REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIODE_TVS_B_SLP1006P2_3.3V | 3.3V | SLP1006P2 |
D3 | LED_HSMX-H670_GRN | GRN | HSMX-H670 |
D4 | DIODE_SOT23CANC_MMBD914 | MMBD914 | SOT23CANC |
D5 | DIODE_ZENER_SOT23CANC_MMBZ5229B | MMBZ5229B | SOT23CANC |
D6 | DIODE_SOT23CANC_MMBD914 | MMBD914 | SOT23CANC |
D7 | LED_HSMX-H670_GRN | GRN | HSMX-H670 |
D8 | DIODE_SOT23CANC_MMBD914 | MMBD914 | SOT23CANC |
D9 | LED_HSMX-H670_GRN | GRN | HSMX-H670 |
D19 | DIODE_SCHOTTKY_SMA_B330A | B330A | SMA |
D22 | DIODE_ZENER_SOT23CANC_MMBZ5229B | MMBZ5229B | SOT23CANC |
D23 | DIODE_DUAL_S_AC_A_C_SOT23AC_A_C | MMBD3004S | SOT23AC_A_C |
D24 | DIODE_ZENER_CR500_300_90_40_1N5 | 1N5243 | CR500_300_90_40 |
D25 | DIODE_DUAL_S_AC_A_C_SOT23AC_A_C | MMBD3004S | SOT23AC_A_C |
D26 | DIODE_SOT23CANC_MMBD4148 | MMBD4148 | SOT23CANC |
D34 | DIODE_TVS_B_SLP1006P2_3.3V | 3.3V | SLP1006P2 |
F1 | FUSE_PTC_RUE300_30V_3A | 30V_3A | RUE300 |
FB1 | SMD_BEAD_FB_L0805_600OHM@100MH | 600 Ohm@100MHz | L0805 |
FB2 | SMD_BEAD_FB_L0805_600OHM@100MH | 600 Ohm@100MHz | L0805 |
J4 | CONN_TRBLK_1X2_930-DS-02_RECP1 | RECP 16-28AWG | 930-DS-02 |
J5 | HEADER 5_HDR1X5_HDR5X1 | HDR 5x1 | HDR1X5 |
J7 | HEADER 5_HDR1X5_HDR5X1 | HDR 5x1 | HDR1X5 |
J8 | HEADER 5_HDR1X5_HDR5X1 | HDR 5x1 | HDR1X5 |
J10 | HDR_2X5_M_HDR_2X5M_2-54MM_B_HDR | HDR 5x2 | HDR_2X5M_2-54MM_B |
J23 | HDRP_7X1_HDR1X7_HDR7X1 | HDR 7X1 | HDR1X7 |
J24 | HDR_1X4_M_HDR_1X4M_1-27MM_5-1X2 | HDR 4x1 | HDR_1X4M_1-27MM_5-1X2-5MM |
J27 | DC_PWR_JACK_613R91_PWRJACK | PWR JACK | 613R91 |
J45 | CONN_RJ11_4P_B_E5364-3000G2_REC | RECP RJ14 | E5364-3000G2 |
JP86 | SMALL_JMP2_HDR1X2_HDR2X1 | HDR 2x1 | HDR1X2 |
K1 | RELAY_PHOTO_TRANS_SMDIP6-1_1.2V | 1.2V 30Rdc | SMDIP6-1 |
L1 | IND_L1008_0.68UH | 0.68uH | L1008 |
L4 | SMD_BEAD_FB_L0805_600OHM@100MH | 600 Ohm@100MHz | L0805 |
Q2 | TRSTR_NCHAN_G1S2D3_SOT23-GDS_NT | NTR4501N | SOT23-GDS |
Q3 | TRSTR_NCHAN_G1S2D3_SOT23-GDS_NT | NTR4501N | SOT23-GDS |
Q12 | BJT_NPN_TO92EBC_MPSA20 | MPSA20 | TO92EBC |
Q13 | BJT_NPN_NUM_TO226AE_TN3019A | TN3019A | TO226AE |
RV1 | VARISTOR_R300_550_220_44_270V_2 | 270V_2500A | R300_550_220_44 |
SW1 | SW_4PIN_TACTILE_SW_4P_4-00MM_6- | SPST | SW_4P_4-00MM_6-2X6-2MM |
SW2 | SW_4PIN_TACTILE_SW_4P_4-00MM_6- | SPST | SW_4P_4-00MM_6-2X6-2MM |
SW3 | SW_4PIN_TACTILE_SW_4P_4-00MM_6- | SPST | SW_4P_4-00MM_6-2X6-2MM |
SW4 | SW_4PIN_TACTILE_SW_4P_4-00MM_6- | SPST | SW_4P_4-00MM_6-2X6-2MM |
T1 | XFORMER_12_43_T671-8056_T_1:1 | T_1:1 | T671-8056 |
TH1 | TOOLING_HOLE_1P_TH250RD125_A_TH | TH250RD125 | TH250RD125_A |
TH2 | TOOLING_HOLE_1P_TH250RD125_A_TH | TH250RD125 | TH250RD125_A |
TH3 | TOOLING_HOLE_1P_TH250RD125_A_TH | TH250RD125 | TH250RD125_A |
TH4 | TOOLING_HOLE_1P_TH250RD125_A_TH | TH250RD125 | TH250RD125_A |
TP17 | HDR_1_HDR1X1_HDR 1X1 | HDR 1x1 | HDR1X1 |
U2 | CX20707_76P_ENG_A_EQFN_76P_0-40 | CX20707-21Z | EQFN_76P_0-40MM_9-0X9-0MM_A |
U4 | SPX3819_L_8P_ENG_SO_8P_1-27MM_5 | SPX3819-ADJ | SO_8P_1-27MM_5-0X4-0MM |
U5 | SPX3819_L_8P_ENG_SO_8P_1-27MM_5 | SPX3819-ADJ | SO_8P_1-27MM_5-0X4-0MM |
U8 | M24C01_8P_SO_8P_1-27MM_5-0X4-0M | EEPROM 128Kb | SO_8P_1-27MM_5-0X4-0MM |
X1 | MICROPHONE_WM-64PN_2.2KOHM_2V | 2.2K Ohm_2V | WM-64PN |
Y1 | CRYSTAL_Y_HC49U-2P_11-5X5-0MM_4 | 48.0MHz | Y_HC49U-2P_11-5X5-0MM |
