重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | B1 | CHOKE_WB-PHENOLIC | RB12/8 | NC(Bell) | BAT2 | CR2032_HOLDER | BATTERY_SD_100_A | CR2032_Holder | CM72 | 1UF_10V_10%_SMD0402 | C0402 | 1uF | CN1 | POWER_CON_HD_5.08MM_DIP_4P | CONRA_4P_200 | Power_CON_HD | CN2 | ATX_CONN_4_0.2MM_DIP_20P | POWER_20M | NC(ATX) | CN3 | POWER_CON_2.54MM_DIP_2P | JP2_250_I | NC(Power_CON,2P) | CN4 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | CN5 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | CN7 | SATA_180D_DOWN_DIP_7P | MTD_CN_SATA_7P_L | SATA1_HOST_DIP | CN8 | SATA_180D_DOWN_DIP_7P | MTD_CN_SATA_7P_L | SATA1_HOST_DIP | CN9 | SATA_180D_DOWN_DIP_7P | MTD_CN_SATA_7P_L | SATA1_HOST_DIP | CN10 | SATA_180D_DOWN_DIP_7P | MTD_CN_SATA_7P_L | SATA1_HOST_DIP | CN18 | DB15_90D_FEMALE_DIP_15P | DB15_FL | DB15_F | CN19 | SIP6_0 | SIP1.27-7P | NC(1.25mmx7) | CN20 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | CON1 | CON-19-HDMI-NS-J_1 | CN_HDMI_19_050 | HDMI-R/A-SMT | CT6 | 100UF_6.3V_20%_C_CASE | CAP_C_6032 | NC(100uF,6.3V) | D1 | SK34_D_LL34 | D_LL34 | SK34 | D2 | SK34_D_LL34 | D_LL34 | SK34 | D3 | SK34_D_LL34 | D_LL34 | SK34 | D4 | IN4148 | MTD_D_LL34 | IN4148 | D15 | SK34_D_LL34 | D_LL34 | NC(SK34) | D18 | INPAQ_TVW_DF10_0 | ESD_10P_050 | NC(HDMI_ESD_Protection) | D19 | INPAQ_TVW_DF10_0 | ESD_10P_050 | NC(HDMI_ESD_Protection) | D88 | VH0603M240CGT2R5_2_0.5PF | VHZ0603 | VH0603M240CGT2R5,2.5pF | D107 | EGA10402V05AH_1 | EGA0402 | EGA10402V05AH_0.2pF | D108 | IN4148 | MTD_D_LL34 | IN4148 | D112 | IN4148 | MTD_D_LL34 | IN4148 | D130 | DIODE_BREAKDOWN_1 | D_P0080 | NC(P0080) | D131 | SRV05 | SOT26 | NC(SRV05) | F1 | FUSE-4A_DIP | FUSE-DIP2 | FUSE-4A_DIP | F2 | FUSE-4A_DIP | FUSE-DIP2 | NC(FUSE-4A_DIP) | F3 | 0.5A_POLY_SWITCH_SMD4532 | PS_S3_4532 | 0.5A,SMD_4532 | FB92 | 100M_30H[_400MA_SMD0603_4 | L0603 | 100M,30£[ | J2 | 1X3P_MALE_DIP_2.0 | SIP_3P_200 | 1X3P_2.0M | J3 | SIP_1 | SIP2P-300 | NC(POWER_SWICTH) | J5 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J6 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J7 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J10 | DC_POWER_JACK_2.0_DIP_3P | MTD_PJ20_3P | DC-Jack | J13 | 1X2P_MALE_DIP_1.27 | SIP_2P_127 | NC(1X2P_1.27M) | J17 | 1X2P_MALE_DIP_2.54 | SIP_2P | 1X2P_2.54M | J23 | RJ45_2 | RJ45-LED-3 | RJ45_0 | J24 | CON40A | IDE40_2.54 | TCON-20X2 | J25 | CON24A | TCON-12X2/HOU | TCON-12X2 | J26 | CON4 | SIP4P_100MIL | NC(USB-2.54) | J27 | CON4 | SIP4P_100MIL | NC(USB-2.54) | J28 | SINGLE_USB | USB-SINGLE-90 | SINGLE_USB | J29 | CON16A | AL_DIP2X8_300MIL | NC(ALARM_DIP2X8) | J30 | CON10 | SIP10P_100MIL | NC(CON10) | J31 | CON16 | FPC2X8-1.0 | NC(DB25_28) | J32 | RJ45_0 | RJ45-LED-3 | RJ45_0 | J33 | USB_A_180_DIP | CN_USB_AI_TACT | USB_A_180_DIP | J34 | USB_A_180_DIP | CN_USB_AI_TACT | USB_A_180_DIP | J35 | 1X2P_MALE_DIP_2.54_2 | SIP_2P | 1X2P_2.54M | J36 | 1X2P_MALE_DIP_2.54_2 | SIP_2P | 1X2P_2.54M | JP1 | 1X2P_MALE_DIP_2.54 | SIP_2P | NC(1X2P_2.54M) | K1 | 20-2051-DPST_0 | REL_SRS | NC(4CSRS-05VDC-SL) | L1 | 10UH/3.8A-_GSSR2-104P-100N | L_GSSR2 | 10uH/3.8A/35mohm | L2 | 3.3UH/6A-_GSSR2-104P-3R3MN | L_GSSR2 | 3.3uH/6A/13mohm | L3 | 10UH/3.8A-_GSSR2-104P-100N | L_GSSR2 | 10uH/3.8A/35mohm | L4 | 10UH/3.8A-_GSSR2-104P-100N | L_GSSR2 | 10uH/3.8A/35mohm | L5 | 1UH/6_0.5A-_GSSR2-104P-1R0N | L_GSSR2 | 1uH/6.5A/10mohm | LED1 | RED_SMD0603_2 | LED0603 | RED | PB1 | PUSH_BOTTOM_DIP | SW_PB4P | Push Button | PT1 | PCB_TRACE_W_8MIL_2 | SJO_8MIL | PCB_Trace,W_8mil | PT2 | PCB_TRACE_W_8MIL_2 | SJO_8MIL | PCB_Trace,W_8mil | Q1 | MMBT3904_SOT23_1 | SOT23 | MMBT3904 | Q45 | MMBT3904_SOT23_1 | SOT23 | MMBT3904 | Q46 | 2N7002_SOT23_0 | SOT23-MOS | 2N7002 | Q47 | 2N7002_SOT23_0 | SOT23-MOS | 2N7002 | SW1 | SLIDE_SWITCH_DIP_3P | SW_SPDT3_1 | SW-SPDT3 | T1 | H5008T_0 | HC5000_24P_P0.99_W19.6 | H5008T | TP214 | TESTPOINT_DIP_1.27 | SIP_1P_127 | NC(TP_1.27) | U1 | GM8210_FCBGA825_10 | BGA825_065_25X25 | GM8210,FCBGA825 | U2 | HP-RE1112291A_5 | HEATSINK_38X38 | NC(GM8210_HeatSink_37x43x23) | U3 | G691L293T73U_SOT23 | SOT23 | G691L293T73U | U4 | DS1307_SOIC8 | SOIC8_150 | DS1307 | U6 | MP1484_SOP8_0 | SOP8+EPAD | MP1484,SOP8 | U7 | G9141T11U_SOT25_0 | SOT25 | G9141T11U | U8 | NB637_QFN14 | QFN14_050 | NB637,QFN14 | U9 | MP1484_SOP8_0 | SOP8+EPAD | MP1484,SOP8 | U10 | MP1484_SOP8_0 | SOP8+EPAD | MP1484,SOP8 | U11 | NB637_QFN14 | QFN14_050 | NB637,QFN14 | U12 | K4B1G1646G-BCK00DT-1600 | DDR3_FBGA_X16_9X15P5 | K4B2G1646G-BCK00DT | U13 | K4B1G1646G-BCK00DT-1600 | DDR3_FBGA_X16_9X15P5 | K4B2G1646G-BCK00DT | U14 | K4B1G1646G-BCK00DT-1600 | DDR3_FBGA_X16_9X15P5 | K4B2G1646G-BCK00DT | U15 | K4B1G1646G-BCK00DT-1600 | DDR3_FBGA_X16_9X15P5 | K4B2G1646G-BCK00DT | U16 | K9F1G08U0B(128MBX8)_TSOP48_0 | TSOP48_12X20 | NAND FLASH K9F1G08U0B(128Mbx8) | U17 | MX25L25735FMI-10G_SOP16 | SOP16_300 | (MX25L25735FMI,SOP16,256Mb)/(MX25L12835FMI,128Mb) | U19 | MAX485_SOIC8 | SOIC8_150 | NC(MAX485,SOIC8) | U20 | 74HC165_1 | SOIC16_6.2 | NC(74HC165) | U33 | G1117-25T63UF | SOT223 | G1117-25T63UF | U35 | GM8312_TFBGA256_2 | GM8312_100 | GM8312_TFBGA256 | U36 | G916-120T1UF_SOT25 | SOT25 | NC(G916-120T1Uf) | U49 | NVP1918/NVP1118B | TQFP128_16 | NVP1918 | U50 | S-1117A18-R3T1U3_0 | SOT223 | S-1117A18 | U52 | NVP1918/NVP1118B | TQFP128_16 | NVP1918 | U53 | S-1117A18-R3T1U3_0 | SOT223 | S-1117A18 | U54 | S-1117A12 | SOT223 | S-1117A12 | U56 | G2997B_MSOP-10(FD)_0 | MSOP10_050_30X49+EPAD | G2997B | U57 | G2997B_MSOP-10(FD)_0 | MSOP10_050_30X49+EPAD | G2997B | U58 | NVP1918/NVP1118B | TQFP128_16 | NVP1918 | U59 | S-1117A18-R3T1U3_0 | SOT223 | S-1117A18 | U61 | NVP1918/NVP1118B | TQFP128_16 | NVP1918 | U62 | S-1117A18-R3T1U3_0 | SOT223 | S-1117A18 | U63 | S-1117A12 | SOT223 | S-1117A12 | U64 | IP1001 | QFN64_050_9X9 | IP1001 | U65 | S-1117A18-R3T1U3_0 | SOT223 | S-1117A18 | U66 | S-1117A12 | SOT223 | S-1117A12 | U67 | SN74LVC1G08DBVR_SOT25 | SOT25 | SN74LVC1G08DBVR_SOT25 | U69 | IP101GR_0 | TQFN32_040+EPAD | IP101GR | U70 | H1102_0 | T16-H1102 | TS8121C | U71 | HY437_SOP8_1 | SOT26 | NC(SOT23-6L) | U72 | 78L05_0 | SOT89 | NC(78L05) | Y1 | 12MHZ_CRY_30PPM_49US | XTAL_UP | 12MHz | Y2 | 12.288MHZ_CRY_30PPM_SMD_5X3 | XTAL_SMD_50X32 | NC(12.288MHz) | Y3 | 32.768KHZ_CRY_30PPM_SIZE_2X6 | XTAL4_2 | 32.768KHz | Y4 | 12MHZ_CRY_30PPM_49US_2 | XTAL_UP | NC(12MHz) | Y5 | 30MHZ_OSC_30PPM_SMD5X3_0 | OSC4_SMD_50X32 | NC(30MHz) |
重要提示:PCB作品文件展下载说明
