TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
GC-VC1A-ETHX-B_TMP2_16_2.rar
(2.48 MB, 下载次数: 11)
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | SYM_NAME | D15 | DS-SOD323A1D1 | BV03C | GBLC05C | DS-SOD323A1D1 | D16 | SMC | S3M | MBRS3100T3 | SMC | D17 | SMA | 60V | | SMA | D18 | SOT-23A | BZX84C3V3 | | SOT-23A | F1 | F1206 | Fuse | | F1206 | F2 | F3812 | Fuse | | F3812 | FB1 | L0603 | 600ohm | 600ohm | L0603 | GDT1 | GDT3-7D6X5X5D9 | B3D420L | | GDT3-7D6X5X5D9 | GDT2 | GDT-4532A29 | BA091N | | GDT-4532A29 | GDT18 | GDT_B | BF091M | | GDT_B | H1 | H3X6D5 | HOLDDNE | | H3X6D5 | H2 | H3X6D5 | HOLDDNE | | H3X6D5 | ICT6 | FID-120 | ICT_DNE | ICT_DNE | FID-120 | J1 | SCONN5X2 | Header_5X2 | | SCONN5X2 | J2 | SCONN7X2 | Header_7X2_DNE | | SCONN7X2 | J3 | BNC2-2D54H1A16D13 | BNC_DNE | | BNC2-2D54H1A16D13 | J4 | CON004H2X2-5D08X7D62A13 | TerminalBlock | TerminalBlock | CON004H2X2-5D08X7D62A13 | J5 | SW10-H2D54LCA10D1 | DA-05-V | | SW10-H2D54LCA10D1 | J6 | CONN2X2 | Header_2X2_DNE | | CONN2X2 | J7 | RJ45-4X8PLED_A | RJ45_3012D40111 | | RJ45-4X8PLED_A | J8 | DDR3-204P-9D2HA-CONN | CON204_DDR3-SODIMM-STD-9.2H | | DDR3-204P-9D2HA-CONN | J10 | CONN4X2 | CONN2X4P | | CONN4X2 | J12 | CONN4X2 | CONN2X4P | | CONN4X2 | J13 | CONN3X2 | CONN2X3P | | CONN3X2 | J15 | CON004H2X2-5D08X7D62A13 | TerminalBlock | TerminalBlock | CON004H2X2-5D08X7D62A13 | J16 | CONN2X2 | Header_2X2_DNE | | CONN2X2 | J17 | CONN2X1 | Header_2p_DNE | | CONN2X1 | J18 | CONN5X2 | CONN2X5P_DNE | | CONN5X2 | L1 | L0603 | 0 | 600ohm | L0603 | L2 | L1210 | 390uH | 10nH | L1210 | L3 | L1210 | 560nH | 10nH | L1210 | L4 | L1210 | 150nH | 10nH | L1210 | L9 | CHOKE-VERT4P_F | 20mH | | CHOKE-VERT4P_F | L11 | INDUCTOR-HOR2PS_I | 3.3uH | | INDUCTOR-HOR2PS_I | L12 | L1210 | 10nH | 10nH | L1210 | L13 | INDUCTOR-HOR2PS_J | 4.7uH | 4.7uH | INDUCTOR-HOR2PS_J | L14 | INDUCTOR-HOR2PS_J | 4.7uH | 4.7uH | INDUCTOR-HOR2PS_J | L15 | L1210 | 15nH | 10nH | L1210 | L16 | CHOKE-HOR2PS_I | 33uH | | CHOKE-HOR2PS_I | L18 | LK-04E6X16H21R19A12D5 | 11mH | | LK-04E6X16H21R19A12D5 | L19 | INDUCTOR-HOR2PS_J | 4.7uH_DNE | 4.7uH | INDUCTOR-HOR2PS_J | L20 | CMS04-2D8X1D15A2 | CHOKE_1000_ohm_DNE | | CMS04-2D8X1D15A2 | L21 | CMS04-2D8X1D15A2 | CHOKE_1000_ohm_DNE | | CMS04-2D8X1D15A2 | L22 | CMS04-2D8X1D15A2 | CHOKE_1000_ohm_DNE | | CMS04-2D8X1D15A2 | L23 | CMS04-2D8X1D15A2 | CHOKE_1000_ohm_DNE | | CMS04-2D8X1D15A2 | L25 | CHOKE-HOR2PS_I | 33uH | | CHOKE-HOR2PS_I | L71 | CHOKE5_S | UT21301V-TS_DNE | | CHOKE5_S | LD1 | LED-HOR3PS_A | LED_SMD | | LED-HOR3PS_A | LD2 | LED-HOR3PS_A | LED_SMD | | LED-HOR3PS_A | LD3 | LED-BR | LED_R_G_SMD | | LED-BR | Q1 | SOT-23C | IRLML5203_DNE | | SOT-23C | Q3 | SOT-23B | 2N3904_DNE | | SOT-23B | RV1 | RV-7X5D6P5X2D5A10 | V82ZA05P_DNE | | RV-7X5D6P5X2D5A10 | RV9 | MOV2P_B | V150ZA4P | | MOV2P_B | S1 | SW04-H4D5X7X2D5A7D2 | Push_BUTTON | | SW04-H4D5X7X2D5A7D2 | T1 | XFMR8PS_C | LAL1217-59 | | XFMR8PS_C | T2 | XFMR16PS_A | POE_XFMR | | XFMR16PS_A | T3 | XFMR16PS_A | POE_XFMR | | XFMR16PS_A | T4 | XFMR16PS_A | POE_XFMR | | XFMR16PS_A | T5 | XFMR16PS_A | POE_XFMR | | XFMR16PS_A | T6 | TFS10-17D5X13D5A12D5 | UT20A71S_DNE | | TFS10-17D5X13D5A12D5 | TP_1P2V | SIP1A | TestPoint DNE | | SIP1A | TP_2P5V | SIP1A | TestPoint DNE | | SIP1A | TP_3P3V | SIP1A | TestPoint DNE | | SIP1A | TP_5V | SIP1A | TestPoint DNE | | SIP1A | TP_48V | SIP1A | TestPoint DNE | | SIP1A | TVS1 | SMC_A | SMDJ60CA | | SMC_A | U1 | PSOP5 | 74LVC1G04_DNE | 74LVC1G04_DNE | PSOP5 | U3 | SO08E127RS240A2D16 | MX25L4006EM2I-12G | | SO08E127RS240A2D16 | U5 | LQFP128E0D4S14A1D6 | MT2301 | | LQFP128E0D4S14A1D6 | U7 | QFN064E0D5S09A0D8HS | MT3301_30A | | QFN064E0D5S09A0D8HS | U8 | SO14_240 | 74HC08 | | SO14_240 | U9 | SSOP5 | G661L293T11U | AND | SSOP5 | U10 | SSOP5 | AND | AND | SSOP5 | U11 | SO8 | LM75_S | LM75_S | SO8 | U12 | PSOP5 | 74LVC1G04 | 74LVC1G04_DNE | PSOP5 | U13 | PSOP5 | NAND2 | 74LVC1G04_DNE | PSOP5 | U14 | QFP176E0D4S20A1D2HS | AR8328N | | QFP176E0D4S20A1D2HS | U15 | SO8 | AT93C66A_DNE | LM75_S | SO8 | U16 | LQFN16 | RT8058GQW | | LQFN16 | U17 | DFN12 | RT8020GQW | | DFN12 | U18 | SOT-143 | SR3.3 | | SOT-143 | U19 | SO8 | SRDA3.3-4 | LM75_S | SO8 | U20 | MSOP10 | TPS54260DGQ | | MSOP10 | U21 | LQFP048E0D5S07A1D6 | M058/M0516LANLQFP48 | | LQFP048E0D5S07A1D6 | U22 | PSOP5 | 74LVC1G04 | 74LVC1G04_DNE | PSOP5 | U23 | PSOP5 | 74LVC1G04 | 74LVC1G04_DNE | PSOP5 | X1 | OSCS2D5X2D0A0D6 | 25MHz | | OSCS2D5X2D0A0D6 | X2 | OSCS2D5X2D0A0D6 | 25MHz | | OSCS2D5X2D0A0D6 | Y1 | XTAL7 | 35.328MHz | | XTAL7 |
