REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
CN3 | 3P_0_1MM25T-3A-8_5X3_7-SMD_3P | 3P | 1MM25T-3A-8_5X3_7-SMD |
CN4 | 4P_2_0MM_4P_2_0MM_4P_2_0MM | 4P_2_0MM | 4P_2_0MM |
D1 | DIODE_SOD323_SS14 | SS14 | SOD323 |
D6 | DIODEDOUBLE_SOT23_A_BAV70 | BAV70 | SOT23_A |
D7 | DIODE_SOD323_SS14 | SS14 | SOD323 |
ED35 | TVS_ESD0402_NC/ESD | NC/ESD | ESD0402 |
ED48 | DIODEBI-DIR TRIG_ESD0402_NC/AZ | NC/AZ5825-01F | ESD0402 |
HOLE1 | TESTPOINT1_0_3R5MM_HOLE | HOLE | 3R5MM |
HOLE2 | TESTPOINT1_0_3R5MM_HOLE | HOLE | 3R5MM |
HOLE3 | TESTPOINT1_0_3R5MM_HOLE | HOLE | 3R5MM |
HOLE4 | TESTPOINT1_0_3R5MM_HOLE | HOLE | 3R5MM |
J7 | HDMI_A_THR-HDMI-STD_HDMICON-SM | HDMICON-SMT | THR-HDMI-STD |
J14 | PJ-3536_0_PJ-342E_PJ342E | PJ342E | PJ-342E |
J92 | 5PIN2.0_PH-5AWD_5PIN2.0 | 5pin2.0 | PH-5AWD |
J93 | PJ-3536_0_PJ-342E_PJ342E | PJ342E | PJ-342E |
J94 | 30P_FPC30-0MM5-19_7X5_4_30P | 30P | FPC30-0MM5-19_7X5_4 |
L3 | INDUCTOR_SWPA6045S_6.8UH | 6.8uH | SWPA6045S |
L4 | INDUCTOR_SWPA6045S_2.2UH | 2.2uH | SWPA6045S |
L6 | INDUCTOR_SWPA6045S_6.8UH | 6.8uH | SWPA6045S |
LED1 | LED_C0603_LED | LED | C0603 |
LED2 | LED_C0603_LED | LED | C0603 |
Q2 | MOSFETP_SOT23_A_AP2305 | AP2305 | SOT23_A |
Q3 | 40852_1_SOT23_A_2N3904 | 2N3904 | SOT23_A |
Q7 | MOSFETP_SOT23_A_AP2305 | AP2305 | SOT23_A |
Q26 | NPN4_SOT23_A_8050 | 8050 | SOT23_A |
Q38 | NPN4_SOT23_A_8050 | 8050 | SOT23_A |
Q39 | NPN4_SOT23_A_8050 | 8050 | SOT23_A |
Q40 | NPN4_SOT23_A_8050 | 8050 | SOT23_A |
SW1 | 4P_1_SW8_4P_1 | 4P_1 | SW8 |
U1 | RT9266PE_2_SOT_23_6_SY8113B | SY8113B | SOT_23_6 |
U2 | SPI_FLASH_SMD_SOP8-1MM27-5_3X7_ | SPI_Flash_SMD | SOP8-1MM27-5_3X7_9 |
U3 | DCDC_SY8088_SOT_23_5_SY8089A | SY8089A | SOT_23_5 |
U4 | AP1117_SOT223_AP1117_TO263 | AP1117_TO263 | SOT223 |
U10 | RDA8503_131_DDR2_LQFP128_QFN128 | RDA8503_QPF128 | QFN128-0MM35-12_3X12_3-EP6X9_5 |
U21 | AP1117_SOT223_AP1117_TO263 | AP1117_TO263 | SOT223 |
U90015 | IR_RX_IR3-2MM54-V_IR_RX | IR_RX | IR3-2MM54-V |
U90016 | IR_RX_IR3-2MM54-V_IR_RX | IR_RX | IR3-2MM54-V |
U90017 | SOP16_SOP16-1MM27-10X6_2_SOP16 | SOP16 | SOP16-1MM27-10X6_2 |
U90018 | AP3032_SOT_23_6_AP3032 | AP3032 | SOT_23_6 |
USB3 | JP_USB2_2.0_USB2_0-4P-H-DXF_USB | USB-HOST | USB2_0-4P-H-DXF |
USB4 | JP_USB2_2.0_USB2_0-4P-H-DXF_USB | USB-HOST | USB2_0-4P-H-DXF |
Y4 | CRYSTAL_4P_CRY4_3R20X2R50X0R80_ | 24MHz | CRY4_3R20X2R50X0R80 |
