查看: 6838|回复: 151
[Allegro17.4以下] HC32F460PETB +HC32F460JETA+WM8731SEDS 做的DEMO板PCB文件
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-8-2 12:40:51 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    EV_F460_LQ100_V20_20210901.7z (801 KB, 下载次数: 6)
    D1DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D2DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D3DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D4DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D5DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D6DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D7NUP2105LT1G_SOT23-3_NUP3105LT1GNUP3105LT1GSOT23-3
    D8DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    D9DIODE_TVS_BI_0603_3PF3pF603
    D10DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    D11DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    D12DIODE_TVS_BI_0603_3PF3pF603
    D13DIODE_TVS_BI_0603_3PF3pF603
    D14DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D15DIODE_TVS_BI_0603_3PF3pF603
    D16DIODE_SCHOTTKY_SOD323_NSR0240HTNSR0240HT1GSOD323
    D17DIODE_TVS_BI_0603_3PF3pF603
    D18DIODE_TVS_BI_0603_3PF3pF603
    D19DIODE_TVS_BI_0603_3PF3pF603
    D20DIODE_TVS_BI_0603_3PF3pF603
    D21DIODE_SCHOTTKY_SOD-128_PMEG40T3PMEG40T30SOD-128
    D22DIODE_SCHOTTKY_SOD-128_PMEG40T3PMEG40T30SOD-128
    D23DIODE_SCHOTTKY_SOD-128_PMEG40T3PMEG40T30SOD-128
    D24DIODE_SCHOTTKY_SOD-128_PMEG40T3PMEG40T30SOD-128
    D25DIODE_TVS_BI_0603_3PF3pF603
    D26DIODE_TVS_BI_0603_3PF3pF603
    D27DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    D28DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    D48DIODE_SCHOTTKY_SOD323_BAT60JBAT60JSOD323
    H1TESTLOOP_HOLE3_2X6_IO_M3M3HOLE3_2X6
    H2TESTLOOP_HOLE3_2X6_IO_M3M3HOLE3_2X6
    H3TESTLOOP_HOLE3_2X6_IO_M3M3HOLE3_2X6
    H4TESTLOOP_HOLE3_2X6_IO_M3M3HOLE3_2X6
    J1HDR7X1_HDR7X1_HDR7HDR7HDR7X1
    J2HDR7X1_HDR7X1_HDR7HDR7HDR7X1
    J3HDR4X1_HDR4X1_HDR4HDR4HDR4X1
    J4HDR5X1_HDR5X1_HDR5HDR5HDR5X1
    J5HDR7X1_HDR7X1_HDR7HDR7HDR7X1
    J6HDR7X1_HDR7X1_HDR7HDR7HDR7X1
    J7HDR4X1_HDR4X1_HDR4HDR4HDR4X1
    J8MICROUSB_CON5_MICROUSB_IO_MICROMICROUSBCON5_MICROUSB
    J9JUMPER3_HDR3X1_DIP_8P8X3P9MM_DIDIP3HDR3X1_DIP_8P8X3P9MM
    J10JUMPER3_HDR3X1_JP3JP3HDR3X1
    J11HDR5X1_HDR5X1_HDR5HDR5HDR5X1
    J12M010_SOCKET_B_HDR13X2_HDR13X2HDR13x2HDR13X2
    J13JACK_AUDIO_JACK_AUDIO_5P_JACK_AJACK_AUDIOJACK_AUDIO_5P
    J14MICROUSB_CON5_MICROUSB_IO_MICROMICROUSBCON5_MICROUSB
    J15JACK_AUDIO_JACK_AUDIO_5P_JACK_AJACK_AUDIOJACK_AUDIO_5P
    J16HDR4X2_HDR4X2_JP4X2JP4x2HDR4X2
    J17M010_SOCKET_C_HDR13X2_HDR13X2HDR13x2HDR13X2
    J18M010_SOCKET_A_HDR13X2_HDR13X2HDR13x2HDR13X2
    J19HDR2X1_HDR2X1_HDR2HDR2HDR2X1
    J20JP2_HDR2X1_JP2JP2HDR2X1
    J21HDR5X1_HDR5X1_HDR5HDR5HDR5X1
    J22M010_SOCKET_D_HDR13X2_HDR13X2HDR13x2HDR13X2
    J23SMARTCARD_TH_CON_52400-25ALF_5252400-25ALFTH_CON_52400-25ALF
    J24HDR2X1_HDR2X1_JP2JP2HDR2X1
    J25HDR10X2_ARMJTAG_HDR10X2_JTAG_HDHDR20HDR10X2_JTAG
    J26HDR4X1_HDR4X1_HDR4,FEMALEHDR4,FEMALEHDR4X1
    J27DIP_SWITCH_DIPSWITCH_DIP2DIP2DIPSWITCH
    J28HDR10X2_TRACE_HDR10X2_TRACE_HDRHDR20HDR10X2_TRACE
    J29TFCARD_SOCKET_TF9_CKT01_009D_TFTF-01ATF9_CKT01_009D
    K0KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K1KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K2KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K3KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K4KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K5KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K6KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K7KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K8KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K9KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    K10KEY_4P_KEY_6P2X6P3_BEND_6P2X6P36P2x6P3mmKEY_6P2X6P3_BEND
    L1INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L2CHOKE_0805_CHOKE_90OHM-400MA90ohm-400mA0805_CHOKE
    L3INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L4INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L5INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L6INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L7INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L8CHOKE_0805_CHOKE_90OHM-400MA90ohm-400mA0805_CHOKE
    L9INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L10INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L11INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L12INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L13INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L14INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L15INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    L16INDUCTOR_FERRITE_0603_DISCRETE_100ohm-3A-0.03ohm603
    LED0LED_LED_0805_DISCRETE_REDREDLED_0805
    LED1LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED2LED_LED_0805_DISCRETE_YELLOWYELLOWLED_0805
    LED3LED_LED_0805_DISCRETE_BLUEBLUELED_0805
    LED4LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED5LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED6LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED7LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED8LED_LED_0805_DISCRETE_GREENGREENLED_0805
    LED9LED_DUAL_RG_LED_DUAL_0603_IC_LELED_DUAL_RGLED_DUAL_0603
    MIC1MIC_MIC_4522_MIC_4522MIC_4522MIC_4522
    Q1NPN_SOT23_MMBT5551MMBT5551SOT23
    Q2NPN_SOT23_MMBT5551MMBT5551SOT23
    Q3NPN_SOT23_MMBT5551MMBT5551SOT23
    Q4MOSFET_N_SOT23_IC_BSS138BSS138SOT23
    Q5NPN_SOT23_MMBT5551MMBT5551SOT23
    Q6PNP_SOT23_MMBT5401MMBT5401SOT23
    Q7NPN_SOT23_MMBT5551MMBT5551SOT23
    Q8NPN_SOT23_MMBT5551MMBT5551SOT23
    Q9NPN_SOT23_MMBT5551MMBT5551SOT23
    Q10NPN_SOT23_MMBT5551MMBT5551SOT23
    Q11NPN_SOT23_MMBT5551MMBT5551SOT23
    SW1JUMPER3_SPDT_12P9X6P6MM_DIP3DIP3SPDT_12P9X6P6MM
    U1USBLC6-2_SOT23-6_USBLC6-2USBLC6-2SOT23-6
    U2M010_LQFP48_LQFP48_S_HC32F460JEHC32F460JETALQFP48_S
    U3WM8731SEDS_SSOP28_WM8731SEDSWM8731SEDSSSOP28
    U4SGM803_SOT23_SGM803SGM803SOT23
    U5TPS2051BDBV_SOT23_SOT23-5_TPS20TPS2051BDBVRSOT23-5
    U6TJA1042T/3_SO8_IC_TJA1042T/3TJA1042T/3SO8
    U7W25Q64JVSSIQ_SO8_L_W25Q64JVSSIQW25Q64JVSSIQSO8_L
    U8HC32F460PETB_S_LQFP100-14X14MM_HC32F460PETBLQFP100-14X14MM
    U9BL6281_SO8_BL6281BL6281SO8
    U10AT24C256_SO8_BL24C256BL24C256SO8
    U11SN74CB3Q3257PWR_TSSOP16_SN74CB3SN74CB3Q3257TSSOP16
    U12LM1117_SOT-223_BL8072CLTR33BL8072CLTR33SOT-223
    U13TS5A4595_SOT23-5_TS5A4595TS5A4595SOT23-5
    Y1XTAL_2P_HC-49S_IC_12.288MHZ,20P12.288MHz,20pFHC-49S
    Y2XTAL_2P_HC-49S_IC_8MHZ,20PF8MHz,20pFHC-49S
    Y3XTAL_4P_SMD3225_IC_8MHZ,12PF8MHz,12pFSMD3225
    Y4XTAL_2P_SMD3215_2P_IC_32.768KHZ32.768KHz,12.5pFSMD3215_2P
    重要提示:PCB作品文件展下载说明
    发表于 2022-8-2 15:30:43 | 显示全部楼层
    STM32替代方案 | HC32F460PETB
    华大单片机HC32F460JETA
    WM8731 / WM8731L便携式因特网音频编解码器与耳机驱动器和可编程的采样率
    发表于 2022-8-2 16:51:11 | 显示全部楼层
    昨天 08:43
  • 签到天数: 228 天
    发表于 2022-8-2 19:20:54 | 显示全部楼层
    PADS20200316初级班
    发表于 2022-8-2 21:27:20 | 显示全部楼层
    昨天 19:04
  • 签到天数: 134 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2022-8-2 22:45:40 | 显示全部楼层
    昨天 11:06
  • 签到天数: 217 天
    发表于 2022-8-3 00:06:25 | 显示全部楼层
    发表于 2022-8-3 00:07:03 | 显示全部楼层
    发表于 2022-8-3 00:10:25 | 显示全部楼层
    发表于 2022-8-3 00:31:57 | 显示全部楼层
