S905X4_AH212_HYBRID_DDR4X2_V1.0_R0.6_20200520.rar
(1.52 MB, 下载次数: 6)
S905X4_DDR4X2 BOX 12nm A55*4
Item
Index | Value | Decal | QTY | Name | Chips | | | 1 | | 1 | S905X4 | BAG396_0P6 | 1 | U1 | Capacitors | | | 1 | | 2 | 0.1uF | C0402 | 1 | C13 | Diodes | | | 6 | | 3 | IR_LED_5MM_GREEN | LED/5_90B | 6 | LED1,LED7,LED8,LED9,LED11,LED13 | Connectors | | | 20 | | 4 | 6.5X0.8X1.28MM | PAD_JACK_(6.5X0.8X1.28) | 19 | J6,J8,J10,J11,J14,J16,J17,J18,J19,J20,J21,J22,J23,J24,J26,J27,J29,J32,J34 | 5 | NC | JACK_SHIELD_56.5X36MM | 1 | J36 | Switchs | | | 1 | | 6 | SW_SLIDE | SK-12D07G5 | 1 | SW1 | Unkowns | | | 833 | | 7 | 0.1UF | C0402 | 101 | 1C12,1C14,1C15,1C17,1C20,1C23,1C24,1C28,1C30,1C32,1C35,1C38,1C39,1C44,1C45,1C46,1C53,2C5,2C7,2C8,2C10,2C12,2C23,2C24,3C1,3C2,3C6,3C8,3C10,3C11,3C12,3C14,3C17,3C18,3C19,3C22,3C25,3C31,3C33,3C35,3C36,3C47,3C48,3C49,3C50,3C51,3C73,3C74,3C76,3C91,4C37,4C38,4C39,4C40,4C46,5C1,5C2,5C3,5C4,5C11,5C16,5C17,5C29,5C30,5C31,5C33,5C35,5C39,5C40,5C42,5C57,6C3,6C6,6C8,6C10,6C13,6C15,6C22,6C43,6C44,6C50,7C28,7C33,7C35,8C2,8C4,8C8,8C12,8C19,8C22,8C31,8C37,8C39,9C2,9C5,9C6,9C10,9C14,9C15,9C17,9C18 | 8 | 0.47UF_25V | C0603 | 2 | 8C15,8C16 | 9 | 0R | C1206 | 2 | 5C18,5C19 | 10 | 0R | R0201 | 3 | 2R51,5R92,5R94 | 11 | 0R | R0402 | 37 | 1R13,1R15,2R29,4R1,4R5,4R49,4R59,5R14,5R15,5R20,5R22,5R29,5R30,6R1,6R5,6R23,6R32,6R44,6R46,6R47,7R2,7R3,7R11,8R10,8R11,8R12,8R13,8R14,8R17,8R18,8R46,8R48,8R64,8R68,9R8,9R10,9R11 | 12 | 0R | R0603 | 3 | 5R80,5R81,7R16 | 13 | 0R | R0805 | 1 | 6R22 | 14 | 1.2PF | C0402 | 1 | 7C2 | 15 | 1.5K_1% | R0402 | 1 | 9R4 | 16 | 1.8UH | L0603 | 1 | 8L4 | 17 | 100K | R0402 | 5 | 1R9,6R51,8R74,9R1,9R21 | 18 | 100K_1% | R0402 | 3 | 1R18,1R19,1R25 | 19 | 100PF_5%_NPO | C0402 | 5 | 2C18,3C26,3C30,8C43,8C44 | 20 | 100R | R0402 | 5 | 2R6,7R13,9R3,9R12,9R14 | 21 | 100R | R0603 | 1 | 8R6 | 22 | 100R_100MHZ_300MA | FB0402 | 1 | 9FB2 | 23 | 100UF_25V | SMD_DL6.3X7.7 | 2 | 8C10,8C56 | 24 | 10K | R0402 | 25 | 1R20,1R29,1R80,4R30,5R13,6R4,6R14,6R38,6R39,6R41,6R55,7R14,7R18,8R1,8R9,8R26,8R29,8R31,8R53,8R66,8R72,8R75,9R2,9R9,9R36 | 25 | 10K_1% | R0402 | 4 | 1R17,6R27,6R64,6R66 | 26 | 10NF | C0402 | 4 | 1C8,2C17,5C7,6C54 | 27 | 10PF | C0402 | 3 | 7C3,7C12,7C27 | 28 | 10R | R0402 | 1 | 8R71 | 29 | 10UF_16V | C0805 | 11 | 1C3,1C5,1C33,1C34,1C36,1C37,1C40,6C12,6C14,6C23,6C26 | 30 | 10UF_6.3V | C0603 | 16 | 1C27,2C4,2C6,2C13,3C13,3C21,3C29,3C34,3C43,5C44,7C5,7C34,8C1,8C21,8C41,9C11 | 31 | 120K_1% | R0402 | 2 | 1R5,9R20 | 32 | 12PF_5%_NPO | C0402 | 2 | 3C5,3C75 | 33 | 137K_1% | R0402 | 1 | 1R23 | 34 | 15.8K_1% | R0402 | 2 | 8R56,8R59 | 35 | 150R_1% | R0402 | 2 | 3R2,3R4 | 36 | 15K | R0402 | 1 | 9R34 | 37 | 15UH | L5050 | 2 | 8L2,8L3 | 38 | 160K_1% | R0402 | 1 | 1R1 | 39 | 16K_1% | R0402 | 1 | 1R4 | 40 | 18.2K_1% | R0402 | 1 | 1R12 | 41 | 18PF_5%_NPO | C0402 | 4 | 2C3,2C9,5C12,5C14 | 42 | 1K | R0402 | 14 | 2R4,2R8,2R9,2R12,2R28,5R67,6R43,6R52,8R30,8R33,8R49,8R62,8R67,8R69 | 43 | 1M | R0603 | 1 | 6R54 | 44 | 1NF | C0402 | 21 | 1C1,1C4,1C43,1C49,1C50,1C51,1C52,2C2,2C21,2C25,2C28,2C39,3C9,5C32,6C5,6C7,6C11,6C16,8C49,8C50,9C8 | 45 | 1NF_2KV | C1206 | 2 | 5C41,5C56 | 46 | 1UF | C0402 | 10 | 6C4,6C24,6C25,8C3,8C5,8C6,8C13,8C14,8C32,9C3 | 47 | 1UF_25V | C0402 | 4 | 8C7,8C11,8C17,8C29 | 48 | 1UF_6.3V | C0402 | 25 | 2C1,2C11,2C14,2C16,2C20,2C22,3C15,3C16,3C23,3C24,3C32,3C40,3C46,3C56,4C3,6C18,6C53,8C40,8C48,8C54,9C1,9C7,9C9,9C16,9C19 | 49 | 2.26K_1% | R0402 | 1 | 5R11 | 50 | 2.2K_1% | R0402 | 4 | 3R3,3R5,3R16,3R17 | 51 | 2.2R | R0402 | 2 | 6R17,6R19 | 52 | 2.2UF_25V | C0603 | 2 | 8C9,8C28 | 53 | 2.2UF_6.3V | C0402 | 2 | 8C46,8C52 | 54 | 2.2UH_1A | L3030 | 1 | 5L1 | 55 | 2.2UH_3A_DCR<=30MOHM | L5050 | 2 | 1L1,1L5 | 56 | 2.49K_1% | R0402 | 1 | 5R21 | 57 | 200R_1% | R0402 | 1 | 6R13 | 58 | 20K_1% | R0402 | 1 | 1R16 | 59 | 22.1K_1% | R0402 | 1 | 1R24 | 60 | 220R_100MHZ_300MA | FB0603 | 1 | 5FB4 | 61 | 220UF_10V±20% | SMD_DL6.3X7.7 | 1 | 5C5 | 62 | 22R | R0402 | 14 | 2R10,5R42,6R49,6R50,7R10,7R21,8R5,8R7,8R24,8R25,8R28,8R32,8R45,8R50 | 63 | 22UF_6.3V | C0805 | 5 | 1C13,1C22,1C26,6C48,6C49 | 64 | 240R_1% | R0402 | 5 | 2R1,2R16,3R1,3R8,3R18 | 65 | 24MHZ_CL12PF_20PPM | XT-SMD4P3225 | 1 | 2Y2 | 66 | 25MHZ_CL12PF_20PPM | XT-SMD4P3225 | 1 | 5Y2 | 67 | 27K_1% | R0402 | 1 | 9R7 | 68 | 27PF_5%_NPO | C0402 | 6 | 1C9,1C16,1C21,1C29,1C42,8C42 | 69 | 2K | R0402 | 6 | 2R18,2R19,5R24,5R25,9R6,9R13 | 70 | 300K_1% | R0402 | 1 | 1R35 | 71 | 30K_1% | R0402 | 1 | 1R10 | 72 | 330PF_5%_NPO | C0402 | 1 | 3C78 | 73 | 33K_1% | R0402 | 1 | 2R27 | 74 | 33R | R0402 | 4 | 5R48,5R51,6R26,6R28 | 75 | 4.7K | R0402 | 9 | 4R2,4R18,5R40,5R46,5R59,5R66,5R69,5R75,8R52 | 76 | 4.7K_1% | R0402 | 5 | 2R20,2R21,2R24,2R30,2R31 | 77 | 4.7R | R0402 | 1 | 2R25 | 78 | 4.7UF_6.3V | C0603 | 15 | 1C2,1C6,1C7,1C11,2C40,3C4,3C7,4C42,5C13,5C34,5C36,5C43,9C4,9C12,9C13 | 79 | 4.7UH_2A_DCR<=70MOHM | L5050 | 2 | 1L2,1L3 | 80 | 4.7UH_3A_DCR<=70MOHM | L5050 | 1 | 1L4 | 81 | 47K | R0402 | 5 | 1R3,1R77,1R79,4R7,8R65 | 82 | 49.9R | R0603 | 3 | 2R13,2R17,2R49 | 83 | 4X0R | RN0402 | 5 | 2RN1,5RN7,6RN4,7RN1,7RN3 | 84 | 4X3.3R | RN0402 | 2 | 9RN2,9RN3 | 85 | 5.1R | R0402 | 4 | 6R2,6R3,6R15,6R48 | 86 | 5.1R_1% | R0402 | 4 | 5R16,5R17,5R18,5R19 | 87 | 5.6K_1% | R0402 | 1 | 6R33 | 88 | 510R | R0402 | 5 | 5R1,5R47,8R4,8R55,8R60 | 89 | 51K_1% | R0402 | 1 | 1R22 | 90 | 562R_1% | R0402 | 1 | 9R33 | 91 | 56K | R0402 | 1 | 1R2 | 92 | 56R_1% | R0603 | 4 | 5R7,5R8,5R9,5R10 | 93 | 60R_100MHZ | L0805 | 1 | 8FB1 | 94 | 66.5K_1% | R0402 | 2 | 8R54,8R61 | 95 | 75R | R0805 | 4 | 5R41,5R68,5R72,5R76 | 96 | 75R_1% | R0402 | 2 | 9R32,9R37 | 97 | 75R_1% | R0603 | 1 | 9R35 | 98 | 8.2K | R0402 | 2 | 2R15,2R36 | 99 | 91K | R0402 | 2 | 2R3,2R35 | 100 | A2501WV-4P | CON_4P_2.0MM_V1 | 1 | 2CON1 | 101 | AZ1043-04F | DFN2510P10E | 2 | 9D1,9D2 | 102 | AZ1165-06F | DFN4120P10E | 1 | 6D12 | 103 | AZ5325-01F | ESD0402 | 4 | 6D7,6D8,6D9,6D10 | 104 | AZ5725-01F | ESD0402 | 1 | 8D3 | 105 | AZC199-04S | SOT23-6 | 1 | 5U2 | 106 | BLM15AX102SZ1 | L0402 | 1 | 9FB1 | 107 | CON_2X18P_2.0 | CON_2.0MM_2X18P | 1 | 5CON1 | 108 | CON_FPC_0.5MM | CON_FPC_REAR_0.5MM_14P | 1 | 8J1 | 109 | DC044 | DCJACK_5.5MM_SEN5 | 1 | 1J5 | 110 | DIO2133CT14 | TSSOP-14-PT065 | 1 | 8U7 | 111 | EMMC_FLASH | BGA169-INAND | 1 | 4U7 | 112 | FT232RL | SSOP28P_GL852G | 1 | 6U4 | 113 | H1601CG | TS8121C | 1 | 5T1 | 114 | HDA31-F1F1-1000-A | JACK_HDMI_19P_SEN5 | 1 | 9J2 | 115 | IRM-3638N3 | IR_3PIN_SEN5 | 1 | 2U1 | 116 | IR_GQ_015_T | OPTICAL1706 | 1 | 8J4 | 117 | JACK_IPEX | JACK_IPEX_4P | 2 | 7J1,7J4 | 118 | K4A8G165WB-BCPB | BGA96-0P8MM_DDR4 | 2 | 3U3,3U4 | 119 | KEY | SW-4P-90_H(7.5MM) | 1 | 2K5 | 120 | KEY | SW-TACH-CHIPIND | 1 | 4K1 | 121 | M.2 | M.2_KEY_E | 1 | 6CON2 | 122 | MARK | MARK | 4 | 1M5,1M6,1M7,1M8 | 123 | MICRO_USB_PORT | MICRO_USB_5P/4DIP | 1 | 6J2 | 124 | NC | ACM2012-2P | 2 | 6L1,6L2 | 125 | NC | C0402 | 8 | 4C225,6C2,7C4,7C11,7C13,7C22,7C30,8C20 | 126 | NC | R0201 | 3 | 2R50,5R91,5R93 | 127 | NC | R0402 | 10 | 1R14,4R3,5R27,5R28,5R77,7R4,7R6,7R15,7R19,7R22 | 128 | NC/0.1UF | C0402 | 13 | 1C47,2C15,2C19,4C7,4C12,4C15,4C17,4C18,6C20,6C27,7C7,8C24,8C25 | 129 | NC/0R | R0201 | 6 | 5R32,5R43,5R45,5R52,5R61,8R37 | 130 | NC/0R | R0402 | 26 | 4R26,4R27,4R28,5R6,5R12,5R35,5R36,5R37,5R38,5R39,5R44,5R83,6R8,6R9,6R10,6R18,6R36,6R45,6R53,7R1,8R3,8R15,8R16,8R19,8R47,9R15 | 131 | NC/0R | R0603 | 4 | 1R78,5R82,6R40,6R56 | 132 | NC/0R | R0805 | 1 | 2R7 | 133 | NC/100K | R0402 | 3 | 2R14,6R12,6R31 | 134 | NC/100PF | C0402 | 2 | 5C15,5C38 | 135 | NC/10K | R0402 | 27 | 1R6,1R7,1R11,2R2,4R6,4R8,4R12,4R32,6R7,6R11,6R20,6R24,6R25,6R29,6R37,6R42,7R5,7R12,7R17,7R20,7R39,7R47,8R39,8R40,8R57,8R58,9R5 | 136 | NC/10PF | C0402 | 6 | 5C6,5C8,5C9,5C10,6C9,6C19 | 137 | NC/10PF_NPO | C0402 | 1 | 5C37 | 138 | NC/10UF_16V | C0805 | 1 | 1C41 | 139 | NC/12PF | C0402 | 2 | 7C23,7C24 | 140 | NC/150PF | C0402 | 2 | 8C47,8C51 | 141 | NC/1K | R0402 | 2 | 2R11,8R41 | 142 | NC/1N4148WT | SOD-523 | 1 | 3D1 | 143 | NC/1NF | C0402 | 2 | 8C26,8C27 | 144 | NC/1NF_6.3V | C0402 | 1 | 4C1 | 145 | NC/1UF_6.3V | C0402 | 2 | 6C1,7C1 | 146 | NC/2.2UH_1.2A_DCR110MOHM | L3030 | 1 | 7L2 | 147 | NC/200R | R0201 | 1 | 2R22 | 148 | NC/220UF_25V±20% | SMD_DL6.3X7.7 | 1 | 1EC1 | 149 | NC/22R | R0402 | 11 | 5R2,5R34,5R62,5R90,6R16,6R30,6R67,7R83,7R84,7R86,8R34 | 150 | NC/22UF_6.3V | C0805 | 4 | 1C10,1C18,1C19,1C25 | 151 | NC/29F64G08CBACA | TSOP-48 | 1 | 4U1 | 152 | NC/2K | R0402 | 2 | 5R5,5R23 | 153 | NC/33R | R0402 | 1 | 5R26 | 154 | NC/33R | R0603 | 1 | 8R8 | 155 | NC/37.4MHZ | Y-SMD4P3225 | 1 | 7Y2 | 156 | NC/4.7K | R0402 | 8 | 2R26,5R3,5R4,5R58,6R6,8R27,8R42,8R63 | 157 | NC/4.7UF_6.3V | C0603 | 2 | 4C16,7C6 | 158 | NC/4.7UF_6.3V_X5R | C0603 | 1 | 7C29 | 159 | NC/470K | R0402 | 1 | 2R5 | 160 | NC/47K | R0402 | 2 | 1R8,4R31 | 161 | NC/47PF | C0402 | 2 | 8C45,8C53 | 162 | NC/4X0R | RN0402 | 2 | 5RN5,5RN6 | 163 | NC/510R | R0402 | 3 | 5R65,5R74,8R51 | 164 | NC/6.8PF_5%_NPO | C0402 | 1 | 7C25 | 165 | NC/75R | R0402 | 1 | 8R2 | 166 | NC/AZ5325-01F | ESD0402 | 8 | 5D1,5D2,5D3,5D4,5D5,5D6,5D7,5D8 | 167 | NC/AZ5725-01F | ESD0402 | 13 | 2D1,2D2,6D1,6D2,6D3,6D4,6D5,6D6,9D3,9D4,9D5,9D7,9D8 | 168 | NC/B5819W | SOD-123 | 1 | 9D6 | 169 | NC/G11T1001 | SOIC24 | 1 | 5T2 | 170 | NC/GREEN | LED0603 | 1 | 8D1 | 171 | NC/MCZ2010DH | EMI-TF2010A4X | 1 | 6L6 | 172 | NC/PMBT3904 | SOT-23 | 1 | 8Q1 | 173 | NC/RS809R/MAX809RD | SOT-23 | 1 | 2U2 | 174 | NC/SDCMA21-4-900-M1T | EMI-TF2010A4X | 2 | 9L1,9L2 | 175 | NC/SGM3157 | SC-70 | 1 | 8U5 | 176 | NC/SK9816_RGB | RGB_SMT_4P | 1 | 8LED5 | 177 | NC/TFWF1-EBF1-1X0X | JACK_TF_CARD | 1 | 6J1 | 178 | NC/WL2803E18-5 | SOT23-5 | 1 | 7U2 | 179 | NC/WNM2020 | SOT-23 | 4 | 6Q2,6Q6,6Q7,6Q8 | 180 | NC/XR_1204RGB | LED_RGB_90_3.2X1MM | 1 | 8LED9 | 181 | PJ-320A | JACK_PHONE_3.5MM_5P_SEN5 | 1 | 8J3 | 182 | PMBT3904 | SOT-23 | 9 | 1Q1,2Q3,2Q4,2Q5,2Q6,2Q7,2Q8,6Q1,8Q4 | 183 | QCA6174 | AP_WIFI2X2_13X15_L | 1 | 7U1 | 184 | RED | LED0603 | 1 | 8D2 | 185 | RJ45_USB3.0_COMBINE | RJ45+USB3.0_SMT-27P | 1 | 5J1 | 186 | RT9701GB | SOT23-5 | 2 | 6U1,6U2 | 187 | RTL8211F-CG | QFN40-PT04-5X5MM | 1 | 5U1 | 188 | SGM3157 | SC-70 | 1 | 8U3 | 189 | SGM8743YC5G/TR | SC70-5 | 1 | HU4 | 190 | SPK | CON-2/2.54MM | 1 | 8J2 | 191 | SY8113B | SOT23-6 | 3 | 1U1,1U4,1U6 | 192 | SY8120B1ABC | SOT23-6 | 2 | 1U3,1U5 | 193 | TDI | TP12 | 5 | 2T1,2T2,2T3,2T4,5T14 | 194 | TEST12 | TEST12 | 8 | 4T3,4T4,4T5,4T7,4T8,4T12,4T23,4T24 | 195 | TEST12 | VIA0.6 | 2 | 5T3,5T4 | 196 | TLC59116IRHBR | QFN32_0P5_5X5MM | 1 | 8U2 | 197 | TP12 | TP12 | 3 | 4T21,4T22,5TP1 | 198 | TP30 | TP12 | 2 | 6T15,6T16 | 199 | TP30 | TP30 | 42 | 5T5,5T6,5T7,5T8,5T9,5T10,5T11,5T12,6T11,6T12,6T17,6T18,6T19,6T20,6T21,6T22,6T25,6T26,6T27,6T28,6T29,6T30,6T31,6T32,6T33,6T34,6T35,6T36,6T37,6T38,6T39,6T40,6T41,6T42,6T43,6T78,6T79,6T80,6T83,6T84,6T85,6T86 | 200 | TPA3112D1 | HTSSOP_28 | 1 | 8U1 | 201 | TUSB320RWBR | X2QFN12 | 1 | 6U3 | 202 | T_POINT_R_1 | PAD_1X4MM | 1 | P10 | 203 | T_POINT_R_1 | PAD_2X3.5MM | 5 | P3,P4,P5,P6,P9 | 204 | USB_TYPE-C | TYPE-C_USB_24P_SMD_V1.0 | 1 | 6J3 | 205 | WL2803E18-5 | SOT23-5 | 2 | 1U2,1U7 | 206 | WL2803E25-5 | SOT23-5 | 1 | 3U2 | 207 | WNM6001 | SOT-23 | 1 | 9Q2 | 208 | WPM3401 | SOT-23 | 2 | 1Q2,8Q3 | 209 | XR_1204RGB | LED_RGB_90_3.2X1MM | 4 | 8LED1,8LED2,8LED3,8LED4 |
