PCB文件和原理图整套,PCB PADS9.5打开,原理图ORCAD16.3打开
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
Reference | Part | pcb footprint | | | | | | | ANT2 | ANT_JACK | RF | C67,C68,C69,C70,C78,C80, | 104 | C0402 | C81,C85,C86,C87,C88,C89, | | | C90,C91,C92,C93,C94,C95, | | | C99,C100,C101,C102,C103, | | | C104,C105,C106,C107,C113, | | | C114,C115,C116,C117,C121, | | | C122,C123,C124,C125,C126, | | | C127,C128,C129,C130,C131, | | | C136,C137,C138,C139,C140, | | | C141,C142,C143,C148,C149, | | | C150,C151,C152,C153,C156, | | | C157,C158,C159,C160,C161, | | | C162,C163,C164,C165,C166, | | | C169,C197,C231,C233,C238, | | | C240,C242,C252,C258,C259, | | | C313 | | | C74,C75 | 8P | C0402 | C79,C83,C84,C98,C135, | 105 | C0402 | C146,C196,C199,C200,C209, | | | C210,C211 | | | C82,C132,C144,C154,C155, | 226 | 226/6V3 | C202,C204 | | | C96,C108,C109,C110,C111, | 102 | C0402 | C134,C147,C167,C201,C205, | | | C222 | | | C97,C133,C145,C203,C206, | 106 | 226/6V3 | C207,C208,C219,C220,C256, | | | C260 | | | C168 | 226 | C0805 | C173 | 1UF | C0402 | C198 | 475 | 226/6V3 | C212,C213,C215,C216 | 226/6V3 | 226/6V3 | C214,C218 | 102/6V3 | C0402 | C221 | 475 | C0402 | C223 | NC/104 | C0402 | C224 | NC/105 | C0402 | C225 | 226/6V3 | C0402 | C227 | 101 | C0402 | C232 | 475 | C0603 | C234,C239,C241,C285,C288 | 10uF | 226/6V3 | C253,C255,C257 | NC | C0402 | C254 | 12P | C0402 | C282 | 47pF | C0402 | D1 | 1N4148 | DIODE | D5 | SS24 | SMBB | D9 | 3.0V | D1206 | D10 | B0530W | SOD123 | D11 | BAT54C | SOT-23 | HCON1 | HDMI_19plug | 16P-5802-0.4MMB | J4 | TF_SD_SOCKET | TFK-1 | K1 | RECOVERY | BST-1114A | LED2,LED3 | Green | 0805LED | L11,L14 | 2.2UH/CD42 | CD32 | L12,L15 | 4.7UF/CD42 | CD32 | L13 | 3.3UH/CD42 | CD32 | P4,P6 | USB-MINI-SOCKET | USB_DIP | P5 | USB-MINI-SOCKET | USB-0400 | Q2 | MMBT3904 | SOT-23 | Q12,Q13 | 8050 | sot-23 | Q14,Q15 | WNM2021/2SK3018 | SOT23 | R28 | 47K | R0402 | R40,R57,R212 | 22K | R0402 | R43,R44 | 100K | R0402 | R46,R51,R52,R54,R55,R88, | 10K | R0402 | R93,R176,R177,R195,R196 | | | R47 | 20K | R0402 | R48,R50 | 43R2 | R0402 | R58 | 22R | R0402 | R59 | 1M | R0402 | R62,R63,R64,R65,R66 | 240R%1 | R0402 | R67,R175 | 100R | R0402 | R68,R69,R70,R71 | 1K%1 | R0402 | R83,R90,R91,R151,R153 | 4K7 | R0402 | R85 | NC/1K | R0402 | R92,R101,R105,R117,R118, | 33R | R0402 | R119,R120 | | | R148 | 1K | R0402 | R152,R154 | 2K | R0402 | R157 | 470R%1 | R0402 | R178 | 0R | R0402 | R179 | NC/10K | R0402 | R211 | NC | R0402 | R319 | 52.3K/1% | R0402 | R320 | 12K/1% | R0402 | R321 | 15K | R0402 | T16,T17,T18,T19,T20,T21, | TEST | TEST | T22,T23,T24,T25,T26,T27, | | | T28 | | | U1 | RK3066 | RK3066_10 | U2,U3,U4,U5 | DDR3_256M_8BIT | DDRIII_8BIT | U6 | NAND_FLASH | NANDFLASH | U8 | NC/HYM8563 | HYM8563 | U10 | CDT-K15370B/K25931/K46620 | CDT-B26628 | U18 | XM5082 | SOT23-5 | U51 | AXP152 | AXP152 | Y1 | NC/32.768K/20ppm/12PF | CRY-MC146 | Y2 | 24M-20ppm | CRYSTAL-4 |
