查看: 1262|回复: 7
[Allegro17.4以下] SAK-TC234L-32F200N+TLF35584QKVS2 做的一个底板PCB文件共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-2-20 19:57:26 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    CDCU-1011-0918.zip (6.31 MB, 下载次数: 0)
    CR1LED_LED_SMD_0603_ST_LEDLEDLED_SMD_0603_ST
    CR2LED_LED_SMD_0603_ST_LEDLEDLED_SMD_0603_ST
    CR5LED_LED_SMD_0402_ST_LEDLEDLED_SMD_0402_ST
    CR6LED_LED_SMD_0402_ST_LEDLEDLED_SMD_0402_ST
    CR501D_3PIN_CC#1_SOT323_D_3PIN_CCD_3PIN_CCSOT323
    D1D_SCHOTTKY_3PIN_AA_DIODE_SMD_TOD_SCHOTTKY_3PIN_AADIODE_SMD_TO277A
    D2D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D3D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D4D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D5D_3PIN_CC_SOT323_D_3PIN_CCD_3PIN_CCSOT323
    D6D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D7D_3PIN_AA_SOT23_D_3PIN_AAD_3PIN_AASOT23
    D8D_ESD_DIFFPAIR#1_TSLP10_P050_02D_ESD_DIFFPAIR#1TSLP10_P050_025X010
    D9D_ESD_DIFFPAIR#1_TSLP10_P050_02D_ESD_DIFFPAIR#1TSLP10_P050_025X010
    D10D_ESD_DIFFPAIR#1_TSLP10_P050_02D_ESD_DIFFPAIR#1TSLP10_P050_025X010
    D11D_ESD_DIODE_SMD_025X013_D_ESDD_ESDDIODE_SMD_025X013
    D13D_ZENER_SOT23_D_ZENERD_ZENERSOT23
    D14D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D15D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D16D_SCHOTTKY_DIODE_SMD_SOD523_B_DD_SCHOTTKYDIODE_SMD_SOD523_B
    D17D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
    D18D_3PIN_CC_SOT323_D_3PIN_CCD_3PIN_CCSOT323
    D19D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D20D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D21D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D22D_ESD#3_SOT553_D_ESDD_ESDSOT553
    D23D_ESD#3_SOT553_D_ESDD_ESDSOT553
    D24D_ESD#3_SOT553_D_ESDD_ESDSOT553
    D25D_ESD#3_SOT553_D_ESDD_ESDSOT553
    D26D_ESD#3_SOT553_D_ESDD_ESDSOT553
    D27D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D28D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D29D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D30D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D31D_SCHOTTKY#1_DIODE_SMD_SOD523_BD_SCHOTTKYDIODE_SMD_SOD523_B
    D32D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D33D_ESD#1_DIODE_SMD_SOD923_D_ESDD_ESDDIODE_SMD_SOD923
    D35D_ESD#2_DFN18_P050_055X015_3XT0D_ESDDFN18_P050_055X015_3XT006X005
    D36D_SOT323_DDSOT323
    D37D#1_SOT323_DDSOT323
    D504D_ESD_DIFFPAIR#1_TSLP10_P050_02D_ESD_DIFFPAIR#1TSLP10_P050_025X010
    D505D_ESD_DIFFPAIR#1_TSLP10_P050_02D_ESD_DIFFPAIR#1TSLP10_P050_025X010
    D506D_ESD_DIFFPAIR_SOT23_6_D_ESD_DID_ESD_DIFFPAIRSOT23_6
    D507D_ESD_DIFFPAIR_SOT23_6_D_ESD_DID_ESD_DIFFPAIRSOT23_6
    DS1LED_LED_SMD_0402_ST_LEDLEDLED_SMD_0402_ST
    F1R_1206_0OHM_0.05OHM0ohm1206
    F2R_1206_0OHM_0.05OHM0ohm1206
    F3R_1206_0OHM_0.05OHM0ohm1206
    F4R_1206_0OHM_0.05OHM0ohm1206
    F5R_1206_0OHM_0.05OHM0ohm1206
    J1CON_SATA_CON_SATA_022_SMT_RA_F_CON_SATACON_SATA_022_SMT_RA_F_P013_C
    J2CON_PCI_EXPRESS_CON_PEX_064_SMTCON_PCI_EXPRESSCON_PEX_064_SMT_ST
    J4HDR_1X2_CON_HDR_001X002_TH_ST_MHDR_1X2CON_HDR_001X002_TH_ST_M_P025
    J5CON_RJ45_CON_MJ08_012_TH_RA_2LECON_RJ45CON_MJ08_012_TH_RA_2LED
    J7HDR_2X10_HDR_002X010_TH_ST_M_P0HDR_2X10HDR_002X010_TH_ST_M_P025
    J8HDR_1X2_CON_HDR_001X002_TH_ST_MHDR_1X2CON_HDR_001X002_TH_ST_M_P025
    J10CON_B2B_60_CON_QSH_060_SMT_ST_PCON_B2B_60CON_QSH_060_SMT_ST_P005
    J12CON_SD_SOCKET_CON_SD_012_SMD_RACON_SD_SOCKETCON_SD_012_SMD_RA
    J13CON_B2B_400_CON_FMC_050X008_BGACON_B2B_400CON_FMC_050X008_BGA_ST_M_P013
    J14HDR_2X7_CON_FTSH_002X007_SMD_STHDR_2X7CON_FTSH_002X007_SMD_ST_M_P013
    J15CON_B2W_1X4_CON_MISC_004_TH_ST_CON_B2W_1X4CON_MISC_004_TH_ST_M_P013_WTB
    J16CON_HDMI_CON_HDMI_019_SMD_RA_F_CON_HDMICON_HDMI_019_SMD_RA_F_C
    J17HDR_1X6_CON_HDR_001X006_TH_ST_MHDR_1X6CON_HDR_001X006_TH_ST_M_P025
    J19CON_USB3_CON_USB_009_TH_RA_138XCON_USB3CON_USB_009_TH_RA_138X165
    J20HDR_1X10#1_CON_HDR_001X010_TH_SHDR_1X10CON_HDR_001X010_TH_ST_M_P025
    J21HDR_2X20_CON_TSM_002X020_SMD_STHDR_2X20CON_TSM_002X020_SMD_ST_M_P025
    J24HDR_1X3_CON_HDR_001X003_TH_ST_MHDR_1X3CON_HDR_001X003_TH_ST_M_P025_C
    J26HDR_2X15_CON_HDR_002X015_TH_ST_HDR_2X15CON_HDR_002X015_TH_ST_M_P025
    J28CON_USB_CON_USB_011_SMD_RA_088XCON_USBCON_USB_011_SMD_RA_088X058
    L1L_CMF_4P_IND_NONRKO_SMD_012X01090ohmIND_NONRKO_SMD_012X010
    L2L#1_IND_NONRKO_SMD_076X076_2.2U2.2uHIND_NONRKO_SMD_076X076
    L3L_CMF_4P_IND_NONRKO_SMD_012X01090ohmIND_NONRKO_SMD_012X010
    L4L_CMF_4P_IND_NONRKO_SMD_012X01090ohmIND_NONRKO_SMD_012X010
    L5L_CMF_4P#2_IND_NONRKO_SMD_012X090ohmIND_NONRKO_SMD_012X010
    L6L_IND_NONRKO_SMD_044X041_1UH_201uHIND_NONRKO_SMD_044X041
    L7L_IND_NONRKO_SMD_073X066_1UH_201uHIND_NONRKO_SMD_073X066
    L8L_IND_NONRKO_SMD_065X069_2.2UH_2.2uHIND_NONRKO_SMD_065X069
    L9L_IND_NONRKO_SMD_078X072_2.2UH_2.2uHIND_NONRKO_SMD_078X072
    L10L_CMF_4P#2_IND_NONRKO_SMD_012X090ohmIND_NONRKO_SMD_012X010
    L11L_CMF_4P#1_IND_NONRKO_SMD_012X080ohmIND_NONRKO_SMD_012X010_B
    L12L_CMF_4P#1_IND_NONRKO_SMD_012X080ohmIND_NONRKO_SMD_012X010_B
    L13L_CMF_4P_IND_NONRKO_SMD_012X01090ohmIND_NONRKO_SMD_012X010
    L15L_IND_NONRKO_SMD_088X084_1UH_201uHIND_NONRKO_SMD_088X084
    L16L_IND_NONRKO_SMD_073X066_1UH_201uHIND_NONRKO_SMD_073X066
    L501L_CMF_4P_IND_NONRKO_SMD_012X0_112ohmIND_NONRKO_SMD_012X010
    L502L_IND_SMD_0402_1NH_30%1nHIND_SMD_0402
    L503L_CMF_4P_IND_NONRKO_SMD_012X0_112ohmIND_NONRKO_SMD_012X010
    L504L_CMF_4P_IND_NONRKO_SMD_012X0_112ohmIND_NONRKO_SMD_012X010
    L505L_IND_SMD_0402_1NH_30%1nHIND_SMD_0402
    L506L_CMF_4P_IND_NONRKO_SMD_012X0_112ohmIND_NONRKO_SMD_012X010
    LB1L_IND_SMD_0402_600OHM_25%600ohmIND_SMD_0402
    MD1DIODE_SDO_219_MSS2P2MSS2P2SDO_219
    MD2LED_S0603_LED_BLUEBlueS0603_LED
    MD4LED_S0603_LED_GREEGreeS0603_LED
    MD7DIODE_SSOD_123_1N4148W_HE3_081N4148W_HE3_08SSOD_123
    MEC1MOUNTING_HOLE#1_MTH_MB_C300NP15MOUNTING_HOLEMTH_MB_C300NP156_NEW
    MEC2MOUNTING_HOLE#1_MTH_MB_C300NP15MOUNTING_HOLEMTH_MB_C300NP156_NEW
    MEC14MOUNTING_HOLE#1_MTH_MB_C300NP15MOUNTING_HOLEMTH_MB_C300NP156_NEW
    MEC17MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC18MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC19MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC20MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC21MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC22MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC23MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MEC24MEC_STANDOFF2_MEC_HOLE_PEM_NTH_MEC_STANDOFF2MEC_HOLE_PEM_NTH_430P
    MIR1R_0603_1K/400MA@100M1K/400mA@100M603
    MIR2R_0603_1K/400MA@100M1K/400mA@100M603
    MJ1CONNRCPT 5X2_RCPT_5X2_CONN RCPCONNRCPT 5x2RCPT_5X2
    MJ4CON40A_0_SI40P_PLUG_SCSI40P-PLUSCSI40P-plugSI40P_PLUG
    MJ5121P_3_JACK_121_121P121PJACK_121
    MJ6CON40A_2_SI40P_PLUG_SCSI40P-PLUSCSI40P-plugSI40P_PLUG
    ML1INDUCTORFERRITE_IND7R5_7R5_4.74.7uH/1722IND7R5_7R5
    MP1TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MP2TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MP3TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MP4TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MP5TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MP6TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MT1TESTPOINT_LTPT28C49P_TEST POINTESTPOINTLTPT28C49P
    MU1SAK-TC234L-32F200NAC_QFP40P180SAK-TC234L-32F200NACQFP40P1800X1800X120-145N-3
    MU2TLF35584QKVS2_QFP50P1200X1200X1TLF35584QKVS2QFP50P1200X1200X160-65N-0
    MU3TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MU4TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MU5TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MU6TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MU7TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MU8TLE9251VSJ_SSOP_8_TLE9251VSJTLE9251VSJSSOP_8
    MX1ZTA_Y50_3R2_8M/10PPM8M/10PPMY50_3R2
    Q1Q_FET_P_ENH#1_DFET_SMD_032X033_Q_FET_P_ENHDFET_SMD_032X033
    Q2Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q3Q_FET_P_ENH#1_DFET_SMD_032X033_Q_FET_P_ENHDFET_SMD_032X033
    Q4Q_FET_N_ENH#3_MULTI_SMD_SOT669_Q_FET_N_ENHMULTI_SMD_SOT669_LFPAK_B
    Q5Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q6Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q7Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q8Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q9Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q10Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q11Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q12Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q13Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
    Q14Q_PNP_SOT23_Q_PNPQ_PNPSOT23
    Q15Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q16Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q17Q_FET_N_ENH_SOT23_6_Q_FET_N_ENHQ_FET_N_ENHSOT23_6
    Q18Q_NPN_SOT23_Q_NPNQ_NPNSOT23
    Q19Q_FET_P_ENH#1_DFET_SMD_032X033_Q_FET_P_ENHDFET_SMD_032X033
    Q20Q_FET_P_ENH_SOT23_Q_FET_P_ENHQ_FET_P_ENHSOT23
    Q21Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q22Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q23Q_FET_N_ENH#4_DFET_SMD_056X052_Q_FET_N_ENHDFET_SMD_056X052_VIAS
    Q24Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q25Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q26Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q27Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q28Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q29Q_FET_N_ENH#4_DFET_SMD_056X052_Q_FET_N_ENHDFET_SMD_056X052_VIAS
    Q30Q_FET_P_ENH#1_DFET_SMD_032X033_Q_FET_P_ENHDFET_SMD_032X033
    Q31Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
    Q32Q_NPN_SOT23_Q_NPNQ_NPNSOT23
    Q33Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q34Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q35Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q36Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
    Q37Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q38Q_FET_N_ENH_SOT23_6_Q_FET_N_ENHQ_FET_N_ENHSOT23_6
    Q501Q_FET_N_ENH_SOT23_6_Q_FET_N_ENHQ_FET_N_ENHSOT23_6
    Q502Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
    Q503Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q505Q_FET_N_ENH#2_DFET_003_SMD_010XQ_FET_N_ENHDFET_003_SMD_010X006_B
    Q506Q_FET_N_ENH#1_SC70_6_Q_FET_N_ENQ_FET_N_ENHSC70_6
    Q507Q_NPN_DFET_003_SMD_010X006_B_Q_Q_NPNDFET_003_SMD_010X006_B
    Q508Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
    Q509Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
    RS1R_SENSE_1206_0.007OHM_1%0.007ohm1206
    S1SW_SPST_PB_SW_04_SMD_ST_1XONOFFSW_SPST_PBSW_04_SMD_ST_1XONOFF_072X040
    S2SW_SPST_PB_SW_04_SMD_ST_1XONOFFSW_SPST_PBSW_04_SMD_ST_1XONOFF_072X040
    S3SW_SPST_PB_SW_04_SMD_ST_1XONOFFSW_SPST_PBSW_04_SMD_ST_1XONOFF_072X040
    S4SW_SPST_PB_SW_04_SMD_ST_1XONOFFSW_SPST_PBSW_04_SMD_ST_1XONOFF_072X040
    T1TR_ENET_MAGCOM_XFMR_SMD_24_151X1:01XFMR_SMD_24_151X071
    TP2LABTESTPOINT#1_LTPT35C49P_LABTELABTESTPOINTLTPT35C49P
    U1U_BUF_OD#1_SC70_5_U_BUF_ODU_BUF_ODSC70_5
    U2U_BUF_OD_SC70_6_U_BUF_ODU_BUF_ODSC70_6
    U3U_BUF_OD_SC70_6_U_BUF_ODU_BUF_ODSC70_6
    U4U_DCDC_BOOST_LM3481_XSOP10_P0501.275VXSOP10_P050_030X030
    U5U_LEVSHFT_3STATE_XSOP08_P065_03U_LEVSHFT_3STATEXSOP08_P065_030X028
    U6U_LEVSHFT_3STATE_XSOP08_P065_03U_LEVSHFT_3STATEXSOP08_P065_030X028
    U7U_LEVSHFT_TXB0108_QFN020R_P050_U_LEVSHFT_TXB0108QFN020R_P050_VIAS
    U8U_SW_ANA_SPDT_BGA_0010_P050_013U_SW_ANA_SPDTBGA_0010_P050_013X020_MARK_A3
    U9U_OPENVREG_TYPE0_DFN10_P050_VIA0.8VDFN10_P050_VIAS
    U10U_PWRMTR_INA3221_1_QFN016Q_P065U_PWRMTR_INA3221QFN016Q_P065_0047_T022X022
    U11U_MEM_EE_I2C_DFN08_P050_030X020U_MEM_EE_I2CDFN08_P050_030X020_T016X016
    U12U_LEVSHFT_3STATE_XSOP08_P065_03U_LEVSHFT_3STATEXSOP08_P065_030X028
    U14U_LEVSHFT_3STATE_XSOP08_P065_03U_LEVSHFT_3STATEXSOP08_P065_030X028
    U16U_SWREG_TPS53015_XSOP10_P050_030.773VXSOP10_P050_030X030
    U18U_PWRMTR_INA3221_QFN016Q_P065_0U_PWRMTR_INA3221QFN016Q_P065_0047_T022X022
    U21U_POWER_SW_SOT23_5_U_POWER_SWU_POWER_SWSOT23_5
    U22U_LEVSHFT_TXB0108_QFN020R_P050_U_LEVSHFT_TXB0108QFN020R_P050_VIAS
    U25U_POWER_SW_SOT23_5_U_POWER_SWU_POWER_SWSOT23_5
    U28U_I2C_EXP_TCA9539_XSOP24_P065_0U_I2C_EXP_TCA9539XSOP24_P065_079X045
    U29U_I2C_EXP_TCA9539_XSOP24_P065_0U_I2C_EXP_TCA9539XSOP24_P065_079X045
    U30U_I2C_PCA9515A_XSOP08_P065_030XU_I2C_PCA9515AXSOP08_P065_030X030
    U31U_SWREG_TPS53015_XSOP10_P050_030.773VXSOP10_P050_030X030
    U32U_RST_TPS3808_SOT23_6_U_RST_TPSU_RST_TPS3808SOT23_6
    U40U_NOR_2IN_SC70_5_U_NOR_2INU_NOR_2INSC70_5
    U41U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
    U42U_FLIPFLOP_D_DFN08_P050_020X010U_FLIPFLOP_DDFN08_P050_020X010
    U43U_NAND_2IN_SC70_5_U_NAND_2INU_NAND_2INSC70_5
    U44U_XOR_2IN_SC70_5_U_XOR_2INU_XOR_2INSC70_5
    U45U_NOT_SC70_5_U_NOTU_NOTSC70_5
    U46U_NOT_SC70_5_U_NOTU_NOTSC70_5
    U48U_OR_2IN_SC70_5_U_OR_2INU_OR_2INSC70_5
    U49U_OR_2IN_SC70_5_U_OR_2INU_OR_2INSC70_5
    U52U_VREG_TPS7A16X_SON08_030X030_T1.2VSON08_030X030_T025X017
    U53U_PB_SRC0XXX_DFN12_P050_030X020U_PB_SRC0XXXDFN12_P050_030X020
    U57U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
    U502U_POWER_SW#2_DFN06_P065_020X020U_POWER_SWDFN06_P065_020X020_T016X010
    U503U_POWER_SW#1_SOT23_5_U_POWER_SWU_POWER_SWSOT23_5
    XR1R_603_1K1K603
    重要提示:PCB作品文件展下载说明
    3 天前
  • 签到天数: 108 天
    发表于 2022-2-20 20:14:37 | 显示全部楼层
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2022-2-21 06:26:54 | 显示全部楼层
    5 天前
  • 签到天数: 126 天
    你必须非常努力才能显
    发表于 2022-2-21 08:57:54 | 显示全部楼层
    5 天前
    发表于 2022-2-21 09:00:10 | 显示全部楼层
    发表于 2022-2-21 09:24:54 | 显示全部楼层
    发表于 2022-2-22 09:09:12 | 显示全部楼层
    3 天前
  • 签到天数: 168 天
    发表于 2022-2-24 08:29:22 | 显示全部楼层
