Name | Part Type | PCB Decal | Value |
BEAD409 | FB_/_BLM18BD252SN1 | BEAD0603 | |
CON1 | MINI_10PIN_3 | MICROUSB/5P/SMD/P0.65/R/KIU90511S1R | KEIRAKU KIU90511S1R |
CON8 | RT9266PE_0 | CON40_CM0_5 | FPC_40PIN_0.5MM |
CON301 | BATCON/4P_5 | BAT-H1.5PH3.0 | |
CON401 | 11-0621120 | 11-0621120 | |
CON809 | FH34S-6S-05SH | FH34S-6S-05SH/FH34SRJ-6S-05SH | |
CON904 | OV7645FB_5 | CON30X2_2.0 | DIP2*30_2.0MM |
CON1001 | CAR_KIT_/_MM8130-2600 | MM8130-2602 | |
CON1101 | MINI_10PIN_8 | MICROUSB | |
D3 | LED | D0805 | LED_G |
D5 | LED | D0805 | LED_Y |
D9 | D_0 | SMA | SM340A |
D301 | DIODE_DIP_SCHOTTKY_1 | SOD-923A | |
D302 | DIODE/ZENER | DIODE/SMD/PZ3D4V2H | PZ3D4V2H |
D303 | DIODE_DIP_SCHOTTKY_1 | SOD-923A | |
D304 | DIODE_DIP_SCHOTTKY_1 | SOD-923A | |
D305 | DIODE_DIP_SCHOTTKY_1 | SOD-923A | |
D901 | D_/_RB160M-60__0 | SOD323/UDZS6.2B | WSB5819W-2/TR |
D1102 | DIODE/ZENER | DIODE/SMD/PZ3D4V2H | MMSZ5232BT1G |
EMI901 | EMIX21A390FNPE_3 | L/CHOKE/SMD/DLP0NS0806/P | |
EMI902 | EMIX21A390FNPE_3 | L/CHOKE/SMD/DLP0NS0806/P | |
EMI1104 | EMI_/_DLP11RN450UL2 | L/CHOKE/SMD/DLP11S0504 | EMI / DLP11RN450UL2 |
EMI1105 | RCLAMP0524P | SLP2510P8/10P/SMD/RCLAMP0524P | RCLAMP0524P |
F1001 | BL1608-05K2450 | BALUN/SMD/BL1608/ACX | BL1608-05K2450 |
GB301 | XC414 | BAT/SMD/XH311HG-IV07E | |
IRM+1 | TP_/_30MIL_1 | PAD/1P/1.7X2.9AA | |
IRM-1 | TP_/_30MIL_1 | PAD/1P/1.7X2.9AA | |
J6 | USB_A | USB_A | CON1 |
J601 | C90-101-0004_0 | C90-101-0004 | |
L1 | L0402 | 402 | 4.7nH |
L2 | L0402 | 402 | 2.7nH |
L4 | CHOKE_2.2UH/4.8A-L6.0W6.0H4.5 | L-VLC6045 | 2.2uH/4.8A-L6.0W6.0H4.5 |
L6 | L_/_6.8_/_NH_/_0402 | L0402 | L / 6.8 / nH / 0402 |
L9 | 111-1002735 | R0603 | BLM18KG221SN1D |
L11 | 111-1002735 | R0603 | BLM18KG221SN1D |
L308 | INDUCTOR | L/IND/SMD/2520 | 2.2uH |
L402 | BEAD | BEAD0603 | |
L901 | INDUCTOR | L/CHOKE/SMD/LQH3NP | 22uH |
L1002 | INDUCTOR | 402 | LQM2HPN2R2MG0 |
L1007 | L0402 | 402 | 8.2nH |
L1101 | L_/_18_/_NH_/_0201 | L0201 | L / 18 / nH / 0201 |
L1102 | L_/_18_/_NH_/_0201 | L0201 | L / 18 / nH / 0201 |
L1201 | FERRITE_BEAD_SMD_0402 | L/IND/SMD/0603 | |
L1202 | FERRITE_BEAD_SMD_0402 | L/IND/SMD/0603 | |
L1802 | INDUCTOR | L/IND/SMD/2520 | 2.2uH |
LED1 | LED_3 | GT-197 | |
LED2 | LED_3 | GT-197 | |
LED303 | LED_3 | GT-197 | |
MIC401 | MULPS-4CX | MULPS-4CX | |
MOT+ | TP_/_30MIL_1 | PAD/1P/1.7X2.9A | |
MOT- | TP_/_30MIL_1 | PAD/1P/1.7X2.9A | |
P1 | LU1S041_1 | RJ45-LUIS041 | LU1S041XLF |
Q13 | MMBT3904_SOT23-3_0 | SOT23 | 2N3904 |
RECE1 | SDRP0612 | SDRP0612K | |
SPK+ | TP_/_30MIL_1 | PAD/1P/1.7X2.9AA | |
SPK- | TP_/_30MIL_1 | PAD/1P/1.7X2.9AA | |
SW901 | SL1104_0 | SL1104_0 | |
SW902 | SL1104_0 | SL1104_0 | |
SW903 | SL1104_0 | SL1104_0 | |
SW904 | SL1104_0 | SL1104_0 | |
U1 | DFN-41 | SHTC1 | |
U2 | SKY77701_2 | SKY77186 | SKY77762 |
U3 | TCXO_RAKON_SMD_4P | TCXO/SMD/2.5X2.0/IT2205BE | RAKON/IT2205BE/26MHz |
U4 | SAW-DPX-RX-BAL | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAYFH836MCC0F0A/BAND2 |
U5 | DC/DC_SY8089A_5.5V-2A_SOT23-5 | DC/DC_SY8089A_5.5V-2A_SOT23-5 | SY8089A/2A_SOT23-5 |
U6 | TPS2054BD_0 | R_PDSO_G16 | TPS2054BD |
U7 | MT6628_E1_WLCSP | MT6628/WLCSP88/SMD/B0.25/3.991X4.452 | MT6628_E1_WLCSP |
U8 | LAN9514_QFN64_0 | QFN64-11X27-SMSC | LAN9514_QFN64 |
U9 | FB_/_BLM15AX221SN1 | L0402 | FB / BLM15AX221SN1 |
U10 | NT78820T_0 | QNF48 | ICN6201 |
U11 | LP3985IM5-3_4.3 | SOT23-5 | TG1805_3V3 |
U12 | LP3985IM5-3_4.3 | SOT23-5 | TG1805_3V3 |
U17 | IC_MOTOR_HG7881 | SOP8 | HG7881 |
U201 | MT6589E1_LPDDR2 | MT6588/VFBGA515/P0.4/B0.25/11.8X11.8 | |
U301 | MT6320E1 | MT6320/TFBGA216/P0.4/B0.25/7.4X7.8 | MT6320E1 |
U333 | RT9193-NNPU5_1 | SIM | SIM |
U501 | LP_DDR2(JEDEC_162B)_6 | FBGA162/P0.5/B0.27/12X13.5/HYNIX | |
U601 | TCVCXO_12 | MT6167/TFBGA100/P0.4/B0.25/4.6X4.6 | MT6167 |
U604 | SAW_2 | SAWEN942MC | SAFEA881MFL0F00R14 |
U607 | SAW-DPX-RX-BAL | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAYFP897MCA0B00 |
U616 | SAW-DPX-RX-BAL | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAYRF1G95HQ0F0A |
U702 | PA_/_SKY77590_0 | SKY77590 | |
U708 | SKY77701_2 | SKY77186 | SKY77765 |
U713 | SKY77701_0 | SKY77186 | SKY77761 |
U1006 | NJG1107HB3_2 | DFN6/SMD/DALLAS/MAX2659 | MAX2659ELT+T |
U1007 | DGLT36M07_0 | SAW/SMD/DGLT36M07/S | |
U1101 | SII_8338_0 | TFBGA64/P0.5/B0.27/TDA19989BET | SiI 8338 |
U1201 | MT3301-140_SMD_PBGA-140_0 | MT6605/MQFN32/SMD/P0.4/4X4/S | |
U1401 | MICROSD/SMD/CLE9108-2A90F | CON-TFCAF1108303SF07 | |
U1601 | BMC050_1 | MMA8452Q | MMA8452Q |
U1602 | YAS532B | YAS532B | |
U1603 | APDS9930 | 8PIN/APDS9930 | |
U1802 | YDA145_0 | QFN24 | BQ24192 |
U1903 | R_/_1_/_M_/_0201 | R0201 | |
U1904 | YDA168 | YDA168 | YDA168 |
U1905 | AW9910STR_0 | AW9910STR | AW9910STR |
U1906 | 24_5804_024_000_829+ | CON_PIN24_G0-4 | |
U1907 | 24_5804_024_000_829+_0 | 24,5804,024,000,829+A | |
U1908 | BMP180 | BMP180 | |
VR1101 | ESD_/_TVS_/_200PF_/_0402_ | VR0402 | ESD / TVS / 200pF / 0402 |
X301 | SSP-T7_0 | SSP-T7 | 32.768KHz |
X601 | TCVCXO_2 | CRYS/SMD/D3.2X2.5/7M26000010 | |
X1201 | QUARTZ_IQX0_1 | CRYS/SMD/FA-128 | QUARTZ 27.12 Mhz |
Y3 | CRYSTAL4/SM | OSC-5X3.2 | 25M CRYSTAL |
