重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | BAT1 | MS621FEFL11E | MS621FEFL11E | NC(MS621FEFL11E) | CN1 | SD_SOCKET_TOP_A_PANASONIC | SD_STANDARD_A | SD_Socket_Top_A_Panasonic | CN2 | USB_A_RECEPTACLE_SMD_4P | CN_USB_A | USB_A_SMD | CN3 | PHONE_JACK_3.5MM_90D_DIP_3P | MINIATURE_JACK | Phone_Jack | CON1 | HDMI_M_0 | CN_HDMI_19_050_ | NC(CON/HDMI) | CT1 | 47UF_6.3V_20%_B_CASE | CAP_B_3528 | 47uF,6.3V | D1 | RB551V-30_SOD323 | SOD323 | RB551V-30 | D2 | RCLAMP0520B_SOT-523 | RCLAMP0502B | NC(RClamp0520B) | D3 | RCLAMP0520B_SOT-523 | RCLAMP0502B | NC(RClamp0520B) | D4 | RCLAMP0524P_SLP2510P8 | RCLAMP0524P | NC(RClamp0524P) | D5 | RCLAMP0524P_SLP2510P8 | RCLAMP0524P | NC(RClamp0524P) | D6 | RB551V-30_SOD323 | SOD323 | RB551V-30 | FB30 | 100M_17H[_600MA_SMD0805 | L0805 | 100M,17£[ | J1 | 1X8P_FEMALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0F) | J2 | 1X8P_FEMALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0F) | J3 | RJ45_0_2 | RJ45_PA6T | RJ45 | J4 | 2X22P_FEMALE_DIP_1.27 | CN22X2_127 | NC(2X22P_1.27F) | J5 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J6 | RCA_JACK_90D_YELLOW_DIP_2P | RCA_JACK | RCA_Yellow | J7 | 1X2P_MALE_DIP_1.27 | JP2_125_I | 1X2P_1.25M | J8 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J9 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J10 | 1X5P_MALE_DIP_2.54 | SIP_5P | 1X5P_2.54M | J11 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | J12 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J13 | DC_JACK | PJ20_3P | DC_JACK | J14 | 1X2P_MALE_DIP_2.0_2 | SIP_2P_200 | NC(1X2P_2.0M) | J15 | 2X15P_FEMALE_DIP_2.0 | CN15X2_200 | 2X15P_2.0F | JP18 | 1X2P_MALE_DIP_2.0 | SIP_2P_200 | 1X2P_2.0M | L1 | 4.7UH_4.2A_20%_SMD_SB0805 | L_SB0805 | 4.7uH | L2 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | L3 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | L4 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | LED3 | RED__SMD0603 | LED0603 | RED | LED4 | GREEN__SMD0603 | LED0603 | GREEN | MIC1 | MIC-MICROPHONE0 | MIC | MIC-EM5BPS | MIC2 | MIC-MICROPHONE0 | MIC | MIC-EM5BPS | PB1 | PUSH_BOTTOM_DIP | SW_PB4P | Push Button | PB2 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY1 | PB3 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY2 | PB4 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY3 | PB5 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY4 | PB6 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY5 | PB7 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY6 | PB8 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY7 | PB9 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY8 | Q1 | AO3415_SOT23 | SOT23 | AO3415 | SW1 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | SW2 | SWITCH_2_PORT_SMD_4P | SW_HDS402 | SW_SMD | SW3 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | SW4 | SW_SPDT3_DIP | SW_SPDT3_1 | SW-SPDT3 | SW5 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | U1 | GM8139_TFBGA256 | BGA256_065_12X12 | GM8139_TFBGA256 | U2 | G691L293T73U_SOT23 | SOT23 | G691L293T73U | U3 | K4B2G1646B-HCK0-1600 | DDR3_FBGA_X16_9X13P3 | K4B2G1646B-HCK0-1600_2G(128Mx16) | U4 | K4B2G1646B-HCK0-1600 | DDR3_FBGA_X16_9X13P3 | K4B2G1646B-HCK0-1600_2G(128Mx16) | U6 | W25P80/16 | SOIC8_208 | W25Q128FV | U7 | SPI_FLASH_SOP16 | SOP16_300 | NC(SPI_FLASH,SOP16) | U8 | K9F1G08U0B(128MBX8)_TSOP48_0 | TSOP48_12X20 | NC(NAND FLASH K9F1G08U0B(128Mbx8)) | U9 | G5250C1T1U | SOT25 | NC(G5250C1T1U) | U10 | IP101GR | TQFN32_040+EPAD | IP101GR | U11 | TS8121C | TS8121C | TS8121C | U12 | CAT6612_0 | QFP80_050 | NC(IT6612) | U13 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U14 | AKU2002C | MIC_AKU2002C | NC(AKU2002C) | U15 | AKU2002C | MIC_AKU2002C | NC(AKU2002C) | U16 | IR_0 | ECM_A38_N3 | IRM3638T,3.3V | U17 | MP1484_SOP8_0 | SOP8+EPAD | MP1482,SOP8 | U18 | G9131-28T73UF_ | SOT23 | G9131-28T73Uf | U19 | G5699_0 | TDFN12_045_3X3 | G5699 | U20 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U21 | G5728B_SOT25 | SOT25 | G5728B | U22 | DS1307_SOIC8 | SOIC8_150 | NC(PT7C4307,SOIC8) | Y1 | 30MHZ_CRY_30PPM_SMD5X3 | XTAL_SMD_50X32 | 30MHz | Y2 | XTAL_32.768KHZ_0 | XTAL_127L | 32.768K | Y3 | 32.768KHZ_CRY_30PPM_SIZE_2X6 | XTAL_0P7L | 32.768KHz |
重要提示:PCB作品文件展下载说明
