Name | Part Type | PCB Decal | Value | ANT1 | CON3P | ANT-BBAA | | ANT2 | VH_TP | BT_ANT | NC | ANT3 | VH_TP | BT_ANT | NC | CN1 | FPC_60 | 60PIN_0.5 | 60Pin/0.5下接 | CN6 | 5P | 5P2.0A | | CON4 | CON_32PIN | 32PIN-2.0MM-C2 | | D1 | VH-DIODE | LL-34 | NC | D2 | VH-DIODE | D4024-1 | IN4001 | D4 | VH-DIODE | VH-SOT-DL-SOD123 | 0R | D5 | ZD-7 | LL-34 | 21V | D6 | VH-DIODE | D4024-1 | IN4001 | D8 | VH-DIODE | LL-34 | LL4148 | D9 | ZD-7 | LL-34 | 7.5V | D10 | VH-DIODE | LL-34 | LL4148 | D13 | VH-DIODE1 | DIODE2-235ABA | IN5404 | D14 | VH-DIODE | LL-34 | LL4148 | D17 | VH-DIODE | LL-34 | LL4148 | D18 | VH-DIODE | LL-34 | LL4148 | D23 | VH-DIODE | VH-SOT-DL-SOD123 | 0R | D26 | VH-DIODE | LL-34 | LL4148 | D30 | VH-DIODE | LL-34 | LL4148 | D34 | VH-DIODE | LL-34 | LL4148 | EC7 | EC | AE5X5.4MM | 47U/16V | EC8 | EC | AE6.3X7.7MM | 100UF/25V | EC13 | EC | 13X | 2200UF/25V | FB3 | L0603 | L0603 | FB/60R/100MHz | FB4 | L0603 | L0603 | FB/60R/100MHz | FB5 | L0603 | L0603 | FB/60R/100MHz | FB6 | L0603 | L0603 | FB/60R/100MHz | FB7 | L0603 | L0603 | FB/60R/100MHz | GND6 | VH_TP | T-1.6 | NC | J1 | GPS_ANT | GPS_ANT | | J2 | ANT-2 | ANT-2 | | J3 | MODULE-80PIN | MODULE-DIP-80P | G99 | J4 | VH_TP | BT_ANT | NC | J5 | CON-20PIN | JACK-POW22PIN | CON-22PIN | J6 | VH-SDKARD | VH_TF_CAH11 | SMD TF,1.6MM | J7 | CON-66PIN | CONN-66PIN-1A | CON-66PIN | J8 | GPS_ANT | GPS_ANT | | J10 | VH_TP | PAD-2.8MM | NC | J15 | VH_TP | PAD-2.8MM | NC | J18 | VH_TP | PAD-2.8MM | NC | J19 | 10P/2.0 | CON-DIP10P-V-2.0-A | NC | J23 | VH_TP | PAD-2.8MM | NC | L1 | L0603 | B1206 | NC | L2 | L0603 | L0603 | 270NH | L3 | L0603 | L0603 | 820NH | L4 | L0603 | B1206 | 4.7uH | L7 | L0603 | L0603 | 270NH | L8 | L0603 | L0603 | 220NH | L10 | EI-15 | L/22X12B | 33uH | L11 | L0603 | B1206 | 4.7uH | L12 | L0603 | VH_L5X5 | 560uH | L20 | L0603 | L0603 | 820NH | M1 | VH_TP-11 | MAK | NC | M2 | VH_TP-11 | MAK | NC | MCU3V3 | VH_TP | T-1.6 | NC | Q1 | VH-TRANSISTOR | SOT-23 | 3904 | Q2 | VH-TRANSISTOR | SOT-23 | 8550 | Q3 | VH-TRANSISTOR | SOT-23 | 8550 | Q4 | VH-TRANSISTOR | SOT-23 | 3904 | Q5 | VH_TRAN-NPN | SOT-23 | 3904 | Q6 | VH-TRANSISTOR | SOT-23 | BAT54S | Q7 | VH_TRAN-NPN | SOT-23 | 3904 | Q8 | VH-TRANSISTOR | SOT-23 | 3904 | Q9 | VH-TRANSISTOR | SOT-23 | 8550 | Q10 | VH_TRAN-NPN | SOT-23 | 3904 | Q14 | VH_TRAN-NPN | SOT-23 | 3904 | Q15 | VH_TRAN-NPN | SOT-23 | 3904 | Q16 | VH_TRAN-NPN | SOT-23 | 3904 | Q17 | VH-TRANSISTOR | SOT-23 | 8550 | Q19 | VH-TRANSISTOR | SOT-23 | 3904 | Q20 | VH_FET | SOT-23 | AO3401A | Q21 | VH-TRANSISTOR | SOT-23 | 3904 | Q22 | VH_TRAN-NPN | SOT-23 | 3904 | Q30 | VH-TRANSISTOR | SOT-23 | 3904 | Q303 | VH-TRANSISTOR | SOT-23 | 3904 | Q305 | VH-TRANSISTOR | SOT-23 | 8550 | RDSET | VH_TP | T-1.6 | NC | S8 | SW4P | SW4 | | SWIM | VH_TP | T-1.6 | NC | U1 | IC-RT9058 | SOT-89 | HT-7533-1 | U3 | NXP665X | TEF665X | NXP6851 | U10 | LM3671MF_ADJ | SOP-5 | BL8568CB5ATR33 | U21 | TDA7383 | TDA7386/88AAAAAA | TDA7388 | U26 | 78MXX | 78MXX | 78M09 | U32 | LQFP48-8S005 | LQFP48 | STM8S005 | Y4 | CRYSTAL | CRY/SMTHC-49 | 4.000M |
