查看: 758|回复: 9
[Allegro17.4以下] S32K358+MK26FN2M0VMI18+PFS26ZZXMA0D+TJA1103A 做的PCB文件
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2023-10-16 11:14:37 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    D1LED_LED_0603_IC_0.67MM_370-75622_LEDORANGELEDORANGELED_0603
    D2LED_LED_0603_IC_0.67MM_370-75622_LEDORANGELEDORANGELED_0603
    D3LED_LED_0603_IC_0.80MM_370-76779_LEDREDLEDREDLED_0603
    D4LED_LED_0603_IC_0.67MM_370-75622_LEDORANGELEDORANGELED_0603
    D5LED_LED_0603_IC_0.67MM_370-75622_LEDORANGELEDORANGELED_0603
    D6DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D7DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D8DIODE_BIDIR_SOD323_BID_IC_1.1MM_480-78805_PESD1LINPESD1LINSOD323_BID
    D9DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D10DIODE_BIDIR_SOD323_BID_IC_1.1MM_480-78805_PESD1LINPESD1LINSOD323_BID
    D11DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D12RCLAMP1654P_NEW_SLP1616P6_IC_0.65MM_480-78843_RCLAMP0854P.TCTRClamp0854P.TCTSLP1616P6
    D13LED_TRI_COLOR_LED6_5X6MM_IC_2.6MM_370-76661_LED RED/GRN/BLLEDRED/GRN/BLLED6_5X6MM
    D14LED_LED_0603_IC_0.9MM_370-76460_LEDORANGELEDORANGELED_0603
    D15LED_LED_0603_IC_0.80MM_370-76779_LEDREDLEDREDLED_0603
    D16ZDIODE_SOD123_IC_1.35MM_480-76297_MMSZ8V2T1GMMSZ8V2T1GSOD123
    D17DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D18DIODE_TVS_BIDIR_DIODE2_50X30_IC_0.36MM_480-77928_PGB101PGB101DIODE2_50X30
    D19DIODE_TVS_BIDIR_DIODE2_50X30_IC_0.36MM_480-77928_PGB101PGB101DIODE2_50X30
    D20LED_LED_0603_IC_0.8MM_370-76670_LED_GRNLED_GRNLED_0603
    D21LED_LED_0603_IC_0.8MM_370-76670_LED_GRNLED_GRNLED_0603
    D22DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    D23DIODE_SCHTKY_SOD-128_IC_1.1MM_480-78943_PMEG4050EPPMEG4050EPSOD-128
    F1FUSE_FUSE_3P1X1P5_DISCRETE_1.575MM_510-78294_0458003.DR0458003.DRFUSE_3P1X1P5
    FL6BEAD_IND_0603_DISCRETE_0.95MM_180-77516_600OHM600OHMIND_0603
    FL7BEAD_IND_0603_DISCRETE_0.95MM_180-77516_600OHM600OHMIND_0603
    FL8BEAD_IND_0603_DISCRETE_0.95MM_180-77516_600OHM600OHMIND_0603
    GND3TEST_POINT_TP_TH_063_IC_5.6MM_210-30155_50065006TP_TH_063
    GND4TEST_POINT_TP_TH_063_IC_5.6MM_210-30155_50065006TP_TH_063
    J1CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J2HDR-3X8_A_CON_3X8_100_TH_IO_16.256MM_210-81399_ESQ-108-33-T-TESQ-108-33-T-TCON_3X8_100_TH
    J3HDR-3X10_A_CON_3X10_100_TH_640H_IO_16.38MM_210-81402_ESQ-110-33-T-TESQ-110-33-T-TCON_3X10_100_TH_640H
    J4CONN_HDR_10X2_HDR210_ESQ_SKT_IO_16.38MM_210-81129_CON 2X10CON2X10HDR210_ESQ_SKT
    J5CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3HDR1X3HDR103_A
    J8CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J9CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J10CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J12CONN_HDR_10X2_HDR210_FTSH_SM_IO_6.35MM_211-78962_HDR_2X10HDR_2X10HDR210_FTSH_SM
    J13CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J14DC_POWER_JACK_SHD_CON3_PWR_JACK_TH_PJ051A_IO_7.5MM_210-79945_CONPWR 3CONPWR 3CON3_PWR_JACK_TH_PJ051A
    J15CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J16CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J18CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3HDR1X3HDR103_A
    J20CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J21CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J22CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3HDR1X3HDR103_A
    J23CONN_HDR_4X2_HDR_2X4_SSW_TH_RA_IO_4.95MM_210-81374_CON SKT 2X4CONSKT 2X4HDR_2X4_SSW_TH_RA
    J24CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J25CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J26CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J27CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J28CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J30CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J31CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3HDR1X3HDR103_A
    J32CONN_HDR_4X1_HDR_1X4_SSW_TH_RA_IO_2.54MM_210-81411_CON_1X4CON_1X4HDR_1X4_SSW_TH_RA
    J34CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J36CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J37CONN_HDR_8X2_HDR208_ESQ_SKT_IO_16.38MM_210-80918_CON_2X8CON_2X8HDR208_ESQ_SKT
    J38CONN_HDR_10X2_HDR210_ESQ_SKT_IO_16.38MM_210-81129_CON 2X10CON2X10HDR210_ESQ_SKT
    J39HDR-3X8_A_CON_3X8_100_TH_IO_16.256MM_210-81399_ESQ-108-33-T-TESQ-108-33-T-TCON_3X8_100_TH
    J40USB_MINI_AB_RECEPTACLE_CON5_MICROUSB_IO_2.65MM_211-78722_MICROUSB AB 5MICROUSB AB 5CON5_MICROUSB
    J41CONN_HDR_5X2_CON_2RH_10_50_IO_3.91MM_210-07961-00_HDR 2X5HDR2X5CON_2RH_10_50
    J42CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J43CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J44CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J413CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J414CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J415CON_1-PORT_MATENET_8P_CON_MATENET_1X2_RA_TH_IO_13.6MM_210-82738_2304372-12304372-1CON_MATENET_1X2_RA_TH
    J418CONN_HDR_5X2_7_HDR205_10M_50_SM_K_P_IO_6.7MM_211-79746_FTSH-105-01-L-DV-007-K-P-TRFTSH-105-01-L-DV-007-K-P-TRHDR205_10M_50_SM_K_P
    J423CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J424CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J425CONN_HDR_3X1_HDR103_A_IO_8.74MM_210-80732_HDR1X3HDR1X3HDR103_A
    J426CONN_HDR_1X1_TH_HDR_1X1_IO_8.59MM_210-81066_HDR1X1HDR1X1HDR_1X1
    J427CONN_HDR_2X1_HDR1X2_5P48X2P69_IO_8.69MM_210-80468_HDR1X2HDR1X2HDR1X2_5P48X2P69
    J428CONN_HDR_2X1_CON2_TB_5P0_TH_457H_IO_11.6MM_210-82945_CONTB 2CONTB 2CON2_TB_5P0_TH_457H
    J430CONN_SDCARD_1X13F_DM3B_CON_SDCARD_14F_43_SM_RA_IO_2.23MM_211-78853_SD/MMCSKTSD/MMCSKTCON_SDCARD_14F_43_SM_RA
    L1INDP_IND2_7P4X6P9_SM_DISCRETE_4.5MM_180-78917_4.7UH4.7uHIND2_7P4X6P9_SM
    L2IND_FERRITE_IND_0603_DISCRETE_0.75MM_180-78352_BLM18KG121TZ1_25%BLM18KG121TZ1IND_0603
    L3INDUCTOR_IND_2016A_DISCRETE_1MM_180-78522_1.0UH1.0uHIND_2016A
    L4IND_FERRITE_IND_0603_DISCRETE_0.75MM_180-78352_BLM18KG121TZ1_25%BLM18KG121TZ1IND_0603
    L5INDUCTOR_FERRITE_IND_0402_DISCRETE_0.55MM_180-77768_30OHM_25%30OHMIND_0402
    L6INDUCTOR_IND2_XAL40_DISCRETE_4.1MM_180-78179_10UH10uHIND2_XAL40
    L7IND_FERRITE_IND_0603_DISCRETE_0.75MM_180-78352_BLM18KG121TZ1_25%BLM18KG121TZ1IND_0603
    L8DLW43_IND_3P4X2P7_SMT_DISCRETE_2.5MM_180-78842_DLW32MH201XK2LDLW32MH201XK2LIND_3P4X2P7_SMT
    L9INDUCTOR_B_IND2_SQ4P31_2_SM_DISCRETE_2MM_180-79766_5.6UH5.6uHIND2_SQ4P31_2_SM
    Q1NPN_SOT23_A_IC_1.1MM_480-79881_BC846BBC846BSOT23_A
    Q2NPN_SOT23_A_IC_1.1MM_480-79881_BC846BBC846BSOT23_A
    Q3BUK6D23-40E_SOT1220_8P_SOT1220_IC_0.65MM_480-80563_BUK9D23-40EXBUK9D23-40EXSOT1220
    Q4TRAN_NPN_SOT223_SOT223_IC_1.8MM_480-79956_BCP56-16TXBCP56-16TXSOT223
    Q5NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF2SC4738-GR,LFSC_75
    Q6NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF2SC4738-GR,LFSC_75
    Q7NPN_SC_75_IC_0.9MM_480-80562_2SC4738-GR,LF2SC4738-GR,LFSC_75
    Q8NPN_SOT23_A_IC_1.1MM_480-80155_BC847BBC847BSOT23_A
    Q9MOSFET_N_SOT-23_IC_1.2MM_480-79852_SI2302CDSSi2302CDSSOT-23
    Q10PNP_SOT23_A_IC_1.1MM_480-79950_BC857BBC857BSOT23_A
    Q11NPN_SOT23_A_IC_1.1MM_480-80155_BC847BBC847BSOT23_A
    Q12PNP_SOT23_A_IC_1.1MM_480-79950_BC857BBC857BSOT23_A
    Q13MOSFET_N_SOT-23_IC_1.2MM_480-79852_SI2302CDSSi2302CDSSOT-23
    Q16MOSFET_P_5P_SO8_MLPAK33_IC_0.9MM_480-80585_PXP400-100QSPXP400-100QSMLPAK33
    Q20PNP_SOT23_A_IC_1.1MM_480-79950_BC857BBC857BSOT23_A
    Q21NPN_SOT23_A_IC_1.1MM_480-80155_BC847BBC847BSOT23_A
    SW1SW3_SPDT_SLD_TH_SW3_SLD_SPDT_RA_IC_6.85MM_510-77905_500SSP3S1M6QEA500SSP3S1M6QEASW3_SLD_SPDT_RA
    SW2ELECTRODE_ELECTRODE_SQ_15MM_IC_0MM_510-76938_ELECTRODEElectrodeELECTRODE_SQ_15MM
    SW3ELECTRODE_ELECTRODE_SQ_15MM_IC_0MM_510-76938_ELECTRODEElectrodeELECTRODE_SQ_15MM
    SW4SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-21825967-2SW4_6X6MM_TH
    SW5SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-21825967-2SW4_6X6MM_TH
    SW6SW_PB_4P_SW4_6X6MM_TH_IC_7.7MM_510-78028_1825967-21825967-2SW4_6X6MM_TH
    U9S32K344_MQFP172_P_T1_ALT2_MQFP172_0P65_16X16_IC_1.75MM_TMP-CIP-6843_S32K344_172MAXQFPS32K344_172MAXQFPMQFP172_0P65_16X16
    U12PFS26ZZXMA0D_LQFP_48_LQFP48_EP146MIL_IC_1.6MM_TMP-CIP-2883_PFS26ZZXMA0DPFS26ZZXMA0DLQFP48_EP146MIL
    U13ESD_DIODE_2LINE_SOT23_A_IC_1.1MM_480-79595_PESD2CANPESD2CANSOT23_A
    U16MX25L6433FM2R_SOP8_SO8-25X75-200_IC_2.16MM_334-77865_MX25L6433FM2I-08GMX25L6433FM2I-08GSO8-25X75-200
    U21NTS0102_XSON8_0P5_3P1X2P1_IC_0.5MM_312-82318_NTS0102GDNTS0102GDXSON8_0P5_3P1X2P1
    U22NTS0102_XSON8_0P5_3P1X2P1_IC_0.5MM_312-82318_NTS0102GDNTS0102GDXSON8_0P5_3P1X2P1
    U2374LVCH1T45_6P_SOT1202_0P35_1P05X1P05_IC_0.35MM_312-81756_74LVC1T45GS74LVC1T45GSSOT1202_0P35_1P05X1P05
    U24MK26FN2M0VMI18_BGA_169P_BGA169_0P65_9X9_IC_1.33MM_344-02189_MK26FN2M0VMI18MK26FN2M0VMI18BGA169_0P65_9X9
    U2574LVCH1T45_6P_SOT1202_0P35_1P05X1P05_IC_0.35MM_312-81756_74LVC1T45GS74LVC1T45GSSOT1202_0P35_1P05X1P05
    U2674LVCH1T45_6P_SOT1202_0P35_1P05X1P05_IC_0.35MM_312-81756_74LVC1T45GS74LVC1T45GSSOT1202_0P35_1P05X1P05
    U27DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U2874LVCH1T45_6P_SOT1202_0P35_1P05X1P05_IC_0.35MM_312-81756_74LVC1T45GS74LVC1T45GSSOT1202_0P35_1P05X1P05
    U29MIC2005-0.8YM6_SOT23-6_A_IC_1.45MM_315-79199_MIC2005-0.8YM6MIC2005-0.8YM6SOT23-6_A
    U31TJA1022T_SO_14P_SOIC14_1P27_4X8_IC_1.75MM_312-81345_TJA1022TTJA1022TSOIC14_1P27_4X8
    U33DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U34TJA1043ATK_14P_EP_HVSON14_0P65_4P6X3P1_EP_IC_1MM_312-82956_TJA1443ATKTJA1443ATKHVSON14_0P65_4P6X3P1_EP
    U35LM4040_SOT23_SOT23-3_IC_1.13MM_315-80874_LM4040C30IDBZRLM4040C30IDBZRSOT23-3
    U36ESD_DIODE_2LINE_SOT23_A_IC_1.1MM_480-80185_PESD2ETH1G-TPESD2ETH1G-TSOT23_A
    U37TJA1103A_HVQFN36_QFN36_0P5_6X6_IC_1.0MM_TMP-CIP-5181_TJA1103ATJA1103AQFN36_0P5_6X6
    U38S32K358_MAXQFP172_A_MQFP172_0P65_16X16_EP_IC_1.75MM_TMP-CIP-9104_S32K358_172MAXQFP_EPS32K358_172MAXQFP_EPMQFP172_0P65_16X16_EP
    U69DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U71DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U72DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U73DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    U74DIODEZ_SOT23_SOT23_A_IC_1.1MM_480-79638_BZX84-A5V6BZX84-A5V6SOT23_A
    Y1XTAL_13_XTLOSC4_3P2X2P5MM_SM_IC_0.6MM_230-78103_25MHZ25MHzXTLOSC4_3P2X2P5MM_SM
    Y2XTAL_XTAL2_4_5P2X3P4_NSP_IC_1.35MM_230-77984_16MHZ16MHZXTAL2_4_5P2X3P4_NSP
    Y3XTAL_XTAL2_4_5P2X3P4_IC_1.5MM_230-78523_16MHZ16MHzXTAL2_4_5P2X3P4
    Y4CLKGEN-SM_XTLOSC4_SM_IC_1.75MM_230-76894_50MHZ50MHZXTLOSC4_SM
    Y8XTAL_13_XTL4_2P1X1P7MM_SM_IC_0.7MM_230-77980_27.12MHZ27.12MHzXTL4_2P1X1P7MM_SM
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2023-10-16 11:17:44 | 显示全部楼层
    PCB文件来了
    S32K3X4EVB-T172_PackRevB_PCBLayout.zip (12.8 MB, 下载次数: 4)
    3 天前
  • 签到天数: 135 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2023-10-16 19:17:05 | 显示全部楼层
    昨天 08:13
  • 签到天数: 129 天
    你必须非常努力才能显
    发表于 2023-10-17 07:51:40 | 显示全部楼层
    昨天 08:33
  • 签到天数: 133 天
    4万
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模最爱沙发社区明星优秀斑竹奖宣传大使奖
    发表于 2023-10-17 08:41:00 | 显示全部楼层
    发表于 2023-10-17 08:59:11 | 显示全部楼层
  • 签到天数: 49 天
    发表于 2023-10-17 09:20:31 | 显示全部楼层
    4 天前
  • 签到天数: 69 天
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2023-10-17 10:22:18 | 显示全部楼层
    前天 08:24
  • 签到天数: 169 天
    发表于 2023-11-10 08:24:09 | 显示全部楼层
    昨天 10:44
  • 签到天数: 125 天
    发表于 2023-11-10 08:36:47 | 显示全部楼层
