查看: 571|回复: 1
[已发密码] PCB Decal 作业
PADS20210412初级班
发表于 2021-5-6 16:27:26 | 显示全部楼层 |阅读模式
请指正,谢谢!
Reading file --  C:\PADS Projects\padsnet.asc
Part name already used U1
U1      VOLTREG1@1117
Part name already used U2
U2      STM32F103ZET6@TQFP144-B
Part name already used P2
P2      HEADER_30X2@60PIN
Part name already used X1
X1      MC306@SM8
Part name already used R16
R16     RES@R0603
Part name already used JP2
JP2     JUMPER3@SIP3
Part name already used R15
R15     RES@R0603
Part name already used R17
R17     RES@R0603
Part name already used CN1
CN1     DB9@DB9
Part name already used L1
L1      INDUCTOR@L0603
Part name already used LD2
LD2     LED2@D0603
Part name already used C25
C25     CAP@C0603
Part name already used U3
U3      ST3232@SOIC-16
Part name already used J2
J2      USB@USB_B
Part name already used J1
J1      HEADER_10X2@JTAG_20PIN
Part name already used P1
P1      HEADER_30X2@60PIN
Part name already used R23
R23     RES@R0603
Part name already used C26
C26     CAP@C0603
Part name already used JP3
JP3     JUMPER3@SIP3
Part name already used R11
R11     RES@R0603
Part name already used JP1
JP1     JUMPER3@SIP3
Part name already used X2
X2      CRYSTAL@SMD5032
Part name already used C24
C24     CAP@C0603
Part name already used R22
R22     RES@R0603
Part name already used C27
C27     CAP@C0603
Part name already used R21
R21     RES@R0603
Part name already used BT1
BT1     BATTERY@BAT
Part name already used R18
R18     RES@R0603
Part name already used R14
R14     RES@R0603
Part name already used S1
S1      SW-PB@SW35X6_25
Part name already used C28
C28     CAP@C0603
Part name already used R19
R19     RES@R0603
Part name already used R20
R20     RES@R0603
Part name already used C21
C21     CAP@C0603
Part name already used C22
C22     CAP@C0603
Part name already used C19
C19     CAP@C0603
Part name already used C20
C20     CAP@C0603
Part name already used C23
C23     CAP@C0603
Part name already used R12
R12     RES@R0603
Part name already used R13
R13     RES@R0603
Part name already used LD3
LD3     LED2@D0603
Part name already used R9
R9      RES@R0603
Part name already used R10
R10     RES@R0603
Part name already used R3
R3      RES@R0603
Part name already used R4
R4      RES@R0603
R1      RES@R0603
R2      RES@R0603
Part name already used R6
R6      RES@R0603
Part name already used R8
R8      RES@R0603
Part name already used R5
R5      RES@R0603
Part name already used LD1
LD1     LED2@D0603
Part name already used R7
R7      RES@R0603
C1      CAP_POL1@3528
Part name already used C3
C3      CAP@C0603
C2      CAP_POL1@3528
Part name already used C4
C4      CAP@C0603
Part name already used C5
C5      CAP@C0603
Part name already used C6
C6      CAP@C0603
Part name already used C7
C7      CAP@C0603
Part name already used C8
C8      CAP@C0603
Part name already used C9
C9      CAP@C0603
Part name already used C10
C10     CAP@C0603
Part name already used C11
C11     CAP@C0603
Part name already used C12
C12     CAP@C0603
Part name already used C13
C13     CAP@C0603
Part name already used C14
C14     CAP@C0603
Part name already used C15
C15     CAP@C0603
Part name already used C16
C16     CAP@C0603
Part name already used C17
C17     CAP@C0603
Part name already used C18
C18     CAP@C0603
Part name already used L2
L2      INDUCTOR@L0603
Part name already used L3
L3      INDUCTOR@L0603
Part name already used L4
L4      INDUCTOR@L0603
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal NETJP2_1
Warning: deleting signal NETJP2_1
**INPUT WARNINGS FOUND**
ntpcb_prj1.pcb
413 KB, 下载次数: 0, 下载积分: 金币 -1 枚
ntpcb_prj1.sch
170 KB, 下载次数: 0, 下载积分: 金币 -1 枚
PADS20210412初级班
 楼主| 发表于 2021-5-6 16:30:29 | 显示全部楼层
请指正,谢谢!
Reading file --  C:\\PADS Projects\\padsnet.asc
U1      VOLTREG1@1117
X1      MC306@SM8
R16     RES@R0603
JP2     JUMPER3@SIP3
R15     RES@R0603
R17     RES@R0603
CN1     DB9@DB9
L1      INDUCTOR@L0603
LD2     LED2@D0603
C25     CAP@C0603
U3      ST3232@SOIC-16
J2      USB@USB_B
R23     RES@R0603
C26     CAP@C0603
JP3     JUMPER3@SIP3
R11     RES@R0603
JP1     JUMPER3@SIP3
X2      CRYSTAL@SMD5032
C24     CAP@C0603
R22     RES@R0603
C27     CAP@C0603
R21     RES@R0603
BT1     BATTERY@BAT
R18     RES@R0603
R14     RES@R0603
S1      SW-PB@SW35X6_25
C28     CAP@C0603
R19     RES@R0603
R20     RES@R0603
C21     CAP@C0603
C22     CAP@C0603
C19     CAP@C0603
C20     CAP@C0603
C23     CAP@C0603
R12     RES@R0603
R13     RES@R0603
LD3     LED2@D0603
R9      RES@R0603
R10     RES@R0603
R3      RES@R0603
R4      RES@R0603
R1      RES@R0603
R2      RES@R0603
R6      RES@R0603
R8      RES@R0603
R5      RES@R0603
LD1     LED2@D0603
R7      RES@R0603
C1      CAP_POL1@3528
C3      CAP@C0603
C2      CAP_POL1@3528
C4      CAP@C0603
C5      CAP@C0603
C6      CAP@C0603
C7      CAP@C0603
C8      CAP@C0603
C9      CAP@C0603
C10     CAP@C0603
C11     CAP@C0603
C12     CAP@C0603
C13     CAP@C0603
C14     CAP@C0603
C15     CAP@C0603
C16     CAP@C0603
C17     CAP@C0603
C18     CAP@C0603
L2      INDUCTOR@L0603
L3      INDUCTOR@L0603
L4      INDUCTOR@L0603
Lib.zip
15 KB, 下载次数: 0, 下载积分: 金币 -1 枚
ntpcb_prj1.pcb
ntpcb_prj1.sch
