TV-MPEG-01 VER0.4.zip
(1.81 MB, 下载次数: 5)
Name | PCB Decal | Part Type | 1C1 | C0603A | C0603 | 1D2 | D-LL34 | D-LL34 | 1D3 | D-LL34 | D-LL34 | 1D4 | D-LL34 | D-LL34 | 1D5 | D3.8MMA | D3.8MMA | 1D6 | D3.8MMA | D3.8MMA | 1D7 | D3.8MMA | D3.8MMA | 1D8 | D3.8MMA | D3.8MMA | 1D9 | D-LL34 | D-LL34 | 1D10 | D-LL34 | D-LL34 | 1D11 | D-LL34 | D-LL34 | 1L1 | H | H | 1L2 | H | H | 1L3 | FB0805 | FB0805 | 1L4 | FB0805 | FB0805 | 1L5 | H | H | 1L6 | H | H | 1L7 | FB0805 | FB0805 | 1L8 | H | H | 1L9 | IND5-8 | IND5-8 | 1L10 | IND5-8 | IND5-8 | 1L11 | IND5-8 | IND5-8 | 1L12 | IND5-8 | IND5-8 | 1L13 | FB0805 | FB0805 | 1L14 | H | H | 1Q1 | SOT23-132 | SOT23-132 | 1Q2 | SOT23-132-1 | SOT23-132-1 | 1Q3 | SOT23-132-1 | SOT23-132-1 | 1Q4 | SOT23-132-1 | SOT23-132-1 | CON1 | HEADER-10P-100 | HEADER-10P-100 | CON2 | CON2.0-5 | CON2.0-5 | CON11 | CON2.0-6 | CON2.0-6 | CON12 | HEADER-7P-80AA | HEADER-7P-80 | CON13 | SIP-6P-80 | SIP-6P-80 | CON14 | CON2.5-4 | CON2.5-4 | CON16 | CON2.0-8 | CON2.0-8 | CON17 | CON2.0-8 | CON2.0-8 | D1 | IN5819 | IN5819 | D2 | IN5819 | IN5819 | D3 | SOT23-132-1 | SOT23-132-1 | D4 | SOT23-132-1 | SOT23-132-1 | D5 | SOT23-132-1 | SOT23-132-1 | D6 | D-LL34 | D-LL34 | D7 | D-LL34 | D-LL34 | D8 | SOT23-132-1 | SOT23-132-1 | D9 | D-LL34 | D-LL34 | D10 | D-LL34 | D-LL34 | D11 | SOT23-132-1 | SOT23-132-1 | D12 | SOT23-132-1 | SOT23-132-1 | D13 | SOT23-132-1 | SOT23-132-1 | D14 | SOT23-132-1 | SOT23-132-1 | D15 | FB0410 | FB0410 | D20 | D-LL34 | D-LL34 | D21 | D-LL34 | D-LL34 | D22 | BAT83 | BAT83 | D23 | SOT23-132-1 | SOT23-132-1 | D24 | SOT23-132-1 | SOT23-132-1 | D25 | SOT23-132-1 | SOT23-132-1 | D26 | D-LL34 | D-LL34 | D27 | D-LL34 | D-LL34 | D28 | D-LL34 | D-LL34 | F1 | FUSE-S | FUSE-S | F2 | FUSE-S | FUSE-S | H1 | PHOLE4A | PHOLE4 | H2 | PHOLE4D | PHOLE4 | H3 | HOLE | HOLE | H4 | PHOLE4B | PHOLE4 | L1 | L-RH125 | L-RH125 | L2 | FB0410 | FB0410 | L3 | FB0410 | FB0410 | L4 | L-RH125 | L-RH125 | L6 | FB0410 | FB0410 | L7 | 1206 | 1206 | L8 | FB0805 | FB0805 | L54 | C0603 | C0603 | L55 | FB0805 | FB0805 | LB1 | FB-T0805 | FB-T0805 | LB2 | FB-T0805 | FB-T0805 | LB3 | FB-T0805 | FB-T0805 | LB4 | CM2012 | CM2012 | LB5 | CM2012 | CM2012 | LB6 | CM2012 | CM2012 | LB7 | CM2012 | CM2012 | LB8 | CM2012 | CM2012 | PCON1 | DF14H-30P-1.25H | DF14H-30P-1.25H | PCON2 | SIP-2X16P-80 | SIP-2X16P-80 | PCON3 | SIP-2.54X18P-80 | SIP-2X18P-80 | PCON5 | SIP-2.54X15P-80 | SIP-2X15P-80 | Q1 | SOT23-132 | SOT23-132 | Q2 | SOT23-132 | SOT23-132 | Q3 | SOT23-132 | SOT23-132 | Q4 | SOT23-132-1 | SOT23-132-1 | Q5 | SOT23-132 | SOT23-132 | Q6 | SOT23-132 | SOT23-132 | Q7 | SOT23-132 | SOT23-132 | Q8 | SOT23-132-1 | SOT23-132-1 | Q9 | SOT23-132-1 | SOT23-132-1 | Q10 | SOT23-132 | SOT23-132 | RP32 | RN-2X4P | RN-2X4P | S1 | 805 | 805 | S2 | 805 | 805 | S3 | 805 | 805 | S4 | R0603 | R0603 | S5 | R0603 | R0603 | U1 | TO-263-5L | TO-263-5L | U2 | SOT263 | SOT263 | U3 | SOT223 | SOT223 | U4 | TO-263-5L | TO-263-5L | U5 | SOT263 | SOT263 | U6 | SOT223 | SOT223 | U7 | SOT223 | SOT223 | U8 | SOT223 | SOT223 | U9 | SOP8 | SOP8 | U10 | SOT223 | SOT223 | U11 | SOT223 | SOT223 | U12 | PQFP208 | PQFP208 | U13 | SOP8 | SOP8 | U14 | TSSOP10 | TSSOP10 | U15 | SOP8 | SOP8 | U16 | SOP8 | SOP8 | U17 | QFP128-3A | QFP128-3 | U18 | TSOP54 | TSOP54 | U19 | SOP16 | SOP16 | U20 | QFP80 | QFP80 | U21 | PLCC44S | PLCC44S | U22 | SOP8 | SOP8 | U23 | QFP100 | QFP100 | U24 | TSSOP32 | TSSOP32 | U25 | QFP80-7 | QFP80-7 | U26 | TA2024 | TA2024 | U27 | TSOP66 | TSOP66 | U28 | TSOP66 | TSOP66 | U29 | SOT252A | SOT252 | U30 | TSSOP38 | TSSOP38 | UA24 | STSSOP32 | STSSOP32 | Y5 | X1 | X1 | Y6 | X1 | X1 |
