TA的每日心情 | 开心 2024-8-11 22:05 |
签到天数: 1 天 [LV.1]初来乍到
- 3683
板子画的好不好 不知道 欢迎大家一起讨论
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | + | HOLE | | HOLE | - | HOLE | | HOLE | C1 | CL18XW10XH16 | 0.47U/275V | CL18XW10XH16 | C2 | CE18315SV | 120U 400V | CE-18X31.5 | C3 | SMD-0805-CAP | 4N7/250V | CAP-0805 | C4 | SMD-0805-CAP | 2U2 | CAP-1206 | C5 | SMD-0603-CAP | 10N | CAP-0603 | C6 | SMD-0603-CAP | 1N | CAP-0603 | C7 | SMD-0603-CAP | N22 | CAP-0603 | C8 | CC14895SV | N47 250V | C103-514895 | C9 | SMD0603(CAP)-MIN | 2N2 | CC01-D002 | C10 | CE10200SV | M68 25V | CE-10X20 | C11 | SMD0603(CAP)-MIN | 10N | CAP-0603 | C12 | SMD-0603-CAP | U10 | CAP-0603 | C13 | SMD-0603-CAP | U10 | CAP-0603 | C14 | SMD0603(CAP)-MIN | 2N2 | CC01-D002 | C16 | SMD-0603-CAP | 10N | CAP-0603 | C18 | CE08150SV | M33 25V | CE-8X15 | C19 | SMD0603(CAP)-MIN | 22N | CAP-0603 | C20 | SMD0603(CAP)-MIN | 1N | CAP-0603 | C21 | SMD0603(CAP)-MIN | 22N | CC01-D002 | C22 | SMD0603(CAP)-MIN | U10/0805 | CAP-0805 | C24 | SMD0603(CAP)-MIN | 22N | CAP-0603 | C25 | SMD0603(CAP)-MIN | 10N | CAP-0603 | C26 | SMD0603(CAP)-MIN | 1N | CAP-0603 | C27 | CAP-CD6X3-5DV | 47P 1KV | CAP-CD6X3 | C28 | CAP-CD6X3-5DV | 4N7 500V | CAP-CD6X3 | C29 | SMD-1206-CAP | 0.1U 100V | CAP-1206 | C30 | SMD-0805-CAP | 2U2 | CAP-1206 | D1 | TO220L5SV | V20100C | 5DD2-5001-A | D2 | DO35-SH | 1SS244 | DIO-DO35 | D3 | SOD80 | LL4148 | DIO-SOD80 | D4 | DO41-DH | HER103 | DIO-DO41 | D7 | DO41SV | 1N4007G | 5DD1-5002 | D9 | SOD80 | LL4148 | DIO-SOD80 | DB1 | KBP206G | GBL06 | KBP206G | F1 | F14.5X4SV | T3.15A 250V | F14.5X4SV | FER1 | FER-2X1-L | 3X3X1.2 | FERRITES | FER2 | FER-2X1-L | 3X3X1.2 | FERRITES | GND | HOLE | | HOLE | JP1 | JUMP-10MM | | JUMP-EVEN | JP2 | JUMP-10MM | | JUMP-EVEN | JP3 | JUMP-10MM | | JUMP-EVEN | JP4 | JUMP-10MM | | JUMP-EVEN | L | HOLE | | HOLE | L1 | 14X8X6 | 16X9X8 | 14X8X6 | L2 | DRW-4X6.3DH | 4X6.3 | XFIL-4X6.3 | L3 | 9X5X3 | 9X5X5 | 9X5X3 | LED | LED-R3SV | | LED | N | HOLE | | HOLE | P6 | HOLE | | HOLE | P8 | HOLE | | HOLE | P10 | HOLE | | HOLE | P13 | HOLE | | HOLE | P15 | HOLE | | HOLE | P19 | HOLE | | HOLE | P20 | HOLE | | HOLE | P21 | HOLE | | HOLE | P23 | HOLE | | HOLE | P24 | HOLE | | HOLE | P34 | HOLE | | HOLE | PC1 | PS10.2-S | | PS2561 | Q1 | SOT-23-S | 3904 | NPN-SOT23-3904BC817-S | Q9 | TO220L5SVAAA | TK10A60D | 5FN2-5002 | R1 | SMD0603-MIN | 10K 5% | RES-0603 | R2 | RES-1/2SH | 0.1R | RES-1/2W | R3 | SMD-0805 | OPEN | RES-0805 | R4 | SMD-1206 | 47K 5% | RES-1206 | R5 | SMD-1206 | 47K 5% | RES-1206 | R6 | SMD-0603 | 1K0 | RES-0603 | R7 | SMD-0603 | 3K9 | RES-0603 | R8 | SMD-1206 | 1U | RES-1206 | R9 | SMD-1206 | 1M 5% | RES-1206 | R10 | SMD-1206 | 1M 5% | RES-1206 | R11 | SMD-0805 | 1R | RES-1206 | R12 | SMD-0603 | 0R | RES-0603 | R13 | SMD-0603 | 27R 5% | RES-0603 | R14 | SMD-0603 | 0R | RES-0603 | R15 | SMD-0603 | 7K5 1% | RES-0603 | R16 | SMD-1206 | 39K | RES-1206 | R17 | SMD-0805 | 2R2 5% | RES-0805 | R18 | SMD-0603 | 0R | RES-0603 | R19 | SMD-0805 | K15 5% | RES-0805 | R20 | SMD-0603 | K47 1% | RES-0603 | R21 | SMD-0603 | M10 5% | RES-0603 | R22 | SMD0603-MIN | 3K3 5% | RES-0603 | R23 | SMD-0603 | 0R | RES-0603 | R28 | SMD-0805 | 7R5 5% | RES-1206 | R29 | SMD-0805 | 7R5 5% | RES-1206 | R32 | SMD-0603 | K47 | RES-0603 | R34 | SMD0603-MIN | 39K 5% | RES-0603 | R35 | SMD-0R | | RES-0R | R36 | SMD-0603 | 1K | RES-0603 | R38 | RES-6MM | 5mR | RES-6MM | R39 | SMD0603-MIN | 1K 5% | RES-0603 | R40 | SMD0603-MIN | OPEN | RES-0603 | R42 | SMD0603-MIN | K56 1% | RES-0603 | R43 | SMD0603-MIN | 39K 1% | RES-0603 | R44 | SMD0603-MIN | 12K 5% | RES-0603 | R45 | SMD0603-MIN | 3K3 5% | RES-0603 | R46 | SMD-0603 | M10 | RES-0603 | R49 | SMD0603-MIN | 6K2 1% | RES-0603 | R52 | SMD-0R | | RES-0R | R53 | SMD0603-MIN | 47K 1% | RES-0603 | R55 | SMD0603-MIN | 33K 5% | RES-0603 | R57 | SMD0603-MIN | 3K3 5% | RES-0603 | R60 | SMD-0R | | RES-0R | R80 | SMD0603-MIN | M11 5% | RES-0603 | T1 | RM10-12PIN | | RM10-12PIN | U1 | SOP-7 | LD7750A | IC-LD7750A1 | U2 | SOP-8 | NCP4300A | AP4310A | X1 | HOLE | | HOLE | X2 | HOLE | | HOLE | Y1 | HOLE | | HOLE | Z1 | SOD80 | 22V | ZEN-SOD80 |
