查看: 3281|回复: 27
[Allegro17.4以下] Intel_82574  Intel82574+IT8760E+ALC662+ISL95870BHRZ 做的底板PCB
此广告位出租
发表于 2021-12-17 22:22:32 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Intel82574.zip (2.29 MB, 下载次数: 12)
ANT1RF_0_MICROWAVE_CON_RFCONRFCONMICROWAVE_CON
AUDIO_J1HEADER2X5N9_4_DIP1X4P_2_54MM_1X1x4P,2.54pDIP1X4P_2_54MM
AUDIO_J2HEADER2X5N9_3_DIP1X4P_2_54MM_1X1x4P,2.54pDIP1X4P_2_54MM
BATT_CON1BAT_CON_0_WAFER_1_25MM_9P_H1_8_bat_9Pin_1.25p_conWAFER_1_25MM_9P_H1_8
CE6CE_C3528_100UF,6.3V100uF,6.3VC3528
CE7CE_C3528_100UF,6.3V100uF,6.3VC3528
CHK1LR4_0_L4_0805_90OHM,0.5A/X90ohm,0.5A/XL4_0805
CHK2LR4_0_L4_0805_90OHM,0.5A/X90ohm,0.5A/XL4_0805
CHK3LR4_0_L4_0805_90OHM,0.5A/X90ohm,0.5A/XL4_0805
CHK4LR4_0_L4_0805_90OHM,0.5A/X90ohm,0.5A/XL4_0805
CHK5SINGLE_CHOCK_0_L4_0805_90OHM,090ohm,0.5A/XL4_0805
CHK6SINGLE_CHOCK_0_L4_0805_90OHM,090ohm,0.5A/XL4_0805
CHK7SINGLE_CHOCK_0_L4_0805_90OHM,090ohm,0.5A/XL4_0805
CHK8SINGLE_CHOCK_0_L4_0805_90OHM,090ohm,0.5A/XL4_0805
CHK9SINGLE_CHOCK_0_L4_0805_90OHM,090ohm,0.5A/XL4_0805
CHR1LED_2_LED4_1206_LED/RED_GREENLED/red_greenLED4_1206
CN1MXM_FINGER_2_PCIE_MXM_3_MXM_FINMXM_FINGERPCIE_MXM_3
CN2DEBUG_6_WAFER_1_25MM_9P_H1_8_9P9pin_1_25p_h1.85waferWAFER_1_25MM_9P_H1_8
D9DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D10DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D11DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D12DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D14DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D16SCHOTTKY_SOD-123_1N5819HW1N5819HWSOD-123
D17IP4220CZ6_SOT23_6_AZC099-04S/XAZC099-04S/XSOT23_6
D18IP4220CZ6_SOT23_6_AZC099-04S/XAZC099-04S/XSOT23_6
D19IP4220CZ6_SOT23_6_AZC099-04S/XAZC099-04S/XSOT23_6
D32DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D34BAT54C_SOT_23A_BAT54CBAT54CSOT_23A
D35BAT54S_SOT_23A_BAT54SBAT54SSOT_23A
D37BAT54C_0_SOT_23A_BAT54CBAT54CSOT_23A
D38DIODE_1_SOD323_1N4148WS1N4148WSSOD323
D39BAT54C_0_SOT_23A_BAT54CBAT54CSOT_23A
D41DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D42DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D43DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D44DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D45DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D46DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D47DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D48DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D49DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D50DIODE_R0402_SESD0402E050M05/XSESD0402E050M05/XR0402
D137SCHOTTKY_SOD-123_1N5819HW1N5819HWSOD-123
DC_CON1DEBUG_2_WAFER_1_25MM_4P_H1_8_4P4pin_1_25p_h1.85waferWAFER_1_25MM_4P_H1_8
DEL_BTN1DEBUG_3_WAFER_CE_1_25MM_2P_H1_82pin_1_25p_h1.85waferWAFER_CE_1_25MM_2P_H1_8
EDP1C4K60_CE_12_I-PEX_20474-030E_I-I-PEX_20525-030E-02I-PEX_20474-030E
FB2FB0603_FB0603_120OHM,800MA120ohm,800mAFB0603
FB3FB0805_FB0603_120OHM,800MA120ohm,800mAFB0603
FB5FERRITEBEAD_FB0603_120OHM, 800120ohm,800mAFB0603
FB9FERRITEBEAD_0_FB0805_120OHM, 5120ohm,5AFB0805
FB10FERRITEBEAD_0_FB0805_120OHM, 5120ohm,5AFB0805
FB11FERRITEBEAD_FB0603_60OHM, 800M60ohm,800mAFB0603
FB12BEAD_FB0603_60OHM,800MA60ohm,800mAFB0603
FB15FERRITEBEAD_FB0603_120OHM, 800120ohm,800mAFB0603
FB16FERRITEBEAD_FB0603_120OHM, 800120ohm,800mAFB0603
FB53FB0805_FB0603_120OHM,800MA120ohm,800mAFB0603
FB75FERRITEBEAD_FB0603_120OHM, 800120ohm,800mAFB0603
HDMI1HDMI_F_19P_SMT_2_HDMI_SMD_CHENBHDMI_F_19P_SMTHDMI_SMD_CHENBAN_H1_7
IOU1H16101ME_8_TR_24PIN_11X15_H4_0_COTOP_C2402NSTR_24PIN_11X15_H4_0
LED1SMD_LED_LED2_0603_GREEN_LEDGREEN_LEDLED2_0603
LED2SMD_LED_LED2_0603_BLUE_LEDBLUE_LEDLED2_0603
LED3SMD_LED_LED2_0603_RED_LEDRED_LEDLED2_0603
LED4SMD_LED_LED2_0603_GREEN_LEDGREEN_LEDLED2_0603
LRJ1DEBUG_7_WAFER_1_25MM_8P_H1_8_8P8pin_1_25p_h1.85waferWAFER_1_25MM_8P_H1_8
MIC1DEBUG_3_WAFER_CE_1_25MM_2P_H1_82pin_1_25p_h1.85waferWAFER_CE_1_25MM_2P_H1_8
MPCIE_SSD1ST_PCIE_2_MINI_PCIE_H5_2_PCIEMPCIEMINI CARD H5.2MINI_PCIE_H5_2
MPCIE_WIFI1ST_PCIE_1_MINI_PCIE_H5_2_PCIEMPCIEMINI CARD H5.2MINI_PCIE_H5_2
PD2DIODE_2_SOD323_1N4148WS1N4148WSSOD323
PD7DIODESCHOTTKY_1_TO-277A_SS5P4SS5P4TO-277A
PD8DIODESCHOTTKY_1_TO-277A_SS5P4SS5P4TO-277A
PL2INDUCTOR_8_SP07B03_4.7UH,4.5A4.7UH,4.5ASP07B03
PL4INDUCTOR_8_SP07B03_4.7UH,4.5A4.7UH,4.5ASP07B03
PL5INDUCTOR_12_SP07B03_10UH,3.6A10UH,3.6ASP07B03
PL6INDUCTOR_8_SP07B03_4.7UH,4.5A,4.7UH,4.5A, TMPC0603H-4R7MG-DSP07B03
PPZ1ZENZE_0_SOD323_BZT52C5V6SBZT52C5V6SSOD323
PPZ2ZENZE_0_SOD323_BZT52C3V6SBZT52C3V6SSOD323
PPZ3ZENZE_0_SOD323_BZT52C3V6SBZT52C3V6SSOD323
PPZ4ZENZE_0_SOD323_BZT52C3V6SBZT52C3V6SSOD323
PQ12N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ22N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ32N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ42N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ52N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ62N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ72N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PQ8NTMD4840_SO8_50_150_AO4822AO4822SO8_50_150
PQ92N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
PS1MINI-FUSE_L1812_FUSE_3A/XFUSE_3A/XL1812
PS2MINI-FUSE_L1812_FUSE_3A/XFUSE_3A/XL1812
PS3MINI-FUSE_L1812_FUSE_3A/XFUSE_3A/XL1812
PS4MINI-FUSE_L1812_FUSE_3A/XFUSE_3A/XL1812
PU1RT9173_0_IC8_SO_RT9045ART9045AIC8_SO
Q8FET_PMOS_8P/1_SO8_50_150_AO4435AO4435SO8_50_150
Q9FET_PMOS_8P/1_SO8_50_150_AO4435AO4435SO8_50_150
Q102N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
Q112N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
Q122N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
Q152N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
Q162N7002_SOT23-3_AP2305NAP2305NSOT23-3
Q172N7002_SOT23-3_AP2305NAP2305NSOT23-3
Q182N7002_SOT23-3_L2N7002KLT1GL2N7002KLT1GSOT23-3
Q19NTMD4840_SO8_50_150_AO4822AO4822SO8_50_150
Q20NTMD4840_SO8_50_150_AO4822AO4822SO8_50_150
Q21TRAN_N23_1_SOT223_4P_BCP69T1BCP69T1SOT223_4P
Q22NTMD4840_SO8_50_150_AO4822AO4822SO8_50_150
Q117MOSN252_9_ULTRA_SO8_3P_AON6718LAON6718LULTRA_SO8_3P
Q118MOSN252_9_ULTRA_SO8_3P_AON6414AAON6414AULTRA_SO8_3P
RA2R_R0402_20K,5%20K,5%R0402
RTCBAT1WAFER1X2_CNS2_R_2P,1.25MM, SMT2P,1.25mm, SMTli, H4.5CNS2_R
RTCBAT2WAFER1X2_CNS2_R_2P,1.25MM, SMT2P,1.25mm, SMTli, H4.5CNS2_R
SPK_L1DEBUG_3_WAFER_CE_1_25MM_2P_H1_82pin_1_25p_h1.85waferWAFER_CE_1_25MM_2P_H1_8
SPK_R1DEBUG_3_WAFER_CE_1_25MM_2P_H1_82pin_1_25p_h1.85waferWAFER_CE_1_25MM_2P_H1_8
SSD_H1HOLE_1_LZ_SSD_H1SSD_H1LZ
U1WPCE775_0_QFP128-16-550X550X63_NPCE985LQFP128-16-550X550X63
U2W25Q80AVSIG_SOP8-50-208X85_W25QW25Q80AVSIGSOP8-50-208X85
U3MAX3232_2_SOIC16-D_MAX3232CDMAX3232CDSOIC16-D
U4IT7271_LQFP-48_0_LQFP48_ITE_IT8ITE_IT8760ELQFP48
U5GA8403_SOP-16_GA8403GA8403SOP-16
U7MAX3232_2_SOIC16-D_MAX3232CDMAX3232CDSOIC16-D
U8ISL95870B_0_QFN20LD_ISL95870BHRISL95870BHRZQFN20LD
U9ISL95870B_0_QFN20LD_ISL95870BHRISL95870BHRZQFN20LD
U10ISL6251HRZ_3_SSOP24-25-150X70_IISL6251HAZSSOP24-25-150X70
U11GPS_N303_GPS_N303_GPS_N303GPS_N303GPS_N303
U19RL5877_2_QFN_64_9_9_10_INTEL_82Intel_82574  Intel82574QFN_64_9_9_10
U20W25P80VSSIG_5_SO8_50_150_W25X10W25X10BVSSIG/XSO8_50_150
U21LM3150_0_TSSOP14_H1_0_LM3150MHLM3150MHTSSOP14_H1_0
U22ISL95870B_3_SOT89-3_HT7550/BL85HT7550/BL8551-50PSMSOT89-3
UA1ALC880_0_QFP_48S_ALC662VDALC662VDQFP_48S
USB3_1DEBUG_8_WAFER_1_25MM_10P_H1_8_110pin_1_25p_h1.85waferWAFER_1_25MM_10P_H1_8
USB1JBG110740001_4_USB3_US3A_FSS2_0US3A-FSS2-001USB3_US3A_FSS2_001
USB2DEBUG_10_WAFER_1_25MM_8P_H1_8_88pin_1_25p_h1.85waferWAFER_1_25MM_8P_H1_8
USB3DEBUG_2_WAFER_1_25MM_4P_H1_8_4P4pin_1_25p_h1.85waferWAFER_1_25MM_4P_H1_8
USB_CON1CN4_0_FPC_1_00MM_4P_4P,1.0MM4P,1.0mmFPC_1_00MM_4P
WIFI_H1HOLE_1_LZ_WIFI_H1WIFI_H1LZ
Y3XTAL_ELLIP_2_SMD_4PIN32X25X07_225MHzSMD_4PIN32X25X07
重要提示:PCB作品文件展下载说明
此广告位出租
    发表于 2021-12-18 00:06:06 | 显示全部楼层
    发表于 2021-12-18 00:33:10 | 显示全部楼层
  • 签到天数: 103 天
    7万
    发表于 2021-12-18 06:14:42 | 显示全部楼层
    发表于 2021-12-18 08:35:49 | 显示全部楼层
    4 小时前
  • 签到天数: 133 天
    1元学习Allegro(1期)
    发表于 2021-12-18 08:44:38 | 显示全部楼层
    昨天 08:47
  • 签到天数: 89 天
    发表于 2021-12-18 08:52:12 | 显示全部楼层
  • 签到天数: 7 天
    社区居民终身成就奖特殊贡献奖
    发表于 2021-12-18 08:54:58 | 显示全部楼层
    发表于 2021-12-18 10:15:14 | 显示全部楼层
    昨天 08:34
  • 签到天数: 69 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2021-12-18 11:01:30 | 显示全部楼层
