查看: 1060|回复: 9
[Allegro17.4以下] UCC21521做的 HV High Frequency LLC  CRD06600DD065N_HV_HF_LLC_REV2
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2022-10-16 11:50:03 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    CRD06600DD065N_HV_HF_LLC_REV2.zip (823 KB, 下载次数: 6)
    C1LEC249_AL_150UF_250V_18ODX25_C30.22uFC3640
    C2LEC249_AL_150UF_250V_18ODX25_C30.22uFC3640
    C4LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C5LEC257_FILM_0.015UF_1KVDC_CAP_22.2nCAP_B32671L_AXIAL_394
    C6LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C7LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C8LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C9LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C10LEC053_CKG_2220_630V_C3640_2.2U2.2uFC3640
    C13LEC257_FILM_0.015UF_1KVDC_CAP_B3.3nCAP_B32671L_AXIAL_394
    C14LEC257_FILM_0.015UF_1KVDC_CAP_14.7nCAP_B32671L_AXIAL_394
    C15LEC257_FILM_0.015UF_1KVDC_CAP_14.7nCAP_B32671L_AXIAL_394
    C16LEC275_2220_250V_C3640_18NF18nFC3640
    C17LEC275_2220_250V_C3640_18NF18nFC3640
    C18LEC275_2220_250V_C3640_18NF18nFC3640
    C19LEC275_2220_250V_C3640_18NF18nFC3640
    C25LEC257_FILM_0.015UF_1KVDC_CAP_22.2nCAP_B32671L_AXIAL_394
    C27LEC172_X7R_1206_1000V_C1812_100100pFC1812
    C28LEC172_X7R_1206_1000V_C1812_100100pFC1812
    C29LEC172_X7R_1206_1000V_C1812_100100pFC1812
    C30LEC172_X7R_1206_1000V_C1812_100100pFC1812
    C31LEC475_CER_1812_1000V_C1812_1.21.2nFC1812
    C32LEC475_CER_1812_1000V_C1812_1.21.2nFC1812
    C35LEC275_2220_250V_C2225_3.9NF3.9nFC2225
    C36LEC275_2220_250V_C2225_3.9NF3.9nFC2225
    C39LEC249_AL_150UF_250V_18ODX25_C30.22uFC3640
    C40LEC249_AL_150UF_250V_18ODX25_LP1uFLP_L-STYLE_CAP
    CON1KEYSTONE8174_KEYSTONE8174_DCIN+DCIN+KEYSTONE8174
    CON2KEYSTONE8174_KEYSTONE8174_DCIN-DCIN-KEYSTONE8174
    CON3KEYSTONE8174_KEYSTONE8174_VOUTPVOUTPKEYSTONE8174
    CON4KEYSTONE8174_KEYSTONE8174_SGNDSGNDKEYSTONE8174
    CT1PA1005_CT_PA1005_CT_PA1005_CTPA1005_CTPA1005_CT
    D1DIODESCHOTTKY_SMDSOD123_B140HWB140HW-7SMDSOD123
    D2DIODESCHOTTKY_SMDSOD123_B140HWB140HW-7SMDSOD123
    D3DIODE_SCHOTTKY_AKA_TO-247-3L_SLC3D16060DTO-247-3L_SLOTTED
    D4DIODE_SCHOTTKY_AKA_TO-247-3L_SLC3D16060DTO-247-3L_SLOTTED
    D5DIODE_SCHOTTKY_AKA_TO-247-3L_SLC3D16060DTO-247-3L_SLOTTED
    D6DIODE_SCHOTTKY_AKA_TO-247-3L_SLC3D16060DTO-247-3L_SLOTTED
    D7DIODESCHOTTKY_SMDSOD123_MMSZ_1MMSZ5226B-7-FSMDSOD123
    D8DIODESCHOTTKY_SMDSOD123_MMSZ52MMSZ5246B-TPSMDSOD123
    D9DIODESCHOTTKY_SMDSOD123_MMSZ_1MMSZ5226B-7-FSMDSOD123
    D10DIODESCHOTTKY_SMDSOD123_MMSZ52MMSZ5246B-TPSMDSOD123
    D11DIODESCHOTTKY_SMDSOD123_B140HWB140HW-7SMDSOD123
    D12DIODESCHOTTKY_SMDSOD123_B140HWB140HW-7SMDSOD123
    D13DIODEZENER_SM_SOD123___20V_20VSM_SOD123
    D14DIODEZENER_SM_SOD123___20V_20VSM_SOD123
    D15DIODEZENER_SM_SOD123___20V_20VSM_SOD123
    D16DIODEZENER_SM_SOD123___20V_20VSM_SOD123
    D17DIODESCHOTTKY_SMDSOD123_MMSZ_1MMSZ5226B-7-FSMDSOD123
    D18DIODESCHOTTKY_SMDSOD123_MMSZ52MMSZ5246B-TPSMDSOD123
    D19DIODESCHOTTKY_SMDSOD123_MMSZ_1MMSZ5226B-7-FSMDSOD123
    D20DIODESCHOTTKY_SMDSOD123_MMSZ52MMSZ5246B-TPSMDSOD123
    D21DIODE_BAT754S_SOT-23_DIODE_BAT7DIODE_BAT754SSOT-23
    D22DIODE_BAT754S_SOT-23_DIODE_BAT7DIODE_BAT754SSOT-23
    D53LED167_Z_4.7V_500MW_SOD123_SOD13.3VSOD123
    D54LED167_Z_4.7V_500MW_SOD123_SOD13.3VSOD123
    D55LED005_1000V_1A_DO214AC_DIO-SMAES1J-LTPDIO-SMA
    D56LED005_1000V_1A_DO214AC_DIO-SMAES1J-LTPDIO-SMA
    D57LED167_Z_4.7V_500MW_SOD123_SOD13.3VSOD123
    D60LED167_Z_4.7V_500MW_SOD123_SOD13.3VSOD123
    D61DIODE_0_TO220-2_STTH5L06STTH5L06TO220-2
    FB1BEAD_R0603_BEADBEADR0603
    FB2BEAD_R0603_BEADBEADR0603
    FB3BEAD_R0603_BEADBEADR0603
    FB4BEAD_R0603_BEADBEADR0603
    HS1HEAT_SINK_MTG_M3_SLOT_MOSFETHEMOSFETHEAT_SINKMTG_M3_SLOT
    HS2HEAT_SINK_DIODE_HS1-2A_DIODEHEDIODEHEAT_SINKDIODE_HS1-2A
    HS3HEAT_SINK_DIODE_HS1-2B_DIODEHEDIODEHEAT_SINKDIODE_HS1-2B
    J1BNC_BNC_HOR_PWMAPWMABNC_HOR
    J2BNC_BNC_HOR_PWMBPWMBBNC_HOR
    J3CONNTRBLK 2_SHRD_TERM_BLK_2X1_12VDCSHRD_TERM_BLK_2X1_197
    J5CONNSOCKET 60X2_HSEC8-160_RVRSCONNSOCKET 60x2HSEC8-160_RVRS_PINS
    J6JUMPER_HEADER_2X1_100_JUMPERJUMPERHEADER_2X1_100
    J7HEADER5X2_HEADER_5X2_100_HEADEHEADER5X2HEADER_5X2_100
    J8JUMPER_HEADER_2X1_100_JUMPERJUMPERHEADER_2X1_100
    J9CON1_JUMPER_PTH_10AWG_VOUTVOUTJUMPER_PTH_10AWG
    J10CON1_JUMPER_PTH_10AWG_HVDCHVDCJUMPER_PTH_10AWG
    J11CON1_JUMPER_PTH_10AWG_GND_PWRGND_PWRJUMPER_PTH_10AWG
    J12CON1_JUMPER_PTH_10AWG_GND_SIGGND_SIGJUMPER_PTH_10AWG
    L1LET0121_CM_2.95MH_0.5MM_CM_CHOK175uH10ACM_CHOKE_74482210002
    L2IND-CSCF2012_IND-CSCF2012_CSCF2CSCF2012-1R5MCIND-CSCF2012
    L3CHOKECM_SM_CHOKE_CM_2_CHOKE CMCHOKECMSM_CHOKE_CM_2
    L4CHOKECM_SM_CHOKE_CM_2_CHOKE CMCHOKECMSM_CHOKE_CM_2
    L5CHOKECM_SM_CHOKE_CM_2_CHOKE CMCHOKECMSM_CHOKE_CM_2
    L6CHOKECM_SM_CHOKE_CM_2_CHOKE CMCHOKECMSM_CHOKE_CM_2
    Q1MOSFET_TO-247-3L_SLOTTED_C3M006C3M0065090DTO-247-3L_SLOTTED
    Q2MOSFET_TO-247-3L_SLOTTED_C3M006C3M0065090DTO-247-3L_SLOTTED
    Q3MOSFET_TO-247-3L_SLOTTED_C3M006C3M0065090DTO-247-3L_SLOTTED
    Q4MOSFET_TO-247-3L_SLOTTED_C3M006C3M0065090DTO-247-3L_SLOTTED
    T3XFMR-PQ5030_XFMR-PQ5030_XFMR-PQxfmr-PQ5030XFMR-PQ5030
    U1UCC21521_0_UCC21521_UCC21521UCC21521UCC21521
    U2UCC21521_0_UCC21521_UCC21521UCC21521UCC21521
    U6LM317/TO220_0_D2PAK123_MC7805MC7805D2PAK123
    X1RP-1212D_0_R12P212D___MEJ2D1209MEJ2D1209SCR12P212D
    X2RP-1212D_0_R12P212D___MEJ2D1209MEJ2D1209SCR12P212D
    X3RP-1212D_0_R12P212D___MEJ2D1209MEJ2D1209SCR12P212D
    X4RP-1212D_0_R12P212D___MEJ2D1209MEJ2D1209SCR12P212D
    X5HV_HF_LLC_CAP_BANK_HV_HF_LLC_CAHV_HF_LLC_CAP_BANKHV_HF_LLC_CAP_BANK
    XA1FLYBACK_PS_FLYBACK_DAUGHTER_BRDFLYBACK_PSFLYBACK_DAUGHTER_BRD
    重要提示:PCB作品文件展下载说明
    2 小时前
  • 签到天数: 206 天
    PADS20220105初级班
    发表于 2022-10-16 11:54:27 | 显示全部楼层
    前天 19:04
  • 签到天数: 134 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2022-10-16 12:01:33 | 显示全部楼层
    发表于 2022-10-16 12:16:26 | 显示全部楼层
  • 签到天数: 28 天
    PADS20210412初级班
    发表于 2022-10-16 20:43:07 | 显示全部楼层
    前天 12:15
  • 签到天数: 197 天
    发表于 2022-10-17 08:36:48 | 显示全部楼层
    发表于 2022-10-17 08:41:07 | 显示全部楼层
    昨天 13:48
  • 签到天数: 104 天
    发表于 2022-10-17 09:08:31 | 显示全部楼层
  • 签到天数: 4 天
    PADS20220105初级班
    发表于 2022-10-17 09:15:38 | 显示全部楼层
    昨天 08:34
  • 签到天数: 69 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2022-10-17 10:44:20 | 显示全部楼层
