REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BH1201 | SPACER_SPACER_139T_IC_1613MM_2 | .635" LONG | SPACER_139T |
BH1202 | SPACER_SPACER_139T_IC_1613MM_2 | .635" LONG | SPACER_139T |
BH1203 | SPACER_SPACER_139T_IC_1613MM_2 | .635" LONG | SPACER_139T |
BH1204 | SPACER_SPACER_139T_IC_1613MM_2 | .635" LONG | SPACER_139T |
BH1206 | MOUNT_HOLE_MH244-166T_IC_213MM | SMTSO-M25 | MH244-166T |
BH1207 | MOUNT_HOLE_STANDOFF_CIRCLE_5P1- | STANDOFF M2.5 | STANDOFF_CIRCLE_5P1-2P5MM_NSP |
BH1208 | MOUNT_HOLE_STANDOFF_CIRCLE_5P1- | STANDOFF M2.5 | STANDOFF_CIRCLE_5P1-2P5MM_NSP |
BH1209 | MOUNT_HOLE_STANDOFF_CIRCLE_5P1- | STANDOFF M2.5 | STANDOFF_CIRCLE_5P1-2P5MM_NSP |
D101 | ZDIODE_SOD523_IC_065MM_480-79 | BZX585-B2V4 | SOD523 |
D301 | DIODE_TVS_SOD123W_IC_11MM_480- | PTVS20VS1UR | SOD123W |
D303 | DIODE_TVS_SOD123W_IC_11MM_480- | PTVS20VS1UR | SOD123W |
D308 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D309 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D310 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D311 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D312 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D313 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D601 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D602 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D603 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D702 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D703 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D704 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D705 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D706 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D707 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D708 | LED_LED_0603_IC_08MM_370-7665 | LED RED | LED_0603 |
D709 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D902 | LED_LED_0603_IC_08MM_370-7667 | LED GREEN | LED_0603 |
D903 | LED_LED_0603_11MIL_IC_028MM_37 | LED_ORANGE | LED_0603_11MIL |
D905 | LED_LED_0603_11MIL_IC_028MM_37 | LED_ORANGE | LED_0603_11MIL |
D906 | LED_LED_0603_IC_08MM_370-7667 | LED GREEN | LED_0603 |
D907 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D908 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D909 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D910 | DIODE_SCHTKY_SOD323_IC_11MM_48 | NSR0320 | SOD323 |
D1001 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
D1002 | DIODE_TVS_SOD-923_IC_040MM_480 | ESD9L5.0ST5G | SOD-923 |
F301 | FUSE_FUSE_3P4X1P8_DISCRETE_086 | 7A | FUSE_3P4X1P8 |
F302 | FUSE_FUSE_3P4X1P8_DISCRETE_086 | 7A | FUSE_3P4X1P8 |
J101 | CONN_HDR_2X1_HDR102_IO_871MM_ | HDR 1X2 TH | HDR102 |
J201 | HDR_2X50_M_CON100_0P4_22P8X3P1_ | DF40C-100DS-0.4V(51) | CON100_0P4_22P8X3P1_SM |
J202 | HDR_2X50_M_CON100_0P4_21P7X2P05 | DF40C-100DP-0.4V(51) | CON100_0P4_21P7X2P05_SM |
J203 | CONN_HDR_10X2_CON20_0P4_5P7X2P0 | DF40C-20DP-0.4V(51) | CON20_0P4_5P7X2P05_SM |
J301 | USB24_TYPEC_SH4_CON24_USB_TYPEC | 23K20101#LCP-582RF | CON24_USB_TYPEC_RA_SMT_TH |
J302 | USB24_TYPEC_SH4_CON24_USB_TYPEC | 23K20101#LCP-582RF | CON24_USB_TYPEC_RA_SMT_TH |
J401 | CON_KJ366EYS_AUDIOJACK_6P_CON6_ | KJ366EYS | CON6_AUDIOJACK_RA_TH |
J501 | RJ45_HR851178C_CON_RJ45_10F_100 | HR851178C | CON_RJ45_10F_100_TH_RA |
J601 | CON_67_FEMALE_RA_A_CON_75_0P5_2 | CON_MINI CARD_RA | CON_75_0P5_22X9_RA |
J701 | CONN_MICRO_SDCARD_9P_CON9_SDCAR | CONN_SD_CARD 9 | CON9_SDCARD_1P1MM |
J801 | CONN_IPASS_36P_CON_36_0P8_TH_IO | IPASS MINISAS | CON_36_0P8_TH |
J802 | CONN_IPASS_36P_CON_36_0P8_TH_IO | IPASS MINISAS | CON_36_0P8_TH |
J901 | MICRO_USB_CONN_11PIN_CON_USB_TY | MICRO_USB_TYPEB | CON_USB_TYPE_B_SM |
J902 | CONN_HDR_5X2_CON_2RH_10_50_IO_3 | HDR 2X5 | CON_2RH_10_50 |
J1001 | CON_1X60_CON_FPC_60F_0P5_SM_RA_ | XF2M-6015-1AH | CON_FPC_60F_0P5_SM_RA |
J1003 | CONN_HDR_20X2_HDR220_TSM_A_SM_I | TSM-120-01-F-DV-A | HDR220_TSM_A_SM |
J1004 | CONN_HDR_4X2_CON_2X4_SKT_100_SM | SSM-104-L-DV | CON_2X4_SKT_100_SM |
L101 | INDUCTOR_IND_IHLP_DISCRETE_3MM_ | 1.5uH | IND_IHLP |
L102 | INDUCTOR_IND_SPH2520_DISCRETE_1 | 0.47uH | IND_SPH2520 |
L401 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
L501 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
L502 | INDUCTOR_IND_VLS252010_DISCRETE | 4.7uH | IND_VLS252010 |
L503 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
L601 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
L602 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
L901 | BEAD_0_0603_CC_DISCRETE_095MM_ | 120OHM | 0603_CC |
Q101 | MOSFET_P_5P_SO8_DFN3P3X3P3_8L_E | AON7405 | DFN3P3X3P3_8L_EX |
Q102 | NX3008NBKW_SOT323_SC70_3_IC_11 | NX3008NBKW,115 | SC70_3 |
Q301 | NX3008NBKW_SOT323_SC70_3_IC_11 | NX3008NBKW,115 | SC70_3 |
Q604 | NX3008NBKW_SOT323_SC70_3_IC_11 | NX3008NBKW,115 | SC70_3 |
Q903 | NX3008NBKW_SOT323_SC70_3_IC_11 | NX3008NBKW,115 | SC70_3 |
Q1001 | MOSFET_P_SOT-23_IC_112MM_480-7 | SI2343DS | SOT-23 |
Q1002 | MOSFET_N_SOT23_A_IC_11MM_480- | 2N7002 | SOT23_A |
Q1003 | NX3008NBKW_SOT323_SC70_3_IC_11 | NX3008NBKW,115 | SC70_3 |
SW101 | SW_DPDT_3_SW6_DPDT_M096H_TH_IC_ | M096H-A020RT21A | SW6_DPDT_M096H_TH |
SW901 | NTC501-BG1G-B160T_SW2_3P4_TACT_ | TACT SWTICH | SW2_3P4_TACT_SM_NSP |
SW902 | NTC501-BG1G-B160T_SW2_3P4_TACT_ | TACT SWTICH | SW2_3P4_TACT_SM_NSP |
SW1101 | SW_DIP-10_SW_DIP10_SM_IC_17MM_ | 97C10ST | SW_DIP10_SM |
SW1102 | SW_DIP-10_SW_DIP10_SM_IC_17MM_ | 97C10ST | SW_DIP10_SM |
TVS303 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS304 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS307 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS308 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS401 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS402 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS701 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS702 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
TVS901 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | ESD5B5.0ST1G | DIODE2_SOD523 |
U101 | MP8759GD_QFN12P_QFN12_0P5_3P1X2 | MP8759GD | QFN12_0P5_3P1X2P1 |
U102 | MP2147GD_QFN_11P_QFN12_0P5_2X3M | MP2147GD | QFN12_0P5_2X3MM_EP |
U201 | PCA6416APW_TSSOP24_TSSOP24_0P65 | PCA6416APW | TSSOP24_0P65_7P9X4P5 |
U202 | SN74AVC8T245_TSSOP24_65MM_IC_1 | 74AVC8T245PW | TSSOP24_65MM |
U203 | NTS0104PW_14P_TSSOP14_IC_11MM_ | NTS0104PW | TSSOP14 |
U204 | 1G125_SC70-5_IC_11MM_315-80956 | 74AUP1G125GW | SC70-5 |
U301 | SGM8709YN5G_SOT-23-5_IC_125MM_ | SGM8709YN5G | SOT-23-5 |
U302 | NX20P3483UK_42P_WLCSP42_0P4_2P9 | NX20P3483UK | WLCSP42_0P4_2P94X2P54_SMDP |
U303 | PTN5110_QFN16_HX2QFN16_0P4_2P7X | PTN5110 | HX2QFN16_0P4_2P7X2P7 |
U304 | SGM8709YN5G_SOT-23-5_IC_125MM_ | SGM8709YN5G | SOT-23-5 |
U305 | NX20P3483UK_42P_WLCSP42_0P4_2P9 | NX20P3483UK | WLCSP42_0P4_2P94X2P54_SMDP |
U306 | PTN5110_QFN16_HX2QFN16_0P4_2P7X | PTN5110 | HX2QFN16_0P4_2P7X2P7 |
U307 | PCMF1USB3S_WLCSP5_WLCSP5_0P4_0P | PCMF1USB3S | WLCSP5_0P4_0P82X1P22 |
U308 | NX20P0407_WLCSP12_A_WLCSP12_0P4 | NX20P0407 | WLCSP12_0P4_1P3X1P7MM_SMDP |
U309 | PCMF1USB3S_WLCSP5_WLCSP5_0P4_0P | PCMF1USB3S | WLCSP5_0P4_0P82X1P22 |
U310 | NX20P0407_WLCSP12_A_WLCSP12_0P4 | NX20P0407 | WLCSP12_0P4_1P3X1P7MM_SMDP |
U311 | SGM8709YN5G_SOT-23-5_IC_125MM_ | SGM8709YN5G | SOT-23-5 |
U312 | TPS709_1_SOT23-5_IC_145MM_315- | TPS70933DBVR | SOT23-5 |
U401 | WM8524GEDT_TSSOP16_IC_12MM_315 | WM8524CGEDT | TSSOP16 |
U501 | AR8031_48P_EP_QFN48_0P4_6X6MM_E | AR8031 | QFN48_0P4_6X6MM_EPAD |
U502 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U503 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U504 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U505 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U506 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U507 | NC7WV16_6P_SC70_6LEAD_IC_11MM_ | NC7WV16 | SC70_6LEAD |
U508 | NTB0102_8P_TSSOP8_A_IC_11MM_31 | NTS0102 | TSSOP8_A |
U601 | 9FGV0241AKLF_24P_QFN24_0P5_4X4_ | 9FGV0241AKLF | QFN24_0P5_4X4_EP2P2 |
U701 | IRM-V538_RCVR_SM_IRM_V5_IC_285 | IRM-V538T/TR1 | RCVR_SM_IRM_V5 |
U702 | ADP172_CSP_4P_WLCSP4_0P4_0P8X0P | NX3P191UK | WLCSP4_0P4_0P8X0P8_SMDP |
U901 | FT2232D_LQFP48_IC_160MM_312-77 | FT2232D | LQFP48 |
U902 | PCMF1USB3S_WLCSP5_WLCSP5_0P4_0P | PCMF1USB3S | WLCSP5_0P4_0P82X1P22 |
U903 | RT9193-33PB_SOT23-5_IC_1295MM_ | RT9193 | SOT23-5 |
U904 | NTB0104BQ_DHVQFN14_3X2P5MM_IC_1 | NTB0104BQ | DHVQFN14_3X2P5MM |
X901 | XTAL_13_XTAL_4_7P2X5P2_IC_13MM | 6MHz | XTAL_4_7P2X5P2 |
Y501 | XTAL_13Y_XTLOSC4_2P5X2MM_SM_IC_ | 25MHz | XTLOSC4_2P5X2MM_SM |
Y601 | XTAL_13Y_XTLOSC4_2P5X2MM_SM_IC_ | 25MHz | XTLOSC4_2P5X2MM_SM |
