REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | DIODE_SOD-523_1SS400 | 1SS400 | SOD-523 |
D2 | DIODEDIAC_SOD-323_TVS-BV05C | TVS-BV05C | SOD-323 |
D51 | DIODEBREAKDOWN_0_SMA_P4SMAJ18C | P4SMAJ18CA | SMA |
D52 | DIODEDIAC_SOD-323_TVS-BV05C | TVS-BV05C | SOD-323 |
F1 | FUSE/SM_F1812_SMD1812P200TS | SMD1812P200TS | F1812 |
J1 | CON2_HDR200M-1X2_CON2 | CON2 | HDR200M-1X2 |
J5 | AUDIO_0_HPJACK-5P_PJ-325C | PJ-325C | HPJACK-5P |
J6 | CON24A_HDR200M-2X12_HDR-F2.0MM | HDR-F2.0mm2*12 | HDR200M-2X12 |
J7 | CON20A_HDR200F-2X10_HDR-M2.0MM | HDR-M2.0mm2*10 | HDR200F-2X10 |
J8 | HR911103A_2_HR911105A_HR911105A | HR911105A | HR911105A |
J9 | HDMI_0_HDMI0119-20-RM-A_HDMI-00 | HDMI-005 | HDMI0119-20-RM-A |
J10 | CON50_0_FPC-50P-P5M_CONLCD | CONLCD | FPC-50P-P5M |
J11 | CON50A_HDR200F-2X25_HDR-M2.0MM | HDR-M2.0mm2*25 | HDR200F-2X25 |
J12 | SDCARD_R5190010_0_SD_CARD_SOCKE | KMSD18-B0 | SD_CARD_SOCKET-11P |
J13 | SDMINI_0_TF-SOCKET-9P-EXT_IO_KM | KMTFA-EXT0X | TF-SOCKET-9P-EXT |
J16 | USB_A_DUAL_1_USBA-8P-DUALL-14M_ | USBAF-90 | USBA-8P-DUALL-14M |
J17 | USB_A_DUAL_1_USBA-8P-DUALL-14M_ | USBAF-90 | USBA-8P-DUALL-14M |
J18 | USB_A_USBA-4P-URD-14M_USB_A | USB_A | USBA-4P-URD-14M |
J19 | USB_MINI_AB_RECEPTACLE_2_MINIUS | MiniUSB AB 5 | MINIUSB5P-0P8MM |
J20 | CON20A_HDR200F-2X10_HDR-F2.0MM | HDR-F2.0mm2*10 | HDR200F-2X10 |
J21 | DB-HDR11-15FG_0_DB-15-VGA_DB-15 | DB-15Y-09 | DB-15-VGA |
J22 | CONNJACK PWR_1_DC-JACK-5P5_DIS | DC-005-2.0 | DC-JACK-5P5 |
J29 | DDR3-FINGER_0_SODIMM-204-0P6_SO | SODIMM-204 | SODIMM-204-0P6 |
L4 | INDUCTOR_LSMD7X7_GCDA0724-6R8M | GCDA0724-6R8M | LSMD7X7 |
L5 | INDUCTOR_LSMD5X5_GCDA0420-2R2M | GCDA0420-2R2M | LSMD5X5 |
MK1 | MICROPHONE_MIC-2-4MM_4015 | 4015 | MIC-2-4MM |
Q1 | NPNBEC_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
Q2 | MOSFET_EN_DIODE_0_SOT-23_SI2312 | Si2312CDS | SOT-23 |
S1 | SW3P_SW-3P-2P5_SS-12F23 | SS-12F23 | SW-3P-2P5 |
SW6 | KEY4PIN_0_TDHP08-4P_THDP08 | THDP08 | TDHP08-4P |
SW7 | SWDIP-6_0_SMT-HP-SW-6_DHN-06F- | DHN-06F-T-V | SMT-HP-SW-6 |
TP16 | TP_0_TP200D100_TP | TP | TP200D100 |
U2 | WM8960GEFL_1_QFN32-5X5-0P5_WM89 | WM8960GEFL | QFN32-5X5-0P5 |
U3 | RT9011-MGPJ6_SOT-23-6_RT9011-MG | RT9011-MGPJ6 | SOT-23-6 |
U4 | DM9000_LQFP48N50P9X9_DM9000AEP | DM9000AEP | LQFP48N50P9X9 |
U5 | ESDA6V8UD_0_DFN-10-2P5X1_ESDA6V | ESDA6V8UD | DFN-10-2P5X1 |
U6 | ESDA6V8UD_0_DFN-10-2P5X1_ESDA6V | ESDA6V8UD | DFN-10-2P5X1 |
U7 | FE1_0_SSOP-28-P64-6X10_FE1_1S | FE1_1S | SSOP-28-P64-6X10 |
U8 | ADM3202_6_SOIC16-10X4-1P27_MAX3 | MAX3232CDR | SOIC16-10X4-1P27 |
U9 | ADM3202_6_SOIC16-10X4-1P27_MAX3 | MAX3232CDR | SOIC16-10X4-1P27 |
U10 | SDA7123_0_LQFP48N50P9X9_SDA7123 | SDA7123 | LQFP48N50P9X9 |
U11 | SN74LVC2T45_TSSOP-8-DCU_SN74LVC | SN74LVC2T45DCUR | TSSOP-8-DCU |
U12 | RT8282_0_SOP-8-1P2-ETP_RT8292BH | RT8292BHZSP | SOP-8-1P2-ETP |
U13 | RT8015_SOP-8-1P27_RT8015GSP | RT8015GSP | SOP-8-1P27 |
U14 | AT88SC0104CA_0_SOP-8-1P27_AT88S | AT88SC0104CA | SOP-8-1P27 |
X1 | CRYSTAL_SM_OSC5032-2P_25MHZ | 25MHz | OSC5032-2P |
X2 | CRYSTAL_SM_OSC5032-2P_12MHZ | 12MHz | OSC5032-2P |
