印制电路板(Printed Circuit Board,PCB)导线(Conductor Pattern)原件面(Component Side)焊接面(Solder side)边接头(Edge connector)槽(Slot)阻焊层(Sloder Mask)丝网印刷层(Silk Screen)图标面(Legend)单面板(Single-Side Board,SSB)双面板(Double-Side Boards,DSB)多层板(Multi-Layer Boards,MLB)过孔(Via)埋孔(Buried Via):埋孔只连接内部的PCB,所以从表面是看不出来的。盲孔(Blind Via):盲孔是将几层内部PCB与表面PCB连接,不需穿透整个板子。通孔(Through Via)信号层(Signal)电源层(Power)地线层(Ground)钻孔(Drill Hole)铜膜导线(Track)安全间距(Clearance)焊盘(Pad)插入式(Through Hole Technology,THT)表面粘贴式(Surface Mounted Technology,SMT)<br / |
