TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 24680
重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | CN5 | CON24P_0P5MM-R | CON24P_0P5MM-R | 翻盖式 间距0.5mm H2.0MM 下接 24PIN | CN6 | CON12P_SMD_05MM_R | CON12P_SMD_05MM_R | 翻盖式间距0.5MM H2.0MM 下接12PIN | CON2 | MICROUSB-1502 | MICROUSB-1502 | USB Port/Mini-B/5pin/SMD | D1 | ES0402_V014CT | ESD0402A | V014CT | D2 | ES0402_V014CT | ESD0402A | V014CT | D4 | SOD-123 | SOD-123 | B5819W | D6 | SOD-123 | SOD-123 | B5819W | D7 | SOT-23 | SOT-23 | BAT54S | D8 | SOD-123 | SOD-123 | NC/18V | D9 | SOT-23 | SOT-23 | BAT54S | D10 | SOD-123 | SOD-123 | NC/-6V | D11 | SOT-23 | SOT-23 | NC/BAT54C | D12 | SOD-123 | SOD-123 | B5819W | D15 | ES0402_V014CT | ESD0402A | V014CT | D16 | ES0402_V014CT | ESD0402A | V014CT/NC | D18 | ES0402_V014CT | ESD0402A | V014CT/NC | D19 | ES0402_V014CT | ESD0402A | V014CT/NC | D21 | ES0402_V014CT | ESD0402A | V014CT/NC | D23 | SOD-123 | SOD-123 | NC/B5819W | FB5 | L0603 | L0603 | NC | FB6 | L0603 | L0603 | NC | FB8 | L0603 | L0603 | 120R/100MHz | FB11 | L0603 | L0603 | 120R/100MHz | FB17 | L0805 | L0805 | 120R/100MHz | J1 | DC-056 | DC-056 | DC-056 | J3 | SMTXH-V-4 | SMTXH-V-4 | NC/CON4P | J4 | RF-1 | RF-1 | RF | J9 | HDMI-19FP_C | HDMI-19FP_C | HDMI_C | J10 | PJ-3537 | PJ-3537 | PJ-3537 | J18 | CARTEST | CARTEST | NC | J19 | AT070TN92 | AT070TN92 | 间距0.5MM,高2.0MM,50PIN 翻盖 双面接触旋转前插后压式 | K1 | BST-114A | BST-114A | Button | K4 | BST-114A | BST-114A | Button | L+1 | CON1 | DRL-3 | CON1 | L-1 | CON1 | DRL-3 | CON1 | L5 | L_SMD_4X4_3 | L_SMD_4X4_3 | 4.7uH | L6 | L4_5 | L4_5 | | L7 | L4_5 | L4_5 | | L8 | L4_5 | L4_5 | 22uH | L9 | COMMON-COIL4P | COMMON-COIL4P | NC/EXD24CD900U | L17 | L4_5 | L4_5 | | L18 | L4_5 | L4_5 | | L19 | L4_5 | L4_5 | | L20 | L4_5 | L4_5 | | M3 | MARK | MARK | CON1 | M4 | MARK | MARK | CON1 | M5 | MARK | MARK | CON1 | M6 | MARK | MARK | CON1 | MK1 | MICROPHONE | MICROPHONE2 | MICROPHONE | Q1 | SI2305_SOT23 | SOT23 | NCE2305 | Q2 | SI2305_SOT23 | SOT23 | NCE2305 | Q3 | 8050_SOT23 | SOT23 | 8050 | Q4 | SI2306_SOT23 | SOT23 | SI2306 | Q6 | SOT-23 | SOT-23 | WPM2015 | Q18 | SI2305_SOT23 | SOT23 | NCE2305 | Q21 | SI2305_SOT23 | SOT23 | NCE2305 | Q23 | SI2305_SOT23 | SOT23 | NCE2305 | RP9 | 4X0402R | 4X0402R | 4x10K | SW1 | BST-114A | BST-114A | Button_PKEY | SW2 | SW-KFC-A04 | SW-KFC-A04 | NC/Reset_KEY | U1 | AXP202-02 | QFN-48P | AXP202-02 | U2 | G5728 | SOT23-5 | LC3406 | U3 | ZEN056 | ZEN056 | NC | U4 | SOT23-6 | SOT23-6 | SY8009BABC | U5 | SOT23-6 | SOT23-6 | SY7152abc | U6 | ALC5631Q_3 | QFN32_5X5MM | WM8960 | U7 | RL_UM02BS_RTL8188CTV | UM02BS | RTL8188EUS | U8 | LM4890 | MSOP8 | MD4103S | U9 | NAND-ALL | TSOP-48 | NC/29F32G08CBACA | U10 | NAND-ALL | TSOP-48 | 29F32G08CBACA | U11 | MC3230_DNF-10 | DFN_10PIN | MC3230 | U13 | SOP_8L_150 | SOP_8L_150 | NC/512KByte_SPI_Nor | U14 | SOT23-6 | SOT23-6 | SY7200A | U15 | SOT23-6 | SOT23-6 | LC3300 | U16 | SY6280_SOT23-5 | SOT23-5 | SY6280 | U17 | TF-CKT01-009D | TF-CKT01-009D | TF | U19 | DFN-10 | DFN-10 | NC | U25 | SLP2510P8 | SLP2510P8 | NC/ESDA6V8UD | U26 | SLP2510P8 | SLP2510P8 | NC/ESDA6V8UD | U28 | VA7318-2.8V_SOT23-5 | SOT23-5 | LC1463CB5ATR28 | U30 | SOT23-5 | SOT23-5 | NC/LC1463CB5ATR18 | U31 | VA7318-1.8V_SOT23-5 | SOT23-5 | LC1463CB5ATR18 | U37 | AML8726-MXS | BGA408_OP65MM_S | AML8726-MXL | U41 | BGA78-DDR3 | BGA78-DDR3 | DDR3_78P_8b | U42 | BGA78-DDR3 | BGA78-DDR3 | DDR3_78P_8b | U43 | BGA78-DDR3 | BGA78-DDR3 | DDR3_78P_8b | U44 | BGA78-DDR3 | BGA78-DDR3 | DDR3_78P_8b | Y1 | XTAL-32K768HZB | XTAL-32K768HZB | 32.768KHz | Y2 | Y-SJK_4P2_5X3_2 | Y-SJK_4P2_5X3_2 | 24MHz_20pF |
重要提示:PCB作品文件展下载说明
