REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
CN1 | XH-3_XH-3_XH-2_5-3P-WHITE | XH-2_5-3P-White | XH-3 |
CN2 | VH-3-2_VH-3-2_VH-2 | VH-2 | VH-3-2 |
CN3 | XH-8_XH-8_XH-2_5-8P-WHITE | XH-2_5-8P-White | XH-8 |
CN4 | PH-13_PH-13_PH-2_0-13P-WHITE | PH-2_0-13P-White | PH-13 |
CN5 | PH-4_PH-4_PH-2_0-4P-WHITE | PH-2_0-4P-White | PH-4 |
CN6 | PH-5_PH-5_PH-2_0-5P-WHITE | PH-2_0-5P-White | PH-5 |
CON1 | PH-6_PH-6_PH2.0-6P_WHITE_STAND | PH2.0-6P_white_stand | PH-6 |
CX1 | X104_X2-224_0.22UF/275V | 0.22uf/275V | X2-224 |
CY3 | Y222_X1-Y1_222/400V | 222/400V | X1-Y1 |
D1 | DO-35_DO-35_9.1V/1/2W_DO-35 | 9.1v/1/2W_DO-35 | DO-35 |
D2 | SOD-80_DO-35_3.3V/1/2W_DO-35/FM | 3.3V/1/2W_DO-35/FM | DO-35 |
D3 | DO-41_DO-41_1N4007_DO-41 | 1N4007_DO-41 | DO-41 |
D4 | DO-41_DO-41_1N4007_DO-41 | 1N4007_DO-41 | DO-41 |
D5 | DO-27_DO-27_HER303_DO-27 | HER303_DO-27 | DO-27 |
D6 | DO-41_DO-41_FR104_DO-41 | FR104_DO-41 | DO-41 |
D7 | DO-41_DO-41_1N4007_DO-41 | 1N4007_DO-41 | DO-41 |
D8 | DO-41_DOL-41_FR107_DO-41 | FR107_DO-41 | DOL-41 |
D9 | DO-41_DO-41_FR104_DO-41 | FR104_DO-41 | DO-41 |
D10 | DO-41_DO-41_FR104_DO-41 | FR104_DO-41 | DO-41 |
D11 | DO-41_DO-41_1N4007_DO-41 | 1N4007_DO-41 | DO-41 |
D12 | DO-27_DO-27_IN5822_DO-27 | IN5822_DO-27 | DO-27 |
D13 | DO-41_DO-41_1N4007_DO-41 | 1N4007_DO-41 | DO-41 |
DW1 | DO-35_DO-35_22V/1/2W_DO-35 | 22V/1/2w_DO-35 | DO-35 |
DW2 | DO-35_DO-35_5.1V/1/2W_DO-35/NC | 5.1V/1/2w_DO-35/NC | DO-35 |
E1 | CD11-8_E5_100UF/16V(5X11MM) | 100uF/16V(5x11mm) | E5 |
E2 | CD11-5_E5_100UF/16V(5X11MM) | 100uF/16V(5x11mm) | E5 |
E3 | CD11-5_E5_2.2UF/50V_K | 2.2uF/50V_K | E5 |
E16 | CD11-5_E5_100U/10V(5X11MM)/TV | 100U/10V(5X11MM)/TV | E5 |
E17 | E8_E8_470UF/16V_M(8X12MM) | 470uF/16V_M(8x12mm) | E8 |
E18 | E8_E8_470UF/16V_M(8X12MM) | 470uF/16V_M(8x12mm) | E8 |
E19 | E_E5_100UF/16V_M(5X11MM)/1517 | 100uF/16V_M(5x11mm)/1517 | E5 |
E20 | E5_E5_10UF/50V_M(5X11MM)/1517 | 10uF/50V_M(5x11mm)/1517 | E5 |
E21 | E6_E6_100UF/25V_M(6X12MM) | 100uF/25V_M(6x12mm) | E6 |
E22 | CD11-16_E16_47UF/400V | 47uF/400V | E16 |
E23 | E10_E10_470UF/25V_M(10X14MM) | 470uF/25V_M(10x14mm) | E10 |
E24 | E6_E6_220UF/16V_M(6X12MM) | 220uF/16V_M(6x12mm) | E6 |
E25 | E8_E8_1000UF/16V_M(8X14MM) | 1000uF/16V_M(8x14mm) | E8 |
E26 | E10_E10_NC | NC | E10 |
E27 | E6_E6_220UF/16V_M(6X12MM) | 220uF/16V_M(6x12mm) | E6 |
E28 | E8_E8_1000UF/16V_M(8X14MM) | 1000uF/16V_M(8x14mm) | E8 |
E29 | E10_E10_NC | NC | E10 |
E30 | E8_E8_1000UF/16V_M(8X14MM) | 1000uF/16V_M(8x14mm) | E8 |
E31 | E5_E5_47UF/50V_M(5X11MM) | 47uF/50V_M(5x11mm) | E5 |
E32 | E5_E5_47UF/16V_M(5X11MM) | 47uF/16V_M(5x11mm) | E5 |
F1 | F3-10_F3-10_T1AL250V | T1AL250v | F3-10 |
JK1 | WP4-3_WP4-3_WP4-3 | WP4-3 | WP4-3 |
JK2 | WP2-16A_WP2-16A_WP2-16A/FM | WP2-16A/FM | WP2-16A |
JK4 | AV4-8_4-13_AV4-8_4-13_AV4-8_4-1 | AV4-8_4-13/OUT | AV4-8_4-13 |
L1 | L0603_L0603_56NH@800MHZ/DCR<1R/ | 56nH@800MHz/DCR<1R/Q>8/FM | L0603 |
L2 | DR6-8_DR6-8_10UH/2A_DR6X8 | 10uH/2A_DR6x8 | DR6-8 |
NTC1 | R8_R8_22D-7 | 22D-7 | R8 |
Q1 | S8050-TO92_TO-92_S8050_TO92 | S8050_TO92 | TO-92 |
Q2 | S8050-TO92_TO-92_S8050_TO92 | S8050_TO92 | TO-92 |
Q3 | S8550_TO92_TO-92_S8550_TO92/TV | S8550_TO92/TV | TO-92 |
Q4 | B772_TO126_TO-126_B772_TO126/DV | B772_TO126/DVD | TO-126 |
Q5 | S8550_TO92_TO-92_S8550_TO92/FM | S8550_TO92/FM | TO-92 |
Q6 | S8050-TO92_TO-92_S8050_TO92/TV | S8050_TO92/TV | TO-92 |
Q7 | S8050-TO92_TO-92_S8050_TO92/DVD | S8050_TO92/DVD | TO-92 |
Q8 | S8050-TO92_TO-92_S8050_TO92/FM | S8050_TO92/FM | TO-92 |
S1 | S15-25_S15-25_S15-25 | S15-25 | S15-25 |
SW1 | VH-3-2_VH-3-2_VH-2 | VH-2 | VH-3-2 |
T1 | EE25-5-7_EE25-5-8_EE25-5-7 | EE25-5-7 | EE25-5-8 |
T2 | UU9_8_UU9_8_UU9.8/40MH | UU9.8/40mH | UU9_8 |
TV1 | CDT-6EPN_CDT-6EPN_CDT-6EPN/TV | CDT-6EPN/TV | CDT-6EPN |
U1 | PT2314_SOP-28_SM9614_SOP-28 | SM9614_SOP-28 | SOP-28 |
U2 | SP3769F_SOIC-16_SP3769F_SOP-16/ | SP3769F_SOP-16/FM | SOIC-16 |
U3 | TDA1517P_DIP-18_TDA1517P_DIP-18 | TDA1517P_DIP-18 | DIP-18 |
U4 | LP2550_TO-220_LP2550_TO220 | LP2550_TO220 | TO-220 |
U5 | PC817_DIP-4_BPC817C | BPC817C | DIP-4 |
U6 | AZ431_TO-92_AZ431 | AZ431 | TO-92 |
Y1 | 6K6_6K6_32.768KHZ/FM | 32.768KHz/FM | 6K6 |
