查看: 3165|回复: 20
[Allegro17.4以下] RK3128 挂MT29PZZZ8D5WKFMW +RTL8189ETV+ESP8089+DF1517 做的机顶盒PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2021-6-28 14:44:49 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    板子没完全画完,如上图。需要的下载。
    RK3128_LPDDR2.zip (692 KB, 下载次数: 18)
    7J1ANT-WIFI_J-MS-1566_ACA-5036-A3-CC-SACA-5036-A3-CC-SJ-MS-1566
    7J2ANT-WIFI_J-MS-1566_ACA-5036-A3-CC-SACA-5036-A3-CC-SJ-MS-1566
    CE2CD5.0/2.5_CD5_0_2_5_100UF/16V100uF/16VCD5_0_2_5
    CON18TMP_222058_SD_F03A_B8502A-13SB-HPA(T-FLASH CARD)B8502A-13SB-HPA(T-Flash Card)SD_F03A
    D1DIODE_2_SOD123_1N40071N4007SOD123
    D2DIODE_2_SOD123_1N40071N4007SOD123
    D3DIODE_SOD123_NC/1N5819NC/1N5819SOD123
    D4DIODE_SOD123_1N58191N5819SOD123
    D5BAT54S/SOT_0_SOT23_BAT54SBAT54SSOT23
    D6DIODE_3_SOT23_BAT54SBAT54SSOT23
    D7DIODEZENER13_0_SOD123_7V7VSOD123
    D8DIODEZENER13_0_SOD123_18V18VSOD123
    D9DIODE_3_SOT23_BAT54SBAT54SSOT23
    D10DIODE_4_SOD123_1N58191N5819SOD123
    ED1DIODEBI-DIR TRIG_E0402N_NC/ESD9B5VNC/ESD9B5VE0402N
    ED21DIODEBI-DIR TRIG_E0402N_NC/ESD9B5VNC/ESD9B5VE0402N
    F1FUSE_0_R0805_NCNCR0805
    FB2INDUCTOR_L0402_BLM18PG181SN1BLM18PG181SN1L0402
    FB3INDUCTOR_L0402_NCNCL0402
    FB5RES1B_0_R0402_22R22RR0402
    FB6RES1B_0_R0402_22R22RR0402
    FB7INDUCTOR_L0603_100MHZ/600R100MHZ/600RL0603
    FB8INDUCTOR_6_R0603_0R0RR0603
    IR1IR_RECEIVE_TO92ECB_IRM-3638IRM-3638TO92ECB
    J1CON4P_2_SMD_1B25_6P_NC/CON4PNC/CON4PSMD_1B25_6P
    J2DC_0_DC36-D_DC-208DC-208DC36-D
    J3XH-2-2_0_XH1-2-2_54_NC/XH-2-2_54NC/XH-2-2_54XH1-2-2_54
    J4CON_2_SMD-L-5_IRCONIRCONSMD-L-5
    J5CON_3_FPC-2-4_CON_2PINCON_2PINFPC-2-4
    J6FPC_3_SMD_1B25_10P_FPC_10FPC_10SMD_1B25_10P
    J8HDMI_A_3_HDMIA_HDMI_AHDMI_AHDMIA
    J9CON_3_FPC-2-4_CON_2PINCON_2PINFPC-2-4
    J10PJ-3537_1_PHONE_T1_PJ-3537PJ-3537PHONE_T1
    J11AVCONNECTOR_2_PHONE_T1_AV_CONNECTORAV_connectorPHONE_T1
    J12FPC_40PIN_3.5MM_CON30P_FPC_30PIN_0.5MMFPC_30PIN_0.5MMCON30P
    L1INDUCTOR_5_IND-4X4_1.0UH/2A1.0uH/2AIND-4X4
    L2INDUCTOR_4_PL_4X4_TYPE3_2.2UH2.2uHPL_4X4_TYPE3
    L3INDUCTOR_4_PL_4X4_TYPE3_2.2UH2.2uHPL_4X4_TYPE3
    L4INDUCTOR_4_PL_4X4_TYPE3_2.2UH2.2uHPL_4X4_TYPE3
    L5INDUCTOR_4_PL_4X4_TYPE3_2.2UH2.2uHPL_4X4_TYPE3
    L6INDUCTOR_5_IND-4X4_1.0UH/2A1.0uH/2AIND-4X4
    L7INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
    L8INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
    L9INDUCTOR_6_L0603_1.8UH1.8uHL0603
    L10INDUCTOR_6_L0603_1.0UH1.0uHL0603
    L11INDUCTOR_7_L4040_22UH22uHL4040
    L12L0402_1.2NH_ACX_C0402_NC/2N7HNC/2n7HC0402
    L13L0402_1.2NH_ACX_C0402_00C0402
    L14INDUCTOR_R0402_22NH22nHR0402
    L15INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
    Q140852_0_SOT23_80508050SOT23
    Q240852_0_SOT23_80508050SOT23
    Q340852_0_SOT23_80508050SOT23
    Q440852_0_SOT23_80508050SOT23
    Q5MOSFETP_SOT23_WPM2015/TCS1015WPM2015/TCS1015SOT23
    Q6FETN MOS_0_SOT23_WNM2021WNM2021SOT23
    Q7FETN MOS_0_SOT23_WNM2021WNM2021SOT23
    Q8MOSFETP_SOT23_TCS1025/AO3423TCS1025/AO3423SOT23
    R6135R_R_0402_0R0RR_0402
    SW1SW4P_1_SMT_TD_15EA_NC/RESETNC/RESETSMT_TD_15EA
    T1TEST_1_T-0_7_EFUSEeFUSET-0_7
    T2TEST_1_T-0_7_GNDGNDT-0_7
    U1RK3128_10_BGA316_14R00X14R00X1R20_RK3128_10RK3128_10BGA316_14R00X14R00X1R20
    U2DF1517_QFN28P1_R4_4X4_DF1517DF1517QFN28P1_R4_4X4
    U5DS8008_6_SOT25_ETA3409A/TCS4201/SY8089AAACETA3409A/TCS4201/SY8089AAACSOT25
    U10DS8008_4_SLP2510P8_NC/RCLAMP0524J/ESDA6V8UDNC/RClamp0524J/ESDA6V8UDSLP2510P8
    U11DS8008_5_SLP2510P8_NC/RCLAMP0524J/ESDA6V8UDNC/RClamp0524J/ESDA6V8UDSLP2510P8
    U12LM4990_3_SOP-8_80028002SOP-8
    U13RT9271_0_SOT23-6_LP3315/RT9284ALP3315/RT9284ASOT23-6
    U14MINIPCI-E_4_QFN-44P_NC/RTL8189ETVNC/RTL8189ETVQFN-44P
    U15ESP8089_0_QFN32-5X5MM_ESP8089ESP8089QFN32-5X5MM
    U16DS8008_6_SOT25_ETA3409A/TCS4201/SY8089AAACETA3409A/TCS4201/SY8089AAACSOT25
    U4701MT29PZZZ8D5WKFMW-18_5_BGA_162PIN_11_5_PITCH_PAD0_275_MT29PZZZ8D5WKFMW-18_1MT29PZZZ8D5WKFMW-18_1BGA_162PIN_11_5_PITCH_PAD0_275
    USB2JP_USB2_1.0_USB4P_USBDIP90CEUSBDIP90CEUSB4P
    Y1CRYSTAL-4_2_CRY-D3225_24M-20PPM24M-20ppmCRY-D3225
    Y2CRYSTAL-4_3_CRY-D3225_26MHZ-10PPM26MHz-10ppmCRY-D3225
    重要提示:PCB作品文件展下载说明
    发表于 2021-6-28 16:53:53 | 显示全部楼层
    这种板子没有画过,难画吗?
    发表于 2021-6-29 05:53:31 | 显示全部楼层
    发表于 2021-6-29 07:57:49 | 显示全部楼层
  • 签到天数: 7 天
    社区居民终身成就奖特殊贡献奖
    发表于 2021-6-29 07:57:55 | 显示全部楼层
    无聊
    5 天前
  • 签到天数: 68 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2021-6-29 08:36:18 | 显示全部楼层
    前天 08:44
  • 签到天数: 177 天
    发表于 2021-6-29 08:52:35 | 显示全部楼层
    前天 08:44
  • 签到天数: 177 天
    发表于 2021-6-29 08:53:26 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2021-6-29 08:54:42 | 显示全部楼层
    非常感谢楼主大神分享
    昨天 15:13
  • 签到天数: 216 天
    发表于 2021-6-29 09:20:59 | 显示全部楼层
