REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
ANT1 | SMA/RF_2_ANT3B300_310H125_WIFI | wifi ant | ANT3B300_310H125 |
BT1 | BATTERY_CON2_BAT | BAT | CON2 |
D5 | LED_0_LED0603_LED | LED | LED0603 |
D6 | LED_0_LED0603_LED | LED | LED0603 |
D24 | DIODE_SOD123_TF5819 | TF5819 | SOD123 |
D26 | DIODE_SOD123_TF5819/NC | TF5819/NC | SOD123 |
D28 | LED_LED0603_CHRG | CHRG | LED0603 |
ESD29 | 1_1.5KE100A_ESD0402_ESD9B5VL-2/ | ESD9B5VL-2/TR | ESD0402 |
ESD30 | 1_1.5KE100A_ESD0402_ESD9B5VL-2/ | ESD9B5VL-2/TR | ESD0402 |
J2 | CON32_8_HDR2_15P200B400_3000H20 | CON30 | HDR2_15P200B400_3000H200 |
J3 | CON32_8_HDR2_15P200B400_3000H20 | CON30 | HDR2_15P200B400_3000H200 |
J5 | CON32_8_HDR2_15P200B400_3000H20 | CON30 | HDR2_15P200B400_3000H200 |
J8 | CON2_2_HDR3P200_CON2 | CON2 | HDR3P200 |
J9 | CON2_2_HDR3P200_CON2 | CON2 | HDR3P200 |
J10 | CON2_0_HDR1_2P200B180_380H610_C | CON2 | HDR1_2P200B180_380H610 |
J11 | CON2_2_SW3P250B160_850H850_CON2 | CON2 | SW3P250B160_850H850 |
L7 | INDUCTOR_CD32_1.5UH-1.5A/DCR<0. | 1.5uH-1.5A/DCR<0.05R | CD32 |
L10 | INDUCTOR_CD32_1.5UH-1.5A/DCR<0. | 1.5uH-1.5A/DCR<0.05R | CD32 |
L11 | INDUCTOR_CD32_1.5UH-1.5A/DCR<0. | 1.5uH-1.5A/DCR<0.05R | CD32 |
Q5 | PMOS_SOT-23_TF3423 | TF3423 | SOT-23 |
U3 | MAX809RD_0_SOT-23_SGM803T/NC | SGM803T/NC | SOT-23 |
U7 | SPI-NOR-SO8_SOP8P127B523_528H21 | MX25L6435F | SOP8P127B523_528H216 |
U8 | 74LS245_7_XR819_MODULE_SMD_XR81 | XR819 module | XR819_MODULE_SMD |
U9 | SPI-NOR-SO8_0_DFN9P127B600_800H | MX35LF1GE4AB | DFN9P127B600_800H75 |
U12 | RT9266PE_12_SOT23-5_LP3981-3.3V | LP3981-3.3V | SOT23-5 |
U13 | RT9266PE_12_SOT23-5_LP3981-3.0V | LP3981-3.0V | SOT23-5 |
U28 | BMA222_LGA12P50B200_200H100_DA2 | DA280 | LGA12P50B200_200H100 |
U29 | RT9266PE_11_SOT23-5_LP4062 | LP4062 | SOT23-5 |
U30 | RT9167-NNCB_3_SOT23-6_LP5300 | LP5300 | SOT23-6 |
U31 | RT9266PE_0_QFN-3X3-20_EA3036C | EA3036C | QFN-3X3-20 |
U32 | V3S_8_ELQFP128P40B14X14_F35 | F35 | ELQFP128P40B14X14 |
USB1 | USB_MINI_SOCKET_2_USB5P0_65B7_2 | MIRCO-USB-5P | USB5P0_65B7_20X9_40H2_80 |
X3 | CRYSTAL_XCOL-3_XCOL-SMD_32.768K | 32.768KHz | XCOL-SMD |
X4 | CRYSTAL-4_0_CRY-TSX3225_24M-20P | 24M-20pF-10PPM | CRY-TSX3225 |
