REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
ANT1 | BUILT-INANT_3P_ACA5036_ACA-503 | ACA-5036-A2-CC-S | ACA5036 |
CON1 | EARPHONEJACK_AUDIO_5P_MJ2135_5 | PJ322 | AUDIO_5P_MJ2135_5D6_14_7X7X6MM |
D1 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D2 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D3 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D4 | D_DO_214AA_SMB_MBRS240LT3 | MBRS240LT3 | DO_214AA_SMB |
D5 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D6 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D7 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D8 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D9 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D10 | D_SOD_123_1N4148W | 1N4148W | SOD_123 |
D11 | DIODETVSBI-DIR_DO_214AA_SMB_S | SMBJ24CA | DO_214AA_SMB |
D12 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D13 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D14 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D15 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D16 | D_SOD_123_1N4148W | 1N4148W | SOD_123 |
D17 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D18 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D20 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
D21 | DIODETVSBI-DIR_D0402_ESDPSA04 | ESDPSA0402V05 | D0402 |
F1 | FUSE_F1812_3A | 3A | F1812 |
FB1 | FB_L0603_100R | 100R | L0603 |
FB2 | FB_L0603_100R | 100R | L0603 |
FB3 | FB_L0603_30R | 30R | L0603 |
FB4 | FB_L0603_120R | 120R | L0603 |
FB5 | FB_L0603_120R | 120R | L0603 |
FB6 | FB_L0402_120R | 120R | L0402 |
FB7 | FB_L0603_120R | 120R | L0603 |
FB8 | FB_L0603_120R | 120R | L0603 |
FB9 | FB_L0402_120R | 120R | L0402 |
FB10 | FB_L0603_120R | 120R | L0603 |
FB11 | FB_L0603_2500R | 2500R | L0603 |
FB12 | FB_L0402_120R | 120R | L0402 |
FB13 | FB_L0402_120R | 120R | L0402 |
FB14 | FB_L0603_30R | 30R | L0603 |
J1 | HEADER_42P_JST4P_SMD_2_0_90D_4 | 4P-2.0mm-90D | JST4P_SMD_2_0_90D |
J2 | USB20_TYPEC_166P_USB2_0_TYPE | USB2.0Type C | USB2_0_TYPE_C |
J3 | HEADER1P_PTH_2_75MM_5D9_ | | PTH_2_75MM_5D9 |
J4 | HEADER1P_PTH_2_75MM_5D9_ | | PTH_2_75MM_5D9 |
J5 | HEADER_42P_JST4P_SMD_2_0_90D_4 | 4P-2.0mm-90D | JST4P_SMD_2_0_90D |
J6 | HEADER1P_PTH_2MM_3D4_HEADER1P | Header1P | PTH_2MM_3D4 |
J7 | HEADER2X35_BTB2X35_0D4_16_6X3X | DF40C(2.0)-70DS-0.4V(51) | BTB2X35_0D4_16_6X3X2MM |
J8 | DUALUSBA_ST-USB-201C_USB-AF-9 | USB-AF-90 | ST-USB-201C |
J9 | TOGGLESWITCH_2CH_SW6_2D54_SMD_ | ToggleSwitch_2CH | SW6_2D54_SMD_7_0X3_5X1_5MM |
J10 | HEADER2X35_BTB2X35_0D4_16_6X3X | DF40C(2.0)-70DS-0.4V(51) | BTB2X35_0D4_16_6X3X2MM |
J11 | HEADER2X20OFST_HEADER_2X20_1 | YL002-007-020 | HEADER_2X20_1MM |
J12 | HEADER1P_PTH_2MM_3D4_HEADER1P | Header1P | PTH_2MM_3D4 |
J13 | RJ45_18P_48F-01_RJ45_18P_48F-01 | 48F-01GY2DPL2NL | RJ45_18P_48F-01GY2DPLXNL |
J14 | HEADER2X35_BTB2X35_0D4_16_6X3X | DF40C(2.0)-70DS-0.4V(51) | BTB2X35_0D4_16_6X3X2MM |
J15 | HEADER1P_PTH_2MM_3D4_HEADER1P | Header1P | PTH_2MM_3D4 |
J16 | RFANT3P_U-FL3P-SMD-2_6X2_6X1_ | U.FL-R-SMT-1(10) | U-FL3P-SMD-2_6X2_6X1_0MM |
J17 | POWERJACK_DC_JACK_DC_005_14_2X | DC-005 | DC_JACK_DC_005_14_2X11X9MM |
J18 | HEADER1P_PTH_2_75MM_5D9_ | | PTH_2_75MM_5D9 |
J19 | HEADER2X20OFRPI_HEADER2X20P_ | Header2x20 2.54mm | HEADER2X20P_2D54_DIP |
J20 | HEADER_22P_JST2P_1D25_7_55X3_9 | Header1x2 1.25mm | JST2P_1D25_7_55X3_9X4_8MM |
J21 | MICROSDCARD_8P_SD-MICRO-SCHA5B | SCHA5B0200 | SD-MICRO-SCHA5B0300 |
J22 | HEADER202P_JST20P_1D0_27_1X5_ | YL002-009-020 | JST20P_1D0_27_1X5_3X2_5MM |
J24 | HEADER1X3_HEADER3P_2D54_DIP_HE | Header1x3 2.54mm | HEADER3P_2D54_DIP |
L1 | L_L3X3MM_33UH | 3.3uH | L3X3MM |
L2 | L_L4X4MM_1UH | 1uH | L4X4MM |
L3 | L_L6_5X6_5_10UH | 10uH | L6_5X6_5 |
L4 | CL_L2012_90R | 90R | L2012 |
L5 | CL_L2012_90R | 90R | L2012 |
L6 | CL_L2012_90R | 90R | L2012 |
LED1 | SINGLELED_LED0603_BLUE | Blue | LED0603 |
LED2 | SINGLELED_LED0603_RED | Red | LED0603 |
LED3 | SINGLELED_LED0603_RED | Red | LED0603 |
LED4 | SINGLELED_LED0603_GREEN | Green | LED0603 |
LED5 | SINGLELED_LED0603_RED | Red | LED0603 |
Q1 | PMOS_123_SOT323_CJ2101 | CJ2101 | SOT323 |
Q2 | PMOS_123_SOT323_CJ2101 | CJ2101 | SOT323 |
Q3 | PMOS_123_SOT323_CJ2101 | CJ2101 | SOT323 |
Q6 | PMOS_1S1G2D_SOT223_4_FDT434P | FDT434P | SOT223_4 |
Q7 | PMOS_123_SOT23_IRLML6402TRPBF | IRLML6402TRPBF | SOT23 |
Q8 | PMOS_123_SOT23_IRLML6402TRPBF | IRLML6402TRPBF | SOT23 |
Q9 | PMOS_123_SOT323_CJ2101 | CJ2101 | SOT323 |
SW1 | TACTILESWITCH_4P_SW_4P_TACTILE | TactileSwitch | SW_4P |
SW2 | TACTILESWITCH_4P_SW_4P_TACTILE | TactileSwitch | SW_4P |
SW3 | TACTILESWITCH_4P_SW_4P_TACTILE | TactileSwitch | SW_4P |
U1 | NUP4114_SOT23_6_NUP4114HMR6T1G | NUP4114HMR6T1G | SOT23_6 |
U2 | NUP4114_SOT23_6_NUP4114HMR6T1G | NUP4114HMR6T1G | SOT23_6 |
U3 | MODULE-WIFI_AP6212_MODULE44-0_9 | AP6236 | MODULE44-0_9-12X12X1_5MM |
U4 | MP2161_TSOT23_8_0D65_2X1MM_MP21 | MP2161GJ | TSOT23_8_0D65_2X1MM |
U5 | KSZ9031RNX_QFN48_0D5_7X7MM_KSZ9 | KSZ9031RNXCA | QFN48_0D5_7X7MM |
U6 | NC7WZ126_US8_0D5_2X2_3X0_7MM_NC | NC7WZ126K8X | US8_0D5_2X2_3X0_7MM |
U7 | NUP4114_SOT23_6_NUP4114HMR6T1G | NUP4114HMR6T1G | SOT23_6 |
U8 | SN74LVC1G07DCK_SOT353_74LVC1G07 | 74LVC1G07GW | SOT353 |
U9 | MP9943_QFN8-0_65-3X3X1MM_MP9943 | MP9943GQ | QFN8-0_65-3X3X1MM |
U11 | WM8960_QFN32_0D5_5X5MM_EP3P3MM_ | WM8960GEFL | QFN32_0D5_5X5MM_EP3P3MM |
U12 | STMPS2252MTR_SO_8_1D27_4_8X3_8M | STMPS2252MTR | SO_8_1D27_4_8X3_8MM |
U14 | ESDA6V1BC6_SOT23_6_ESDA6V1BC6 | ESDA6V1BC6 | SOT23_6 |
X1 | XTAL_4P_X4-SMD-3_2X2_5X1_0MM_26 | 26MHz16pF | X4-SMD-3_2X2_5X1_0MM |
X3 | XTAL_4P_X4-SMD-3_2X2_5X1_0MM_25 | 25MHz18pF | X4-SMD-3_2X2_5X1_0MM |
