S905Y4_AP222_DDR4X4_V1.0_R0.5_20201214.zip
(1.56 MB, 下载次数: 7)
S905Y4/W2_DDR4X4 BOX芯片A35
Item
Index | Value | Decal | QTY | Name | Chips | | | 1 | | 1 | S905Y4_20201210 | BGA315_0P65_S4 | 1 | U1 | Diodes | | | 6 | | 2 | IR_LED_5MM_GREEN | LED/5_90B | 6 | LED1,LED7,LED8,LED9,LED11,LED13 | Connectors | | | 19 | | 3 | 6.5X0.8X1.28MM | PAD_JACK_(6.5X0.8X1.28) | 18 | J6,J8,J10,J11,J14,J16,J17,J19,J20,J21,J22,J23,J24,J26,J27,J29,J32,J34 | 4 | NC | JACK_SHIELD_56.5X36MM | 1 | J36 | Switchs | | | 1 | | 5 | NC/SW_SLIDE | SK-12D07G5 | 1 | SW1 | Unkowns | | | 688 | | 6 | 0.1UF | C0402 | 2 | 3C50,8C39 | 7 | 0.1UF_16V | C0402 | 13 | 1C12,1C14,1C15,1C17,1C20,1C23,1C24,1C28,1C32,1C35,1C38,1C39,1C44 | 8 | 0.1UF_6.3V | C0201 | 9 | 2C8,2C12,2C24,3C10,3C27,4C46,5C17,7C35,9C1 | 9 | 0.1UF_6.3V | C0402 | 66 | 1C30,1C45,1C46,1C47,2C5,3C11,3C18,3C20,3C21,3C22,3C23,3C24,3C26,3C28,3C29,3C33,3C34,3C36,3C37,3C45,3C46,3C47,3C48,3C49,3C52,3C53,3C55,3C58,3C59,3C60,3C61,3C62,3C63,3C65,3C66,3C67,3C70,3C71,3C73,4C37,4C38,4C39,4C40,5C1,5C3,5C4,5C5,6C2,6C7,6C13,6C15,6C17,6C22,6C31,6C33,6C34,6C37,6C38,6C40,7C28,7C33,8C19,8C40,9C5,9C6,9C10 | 10 | 0R | R0402 | 23 | 2R29,3R19,4R1,4R5,4R49,4R59,6R23,6R32,6R44,6R46,6R47,7R2,7R3,7R10,7R11,7R21,7R31,7R32,7R33,7R34,8R17,8R18,9R8 | 11 | 0R | R0603 | 1 | 7R16 | 12 | 1.2PF | C0402 | 1 | 7C2 | 13 | 1.3K_1% | R0402 | 1 | 9R4 | 14 | 1.8UH | L0603 | 1 | 8L4 | 15 | 1000R_200MA | L0402 | 1 | 9FB1 | 16 | 100K | R0402 | 3 | 2R36,9R1,9R21 | 17 | 100K_1% | R0402 | 3 | 1R18,1R19,1R25 | 18 | 100PF | C0402 | 4 | 2C18,2C39,8C43,8C44 | 19 | 100R | R0402 | 7 | 2R6,6R43,7R13,8R6,9R3,9R12,9R14 | 20 | 100R_300MA | FB0402 | 1 | 9FB2 | 21 | 10K | R0402 | 17 | 1R20,1R29,2R8,2R9,2R12,4R30,5R3,5R5,5R6,6R4,6R20,6R39,6R55,7R14,7R18,8R53,9R2 | 22 | 10K_1% | R0402 | 2 | 1R17,6R27 | 23 | 10NF | C0402 | 1 | 1C8 | 24 | 10PF | C0402 | 3 | 7C3,7C12,7C27 | 25 | 10UF_16V | C0805 | 10 | 1C3,1C5,1C33,1C34,1C36,1C37,1C40,6C12,6C14,6C26 | 26 | 10UF_6.3V | C0603 | 13 | 1C27,3C25,3C30,3C31,3C32,3C39,3C54,3C56,6C23,7C5,7C34,8C41,9C11 | 27 | 120K_1% | R0402 | 2 | 1R5,9R20 | 28 | 137K_1% | R0402 | 1 | 1R23 | 29 | 15.8K_1% | R0402 | 2 | 8R56,8R59 | 30 | 160K_1% | R0402 | 1 | 1R1 | 31 | 16K_1% | R0402 | 1 | 1R4 | 32 | 18.2K_1% | R0402 | 1 | 1R12 | 33 | 18PF | C0402 | 2 | 2C3,2C9 | 34 | 1K | R0402 | 5 | 1R13,2R4,2R28,6R52,8R62 | 35 | 1M | R0603 | 1 | 6R54 | 36 | 1NF | C0402 | 17 | 1C1,1C4,1C43,1C49,1C50,1C51,1C52,2C21,2C25,2C28,3C72,6C5,6C16,6C41,8C49,8C50,9C8 | 37 | 1NF_2KV | C1206 | 1 | 6C11 | 38 | 1UF_6.3V | C0201 | 6 | 2C2,2C11,2C20,2C23,3C2,3C6 | 39 | 1UF_6.3V | C0402 | 21 | 3C1,3C3,3C12,3C17,3C41,3C51,3C57,3C64,3C68,3C69,3C74,4C3,6C1,6C4,6C18,6C24,6C25,8C48,8C54,9C3,9C16 | 40 | 2.2PF | C0402 | 1 | 3C147 | 41 | 2.2R | R0402 | 2 | 6R19,6R69 | 42 | 2.2UF_6.3V | C0402 | 2 | 8C46,8C52 | 43 | 2.2UH_3A_DCR<=30MOHM | L5050 | 2 | 1L1,1L5 | 44 | 20K_1% | R0402 | 1 | 1R16 | 45 | 22.1K_1% | R0402 | 1 | 1R24 | 46 | 220UF_10V | SMD_DL6.3X7.7 | 1 | 6C35 | 47 | 22R | R0402 | 7 | 2R10,6R26,6R28,6R30,6R49,6R50,8R50 | 48 | 22UF_6.3V | C0805 | 3 | 1C13,1C22,1C26 | 49 | 240R_1% | R0201 | 1 | 3R1 | 50 | 240R_1% | R0402 | 8 | 2R1,2R16,3R2,3R7,3R9,3R14,6R62,6R63 | 51 | 24MHZ_CL12PF_20PPM | XT-SMD4P3225 | 1 | 2Y2 | 52 | 27K_1% | R0402 | 1 | 9R7 | 53 | 27PF | C0402 | 6 | 1C9,1C16,1C21,1C29,1C42,8C42 | 54 | 2K | R0402 | 4 | 6R65,6R66,9R6,9R13 | 55 | 2K_1% | R0402 | 8 | 3R3,3R4,3R5,3R8,3R10,3R11,3R12,3R13 | 56 | 300K_1% | R0402 | 1 | 1R35 | 57 | 30K_1% | R0402 | 1 | 1R10 | 58 | 33K_1% | R0402 | 1 | 2R27 | 59 | 4.7K | R0402 | 5 | 1R3,4R18,6R6,6R51,8R52 | 60 | 4.7K_1% | R0402 | 5 | 2R20,2R21,2R24,2R30,2R31 | 61 | 4.7UF_6.3V | C0402 | 5 | 2C6,2C7,2C13,2C16,3C19 | 62 | 4.7UF_6.3V | C0603 | 11 | 1C2,1C6,1C7,1C11,2C40,3C4,3C7,4C42,5C2,9C12,9C13 | 63 | 4.7UH_3A_DCR<=70MOHM | L5050 | 3 | 1L2,1L3,1L4 | 64 | 47K | R0402 | 3 | 4R7,5R2,6R41 | 65 | 4X0R | RN0402 | 1 | 7RN1 | 66 | 4X3.3R | RN0402 | 2 | 9RN2,9RN3 | 67 | 5.1R | R0402 | 9 | 2R25,6R2,6R3,6R15,6R16,6R17,6R18,6R48,6R70 | 68 | 5.6K_1% | R0402 | 1 | 6R33 | 69 | 510R | R0402 | 5 | 8R3,8R4,8R8,8R55,8R60 | 70 | 51K_1% | R0402 | 1 | 1R22 | 71 | 56K | R0402 | 1 | 1R2 | 72 | 56R | R0603 | 3 | 2R13,2R17,2R49 | 73 | 66.5K_1% | R0402 | 2 | 8R54,8R61 | 74 | 75R | R0805 | 4 | 6R21,6R22,6R60,6R61 | 75 | 75R_1% | R0402 | 1 | 9R32 | 76 | 8.2K | R0402 | 1 | 2R15 | 77 | 91K | R0402 | 1 | 2R3 | 78 | A2501WV-4P | CON_4P_2.0MM_V1 | 1 | 2CON1 | 79 | AZ1043-04F | DFN2510P10E | 2 | 9D1,9D2 | 80 | AZ5325-01F | ESD0402 | 8 | 6D7,6D8,6D9,6D10,6D11,6D12,6D13,6D14 | 81 | AZ5725-01F | ESD0402 | 13 | 6D1,6D2,6D3,6D4,6D5,6D6,8D3,8D5,8D6,9D3,9D4,9D5,9D7 | 82 | AZC199-04S | SOT23-6 | 1 | 6U2 | 83 | CON_2X18P_2.0 | CON_2.0MM_2X18P | 1 | 5CON1 | 84 | DC044 | DCJACK_5.5MM_SEN5 | 1 | 1J5 | 85 | DIO2133CT14 | TSSOP-14-PT065 | 1 | 8U7 | 86 | FT232RL | SSOP28P_GL852G | 1 | 6U4 | 87 | GREEN | LED0603 | 1 | 8D1 | 88 | H1601CG | TS8121C | 1 | 6T1 | 89 | HDA31-F1F1-1000-A | JACK_HDMI_19P_SEN5 | 1 | 9J2 | 90 | IRM-3638N3 | IR_3PIN_SEN5 | 1 | 2U1 | 91 | IR_GQ_015_T | OPTICAL1706 | 1 | 8J4 | 92 | JACK_IPEX | JACK_IPEX_4P | 2 | 7J1,7J4 | 93 | KEY | SW-4P-90_H(7.5MM) | 1 | 2K5 | 94 | KEY | SW-TACH-CHIPIND | 1 | 4K1 | 95 | KLMAG1JETD-B041 | BGA169-INAND | 1 | 4U7 | 96 | MARK | MARK | 4 | 1M5,1M6,1M7,1M8 | 97 | MICRO_USB_PORT | MICRO_USB_5P/4DIP | 1 | 6J2 | 98 | NC | ACM2012-2P | 2 | 6L1,6L2 | 99 | NC | C0402 | 8 | 4C225,6C32,7C4,7C11,7C13,7C22,7C30,8C20 | 100 | NC | R0402 | 5 | 2R35,4R3,7R4,7R6,7R19 | 101 | NC | TEST_R | 2 | 9R9,9R80 | 102 | NC/0.05R | R0805 | 13 | RT1,RT2,RT3,RT6,RT7,RT8,RT9,RT10,RT11,RT12,RT13,RT14,RT15 | 103 | NC/0.1UF | C0402 | 1 | 8C2 | 104 | NC/0.1UF_16V | C0402 | 3 | 8C8,8C12,8C37 | 105 | NC/0.1UF_6.3V | C0402 | 11 | 2C15,4C7,4C12,4C15,4C17,4C18,7C7,8C4,8C22,8C25,8C31 | 106 | NC/0.47UF_25V | C0603 | 2 | 8C15,8C16 | 107 | NC/0R | R0402 | 16 | 4R26,4R27,4R28,6R45,6R53,7R1,7R27,7R28,7R29,7R30,7R54,7R59,7R60,8R10,8R12,8R13 | 108 | NC/0R | R0603 | 3 | 5R1,6R40,6R56 | 109 | NC/0R | R0805 | 1 | 2R7 | 110 | NC/100K | R0402 | 4 | 2R14,6R12,6R31,8R74 | 111 | NC/100PF | C0402 | 2 | 3C43,3C44 | 112 | NC/100UF_25V | SMD_DL6.3X7.7 | 2 | 8C10,8C56 | 113 | NC/10K | R0402 | 33 | 1R6,1R7,1R11,2R2,4R8,4R12,4R32,6R24,6R25,6R29,6R37,6R42,6R64,6R67,7R5,7R12,7R17,7R20,7R22,7R39,7R47,8R1,8R9,8R26,8R29,8R31,8R39,8R40,8R57,8R58,8R66,8R72,8R75 | 114 | NC/10PF | C0402 | 9 | 3C5,3C42,6C6,6C8,6C10,6C39,7C19,8C26,8C27 | 115 | NC/10R | R0402 | 1 | 8R71 | 116 | NC/10UF_16V | C0805 | 1 | 1C41 | 117 | NC/10UF_6.3V | C0603 | 2 | 8C1,8C21 | 118 | NC/12PF | C0402 | 2 | 7C23,7C24 | 119 | NC/137K_1% | R0402 | 1 | 9R16 | 120 | NC/150PF | C0402 | 2 | 8C47,8C51 | 121 | NC/15UH_2A_DCR<=70MOHM | L5050 | 2 | 8L2,8L3 | 122 | NC/1K | R0402 | 6 | 2R11,8R2,8R30,8R33,8R49,8R67 | 123 | NC/1NF | C0402 | 1 | 4C1 | 124 | NC/1UF | C0402 | 1 | 8C3 | 125 | NC/1UF_16V | C0402 | 4 | 8C7,8C11,8C17,8C29 | 126 | NC/1UF_6.3V | C0402 | 8 | 7C1,8C5,8C6,8C13,8C14,8C32,9C7,9C9 | 127 | NC/2.26K_1% | R0402 | 1 | 6R11 | 128 | NC/2.2UF_25V | C0603 | 2 | 8C9,8C28 | 129 | NC/2.2UH_1.2A_DCR110MOHM | L3030 | 1 | 7L2 | 130 | NC/2.2UH_1.7A | L3030 | 1 | 7L1 | 131 | NC/220UF_25V | SMD_DL6.3X7.7 | 1 | 1EC1 | 132 | NC/22R | R0402 | 9 | 7R15,8R5,8R7,8R24,8R25,8R28,8R32,8R34,8R45 | 133 | NC/22UF_6.3V | C0805 | 4 | 1C10,1C18,1C19,1C25 | 134 | NC/32.768KHZ_CL15PF_10PPM | XTAL_3225 | 1 | 7Y1 | 135 | NC/330PF | C0402 | 1 | 3C40 | 136 | NC/37.4MHZ | Y-SMD4P3225 | 1 | 7Y2 | 137 | NC/4.7K | R0402 | 6 | 1R8,2R26,4R2,4R4,4R6,8R63 | 138 | NC/4.7K_1% | R0402 | 1 | 9R18 | 139 | NC/4.7UF_6.3V | C0603 | 4 | 4C16,7C6,7C16,7C29 | 140 | NC/470K | R0402 | 2 | 2R5,7R55 | 141 | NC/47K | R0402 | 2 | 4R31,8R65 | 142 | NC/47PF | C0402 | 3 | 7C8,8C45,8C53 | 143 | NC/56R_1% | R0603 | 4 | 6R7,6R8,6R9,6R10 | 144 | NC/6.8PF | C0402 | 1 | 7C25 | 145 | NC/60R_2A | L0805 | 1 | 8FB1 | 146 | NC/AZ5725-01F | ESD0402 | 2 | 2D1,2D2 | 147 | NC/B5819W | SOD-123 | 1 | 9D6 | 148 | NC/CON_FPC_0.5MM | CON_FPC_REAR_0.5MM_14P | 1 | 8J1 | 149 | NC/PMBT3904 | SOT-23 | 1 | 8Q4 | 150 | NC/RS809R/MAX809RD | SOT-23 | 1 | 2U2 | 151 | NC/SDCMA21-4-900-M1T | EMI-TF2010A4X | 2 | 9L1,9L2 | 152 | NC/SGM2032-ADJ | SOT23-5 | 1 | 9U1 | 153 | NC/SGM3157 | SC-70 | 2 | 8U3,8U5 | 154 | NC/SLC_NAND | TSOP-48 | 1 | 4U1 | 155 | NC/SPK | CON-2/2.54MM | 1 | 8J2 | 156 | NC/TLC59116IRHBR | QFN32_0P5_5X5MM | 1 | 8U2 | 157 | NC/TPA3112D1 | HTSSOP_28 | 1 | 8U1 | 158 | NC/WL2803E18-5 | SOT23-5 | 1 | 7U2 | 159 | NC/WNM2020 | SOT-23 | 4 | 6Q2,6Q6,6Q7,6Q8 | 160 | NC/WPM3401 | SOT-23 | 1 | 8Q3 | 161 | NC/XR_1204RGB | LED_RGB_90_3.2X1MM | 5 | 8LED1,8LED2,8LED3,8LED4,8LED9 | 162 | NT5AD256M16D4-HR | BGA96-0P8MM_DDR4 | 4 | 3U1,3U3,3U4,3U5 | 163 | PJ-320A | JACK_PHONE_3.5MM_5P_SEN5 | 1 | 8J3 | 164 | PMBT3904 | SOT-23 | 7 | 2Q3,2Q4,2Q5,2Q6,2Q7,2Q8,6Q1 | 165 | QCA6174A-3(8274B-SR) | AP_WIFI2X2_13X15_L | 1 | 7U1 | 166 | RED | LED0603 | 2 | 8D2,8D4 | 167 | RJ45_USB3.0_COMBINE | RJ45+USB3.0_SMT-27P | 1 | 6J4 | 168 | RT9701GB | SOT23-5 | 2 | 6U1,6U5 | 169 | SY8113BADC | SOT23-6 | 1 | 1U4 | 170 | SY8120B1ABC | SOT23-6 | 4 | 1U1,1U3,1U5,1U6 | 171 | TDI | TP12 | 5 | 3T5,3T10,5T1,5T2,5T16 | 172 | TEST12 | TEST12 | 9 | 4T1,4T3,4T4,4T5,4T7,4T8,4T12,4T23,4T24 | 173 | TEST12 | TP12MIL | 7 | 6T2,6T3,6T4,6T5,6T6,6T7,6T8 | 174 | TEST12 | TP_0P8 | 7 | 1TP1,1TP2,1TP3,1TP4,1TP5,1TP6,1TP7 | 175 | TFWF1-EBF1-1X0X | JACK_TF_CARD | 1 | 6J1 | 176 | TUSB320RWBR | X2QFN12 | 1 | 6U3 | 177 | T_POINT_R_1 | PAD_1X4MM | 1 | P10 | 178 | T_POINT_R_1 | PAD_2X3.5MM | 5 | P3,P4,P5,P6,P9 | 179 | USB_TYPE-C | TYPE-C_USB_24P_SMD_V1.0 | 1 | 6J3 | 180 | WL2803E18-5 | SOT23-5 | 2 | 1U2,1U7 | 181 | WL2803E25-5 | SOT23-5 | 1 | 3U2 | 182 | WNM6001 | SOT-23 | 1 | 9Q2 | 183 | WPM3401 | SOT-23 | 1 | 5Q1 |
