查看: 4655|回复: 25
[Allegro16.6以下] VXS-DSP FMC Carrier
发表于 2019-10-30 19:28:15 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
PCB.rar (4.28 MB, 下载次数: 37) EDA-02281-V3-0_sch.pdf (2.4 MB, 下载次数: 37)
板子实物图
板子实物图
VXS-DSP FMC Carrier
板子实物图
板子实物图
C1->C33B45196E2476M40910V 20% SMD Tantalum Electrolytic Capacitor47uFSIEMENSB45196E2476M409D
C41T491X157K016ASMD Tantalum Electrolytic Capacitor150uFKEMETT491X157K016AX
C5,C73,C457,C4606CC0603_100NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor100nFGENERICCC0603_100NF_16V_10%_X7R0603
C671,C701
C6,C1462CTE7343_22UF_16V_20%16V 20% SMD Tantalum Electrolytic Capacitor22uFGENERICCTE7343_22UF_16V_20%D
C7,C192,C19332CTE3216-18_22UF_6.3V_10%SMD Tantalum Electrolytic Capacitor22uFGENERICCTE3216-18_22UF_6.3V_10%A
C200->C204,C229,C230
C249,C266,C267,C295
C305,C339->C341
C491,C492,C563->C567
C583,C627,C628,C630
C706,C709,C712
C8->C71,C113->C144140CC0402_10NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor10nFGENERICCC0402_10NF_16V_10%_X7R0402
C645->C658,C660->C664
C666->C668,C674
C676->C678,C680->C686
C688,C691->C699
C708
C721T491X107K020ASMD Tantalum Electrolytic Capacitor100uFKEMETT491X107K020AX
C74->C103,C110->C11298CC0603_47NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor47nFGENERICCC0603_47NF_16V_10%_X7R0603
C186,C187,C190,C191
C402->C429,C434->C447
C450,C452->C454
C456,C459,C466
C632->C635,C700
C702->C704,C710,C711
C714,C715
C104,C105,C147->C18571CC0603_10NF_50V_10%_X7R50V 10% SMD X7R Ceramic Capacitor10nFGENERICCC0603_10NF_50V_10%_X7R0603
C188,C189,C196->C199
C449,C455,C458
C461->C465,C626,C629
C631,C636->C643
C669,C670,C672,C705
C713
C106->C109,C194,C195349CC0402_22NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor22nFGENERICCC0402_22NF_16V_10%_X7R0402
C205->C228,C231->C248
C250->C265,C268->C294
C296->C304,C306->C338
C342->C401,C430->C433
C467->C490,C493->C562
C568->C582,C584->C625
C707
C145,C644,C659,C6659CC0805_10UF_10V_10%_X5R10V 10% SMD X5R Ceramic Capacitor10uFGENERICCC0805_10UF_10V_10%_X5R0805
C675,C679,C687,C689
C690
C448,C4512CTE2012_6.8UF_6V3_10%6.3V 10% SMD Tantalum Electrolytic Capacitor6.8uFGENERICCTE2012_6.8UF_6V3_10%0805
C6731CC0603_1NF_50V_10%_X7R50V 10% SMD X7R Ceramic Capacitor1nFGENERICCC0603_1NF_50V_10%_X7R0603
D1->D33VS-15MQ040NPBF40V 3A Schottky RectifierVISHAYVS-15MQ040NPBFSMA
D41PRTR5V0U4YIntegrated Quand Ultra-Low Capacitance ESD Protection DeviceNXP/PHILIPSPRTR5V0U4YSOT363
IC11LP3961EMP-1.8800mA Fast Ultra Low Dropout Linear Regulator1.8VNATIONAL SEMICONDUCTORLP3961EMP-1.8SOT223_5
IC2->IC43XCF32P FSG48 CPb-Free Platform Flash In-System Programmable Configuration PROMXILINXXCF32P FSG48 CTFBGA48
IC5,IC8,IC32,IC334SN74LVTH16245ADGGR3.3-V ABT 16-Bit Bus Transceiver with 3-State OutputsTEXAS INSTRUMENTSSN74LVTH16245ADGGRTSSOP48
IC6,IC72SN74LVTH16244ADGGR3.3V ABT 16-Bit Buffers/Drivers with 3-State OutputsTEXAS INSTRUMENTSSN74LVTH16244ADGGRTSSOP48
IC91XC5VSX95T-FF1136Virtex-5 Family FPGA DeviceXILINXXC5VSX95T-FF1136BGA1136
IC10,IC112MC100EP11DTGECL 1:2 Differential Clock/Data Fanout BufferON SEMICONDUCTORMC100EP11DTGTSSOP8
IC12,IC142AD9512BCPZ1.2GHz Clock Distribution IC, 1.6GHz Inputs, Dividers, Delay Adjust, Five OutputsANALOG DEVICESAD9512BCPZLFCSP
IC131MC100EP56DTG3.3V / 5V ECL Dual Differential 2:1 MultiplexerON SEMICONDUCTORMC100EP56DTGTSSOP20
IC151MC10EP52DG3.3V/5V ECL Differential Data and Clock D Flip-FlopON SEMICONDUCTORMC10EP52DGSOIC8
IC161MC100EPT21DG3.3V Differential LVPECL/LVDS/CML to LVTTL/LVCMOS TranslatorON SEMICONDUCTORMC100EPT21DGSOIC8
IC17,IC182CY7C1474V33-167BGC72-Mbit (2M x 36) Pipelined SRAM with NoBL(TM) ArchitectureCYPRESSCY7C1474V33-167BGCfpBGA209
IC20,IC48,IC49374LCX125MTCLow Voltage Quad Buffer with 5V Tolerant Inputs and OutputsFAIRCHILD SEMICONDUCTOR74LCX125MTCTSSOP14
IC21174LCX126MTCLow Voltage Quad Buffer with 5V Tolerant 3-State Inputs and OutputsFAIRCHILD SEMICONDUCTOR74LCX126MTCTSSOP14
IC221ISPPAC-CLK5610AV-01TN48CIn-System Programmable, Enhanced Zero-Delay Clock Generator with Universal Fan-Out BufferLATTICEISPPAC-CLK5610AV-01TN48CTQFP48
IC231AD9510BCPZ1.2GHz Clock Distribution IC PLL Core Divider Delay Adjust Eight OutputsANALOG DEVICESAD9510BCPZQFN64
IC241DS18B20Z+Programmable Resolution 1-Wire Digital ThermometerMAXIMDS18B20Z+SOIC8
IC251PCA9552BS16-bit I2C-Bus LED Driver with Programmable Blink RatesNXP/PHILIPSPCA9552BSHVQFN24
IC26,IC272CY7C1472V33-167AXC167MHz 72-Mbit (4Mx18) Pipelined Sync SRAM Speed with NoBL Architecture167MhzCYPRESSCY7C1472V33-167AXCTQFP
IC281XC5VLX110T-FF1136Virtex-5 Family FPGA DeviceXILINXXC5VLX110T-FF1136BGA1136
IC291M25P20-VMN6P2Mbit, Low Voltage, Serial Flash Memory with 75 Mhz SPI bus InterfaceNUMONIXM25P20-VMN6PSO8
IC301FM25W256-G256Kb Ferroelectric Nonvolatile RAMRAMTRONFM25W256-GSOIC8
IC311ADSP-21369KBPZ-3ASHARC Processors 400MHzANALOG DEVICESADSP-21369KBPZ-3ABP-256
IC34,IC35,IC42,IC4311SN74LVC1G97DCKTConfigurable Multiple-Function GateTEXAS INSTRUMENTSSN74LVC1G97DCKTSC70
IC46,IC47,IC50->IC53
IC57
IC361MAX1230BCTI+12-Bit 300ksps ADCs with FIFO, Temp Sensor, Internal ReferenceMAXIMMAX1230BCTI+TQFN-28
IC37->IC393LMP8645MKPrecision High Voltage Current Sense AmplifierNATIONAL SEMICONDUCTORLMP8645MKTSOT-6
IC401IPS7081SPBFIntelligent Power High Side SwitchINTERNATIONAL RECTIFIERIPS7081SPBFD2PAK
IC41,IC58,IC593FDMC769630V 12A 11.5mohm N-Channel PowerTrench(R) MOSFETFAIRCHILD SEMICONDUCTORFDMC7696QFN-8
IC44,IC452SN74LVC1G126DCKSingle Bus Buffer Gate with 3-State OutputTEXAS INSTRUMENTSSN74LVC1G126DCKSC70-5
IC541LT1964ES5-BYP200 nA Low Noise Low Dropout Negative Micropower Regulator in ThinSOTLINEAR TECHNOLOGYLT1964ES5-BYPSOT
J1,J22ASP-134486-011.27mm pitch Socket Array Assembly Similar to VITA57SAMTECASP-134486-01
J3147082-1000External SATA Receptacle SMT with ShellMOLEX47082-1000
J41N2510-5002RB0.1 x 0.1 Low Profile Right-Angle Header 2500 Series3MN2510-5002RB
J511410147-1Tier 2, 7-Row, Center Module, 0.8 Pitch, Right AngleTYCO ELECTRONICS1410147-1
J61MTLW-102-07-L-S-2502 Contacts 2.54mm Pitch Single Row Vertical 0.25 Square Post Header - Insulator 1.52mmSAMTECMTLW-102-07-L-S-250
J71HTSS-107-01-F-D-0314 Contacts 2.54mm Pitch Double Row Shrouded Vertical Header with Pin 3 Omitted - HTSS SeriesSAMTECHTSS-107-01-F-D-03
L1,L6,L784701-001SMD EMI/RFI Filter 4700pi SeriesTUSONIX4701-001
L9->L11,L13,L17
L21UP3B-1R0-RPower Inductor1uHCOOPER-BUSSMANNUP3B-1R0-R_
L3->L5,L12,L146NR 10050T 220MSMD Inductor22uHTAIYO YUDENNR 10050T 220M_
L15
L8174275115A SMD Ferrite Bead WE-SUKWWURTH7427511
L16174279216200mA SMD Multilayer FerriteWURTH742792161206
L18->L2037427512SMD EMI Suppression 5-Hole Ferrite Bead - WE-SUKW SeriesWURTH7427512WE-SUKW
L211BLM18AG102SN1400mA 1Kohm SMD Chip Ferrite BeadMURATABLM18AG102SN10603
LD1->LD66HSMF-C113Surface Mount Tricolor ChipLEDAVAGO TECHNOLOGIESHSMF-C1132.5x1.0mm
LD7,LD82HSMS-C170High Efficiency Red SMD Chip LEDHERAVAGO TECHNOLOGIESHSMS-C1700805
P1,P2202 01 160 21012.54mm Pitch 160 Poles(ABCDZ32) DIN 41612 HAR-BUS Right-Angle Male ConnectorHARTING02 01 160 2101
PB11DTSL-61R-BSMD Momentary Push-ButtonDIPTRONICSDTSL-61R-B_
QZ11CCPD-034-50-200.0003.3V LVPECL Clock Oscillator - CCPF-034 Series200.000MHzCRYSTEK CRYSTALSCCPD-034-50-200.000SMD5X7mm
R1,R2,R48311.24.03.215.20.1W 1% SMD Resistor150GENERICR0603_150R_1%_0.1W_100PPM0603
R3,R982CMB02070X1004G1W 2% 500V Carbon Film High Pulse Load MELF Resistor1MTOKENCMB02070X1004G0207
R4,R5,R9419R0603_10K_1%_0.1W_100PPM0.1W 1% SMD Resistor10kGENERICR0603_10K_1%_0.1W_100PPM0603
R123->R130,R161
R181->R185,R207,R208
R6,R97,R100,R2107R2512_0R005_1%_1W_75PPM1% SMD Low Ohmic Current Sense Resistors0R005GENERICR2512_0R005_1%_1W_75PPMRESC6432X60N
R221->R223
R7->R14,R36,R514011.24.03.333.70.1W 1% SMD Resistor3.3kGENERICR0603_3K3_1%_0.1W_100PPM0603
R70,R82,R95,R96
R105->R111,R117
R155->R160,R162,R172
R188->R191,R195,R196
R205,R206,R209,R225
R15,R16,R18,R47411.24.03.227.80.1W 1% SMD Resistor270GENERICR0603_270R_1%_0.1W_100PPM0603
R17,R19,R49,R601111.24.03.218.90.1W 1% SMD Resistor180GENERICR0603_180R_1%_0.1W_100PPM0603
R61,R83,R84,R86
R87,R89,R90
R20,R21,R28,R392211.24.03.200.90.1W 1% SMD Resistor100GENERICR0603_100R_1%_0.1W_100PPM0603
R40,R54,R55,R62
R77->R79,R85,R88
R91,R114,R115,R121
R122,R153,R154,R177
R178
R22,R27211.24.03.362.20.1W 1% SMD Resistor6.2kGENERICR0603_6K2_1%_0.1W_100PPM0603
R23->R25,R30->R342811.24.03.220.50.1W 1% SMD Resistor200GENERICR0603_200R_1%_0.1W_100PPM0603
R37,R38,R41,R42
R52,R53,R56->R59
R71->R76,R80,R81
R167,R168
R26,R29,R92,R931311.24.03.347.10.1W 1% SMD Resistor4.7kGENERICR0603_4K7_1%_0.1W_100PPM0603
R113,R116,R119,R120
R169->R171,R218,R224
R35,R50,R69311.24.03.282.20.1W 1% SMD Resistor820GENERICR0603_820R_1%_0.1W_100PPM0603
R43->R46,R63->R681811.24.03.151.50.1W 1% SMD Resistor51GENERICR0603_51R_1%_0.1W_100PPM0603
R131->R134,R136,R137
R140,R141
R99,R211211.24.03.600.70.1W 1% SMD Resistor1MGENERICR0603_1M_1%_0.1W_100PPM0603
R101,R200,R215->R217511.24.03.500.30.1W 1% SMD Resistor100kGENERICR0603_100K_1%_0.1W_100PPM0603
R102,R103,R197,R198411.24.04.400.30.125W 1% SMD Resistor10kGENERICR0805_10K_1%_0.125W_100PPM0805
R104,R135,R199,R214411.24.04.333.70.125W 1% SMD Resistor3.3kGENERICR0805_3K3_1%_0.125W_100PPM0805
R112,R118211.24.03.233.00.1W 1% SMD Resistor330GENERICR0603_330R_1%_0.1W_100PPM0603
R138,R139,R142->R1441011.24.03.000.50603 Size SMD Jumper00GENERICR0603_00_JUMPER0603
R186,R187,R192->R194
R145->R1484R0402_100R_1%_0.063W_200PPM0.063W 1% SMD Resistor100GENERICR0402_100R_1%_0.063W_200PPM0402
R149->R152,R163,R1641711.24.03.300.60.1W 1% SMD Resistor1kGENERICR0603_1K_1%_0.1W_100PPM0603
R173->R176,R179,R180
R201->R204,R212
R165111.24.03.413.80.1W 1% SMD Resistor13kGENERICR0603_13K_1%_0.1W_100PPM0603
R166111.24.03.382.80.1W 1% SMD Resistor8.2kGENERICR0603_8K2_1%_0.1W_100PPM0603
R213111.24.03.330.00.1W 1% SMD Resistor3kGENERICR0603_3K_1%_0.1W_100PPM0603
R2191R0603_47R_1%_0.1W_100PPM0.1W 1% SMD Resistor47GENERICR0603_47R_1%_0.1W_100PPM0603
R2201R2512_0R05_1%_2W_75PPM1% SMD Resistor0R05GENERICR2512_0R05_1%_2W_75PPM2512
R226111.24.03.512.60.1W 1% SMD Resistor120kGENERICR0603_120K_1%_0.1W_100PPM0603
RZ112350-230-21030.031W 1% 8 Resistor Network TYPE RNA310 with Common Point10kPHICOMP2350-230-2103LCC10
SW11MCDHN-04F-T-V4x SMD Sliding SwitchesMULTICOMPMCDHN-04F-T-V_
T1->T17172N7002N-Channel Enhancement Mode Field Effect TransistorFAIRCHILD SEMICONDUCTOR2N7002SOT23
重要提示:PCB作品文件展下载说明
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-10-30 20:12:35 | 显示全部楼层
    谢谢分享VXS-DSP FMC Carrier PCB
    昨天 08:17
  • 签到天数: 256 天
    发表于 2019-10-30 20:24:26 | 显示全部楼层
    昨天 15:09
  • 签到天数: 216 天
    终身成就奖社区居民忠实会员
    发表于 2019-10-30 21:39:47 | 显示全部楼层
  • 签到天数: 58 天
    发表于 2019-10-31 00:01:44 | 显示全部楼层
    发表于 2019-10-31 08:02:43 | 显示全部楼层
    PADS-190819初级班
    发表于 2019-10-31 08:10:51 | 显示全部楼层
    发表于 2019-10-31 08:36:26 | 显示全部楼层
    昨天 11:13
  • 签到天数: 252 天
    发表于 2019-10-31 08:41:40 | 显示全部楼层
    昨天 19:27
  • 签到天数: 240 天
    发表于 2019-10-31 09:00:34 | 显示全部楼层
