IP101GA(R)_B2B DEMO BOARD_V01-120529.pcb
(662 KB, 下载次数: 19)
IP101GA(R)_B2B DEMO BOARD_V02_20120809.rar
(96 KB, 下载次数: 18)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | C1 | C0603 | 30pF | CAP_NP_4 | C2 | C0603 | 30pF | CAP_NP_4 | C3 | C0603 | 0.1uF | CAP_NP | C6 | C0805 | 10uF | C-POL | C7 | C0603 | 0.1uF | C_3 | C9 | C0603 | 0.1uF | C_0 | C11 | C0603 | 0.1uF | C_4 | C12 | C0805 | 10uF | C-POL | C15 | C0603 | 30pF | CAP_NP_4 | C16 | C0603 | 30pF | CAP_NP_4 | C20 | C0805 | 10uF | C-POL | C21 | C0603 | 0.1uF | C_3 | C23 | C0603 | 0.1uF | C_0 | C25 | C0805 | 10uF | C-POL | C26 | C0603 | 0.1uF | C_2 | C29 | CB | 22uF/1206/NA | C-POL_0 | C30 | C0603 | 0.1uF/NA | CAP_NP_2 | C31 | C0603 | 10nF/NA | CAP_NP_2 | C32 | CB | 22uF/1206/NA | C-POL_0 | C33 | C0603 | 1nF/NA | CAP_NP_2 | C34 | C0603 | 0.1uF/NA | CAP_NP_2 | C35 | C0603 | 30pF | CAP_NP_3 | C36 | C0603 | 30pF | CAP_NP_3 | C37 | C0805 | 10uF | C-POL_2 | C39 | C0603 | 0.1uF | CAP_NP_0 | C40 | C0603 | 0.1uF | CAP_NP_0 | C43 | C0603 | 0.1uF | CAP_NP_0 | C44 | C0603 | 0.1uF | CAP_NP_0 | C45 | C1206 | 1n/2KV/1206 | CAP_NP_0 | C46 | C1206 | 1n/2KV/1206 | CAP_NP_0 | C47 | C1206 | 1n/2KV/1206 | CAP_NP_0 | C48 | C1206 | 1n/2KV/1206 | CAP_NP_0 | D1 | D0603 | GLED | LED | D4 | D0603 | GLED | LED | D6 | D0603 | GLED | LED | D9 | D0603 | GLED | LED | J1 | SIP3-2.54 | HEADER 3 | HEADER_3 | J2 | SIP3-2.54 | HEADER 3 | HEADER_3 | JP1 | SIP5-2.54 | HEADER 5 | HEADER_5 | L1 | L0603 | 0R | INDUCTOR_0_2 | L4 | L0603 | 0R | INDUCTOR_0_2 | L5 | L0603 | 0R | INDUCTOR_0_2 | L8 | L0603 | 0R | INDUCTOR_0_2 | PC1 | C0805 | 10nF | CAP_NP | PC2 | C06-025 | 47uF/35V | CAP_NP | PC3 | C0805 | 6.8nF | CAP_NP | PC4 | C05-025 | 22uF/16V | CAP_1 | PC5 | C0603 | 0.1uF | CAP_NP | PC6 | C0603 | 0.1uF | CAP_NP | PC7 | C0805 | 10uF/35V | CAP_NP | PC8 | C0603 | 10nF | CAP_NP | PC9 | C0603 | 0.1u/NA | CAP_NP | PL1 | L100UH | 10uH/3A | INDUCTOR_TORROID | PL1-1 | L0805 | 0/BEAD(120ohm@120MHz/2A) | INDUCTOR_0 | PL2 | 3T | 3T | INDUCTOR_0 | PPJ1 | DC-JACK-1 | DC JACK | PHONEJACK_0 | PR1 | R0603 | 24K | RESISTOR_2 | PU1 | SOP-8L-EP | AP6503 | AME5268_0 | R1 | R0603 | 6.19K/1% | R_0 | R2 | R0603 | 5.1k | RESISTOR_2 | R3 | R0603 | 5.1K | R_0 | R4 | R0603 | 330R | R_2 | R9 | R0603 | 470K | RESISTOR_3 | R10 | R0603 | 5.1K | R_0 | R12 | R0603 | 330R | R_2 | R16 | R0603 | 0R | R_1 | R17 | R0603 | 0R | R_1 | R18 | R0603 | 0R | R_1 | R19 | R0603 | 0R | R_1 | R20 | R0603 | 0R | R_1 | R21 | R0603 | 0R | R_1 | R22 | R0603 | 0R | R_1 | R23 | R0603 | 0R | R_1 | R24 | R0603 | 0R | R_1 | R25 | R0603 | 0R | R_1 | R28 | R0603 | 0R/0402 | R_1 | R29 | R0603 | 0R/0402/NA | R_1 | R30 | R0603 | 0R | R_1 | R31 | R0603 | 10K/NA | R_0 | R32 | R0603 | 1K | R_0 | R33 | R0603 | 0R | R_1 | R34 | R0603 | 10K/NA | R_0 | R35 | R0603 | 1K | R_0 | R36 | R0603 | 0R | R_1 | R37 | R0603 | 0R/0402/NA | R_1 | R38 | R0603 | 0R | R_1 | R39 | R0603 | 0R | R_1 | R40 | R0603 | 5.1k | RESISTOR_2 | R41 | R0603 | 6.19K/1% | R_0 | R42 | R0603 | 5.1K | R_0 | R43 | R0603 | 330R | RESISTOR_2 | R44 | R0603 | 5.1K | R_0 | R46 | R0603 | 5.1K | R_0 | R50 | R0603 | 5.1K | R_0 | R51 | R0603 | 330R | R_2 | R52 | R0603 | 5.1k | RESISTOR_2 | R55 | R0603 | 0R | R_1 | R56 | R0603 | 0R | R_1 | R59 | R0603 | 10K/NA | R_0 | R60 | R0603 | 1K | R_0 | R61 | R0603 | 10K/NA | R_0 | R62 | R0603 | 1K | R_0 | R65 | R0603 | 110R/1%/NA | RESISTOR | R66 | R0603 | 110R/1%/NA | RESISTOR | R67 | R0603 | 4.7K | RESISTOR | R68 | R0603 | 4.7K/NA | RESISTOR | R69 | R0603 | 4.7K/NA | RESISTOR | R70 | R0603 | 4.7K | RESISTOR | R71 | R0603 | 4.7K | RESISTOR | R72 | R0603 | 4.7K | RESISTOR | R73 | R0603 | 4.7K | RESISTOR | R74 | R0603 | 0R | RESISTOR | R75 | R0603 | 0R | RESISTOR | R76 | R0603 | 0R | RESISTOR | R77 | R0603 | 0R | RESISTOR | R78 | R0603 | 0R | RESISTOR | R79 | R0805 | 0R/0805 | RESISTOR_4 | R80 | R0603 | 10K | RESISTOR | R86 | R0603 | 75R | R_1 | R87 | R0603 | 75R | R_1 | R88 | R0603 | 75R | R_1 | R89 | R0603 | 75R | R_1 | R95 | R0603 | 75R | R_1 | R96 | R0603 | 75R | R_1 | R97 | R0603 | 75R | R_1 | R98 | R0603 | 75R | R_1 | R99 | R0603 | 10K/NA | RESISTOR_2 | R100 | R0603 | 10K/NA | RESISTOR_2 | R101 | R0603 | 0R/0402 | R_1 | R102 | R0603 | 0R | RESISTOR_2 | R103 | R0603 | 0R | RESISTOR_2 | R104 | R0603 | 0R | RESISTOR | R105 | R0603 | 0R | RESISTOR | R106 | R0603 | 330R | RESISTOR_2 | RJ1 | RJ45_AMP-MJ8A | RJ8-45 | RJ8-45_3 | RJ2 | RJ45_AMP-MJ8A | RJ8-45 | RJ8-45_3 | RP1 | R0603 | 0R | RESISTOR_2 | RP2 | R0805 | 0R | RESISTOR_2 | RP6 | R0805 | 0R | RESISTOR_2 | RP7 | R0603 | 10K | RESISTOR_2 | RP8 | R0603 | 6.8K | RESISTOR_2 | RP9 | R0603 | 100K | RESISTOR_2 | RP10 | R0603 | 0R/NA | R | RP11 | R0805 | 0R/NA | RESISTOR_2 | SW1 | SW-DIP-1B | SW PUSHBUTTON | SW_PUSHBUTTON | SW3 | SW-DIP-8B | SW DIP-8 | SW_DIP-8 | SW4 | SW-DIP-1B | SW PUSHBUTTON | SW_PUSHBUTTON_1 | T1 | TRANS-16P-SMD | TS8121 | TS8121_2 | T2 | TRANS-16P-SMD | TS8121 | TS8121_2 | TP1 | TP30MILS | T_POINT_R | T_POINT_R | TP2 | TP30MILS | T_POINT_R | T_POINT_R | U1 | IP101GR | IP101GR | IP101GR_0 | U4 | LQFP48-0909-.5 | IP101AGA | IP101G_11 | U5 | TO-252B2 | AME1085/NA | LT1086CT_0 | U6 | DIP20 | AT89C2051/SO | AT89C2051/SO_0 | Y1 | XTAL | 25MHZ | CRYSTAL_0 | Y2 | XTAL | 25MHZ | CRYSTAL_0 | Y3 | XTAL | 11.059MHz | CRYSTAL | Z1 | D0603 | RLED | LED |
评分
查看全部评分
