Name | Part Type | PCB Decal | Value |
C247 | NFM18PC104R1C3 | NFM18PC104R1C3D | NFM18PC104R1C3D |
C248 | CAP_CER_0402_0.1UF_16V_10% | CAP0402 | 0.1uF |
C249 | NFM18PC104R1C3 | NFM18PC104R1C3D | NFM18PC104R1C3D |
C250 | CAP_0603_2.2UF_16V_1% | CAP0603 | 2.2uF |
C301 | 6TPE680M | 6TPE680M | 680uF |
C456 | CAP_CER_0603_0.1UF_50V_10% | CAP0603 | 0.1uF |
D1 | SMP1330-085LF | SMP1330-085LF | SMP1330-085LF |
D2 | LED_0603_BLUE | LED0603 | LDE0603,BLUE |
D7 | SMP1304-079LF | SMP1304-079LF_SC-79 | SMP1304-079LF |
D8 | SMP1304-079LF | SMP1304-079LF_SC-79 | SMP1304-079LF |
D16 | 5.0SMDJ33CA | 5.0SMDJ33CA | 5.0SMDJ33CA |
D17 | VS-30BQ060PBF | VS-30BQ060PBF | VS-30BQ060PbF |
J1 | SMA-KFD1533 | SMA-KFD1533 | SMA-KFD1533 |
J3 | J30J-9ZKWP7-J | J30J-9ZKWP7-J | |
J4 | SMA-KFD1533 | SMA-KFD1533 | SMA-KFD1533 |
J5 | SMA-KFD1533 | SMA-KFD1533 | SMA-KFD1533 |
J8 | 532610471 | 532610471 | |
J11 | CONN._2X6_SMT_1.27MM | CONN._2X6_SMT_1.27MM | |
J12 | 532610571 | 532610571 | 532610571 |
J14 | DIP-3_2.54MM | DIP-3_2.54MM | |
L1 | IND_TMAX-0630-150-M_15.0UH_4.0A_20% | TMAX-0630-150-M | 15.0uH |
L2 | IND_0603_56NH_360MA_2%_LQW18 | IND0603 | 56nH |
L3 | IND_0805_220NH_2%_400MA_LQW2BA | IND0805 | LQW2BASR22G00L |
L4 | IND_0805_220NH_2%_400MA_LQW2BA | IND0805 | LQW2BASR22G00L |
L5 | IND_0603_110NH_200MA_2%_LQW18 | IND0603 | 110nH |
L6 | IND_0603_56NH_360MA_2%_LQW18 | IND0603 | DNP_56nH |
L7 | IND_0402_1.2NH_0.3_300MA_LQG15 | IND0402 | DNP_1.2nH |
L8 | IND_0402_1.0NH_0.3_300MA_LQG15 | IND0402 | DNP_1.0nH |
L9 | IND_0402_BLM15AX221SN1 | IND0402 | BLM15AX221SN1 |
L10 | IND_0603_56NH_360MA_2%_LQW18 | IND0603 | 56nH |
L11 | IND_0402_BLM15AX102SN1 | IND0402 | DNP_BLM15AX102SN1 |
L12 | IND_0805_220NH_2%_400MA_LQW2BA | IND0805 | LQW2BASR22G00L |
L13 | IND_0402_18NH_3%_370MA_LQW15 | IND0402 | 18nH |
L14 | IND_0402_1.2NH_0.3_300MA_LQG15 | IND0402 | 1.2nH |
L16 | IND_0805_220NH_2%_400MA_LQW2BA | IND0805 | LQW2BASR22G00L |
L19 | IND_0402_1.2NH_0.3_300MA_LQG15 | IND0402 | 1.2nH |
L23 | IND_0402_5.6NH_0.2_600MA_LQW15 | IND0402 | 5.6nH |
L24 | IND_0402_5.6NH_0.2_600MA_LQW15 | IND0402 | 5.6nH |
L27 | IND_0402_BLM15AX102SN1 | IND0402 | BLM15AX102SN1 |
L28 | IND_0402_2.2NH_0.2_1000MA_LQW15 | IND0402 | 2.2nH |
L29 | IND_0402_2.2NH_0.2_1000MA_LQW15 | IND0402 | 2.2nH |
L31 | IND_0402_8.2NH_3%_540MA_LQW15 | IND0402 | 8.2nH |
L34 | IND_0402_3.3NH_0.5_900MA_LQW15 | IND0402 | 3.3nH |
L38 | IND_0402_BLM15AX221SN1 | IND0402 | BLM15AX221SN1 |
L41 | IND_0603_56NH_360MA_2%_LQW18 | IND0603 | DNP_56nH |
L48 | IND_0402_BLM15AX102SN1 | IND0402 | BLM15AX102SN1 |
L64 | BLM18KG260TN | IND0603 | BLM18KG260TN |
L66 | IND_XPL2010-103MLB_10UH_20% | XPL2010 | 10uH |
Q2 | DTC114YE | DTC144YE_SOT523 | DTC114YE |
Q3 | 2N7002LT1G | 2N7002LT1_SOT-23 | 2N7002LT1G |
Q4 | DTC114YE | DTC114YE_SC-75 | DTC114YE |
Q5 | 2N7002LT1G | 2N7002LT1_SOT-23 | 2N7002LT1G |
Q6 | DTC114YE | DTC144YE_SOT523 | DTC114YE |
Q7 | BC807-40LT1 | BC807-40LT1_SOT-23 | |
Q8 | DTC114YE | DTC114YE_SC-75 | DTC114YE |
Q11 | BC807-40LT1 | BC807-40LT1_SOT-23 | |
Q13 | DTC114YE | DTC114YE_SC-75 | DTC114YE |
Q14 | BLC9G20XS-160AV | BLC9G20XS-160AV | BLC9G20XS-160AV |
Q21 | DTC114YE | DTC114YE_SC-75 | DTC114YE |
Q22 | AFT27S010NT1 | AFT27S010NT1 | AFT27S010NT1 |
U1 | SC1894A-00A00 | SC1894A-00A00_QFN64P_9X9 | |
U2 | MAX4003EUA | MAX4003EUA | |
U3 | XDL15-2-020S | XDL15-2-020S | XDL15-2-020S |
U4 | SF9332 | SF9332_3.0X3.0 | SF9332 |
U5 | BDCN-7-25+ | BDCN-7-25+ | U00000000369 |
U6 | TPS54202DDC | TPS54202DDC_SOT23-6 | TPS54202DDC |
U7 | MAX4003EUA | MAX4003EUA | |
U8 | SF9332 | SF9332_3.0X3.0 | SF9332 |
U9 | BDCN-7-25+ | BDCN-7-25+ | U00000000369 |
U10 | TQP3M9037 | TQP3M9037 | TQP3M9037 |
U11 | LM50CIM3/NOPB | LM50CIM3/NOPB_SOT-23 | LM50CIM3/NOPB |
U12 | XDL15-2-020S | XDL15-2-020S | XDL15-2-020S |
U14 | LM7301SN1T1G | LM7301SN1T1G_TSOP-5 | |
U15 | PGA-102+ | PGA-102+_SOT89-4 | DNP_PGA-102+ |
U16 | NC7WZ04P6X | NC7WZ04P6X_SC-70-6L | NC7WZ04P6X |
U17 | BD1631J50100AHF | BD1631J50100AHF | BD1631J50100AHF |
U18 | BD1631J50100AHF | BD1631J50100AHF | BD1631J50100AHF |
U19 | H180AZ/1375-1525MHZ | H180AZ/1375-1525MHZ | H180AZ/1375-1525MHz |
U20 | BD1631J50100AHF | BD1631J50100AHF | BD1631J50100AHF |
U23 | SKY12208-478LF | SKY12208-478LF_QFN-16 | SKY12208-478LF |
U27 | C1015J5003AHF | C1015J5003AHF | C1015J5003AHF |
U28 | TQP7M9102 | TQP7M9102_SOT89-4 | DNP_TQP7M9102 |
U32 | STM32F303C8T6 | STM32F303C8T6_LQFP48-7X7 | STM32F303C8T6 |
U33 | LMP92066 | LMP92066 | LMP92066 |
U34 | HC1400P03 | HC1400P03 | HC1400P03 |
U36 | FDG6332C | FDG6332C_SC70-6 | FDG6332C |
U44 | LMP92066 | LMP92066 | LMP92066 |
U46 | LMZ21701SILT | LMZ21701SILT | LMZ21701SILT |
U47 | SGM2019-3.3YN5 | TSOT-23_5 | SGM2019-3.3YN5 |
U48 | LMZ21701SILT | LMZ21701SILT | LMZ21701SILT |
U52 | CJ3439KDW | FDG6332C_SC70-6 | CJ3439KDW |
X1 | X32F-C12SSA_20MHZ | X32F-C12SSA_20MHZ | X32F-C12SSA_20MHZ |
