NCP3063 | U7 | SOIC-8 | W25Q32VSSIG | FLASH_SRL_25XN | U10 | TSOP-54 | W9812G6GH | MT48LC8M16A2_0 | U11 | SOIC-8 | W25Q32VSSIG | FLASH_SRL_25XN | U13 | TO252 | NC | LP38691DT-1_2.8 | U15 | TO252-5L | AP1507-33D5 | AP1507_1 | U17 | RF-4180-MODULE | LMX4180_module | LMX4180_MODULE_1 | U20 | SOT-25 | RT9167A-2.5CB | RT9167_2 | U22 | PS2913-1 | PS2911 | PS2913-1 | U23 | PQFP-128-FIX | RTL8306SD | RTL8305SC_0 | U24 | SI3440DV | FDC2512 | SI3440DV | U25 | SOT23 | 2N7002 | 2N7002 | Y1 | X-3.58MHZAAAAAB | 10,368MHz | CRYSTAL | Y2 | XTAL-SMD | NC | CRYSTAL | Y3 | X-3.58MHZAAAAAB | 25.000MHZ | CRYSTAL |
