[IC] MT2492 规格书
查看1099 | 回复3 | 2020-3-29 15:30:35 | 显示全部楼层 |阅读模式
High Efficiency: Up to 96%
600KHz Frequency Operation
2A Output Current
No Schottky Diode Required
4.5V to 16V Input Voltage Range
0.6V Reference
Slope Compensated Current Mode Control for
Excellent Line and Load Transient Response
Integrated internal compensation
Stable with Low ESR Ceramic Output
Capacitors
Over Current Protection with Hiccup-Mode
Thermal Shutdown
Inrush Current Limit and Soft Start
Available in SOT23-6 Package
-40°C to +85°C Temperature Range
MT2492 规格书.PDF
390 KB, 下载次数: 0, 下载积分: 金币 -1 枚
请输入描述
kingboy100 | 2020-3-30 07:43:39 | 显示全部楼层
tclin08 | 2020-3-30 08:03:15 | 显示全部楼层
wangy2000 | 2020-3-30 08:04:52 | 显示全部楼层
