REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | BATTERY_HDR102_BATTERY | BATTERY | HDR102 |
D1 | LED_LED_0603_C1_0.8MM_370-75079 | LED | LED_0603_C1 |
D4 | LED_HDR102_TSAL6200 | TSAL6200 | HDR102 |
D5 | LED_LED-0603_LED | LED | LED-0603 |
D6 | LED_LED_0603_LED | LED | LED_0603 |
D7 | LED_LED_0603_LED | LED | LED_0603 |
D14 | LED_LED_0603_LED | LED | LED_0603 |
D15 | LED_LED_0603_LED | LED | LED_0603 |
D16 | LED_LED_0603_LED | LED | LED_0603 |
D17 | DIODE_SCHTKY_SMA_IC_0.73MM_480- | SMAJ6.0CA | SMA |
D18 | DIODE_SCHTKY_SMA_IC_SMAJ6.0CA | SMAJ6.0CA | SMA |
D19 | DIODE_SCHTKY_SMA_IC_SMAJ6.0CA | SMAJ6.0CA | SMA |
D20 | 5365F_0_LED-ABP3025_5365F | 5365F | LED-ABP3025 |
D21 | 5365F_0_LED-ABP3025_5365F | 5365F | LED-ABP3025 |
D22 | 5365F_0_LED-ABP3025_5365F | 5365F | LED-ABP3025 |
E1 | ESD_E0603_ESD | ESD | E0603 |
J3 | HEADER18_DIP18-3X254_HEADER 18 | HEADER 18 | DIP18-3X254 |
J6 | DC POWERJACK_PJ-102AH_100_11MM | DC_POWER_JACK | PJ-102AH_100 |
J7 | 4 HEADER_DIP4_4HEADER | 4 HEADER | DIP4 |
J1402 | CN,XRJMS-01-8-8-1-F2,RJ45_XRJMS | RJ45 | XRJMS01 |
J1403 | CON3_DIP3_CON3 | CON3 | DIP3 |
J1405 | CON20A_DIP20-254_CON20A | CON20A | DIP20-254 |
L1 | CHOKE_IND_0603_470OHM | 470OHM | IND_0603 |
L2 | CHOKE_IND_0603_470OHM | 470OHM | IND_0603 |
L3 | BEAD_IND-0603_26OHM | 26OHM | IND-0603 |
L4 | BEAD_IND_0603_100OHM@100MHZ | 100OHM@100MHz | IND_0603 |
L5 | BEAD_IND_0603_100OHM@100MHZ | 100OHM@100MHz | IND_0603 |
L6 | BEAD_IND_0603_100OHM@100MHZ | 100OHM@100MHz | IND_0603 |
L7 | BEAD_IND_0603_100OHM@100MHZ | 100OHM@100MHz | IND_0603 |
L8 | INDUCTOR_IND_0603_0.95MM_180-76 | 10UH | IND_0603 |
L9 | INDUCTOR_IND_0603_0.95MM_180-76 | 10UH | IND_0603 |
L10 | INDUCTOR_IND2220_3.7MM_180-7557 | 250Ohm/100Mhz | IND2220 |
Q1 | 2N1070_SOT23_9013 | 9013 | SOT23 |
Q2 | PNP_SOT23_9012 | 9012 | SOT23 |
Q5 | PNP_SOT-23_MC9012 | MC9012 | SOT-23 |
Q6 | PNP_SOT-23_MC9012 | MC9012 | SOT-23 |
Q7 | PNP_SOT-23_MC9012 | MC9012 | SOT-23 |
Q8 | PNP_SOT-23_MC9012 | MC9012 | SOT-23 |
Q9 | PNP_SOT23_3906 | 3906 | SOT23 |
Q10 | PNP_SOT23_3906 | 3906 | SOT23 |
Q11 | PNP_SOT23_3906 | 3906 | SOT23 |
Q12 | PNP_SOT23_3906 | 3906 | SOT23 |
Q13 | PNP_SOT23_3906 | 3906 | SOT23 |
Q14 | PNP_SOT23_3906 | 3906 | SOT23 |
Q15 | 2N1070_SOT23_MC9013 | MC9013 | SOT23 |
Q16 | PNP_SOT23_9012 | 9012 | SOT23 |
Q17 | PNP_SOT23_9012 | 9012 | SOT23 |
Q18 | PNP_SOT23_MC9012 | MC9012 | SOT23 |
RESET | SW_PB_ESW_SW4_PB_ESW_SM_P177_4. | SPST PB NO | SW4_PB_ESW_SM_P177 |
TP1 | TESTLOOP_TP40_IC_TESTLOOP | TestLoop | TP40 |
TP2 | TESTLOOP_TP40_IC_TESTLOOP | TestLoop | TP40 |
TP3 | TESTLOOP_TP40_IC_TESTLOOP | TestLoop | TP40 |
TVS1 | DIODE_TVS_BIDIR_R512_315_138_39 | P6KE6.8CA | R512_315_138_39 |
TVS2 | DIODE_TVS_BIDIR_R512_315_138_39 | P6KE6.8CA | R512_315_138_39 |
TVS3 | DIODE_TVS_BIDIR_R512_315_138_39 | P6KE6.8CA | R512_315_138_39 |
U1 | K60_LQ_LQFP_144P_LQFP144_IC_1.6 | MK60DN512VLQ10 | LQFP144 |
U3 | NC7SZ14_SOT-23-5_1.45MM_312-759 | SN74LVC1G04 | SOT-23-5 |
U4 | RX-8025T_SOP14_RX-8025T | RX-8025T | SOP14 |
U5 | K9F1208U0B_TSOP-48_K9F1208U0B | K9F1208U0B | TSOP-48 |
U6 | IS62WV12816DBLL_TSOP44_T2_IS62W | IS62WV12816DBLL | TSOP44_T2 |
U7 | ESAM_DIP8_ESAM | ESAM | DIP8 |
U8 | LAN8720_QFN24_0P5_4X4MM_LAN8720 | LAN8720AI | QFN24_0P5_4X4MM |
U9 | 11FB-05NL_SOP16-13X10MM_11FB-05 | 11FB-05NL | SOP16-13X10MM |
U10 | W25Q32_SOIC16_4X10MM_W25Q32 | W25Q32 | SOIC16_4X10MM |
U11 | HS0038B3V_LED_DIP3_2P5_HS0038B3 | HS0038B3V | LED_DIP3_2P5 |
U12 | MAX706TESA_MSOP8_MAX706TESA | MAX706TESA | MSOP8 |
U13 | MAX3085CSA_SO8_MAX13085 | MAX13085 | SO8 |
U14 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U15 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U16 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U17 | MAX3085CSA_SO8_MAX13085 | MAX13085 | SO8 |
U18 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U19 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U20 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U21 | MAX3085CSA_SO8_MAX13085 | MAX13085 | SO8 |
U22 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U23 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U24 | PS2501_DIP_4P_SMT_PS2501-1 | PS2501-1 | DIP_4P_SMT |
U26 | 74HC32_SSOP14_74HC32 | 74HC32 | SSOP14 |
U27 | AMS3132_TO263-5_AMS3132M | AMS3132M | TO263-5 |
U28 | AMS1117_SOT223_AMS1117 | AMS1117 | SOT223 |
X1 | USB ACONNECTOR_USB_A_VT_USB A | USB A Connector | USB_A_VT |
X3 | CON2_DIP2_CON2 | CON2 | DIP2 |
X4 | CON2_DIP2_CON2 | CON2 | DIP2 |
X5 | CON2_DIP2_CON2 | CON2 | DIP2 |
X6 | CON2_DIP2_CON2 | CON2 | DIP2 |
Y1 | CLKGEN-SM_XTLOSC4_SM_IC_1.75MM_ | 50MHZ | XTLOSC4_SM |
