要T0 T1产生中断其实很容易,开 ET0 允许中断,然后开 EA 就行了。; MCU : AT89S52 at 12MHZ; Compiler: Keil C51; Author : Etual; Date : 2012-1-7;-------------------------------------------------; vector;------------------------------------------------- ORG 00H LJMP RESET_HANDLER ORG 0BH LJMP INT_T0 ORG 1BH LJMP INT_T1;-------------------------------------------------; main program;-------------------------------------------------INT_T0: PUSH ACC PUSH PSW CPL P1.0 POP PSW POP ACC RETIINT_T1: PUSH ACC PUSH PSW CPL P1.1 POP PSW POP ACC RETI ;-------------------------------------------------; main program;-------------------------------------------------RESET_HANDLER: MOV SP,#70HMAIN: CALL SYSTEM_INIT MOV TMOD,#12H SETB TR0 SETB TR1 SETB ET0 SETB ET1 SETB EALOOP: JMP LOOP;-------------------------------------------------; sub routine;-------------------------------------------------; SYSTEM INITSYSTEM_INIT:SYSTEM_INIT_END: RET END |
