查看: 976|回复: 7
[Allegro17.4以下] DP83848KSQ+USB2517i  做的一个板子PCB文件共享
此广告位出租
发表于 2022-3-6 12:39:31 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
J2005_P2_01.01A.zip (902 KB, 下载次数: 8)
B1F0401_3.6V,1.2AH,1/2AA_BAT_24MMF0401(3.6V,1.2AH,1/2AA)BAT_24MM5X14MM5_26MM
BZ1TMB12A05_BZ_12MM_7MM6_TMB12A05TMB12A05BZ_12MM_7MM6
D1LED_IR_6MM_2MM54_LEDLEDIR_6MM_2MM54
D2LED_D_A_LED_1206_4_LED_D_ALED_D_ALED_1206_4
D3LED_D_A_LED_1206_4_LED_D_ALED_D_ALED_1206_4
D4ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D5ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D6ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D7ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D8ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D9BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D10ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D11ESD0532_Q_SOT23_ESD0532ESD0532Q_SOT23
D12TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D13TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D14LED_LED_1206_LEDLEDLED_1206
D15LED_LED_1206_LEDLEDLED_1206
D16LED_LED_1206_LEDLEDLED_1206
D17LED_D_A_LED_1206_4_LED_D_ALED_D_ALED_1206_4
D18LED_D_A_LED_1206_4_LED_D_ALED_D_ALED_1206_4
D19BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D20BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D21BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D22BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D23BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D24TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D25BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D26M7_D_DO_214AC_M7M7D_DO_214AC
D27TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D28BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D29BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D30BAV70_U_SOT23_3_BAV70BAV70U_SOT23_3
D31M7_D_DO_214AC_M7M7D_DO_214AC
D32TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D33M7_D_DO_214AC_M7M7D_DO_214AC
D34TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D35BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D36BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D37M7_D_DO_214AC_M7M7D_DO_214AC
D38BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D39TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D40BAT54WSL9_D_SOD_323_BAT54WSL9BAT54WSL9D_SOD_323
D41SS34_D_DO_214AC_SS34SS34D_DO_214AC
D42M7_D_DO_214AC_M7M7D_DO_214AC
D43TVS_D_DO_214AA_SMBJ6.0CASMBJ6.0CAD_DO_214AA
D44SS24_D_DO_214AC_SS24SS24D_DO_214AC
D45LED_LED_1206_LEDLEDLED_1206
D46LED_LED_1206_LEDLEDLED_1206
D47TVS_D_DO_214AA_SMBJ10CASMBJ10CAD_DO_214AA
D48TVS_D_DO_214AA_SMBJ10CASMBJ10CAD_DO_214AA
D49TVS_D_DO_214AA_SMBJ10CASMBJ10CAD_DO_214AA
E1LTV-816S-TAI-D-CU_U_SOP4_9MM_2MLTV-816S-TAI-D-CUU_SOP4_9MM_2MM54
J1USB-AF_USB_A_H_USB-AFUSB-AFUSB_A_H
J2RJ45_LED_CN_RJ45_RJ45_LEDRJ45_LEDCN_RJ45
J3USB-AF_USB_A_H_USB-AFUSB-AFUSB_A_H
J4CON30A_CN_2X15A_CON30ACON30ACN_2X15A
J5JUMP_JP_1X2_6MM_JUMPJUMPJP_1X2_6MM
J6JUMP_JP_1X2_6MM_JUMPJUMPJP_1X2_6MM
J7CON26A_CN_2X13_22_CON26ACON26ACN_2X13_22
J8JUMP_JP_0805_JUMPJUMPJP_0805
J9USB-AF_USB_A_V_USB-AFUSB-AFUSB_A_V
J10PS/2_CN_MDC_6_04_PS/2PS/2CN_MDC_6_04
J11CON2_CN_1X2_CON2CON2CN_1X2
J12CON2_CN_1X2_CON2CON2CN_1X2
J13CON2_CN_1X2_CON2CON2CN_1X2
J14CON3_CN_1X3_3_CON 3CON3CN_1X3_3
J15CON1_TE_THRU_1MM2_0MM8_CON1CON1TE_THRU_1MM2_0MM8
J16CON1_TE_THRU_1MM2_0MM8_CON1CON1TE_THRU_1MM2_0MM8
J17CON4_CN_1X4_CON 4CON4CN_1X4
J18CON10_CN_1X10_10_CON10CON10CN_1X10_10
J19CON18A_CN_2X9_14_CON18ACON18ACN_2X9_14
J20CON4_CN_1X4_CON 4CON4CN_1X4
J21CON2_CN_5624_2HX_CON2CON2CN_5624_2HX
J22JUMP_JP_0805_JUMPJUMPJP_0805
J23CON4_JW_1X4_CON 4CON4JW_1X4
J24CON20_8_CN_2X10_8_CON20_8CON20_8CN_2X10_8
L2L_R0805_SMB0805-601MSMB0805-601MR0805
L3L_R0805_SMB0805-601MSMB0805-601MR0805
L4L_R0805_SMB0805-601MSMB0805-601MR0805
L5SFT1206-900P_L_SFT1206_SFT1206-SFT1206-900PL_SFT1206
L6L_L_SHP0603_INDINDL_SHP0603
L7L_L_SNR2015_SNR2015-2R2NSNR2015-2R2NL_SNR2015
Q1PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q2NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q3NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q4NPN_Q_SOT23_NPNNPNQ_SOT23
Q5NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q6NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q7PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q8NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q9NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q10NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q11NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q12MOSFETP_Q_SOT23_DTS2301SDTS2301SQ_SOT23
Q13PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q14NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q15PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q16PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q17PNP_Q_SOT23_BC807-40LT1(5C)BC807-40LT1(5C)Q_SOT23
Q18NPN_Q_SOT23_NPNNPNQ_SOT23
Q19NPN_Q_SOT23_BC817-40LT1(6C)BC817-40LT1(6C)Q_SOT23
Q20NPN_Q_SOT23_NPNNPNQ_SOT23
RP1FUSE_R1206_FUSEFUSER1206
RP2RP_R_15MMX5MM5_21MM_RESRESR_15MMX5MM5_21MM
RP3RP_R_10MMX4MM_15MM_RESRESR_10MMX4MM_15MM
RT1PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT2PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT3PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT4PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT5PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT6PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT7PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT8PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT9PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
RT10PTC_RT_10MM5X5MM_5MM_<VALUE><Value>RT_10MM5X5MM_5MM
S1S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
S2S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
S3S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
S4S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
S5S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
S6S_TACT_SOP-4_4P_ST-L6W6H5-BK_SWRESETSW_DP4_6MMX6MM
T1FC1008CLE_U_SOP16_9MM_1MM27_FC1FC1008CLEU_SOP16_9MM_1MM27
U1IRCS_IR_6MMX7MM_2MM54_<VALUE><Value>IR_6MMX7MM_2MM54
U2HYG160160A4G-VB_CN_FPC_9_1MM_HYHYG160160A4G-VBCN_FPC_9_1MM
U3USB2517I_U_QFN64_9MM_0MM5_USB25USB2517iU_QFN64_9MM_0MM5
U4SP2526A-2EN-L_U_SOP8_6MM_1MM27_SP2526A-2EN-LU_SOP8_6MM_1MM27
U5DP83848KSQ_1_U_QFN40_5MM8_0MM5_DP83848KSQU_QFN40_5MM8_0MM5
U6SPX3819_U_SOT23_5_SPX3819-M5-L-SPX3819-M5-L-3-3U_SOT23_5
U7SPX29302_U_TO263_5_SPX29302SPX29302U_TO263_5
U8DP83848KSQ_1_U_QFN40_5MM8_0MM5_DP83848KSQU_QFN40_5MM8_0MM5
U9SP2323EEN_U_SOP16_6MM_1MM27_SP2SP2323EENU_SOP16_6MM_1MM27
U10AZRS485_1_U_SOP8_6MM_1MM27_AZRSAZRS485U_SOP8_6MM_1MM27
U11CON_CORE_9_CN_CORE_CON_CORECON_CORECN_CORE
U12AZRS485_1_U_SOP8_6MM_1MM27_AZRSAZRS485U_SOP8_6MM_1MM27
U13YH148_U_SOT23_3_YH148YH148U_SOT23_3
U14YH148_U_SOT23_3_YH148YH148U_SOT23_3
U15YH148_U_SOT23_3_YH148YH148U_SOT23_3
U16AZRS485_1_U_SOP8_6MM_1MM27_AZRSAZRS485U_SOP8_6MM_1MM27
U17RX8025T_U_SOP14_6MM_1MM27_RX802RX8025TU_SOP14_6MM_1MM27
U18L78L05_U_TO_92_L78L05L78L05U_TO_92
U19MP9943_U_QFN_8_MP9943MP9943U_QFN_8
U20HT7133-3_U_SOT_89_HT7133-3HT7133-3U_SOT_89
U21BL8028_U_SOT23_5_BL8028BL8028U_SOT23_5
U22SGM324SY14_U_SOP14_6MM_1MM27_SGSGM324SY14U_SOP14_6MM_1MM27
U23ESAM_U_SOP8_6MM_1MM27_ESAMESAMU_SOP8_6MM_1MM27
U24L78L05_U_TO_92_L78L05L78L05U_TO_92
U25SPX29302_U_TO263_5_SPX29302SPX29302U_TO263_5
U26SPX3819_U_SOT23_5_SPX3819-M5-L-SPX3819-M5-L-3-3U_SOT23_5
X1CRY_X_HC_49S_2_24.000MHZ24.000MHzX_HC_49S_2
X2CRY_ACT_X_CYC50M_CPY_ACTCPY_ACTX_CYC50M
重要提示:PCB作品文件展下载说明
此广告位出租
    3 天前
  • 签到天数: 193 天
    1元学习Pads(221219)旁听
    发表于 2022-3-6 13:01:55 | 显示全部楼层
    5 天前
    发表于 2022-3-7 08:46:40 | 显示全部楼层
  • 签到天数: 48 天
    PADS-180606高级班
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2022-3-7 09:19:17 | 显示全部楼层
    昨天 09:00
  • 签到天数: 227 天
    发表于 2022-3-7 19:58:24 | 显示全部楼层
  • 签到天数: 51 天
    发表于 2022-3-8 09:01:49 | 显示全部楼层
    3 天前
  • 签到天数: 168 天
    发表于 2022-3-25 08:39:19 | 显示全部楼层
    5 天前
  • 签到天数: 103 天
    发表于 2022-3-25 08:45:04 | 显示全部楼层
