REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
CN1 | BATT_CONN_3PIN_1_VT-SWITCH_SKHH | SKHHLUA010 | VT-SWITCH |
CN2 | CON_USB_7P_SOCKET2_0_HY07-AB070 | HY07-AB0700 | HY07-AB0700-A1 |
D1 | LEDA_4PIN_LED0605_BL-HJEGKBE36T | BL-HJEGKBE36T-TRB | LED0605 |
D1101 | WSB5819W-2TR_WSB5819_WSB5819 | WSB5819 | WSB5819 |
D1102 | WSB5819W-2TR_WSB5819_SS34 | SS34 | WSB5819 |
ESD1 | DIODETVS BI-DIR_SLP1006P2_PESD | PESD5V0S1BLD | SLP1006P2 |
J2 | HYX-TF008011019_0_SD_473521001_ | 473521001 | SD_473521001 |
J7 | 5_2.0QHD_LCM_FH26-25S-0_3SHW_5. | 5.0QHD_LCM | FH26-25S-0_3SHW |
J8 | 5_0.0QGD_TP_CONN_ZIF_6P_05MM_DO | 5.0QGD_TP | CONN_ZIF_6P_05MM_DOWN |
J1202 | PJ-393_PJ-393_PJ-393 | PJ-393 | PJ-393 |
J1203 | BT032Q-034BP_FH26-45S-0_3SHW_BT | BT032Q-034BP(NC) | FH26-45S-0_3SHW |
J1204 | XRM144A2315_XRM144A2315_XRM144A | XRM144A2315(NC) | XRM144A2315 |
J1205 | RGB/MCU_2MM_25X2_RGB/MCUPIN | RGB/MCUPIN | 2MM_25X2 |
JF001 | CON,RF,C89P109-1000X-H_5_RF_CAB | C89P109-1000X-H | RF_CABLE_CON_2M0X1M7_C89P109 |
LP1101 | INDUCTOR_POWER_LPS3015_22UH | 22uH | LPS3015 |
MIC1 | MICROPHONE_2_MICROPHONE_BOM6015 | BOM6015EP1.8-G423-RC-R6818 | MICROPHONE |
P2 | ENS000046760_GPSWIFI_ANT_ENS000 | ENS000046760 | GPSWIFI_ANT |
P5 | CAM_CM9080_LED_AXE624124_CAM_CM | CAM_CM9080 | AXE624124 |
P7 | POWER_DC-005-5_5X2_POWER | power | DC-005-5_5X2 |
P8 | P3_DIP-3_P3 | P3 | DIP-3 |
P9 | MIPI_2MM_15X2_MIPIPIN | MIPIPIN | 2MM_15X2 |
P10 | P4_DIP-4_I2C | I2C | DIP-4 |
REC502 | REC/ 2403 260 00031 _CON2_3M5X | RECEIVER | CON2_3M5X7M5_3M94 |
RF1 | GPS_ANT_U_FL-R-SMT-1_GPS_ANT | GPS_ANT | U_FL-R-SMT-1 |
SH1 | SHUNT_R0402_SHUNT_L4-SIG_PWR_P4 | SHUNT_L4-SIG_PWR_P4XP6 | R0402 |
SPK501 | MIC_1_DF13C-2P-1P25V_DF13C-2P-1 | DF13C-2P-1.25V | DF13C-2P-1P25V |
U1112 | CP2123ST-A1_SOT-23-6_CP2123ST-A | CP2123ST-A1 | SOT-23-6 |
U1508 | G9091-330T11U_SOT-23-5_G9091-33 | G9091-330T11U | SOT-23-5 |
U2107 | MT6572-DOU-DEV_MT72_MODULE_SMT_ | MT6572-DOU-DEV | MT72_MODULE_SMT_DOU |
U2108 | AW8110CSR_BGA9_1M5X1M5_P05M_AW8 | AW8110CSR(NC) | BGA9_1M5X1M5_P05M |
U2109 | SIM_2_TSP-6P-18T_TSP-6P-18T | TSP-6P-18T | TSP-6P-18T |
U2111 | MAX2659_UDFN6_1M5X1_P05M_MAX265 | MAX2659ELT+ | UDFN6_1M5X1_P05M |
U2113 | KXTE9-1050_LGA10_3X3M_P065M_KXT | KXTE9-1050 | LGA10_3X3M_P065M |
U2114 | SIM_2_TSP-6P-18T_TSP-6P-18T | TSP-6P-18T | TSP-6P-18T |
U2115 | RCLAMP0504FA_RCLAMP0504FA_RCLAM | rclamp0504fa | RCLAMP0504FA |
U2117 | MIC29302BU_TO-220_MIC29302BU | MIC29302BU | TO-220 |
U2118 | SMF05C_SMF05C_SMF05C | SMF05C | SMF05C |
U2119 | SMF05C_SMF05C_SMF05C | SMF05C | SMF05C |
U2120 | LT0308H111_LT0308H111_LT0308H11 | LT0308H111 | LT0308H111 |
U2121 | NL27WZ07_07_TSOP-6_NL27WZ07_07 | NL27WZ07_07 | TSOP-6 |
U2122 | NL27WZ07_07_TSOP-6_NL27WZ07_07 | NL27WZ07_07 | TSOP-6 |
U2123 | CH1002_SOT23-6_CH1002 | CH1002 | SOT23-6 |
UE001 | IC-ECOMPASS-AK8963C_BGA14_1M6X1 | AK8963C | BGA14_1M6X1M6_P04M |
UE002 | IC-PROLIGHT SENSOR-STK3171-018 | STK3171-018 | DFN8_3M94X2M36_P097M |
V9003 | VDR0402 14V 10PF +/-30%_3_R040 | SDV1005H140C100NPTF | R0402 |
Z1 | MOTO_3P_CE_RENESAS_VIB_ALT_GS-3 | GS-3200 | CE_RENESAS_VIB_ALT |
Z2 | SAWA_5PIN_1A4B235G_RFSAW_5P_1M4 | SAFEB1G57KE0F00 | RFSAW_5P_1M4X1M1_P05M |
